|  15.05.2019., 15:18 | #301 | |
| Premium Datum registracije: Feb 2007 Lokacija: Zagreb
					Postovi: 4,383
				 | Citiraj: | |
|  15.05.2019., 15:34 | #302 |
| Premium Datum registracije: Feb 2005 Lokacija: Zagreb
					Postovi: 2,138
				 | GTA V, Meltdown/Spectre protection enabled: Frames Per Second (Higher is better) Min, Max, Avg Pass 0, 12.466310, 87.951523, 67.537834 Pass 1, 35.587948, 102.294464, 77.057365 Pass 2, 45.975742, 123.643021, 79.567863 Pass 3, 44.063927, 114.885742, 86.587761 Pass 4, 22.912081, 130.247345, 77.674034 GTA V, Meltdown/Spectre protection disabled: Frames Per Second (Higher is better) Min, Max, Avg Pass 0, 18.301443, 94.711319, 76.394928 Pass 1, 49.353958, 135.707306, 87.262985 Pass 2, 49.573666, 136.217514, 88.964317 Pass 3, 55.602509, 132.006226, 101.361748 Pass 4, 25.132448, 149.900314, 85.941391 Ghost Recon Wildlands, Meltdown/Spectre protection enabled: FPS:Average: 50.48 Min: 34.72 Max: 56.16 GPU peak temp: 74 CPU usage: Average: 46.0% Min: 36.7% Max: 59.5% GPU usage: Average: 76.1% Min: 65.8% Max: 86.1% RAM usage: Average: 2.8 GB Min: 2.7 GB Max: 2.9 GB Ghost Recon Wildlands, Meltdown/Spectre protection disabled: FPS: Average: 54.50 Min: 45.14 Max: 58.59 GPU peak temp: 74 CPU usage: Average: 42.7% Min: 32.3% Max: 52.3% GPU usage: Average: 81.9% Min: 62.5% Max: 92.3% RAM usage: Average: 2.7 GB Min: 2.6 GB Max: 2.8 GB It may be worth noting the higher CPU and lower GPU usage in Ghost Recon Wildlands with Meltdown/Spectre patches enabled, which may indicate TLB flushing is eating CPU cycles and bottlenecking the GPU in this scenario. TL;DR Meltdown/Spectre protection patches hit the performance of open-world games particularly hard on pre-Haswell CPUs. Win10 Unpatched Win10 Meltdown Patch Win10 Meltdown + Microcode Patch The Witcher 3, Ultra, No HairWorks 139.8fps 128.3fps 126.6fps Rise of the Tomb Raider, Very High, DX12 121.6fps 117.2fps 121.6fps Far Cry Primal, Ultra 128.4fps 127.0fps 126.2fps Crysis 3, Very High 129.3fps 129.2fps 126.8fps Ashes of the Singularity, CPU Test 35.3fps 35.5fps 35.6fps Assassin's Creed Unity, Ultra High 131.1fps 131.2fps 130.3fps
				__________________  |
|  15.05.2019., 16:48 | #303 |
					Postovi: 4,383
				 | Ovdje su testirali i razlike su bile u jednoj igri, sa drugim intelom čak ni ni u toj jednoj igri...par postotaka razlike.  https://youtu.be/LC1WuKdPVCQ |
|  15.05.2019., 17:31 | #305 | |
					Postovi: 2,138
				 | Citiraj:
				__________________  | |
|  15.05.2019., 19:06 | #306 |
| DIY DILETANT Datum registracije: Jan 2009 Lokacija: Čistilište
					Postovi: 3,638
				 | Mislim da je Mladenxy pitao za utjecaj Retpoline patch-a. |
|  16.05.2019., 13:18 | #307 | |
| McG Datum registracije: Feb 2014 Lokacija: Varaždin
					Postovi: 8,373
				 | Intel Tried to Bribe Dutch University to Suppress Knowledge of MDS Vulnerability Citiraj:
|  16.05.2019., 14:21 | #310 |
					Postovi: 4,383
				 | Treba pričekati da netko relevantan napravi nove testove, po ovim prethodnim zakrpama nije se izgubilo praktički ništa za kućnog korisnika. Osobno nisam ništa osjetio a windowsi se krpaju redovno kao i biosi na zadnje verzije. https://www.youtube.com/watch?v=_qZksorJAuY |
|  16.05.2019., 16:14 | #312 |
					Postovi: 8,373
				 | Noviji hardver još i relativno dobro podnosi sve te zakrpane peripetije, ali nažalost Sandy, Ivy, Haswell i Broadwell znaju pokleknuti, a još uvijek se koriste. |
|  16.05.2019., 16:20 | #313 |
					Postovi: 2,138
				 | Ali i na novijima su razlike vece nakon 1809 ak sam dobro skuzio piskaranja po netu jer su dodatne zakrpe tad metnuli Kroz koji tjedan ce se znat sto je s ovim zadnjim failom, kako te zakrpe utjecu na perf.
