Staro 10.01.2020., 16:36   #7141
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Ali onda je velika rupa izmedju mobilnih i desktop apua
Campeonato je online   Reply With Quote
Staro 10.01.2020., 20:11   #7142
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Nije rupa kad će biti brandirani kao 4000 serija. Njih izbace na ljeto, onda na jesen/zimu desktop cpu 4000 (zen3)
Kod prve generacije zena na AM4 socketu nije bilo APU-a sa zen arhitekturom, nego se radilo o staroj CMT arhitekturi (najjači A12 9800), kad je došao zen+, apu je bio zen, kod zen2 apu je zen+, a sada će uoči zen3 apu biti zen2
Staro 10.01.2020., 23:21   #7143
Zen2 APU ako bude 8t/16c + iGPU... to će biti strava.
Staro 11.01.2020., 00:21   #7144
Postovi: 8,353
Moje prošlogodišnje trabunjanje više nije ni takav Sci-Fi, jer za 8C/16T ili 6C/12T + iGPU AM4 Ryzen 4000 APU imaju već gotove monolitne komade, samo ih treba pripasati za desktop socket i vozi.
The new Ryzen 4000 series, codenamed Renoir, it’s a fully integrated monolithic piece of 7nm silicon, containing 8 Zen 2 cores and up to 8 compute units of enhanced Vega graphics. The new 8 core / 8 CU chip on 7nm is also very small. AMD wouldn’t let us measure it directly, or take pictures before the keynote, but by putting the chip next to a Zen 2 desktop chiplet, I was able to make out that the new APU is pretty much double the size of a single Zen 2 chiplet, and double 74mm2 is 148mm2 or 150mm2 for a round number. Given TSMC’s defect rate of 0.09 per cm2, this would give a yield around 87%.
U slučaju da AMD-u pukne film do kraja, ovak bi to moglo izgledati nafilano do ibera - 16C/32T CPU + I/O + iGPU.
Tak jasno da ovo moje fantaziranje ne bude ugledalo svjetlo dana, ali sve paše na PCB koji su jučer pokazali.
Zadnje izmijenjeno od: The Exiled. 11.01.2020. u 00:26.
Staro 11.01.2020., 02:30   #7145
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,393
Usporedba sa Zen 2 chipletom nije baš najpreciznija s obzirom da x86 dio na mobilnoj platformi ima 4 puta manji L3 (8MB). Na L3 ide gotovo jednako površine kao i na same jezgre. Znači, ukupno manja površina nego klasični chiplet (matematički cca 62,5% površine chipleta).
No, zanimljivo je koliko su povećali clock i efikasnost Vege na mobilnoj platformi. Koji CU više za desktop bi dobro došao, plus očekivani clock sjeverno od 2Ghz.
Također je pitanje chiplet dizajna za desktop. Za mobilnu platformu im nije trebao PCIe 4.0 (potrošnja i broj linija) pa je monolitni dizajn vjerojatno bio pogodniji.
IMHO, za desktop bi imao smisla postojeći IO die + jedan 7nm hibridni chiplet sa smanjenim L3. Pitanje da li bi bio veći od 100mm2. Ovisno što im je jeftinije/proizvodljivije ... na kraju možda bude i monolit kao što je i Xbox chip.
Zadnje izmijenjeno od: stef. 11.01.2020. u 02:41.
Staro 11.01.2020., 08:16   #7146
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Pa vjerujem da im je najisplativije iste proizvode s mobilnog dijela prodavati kao desktop apu-e. Cak i 6/8 jezgreni cpu sa 7/8cu grafom je cist ok za, usudim se reci, sve non hardcore gaming usere sljedecih 3-5 godina. I svi procesori su zapravo isti cip, pa se sa cherry pickingom stavlja brojka 3,5,7 pokraj slova r i ogranicava broj cu u grafickom dijelu. Lijepo iznenadjenje bi bilo da puni 7nm apu chip ima 8cpu/11/13/16?gpu jezgri u 65w konfiguraciji.
Takav monolitni 8cpu chip s integriranim io dijelom ocekujem i u konzolama + navi chip pokraj, kao sto je i u trenutnim konzolama. Di navi radi samo u igrama, a integrirani vega chip za sve ostalo.
