Staro 24.08.2020., 23:28   #8221
Postovi: 8,545
TSMC details 3nm process technology: Full node scaling for 2H22 volume production
At TSMC’s annual Technology Symposium, the Taiwanese semiconductor manufacturer detailed characteristics of its future 3nm process node as well as laying out a roadmap for 5nm successors in the form of N5P and N4 process nodes. TSMC details that N5 currently is progressing with defect densities one quarter ahead of N7, with the new node having better yields at the time of mass production than both their predecessor major nodes N7 and N10, with a projected defect density that’s supposed to continue to improve past the historic trends of the last two generations.
Beyond N5P, TSMC is also introducing the N4 node that represents a further evolution from the N5 process, employing further EUV layers to reduce masks, with minimal migration work required by chip designers. We’ll be seeing N4 risk production start in 4Q21 for volume production later in 2022. Today’s biggest news was TSMC’s disclosure on their next big leap past the N5 process node generation family, which is the 3nm N3 node. We’ve heard that TSMC had been working on defining the node back last year with progress going well. Contrary to Samsung’s 3nm process node which makes use of GAA (Gate-all-around) transistor structures, TSMC will instead be sticking with FinFET transistors and relying on “innovative features” to enable them to achieve the full-node scaling that N3 promises to bring. Compared to it’s N5 node, N3 promises to improve performance by 10-15% at the same power levels, or reduce power by 25-30% at the same transistor speeds. N3 is planned to enter risk production in 2021 and enter volume production in 2H22.
Izvor: AnandTech
Staro 31.08.2020., 07:10   #8222
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,381
Navodno su počeli pomalo izbacivat BIOS koji podržava Zen3 (Agesa V2 1.0.0.8):
https://www.reddit.com/r/Amd/comment...ng_to_am4_now/
Slobodno me dodajte na PSN
Staro 31.08.2020., 07:31   #8223
Yoman
Yoman's Avatar
Postovi: 715
Nadam se da sam pogodio pravu temu za pitanje.
Trenutno imam Ryzen 2600, MSI B450 solidnu ploču i 2x8 GB 3Ghz rame.
Kao i svi ovdje, nahajpan sam na nove Ryzen desktop CPU-ove koji uskoro izlaze. Planiram uzeti 4600/5600 model.
Uzeo bih i nove rame, 2x16GB, 3400/3600 Mhz - nešto ovako, čini mi se ok cijena.
S matičnom sam stvarno zadovoljan (OK featuri, dobar VRM) i ne bih ju htio mijenjati.
Zanima me da li od strane B450 čipseta postoji kakvo ograničenje u vidu brzine rama? Ako dobro shvaćam AMD ima ram kontroler direktno na CPU i sam čipset nema ništa s ramima. Da li to znači da ako novi Ryzeni budu kompatibilni s 3600+ Mhz memorijom, sam B450 čipset ne bi trebao raditi probleme?
U bios-u imam navedene "standardne" brzine rama do 2933 Mhz, a sve preko toga je označeno sa "OC" znakom. Da li su to tako označili radi tadašnjih Ryzen 2000 procesora koji su znali imati problema s RAM-om preko 3Ghz ili stvarno postoji neka nekompatibilnost baš sa samim čipsetom?
Znam da još treba pričekati da MSI i ostali proizvođači službeno izbace nove BIOS-e za stariji B450 čipset pa sigurno neću kupovati prije toga.
Puno hvala
Zadnje izmijenjeno od: Yoman. 31.08.2020. u 08:05.
Yoman je offline   Reply With Quote
Staro 31.08.2020., 07:46   #8224
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,838
nisu to nikavi problemi (oc znak), nego upravo to što si rekao, ograničenost IMC kontrolera na procu.. slobodno uzmi 3600mhz rame, sad koliko će to bit u praksi dobro (isplativo), vidjet ćeš.. i da, ploča ti je stvarno vrlo vrlo dobra
Staro 31.08.2020., 07:59   #8225
Yoman
Yoman's Avatar
Postovi: 715
Thx.
Planiram duže ostati na tom procu i ne ići na DDR5 platformu bar 3-4 godine, pa sam tom logikom išao da odma prijeđem s 16 na 32GB rama.
Pretpostavljam da će razlika između npr. Aegis 3Ghz budget kita i ovog 3600 kita kojeg sam linkao biti neprimjetna, al kad je bal .... Razlika je nekakvih 35€ pa eto.
Hvala za savjet. Još držati fige da "beta" BIOS ne bude prebagovit i preokljaštren pa da malo upgrejdam kantu.
Staro 31.08.2020., 08:57   #8226
John Creasy
Lokacija: Beograd
Postovi: 2,838
ako već tražiš nešto na 3600mhz, probaj naći ram sa što manjom latencijom.. ili idi na neki turbo 3200 CL14, ovisno o cijeni
Staro 31.08.2020., 14:46   #8227
Yoman
Yoman's Avatar
Postovi: 715
Nekako mi se čini, barem tako net kaže, da infinity fabric više dobiva s frekvencijom RAM-a nego sa zatezanjem tajminga. Zašto misliš da je 3200 CL14 bolja opcija?
