Xulos :)
Postovi: 7,581
Intel ARC/Xe GPU
Nekoliko novosti o intelovoj dGPU , pod nazivom Xe: Intel Puts Out More Official-looking Renders of the Xe Graphics Card "Intel China through its Weibo (Twitter-equivalent) handle put out more official-looking renders of its Xe graphics card. The Weibo post doesn't cite an author, leading us to speculate that the company's industrial design team is close to finalizing a product-design for at least the client-segment derivative of Xe. The swanky-looking card apparently has a stamped metal cooler shroud, a cooling solution that's based on a fin-stack heatsink that's ventilated by three fans, and quite some LED embellishment. An interesting design detail is the exponent symbol projected on the center fan. The power inputs are located at the tail end of the card, which is where most professional graphics cards have them; and consist of a pair of 8-pin PCIe inputs. Display inputs include three DisplayPorts, and an HDMI. The first Xe graphics card bound for 2020 will be built on Intel's 10 nm silicon fabrication process, which offers comparable transistor-densities to current 7 nm nodes." ![]() ![]() ![]()
...samo te gledam...
Postovi: 2,838
S obzirom da je Intel počeo kuhati Larrabee još sada davne 2010. nadam se da će Xe biti dostojan pojavljivanja na tržištu uz Nvidiu i AMD. |
Postovi: 2,838
S obzirom da Intel cilja na tržište brze pohrane podataka koja će pratiti nadolazeću 5G mrežu i na servere koji će to objediniti, ne bih se čudio da ovom grafičkom karticom ulaze i u dio tržišta koje Nvidia pokriva svojim Tesla karticama. |
#5 | |
Postovi: 14,589
To su konceptualni cooleri od umjetnika (vjerojatno neće vidjeti tržište jer ne radi za vendore) Zašto ih intel predstavlja - vjerojatno da golica maštu i da se priča o njihovim gpu Mene najviše zanima rang performansi, spominjalo se od gtx 1060 pa do gtx 1080, no random rant, nije ni leak. Vrlo vjerojatno neće napasti nvidia high end, a možda ni rang najjačih amd-ovih (tada navi 20) |
Postovi: 2,838
https://www.tomshardware.com/news/in...res,38246.html Imaš na slici pod nazivom GPU IP SCALABILITY navedeno "Datacentre/AI". I na tom linku pretpostavljaju: If successful, this could be Intel's answer to Nvidia's CUDA, except it would work on any Intel processor. |
#7 | |
Postovi: 8,655
Postovi: 2,838
Ma tako sam nekako i ja razmišljao sve dok nisam shvatio da je Intelu ciljano tržište zapravo upravo ovo navedeno, "Datacentre/AI". Ne mora sama grafička biti posebno brža od Nvidia pandana, dovoljno je da Intel uklopi svu novu tehnologiju pa da se to na serverima ipak dobro vrti. Tu mislim na brze SSD-ove, Optane i pitanje što još Intel skriva kao asa u rukavu, ako se to sve ukomponira u server koji ima ultrabrzi dohvat i pohranu podataka, to bi moglo biti pun pogodak. |
Dobro je sve.
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,534
https://www.pcgamesn.com/intel/xe-ma...s-card-hbm?amp https://youtu.be/05Vx51gh6Mo Sent from my Redmi Note 5 using Tapatalk |
#10 | |
Postovi: 8,655
Intel’s 2021 Exascale Vision in Aurora: Two Sapphire Rapids CPUs with Six Ponte Vecchio GPUs Citiraj:
#11 | |
Postovi: 8,655
Intel Xe rumors: Development reportedly stagnating and efficiency worse than its competitors Citiraj:
Postovi: 8,655
Uspješno prelazi iz firme u firmu pri čemu uvijek zadržava rukovodeće pozicije. ![]() Super su mi ovakvi intervjui s njim u kojima uvijek priča iste stvari i uvijek je fokus stavljen na arhitekturu.Ko zna kaj bude na kraju ispalo od Intelovih GPU rješenja, ali ne bi me čudilo da Raja Maharadža i ovaj brod napusti u potrazi za novim izazovima. Možda ga Kožna Jaketa angažira. ![]() |
#18 |
Postovi: 14,589
Sad lik više nema izgovora. Imao je vremena, financije i ljude, ako to već nije imao u AMD-u Osobno ne vjerujem da će biti nešto mega, ali ne bi bilo dobro da intelove gpu ispadnu flop, one time, tj. da ne ostanu 3 igrač |
#19 | |
Postovi: 2,138
To je doba bilo ono doba terrascale arch
#20 |
Postovi: 8,655
Da, ali to je već bilo u planu i opticaju prije njegovog (ponovnog) dolaska u AMD. Nekak ostaje dojam da su za njegove uspjehe zaslužni drugi, tj. timovi za koje je bil zadužen. Slično kak se Jim Keller spominje u Zen kontekstu, a zapravo je Michael Clark (1 - 2 - 3) zaslužan za sve uistinu bitno. ![]() Previše toga je trenutno ni-vrit-ni-mimo u Intelu, a Raja i biser Ryan Shrout baš ne pomažu u takvoj situaciji. |
#21 |
Postovi: 2,138
Ne baš, terrascale je izašao 2007, a on je u ATi-u od 2001, istina nije samo on zaslužan za uspjeh odredjene qarch, ali isto tako nije ni jedini krivac. Za ostalo se sve slažen, kak si napisao, ni vrit ni mimo
#22 |
Postovi: 14,589
#29 |
Legendo ovo je sviralo u autu jutros ![]() Svakako paše za tematiku. A ovo za Intel i ekipu oko njega, pocjeća me na kolegu iz srednje. Lik je slušao Beatlese. Glavni argument mu je bio "to je najbolji i najprodavaniji bend svih vremena, ove vaše Metalike i to, to je qrac. Svi skupa nemaju prodanih albuma ko ovi moji". Tako da ono... valid ground je valid ground ![]() Iskreno, bilo bi dobro da kad grafičke izađu da ne bude samo "rekordna zarada" nego da se hvatamo čak i usporedbi sa duopolistima. Držim fige. |
#30 |
Postovi: 4,510
Akcija i reakcija...mindfacory de statistika svako malo i sl. |