Tako da navijam za ljeto, skupa sa b550 chipsetom. Znam da ce to biti gotovo isti cip kao b450 ali ocekujem vise itx varijacija od mbo proizvodjaca i s boljim (vecim) biosom.
Na sljedecu zimu nas opet ceka nesto novo, tj poboljsano, zen 3. A to je opet godinu i pol od zen2. Tolika vremenska razlika je bila izmedju prvih conroe (e6 c2d) i sljedecih wolfdale (e8 c2d) procesora, kao i malo vise nego izmedju zen i zen2.
I jos nesto, cini mi se da amd popravlja politiku nazivanja modela i konfiguraciju jezgri. Ovi uvodni ryzen4000 imaju smisleni poredak. Taman je jos ostalo mjesta za r9 4900 i 4950, kao i za osnovni Athlon 4000.
Zadnje izmijenjeno od: Campeonato. 11.01.2020. u 09:02.
Staro 11.01.2020., 09:30   #7147
Manuel Calavera
Postovi: 14,584
Naming shema Ryzena je čisti copy/paste intelove
Čak i mobilci imaju H i U sufikse
Staro 11.01.2020., 10:38   #7148
Gašpar
trpi, trpi...
Datum registracije: Oct 2019
Lokacija: CRO
Postovi: 110
amd da napravi 8core cpu sa integriranom grafickom
thumb very nice great success great succes borat very nice 50474139
intel vec godinama
flat,750x,075,f pad,750x1000,f8f8f8.u1
Gašpar je offline   Reply With Quote
Staro 11.01.2020., 11:07   #7149
Manuel Calavera
Postovi: 14,584
Godinama?
i9 9900K je vani godinu i koliko mjesec-dva? S tim da će igpu biti mnogo ozbiljniji
Staro 11.01.2020., 11:32   #7150
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,488
Peca tip na losu ljasku.
Staro 11.01.2020., 11:45   #7151
sti
Lokacija: Lawl
Postovi: 1,378
Crveni trokut ispod avatara, prijava za spam, trollanje, birajte...
Staro 11.01.2020., 13:22   #7152
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Tako je to kad ne procita o cemu se raspravlja i samo uleti sa svojim biserom .
Staro 11.01.2020., 15:03   #7153
Postovi: 8,353
Autor stef Pregled postova
To si 100% u pravu, ovo moje je prije svega odokativno, ali ono kaj sam htel reći - mogu komotno ići putem dva punokrvna Zen 2 chipleta. Jedan samo s CPU jezgrama, drugi je iGPU i još I/O da sve fino poveže i da ostane PCI-E 4.0.
EDIT:
Ovak bi to izgledalo na primjeru R9 3950X modela, ali u ovom slučaju dobimo R7 3700X kojem je drugi chiplet zapravo 7nm Vega iGPU, dok sve ostalo ostaje ko i dosad.
Zadnje izmijenjeno od: The Exiled. 11.01.2020. u 16:30.
Staro 11.01.2020., 22:47   #7154
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
AMD’s Budget B550 & Entry Tier A520 Chipset Mass Production For 3rd Gen Ryzen CPUs Commences in Q1 2020
https://wccftech.com/amd-b550-a520-c...-2020-asmedia/
"It is expected that the retail products based on these chipsets would be available on shelves within the first half of 2020....."
Staro 14.01.2020., 18:49   #7155
BusMaster
BusMaster's Avatar
Postovi: 343
Staro 14.01.2020., 18:51   #7156
BusMaster
BusMaster's Avatar
Postovi: 343
Staro 16.01.2020., 21:03   #7157
Manuel Calavera
Postovi: 14,584
Electronic Times:
600 čipset dolazi krajem godine - donosi usb 3.2 i usb 4.0 support
Pretpostavka je da zen3 onda izlazi na CES-u 2021 god. (početak 1 mjeseca)
Staro 20.01.2020., 08:32   #7158
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
Inace AMD je all time high na burzama.
Di je onaj "ekonomist" sto je tvrdio da ce bankrotirati 2018.