Ovaj Ripjaws V 3600 CL16-19-19-39 mi se čini kao dosta dobra opcija s obzirom na cijenu. Našao sam ga u stranom shopu za 139€.
Možda bi ga se dalo natjerati na 3200 CL14-16-16-36. Nisam baš neki ekspert za RAM-e pa ne znam da li je ovaj drugi setting znatno agresivniji od prvog, ili možda obratno
EDIT: Bacio sam neku brzinsku računicu, te mi djeluje da je 3600 setting agresivniji gledajući odzive u nanosekundama. Znaci da ovi Ripjawsi bez beda idu na 3200 CL14.
Mislim da smo lagano ušli u OT s ramima, ali ako imaš neku preporuku boljeg rama za slične novce slobodno pošalji na PM.
Ima li već kakvih pouzdanih informacija o CCX layoutima? Prije mjesec-dva sam naletio na neki rekla-kazala članak u kojem su rekli da bi na Ryzen 4000 seriji AMD mogao gurati što više jezgri/threadova na isti CCX kako bi se izbjegle latencije u CCX to CCX komunikaciji.
Koliko je moguće da npr Ryzen 4600 ima svih 6/12 na istom CCX-u kao kod Ryzen-a 3300X? Tada bi brzina RAMA imala još manju ulogu u konačnim performansama cijelog sistema, i ne bi imalo smisla kupovati ništa bolje od G.Skill Aegis 3000Mhz?
Zadnje izmijenjeno od: Yoman. 31.08.2020. u 14:54.
Staro 31.08.2020., 14:51   #8228
Postovi: 8,545
Da, potvrđeno je da Zen 3 ima jedan monolitni osmerojezgreni CCD/CCX + SMT i 32MB L3 cachea.
Zen 3 dies will feature a single 8-core CCX with 32MB of L3 cache. This change eliminates inter-CCX latencies for AMD's Zen 3 dies, which has the potential to increase Zen 3's performance in latency-sensitive workloads significantly.
Staro 31.08.2020., 15:09   #8229
Yoman
Yoman's Avatar
Postovi: 715
Pretpostavljam da će 4600 ostati 6/12, a 4700 8/16? Znaći obadva su na single CCX dizajnu. Nice
Zna li se išta o datumu izlaska na tržište?
Sry ako djeluje malo ljeno, ali net je prepun kontradiktornih informacija. Glava zna zabolit kad na tri mjesta pročitam tri drugačije informacije, pa pitam ovdje.
Staro 31.08.2020., 15:27   #8230
Postovi: 8,545
Da, trebalo bi biti ko i dosad po pitanju jezgri, a službeni datum se još ne zna, ali bude kroz kojih dva mjeseca, tj. do kraja godine 100%.
Staro 07.09.2020., 21:34   #8231
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Mozda ipak ne, ako je vjerovati 1usmus-u, mozda dobijemo prinovu u obliku 10-core zen3 cpu-a
Par novosti o zen3 na jednom mjestu za one koje ne prate twitter...
Zadnje izmijenjeno od: Sn4k3. 07.09.2020. u 21:48.
Staro 07.09.2020., 22:01   #8232
Exomaniac
Datum registracije: Mar 2016
Postovi: 774
Tko zna hoće li se možda onda dati otključati 2 ostale jezgre na 6-core verzijama ako nisu oštećene ili će ih namjerno fizički disejblati.
Exomaniac je online   Reply With Quote
Staro 07.09.2020., 23:00   #8233
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Autor Exomaniac Pregled postova
Nema vise otkljucavanja jezgri ko u vrijeme Phenoma. Visak jezgri se fizicki onemoguci...
Btw, ako stvarno dobijemo 10-core model, moja pretpostavka za line-up ide ovako:
Ryzen 4000:
R3 4200/4300 = 4/8 cores/threads
R5 4500 = 6/12
R5 4600 = 8/16
R7 4700 = 10/20
R9 4900 = 12/24
R9 4950 = 16/32
Threadripper 4000:
4960x
4970x
4990x?
Staro 07.09.2020., 23:09   #8234
Postovi: 8,545
U slučaju da bude taj 10-core model, onda lako i ostale preslože oko njega, mada mogu kaj god ih volja, ako baš budu htjeli.
Staro 08.09.2020., 00:07   #8235
sti
Lokacija: Lawl
Postovi: 1,380
Kako uopće izvesti 10 jezgri, ako su rekli da idu monolitni čipleti sa 8 jezgri unutra?
Jedino ako stave 2 čipleta sa 5 jezgri u svakom, što ostavlja 6 jezgri škarta.
Staro 08.09.2020., 00:40   #8236
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Autor sti Pregled postova
Tocno tako... Ne mora nuzno znaciti da su ostale jezgre skart ali da - moguc scenarij.