Amd_Shill je offline   Reply With Quote
Staro 22.01.2020., 12:58   #7159
sti
Lokacija: Lawl
Postovi: 1,378
Staro 22.01.2020., 13:20   #7160
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,268
vrijeme za jos jednu uplatu na dionice ? zjbvm
bit ce to mocna stanica ako netko upari taj proc sa 2070 ili 2080 diskretnim GPUom
Staro 23.01.2020., 07:54   #7161
Manuel Calavera
Postovi: 14,584
Kao što je AdoredTV upozorio ti AMD slajdovi su malo sumnjivi tj. gotovo sigurno netočni (recimo da je 4800H bolji od desktop i7 9700K u faking gamingu, da je bolji u "creationu" je možda i moguće, no pitanje je u čemu točno i da li je cherry pickano), no sigurno će biti najbolji i najkonkurentniji AMD cpu do sada na laptop tržištu, te će ići i u laptope sa high end gpu
Staro 23.01.2020., 08:01   #7162
MAHER
Postovi: 1,583
Autor Psycho Pregled postova
Ako je stvarno toliko jak, zasto bi dozvolili prodaju sa nvidiom? Uparis ga fino sam nekakvom amd mobile grafom i nek se prodaje.
MAHER je offline   Reply With Quote
Staro 23.01.2020., 08:06   #7163
Postovi: 8,353
Imaju kombinacije sa svojim i nVidia karticama, a kak god se okrene nVidia trenutno nudi bolje. Na CES-u je bilo dosta high-end modela uredno s GeForce karticama i kao takvi stižu na tržište.
Staro 23.01.2020., 09:44   #7164
Manuel Calavera
Postovi: 14,584
Autor MAHER Pregled postova
Zato što nemaju high end gpu u laptopima (niti na desktopu), te drugi i važniji razlog - zašto bi se limitirali na svoje gpu, nvidia se prodaje kao alva, šire im je tržište ovako
Staro 23.01.2020., 11:16   #7165
Psycho
Master Of Disaster
Psycho's Avatar
Postovi: 1,268
tocno to. Dok ne prodje 6-8 mjeseci 2020e i neko cudo se desi, Nvidia je i dalje bog i batina high end GPU trzista.
Staro 25.01.2020., 11:05   #7166
MAHER
Postovi: 1,583
Ok, ali ako toliko mlate intel popravili bi si prodaju monile gpu time, a koznati neka se natjece na nekom intel odronu.
Vrlo brzo bi se gledale performanse i naravno cijena intel+nvidija vs amd kao platforme, a nisam siguran kako bi to izaslo.
Staro 25.01.2020., 11:09   #7167
Manuel Calavera
Postovi: 14,584
Ako je high end gamerski laptop, na kraju se ipak kupuje zbog gpu. A amd kao što sam rekao to nema...
AMD na kraju dana samo prodaje komponente (točnije cpu i gpu) laptop vendorima, ne sastavljaju oni laptope pa da diktiraju koju će gpu asus i slični staviti sa njihovim cpu
Staro 25.01.2020., 15:58   #7168
MAHER
Postovi: 1,583
Niti ne moraju, samo se igras rabatima, full cijena ako uzmes samo proc. 70% rabata ako ga paris sa mojim cipsetom i gpu.
Intel se igrao slicno sa serijama laptopa u proslosti, pa je onda sve bilo njihovo, samo nisu imali gpu za gurat sve.
Staro 26.01.2020., 00:12   #7169
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Evo jedna stara vijest,zanimljiva jer smo uplovili u 2020.
LINK
Da su unajmili mene da im napisem analizu bila bi puno tocnija.
Staro 29.01.2020., 08:46   #7170
Postovi: 8,353
AMD's 4Q/FY19 Financial Report: Revenue up 50% from 4Q18, Debt Halved
For the full financial year, AMD is reporting revenue of $6.73 billion, up 4% from 2018, and a full year gross margin of 43%, up from 38%. Operating income was up 40% to $631 million, but net income was almost flat at $341 million. Earnings per share for the full year were down 6% to $0.30. Within Q4, AMD paid down a lot of debt - down from $1087m in 3Q19 to $563m in 4Q19, which would lead to suggestions that AMD could pay off its debt by the start of 3Q20. This also corresponds with a positive free cash flow, increasing from $1209m in 3Q to $1503m in 4Q.
Izvor: AnandTech