Staro 08.09.2020., 07:34   #8237
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Pa tako. Jedini način
Staro 09.09.2020., 19:23   #8238
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Sluzbena najava na twitteru od AMD-a i Lise Su:
08.10. - zen3
28.10. - RDNA2
AMD to introduce Zen3 on October 8, Radeon RX 6000 series on October 28
ID:	22654   Click image for larger version
ID:	22655   Click image for larger version
Zadnje izmijenjeno od: Sn4k3. 09.09.2020. u 19:30.
Staro 09.09.2020., 20:38   #8239
Postovi: 8,545
Ko nema, nek kupi neki UPS do onda, jer moglo bi struje nestati. Baba obično ne najavljuje pizdarije po Internetima, pa se nadamo da bude tak i ovaj put.
Staro 09.09.2020., 21:51   #8240
Manuel Calavera
Postovi: 14,589
Eh leakovi od prije više od pola godine govorili zen3 i RDNA2 u 10 mjesecu...
Staro 09.09.2020., 22:22   #8241
Gigi1
Postovi: 2,138
Autor Sn4k3 Pregled postova
08.10. - zen3
28.10. - RDNA2
po slici bi se dalo zakljuciti da više nema blowera ni kod amd-a(znaci obistinilo se ono sto su rekli pred cca godinu dana da odsutaju od blowera, svejedno sam tužan jer bloweri imaju svoju svrhu)
Staro 09.09.2020., 22:32   #8242
Manuel Calavera
Postovi: 14,589
Mogu postojati od strane AiB partnera, kao posebna niša, no nema nikakvog smisla da referentni cooler bude blower, izbaciš novu high end gpu, koja uvjek hvala bogu ima visok TDP, pa te onda prozivaju da zvuči kao mlažnjak. Blower treba ostati samo niša, te nisu dovoljno dobri za high end (onaj stari oko 250w), a kamoli ovo novo što dolazi preko 300w
Staro 09.09.2020., 22:40   #8243
Gigi1
Postovi: 2,138
ma slažem se pogotovo sto je konkurencija ditchala blowere ali mogu bloweri biti dobri, problem je sto se i na njima štedi, pogotovo na bakru, npr. kod referentnih vegi je dobar dio površine koja je mogla služiti za dodatnu disipaciju(da se stavilo više bakra/aluminija tj. veci hladnjak) ostao neiskorišten
Staro 09.09.2020., 22:53   #8244
Manuel Calavera
Postovi: 14,589
Nažalost tek AiB partneri rade plastična smeća od blowera...
Kažem, za high end nema smisla, a za mainstream gpu prave smeća od blowera tj. neće za neku gpu od 150w napraviti top blower kao što spominješ. Taj tip coolera je u sljepoj ulici
Staro 09.09.2020., 22:58   #8245
Postovi: 8,545
Da ne bi na kraju ispal ovakav hladnjak za RX 6000 seriju.
Staro 09.09.2020., 23:05   #8246
Manuel Calavera
Postovi: 14,589
AMD ako ide preko 300w sigurno idu na vodu.
BTW kriva tema, možete prebaciti u Navi
Staro 09.09.2020., 23:15   #8247
Postovi: 8,545
Iskreno se nadam da su im svi cooleri zračni, jer ako nVidia može na šrot Samsung 8nm procesu svoje 320/350W+ grdosije hladiti zrakom - mogu i ovi na 7nm TSMC - ili su stvarno nesposobni, pa čak i kad ih ide, opet se sjebu.
Staro 13.09.2020., 18:22   #8248
Manuel Calavera
Postovi: 14,589
Staro 13.09.2020., 18:37   #8249
Manuel Calavera
Postovi: 14,589
https://youtu.be/RYV4muLkbss
Svašta je napričao:
Ne sjećam se više šta je fact, a šta gestimate:
50% bolja efikasnost ne da je postignuta, nego je i pređena (cca 60%). To je navodno fact
Ovo je mislim gestimate (u koji osobno nisam uvjeren):
6700 - konkurent 3070
6700XT - konkurent 3070ti
6800- konkurent 3080
6800XT - konkurent 3080ti
6900 - pokušati konkurirati 3090 (sporija, no brža od 3080ti)
XT modeli bi vjerojatno kao i u slučaju Ti/super kod nvidije došli kasnije
Postoji priča (u koji nisu svi skroz uvjereni) da će AMD nedostatak bandwidtha za nvidijom rješiti sa chache-om od 128gb
Što se tiče RT, nitko dosad nije uvjeren da će konkurirati Ampere, jedan izvor čak sumnja da će biti uopće bolji i od Turinga
Staro 13.09.2020., 18:50   #8250
Postovi: 8,545
Lagno se nakotilo tih tzv. JubiTo analitičara i proricatelja gdje svaki ima svoje izvore koji ih nikad nisu izdali, da što dalje to više rađe pogledam ovakav materijal (1 - 2), dok u međuvremenu čekam službene recenzije.
Nek i jedni i drugi izdaju kaj imaju za plasirati na tržište i voljno. Škot i onaj Moore's Law is Dead, ajde još nekak, ali jebote, pa sad svi i njihova baka imaju izvore u svim mogućim firmama.