|  16.05.2019., 18:59 | #314 |
					Postovi: 4,383
				 | Kažu ovdje https://www.pcgamesn.com/intel/zombi...on-performance Intel’s benchmarks suggest only a marginal decrease in within some tasks while Zombieload mitigations are in place. Within the company’s in-house testing, a Core i9 9900K with HyperThreading enabled drops 3% performance in WebXPRT 3 testing. At best, it gained 1% within SPECint_rate_base 2017 (1 copy) testing. Problem je ovo gašenje HT-a dok ne izdaju mikrokodove. |
|  16.05.2019., 22:19 | #316 | |
					Postovi: 8,373
				 | Kak god se okrene daleko je ovo od zajebancije koje će se "riješiti" hrpom zakrpa, koje pak same po sebi nisu nikakvo rješenje - pogotovo, ako se gubi dobar dio funkcionalnosti. Citiraj:
|  18.05.2019., 19:17 | #319 | |
					Postovi: 8,373
				 | The Performance Impact of MDS / Zombieload: The overall cost of Spectre/Meltdown/L1TF/MDS Citiraj:
|  21.05.2019., 18:44 | #320 |
					Postovi: 4,383
|  23.05.2019., 21:31 | #321 | |||
					Postovi: 8,373
				 | Windows 10 Security Patch Slowed Intel Core i9 9900K in Pix4D, Metashape & RealityCapture Citiraj:
|  25.05.2019., 17:05 | #322 |
					Postovi: 4,383
				 | Ako bude ovako biti će totalna katastrofa za i7 4/8 procesore a 2/4 procesori će postati totalno neupotrebljivi. https://www.youtube.com/watch?v=O9t7u5pM1cE Za te korisnike jedino rješenje je ne nadograđivati BIOS ali opet je upitno kao će razviti situacija nakon krpanja windowsa. |
|  25.05.2019., 18:50 | #323 |
					Postovi: 8,373
				 | Bojim se da bi u par godina ista stvar mogla dočekati trenutno aktualne Intelove 6C/12T i 8C/16T modele, jer primjera radi - Core i7-7700K je daleko od lošeg procesora. Nažalost, taman kad je lansiran su izašli i novi Ryzen modeli, a sve ostalo u pogledu ovih sigurnosnih propusta je samo dodatno zapečatilo sudbinu nekadašnjih high-end 4C/8T procesora. Neovisno o AMD-u i Ryzenima, Intel bi ovo kad-tad dočekalo, možda bi zabava potrajala još koju godinu, ali sustiglo bi ih svakak. |
|  25.05.2019., 19:28 | #324 |
					Postovi: 4,383
				 | Bude li stvarno ovako po 30% pada performansi nakon novih biosa ili nadograđenih windowsa tužbe bi morale pljuštati barem u USA. Nisu ni nvidiji gledali kroz prste sa GTX 970 i lažno predstavljenih kartica sa vramom. Vraćali su kupcima dio novaca. Kaj se tiče i7 7700K deleko je još on pečačenja, po svim testovima dere u gamingu pogotovo kada se kloka, bez obzira na konkurenciju. |
|  25.05.2019., 19:39 | #325 |
					Postovi: 8,373
				 | Ma je, sve je jasno, a 7700K sam samo za primjer navel, jer vidi kaj se događa kad se sve te zakrpe nabacaju na hardver koji uopće nije za baciti. Izuzev kompletno nove arhitekture, nemaju baš puno manevarskog prostora. Na stranu isključivo igranje, već kad se pogleda kompletna slika - igre + općenito svakodnevno korištenje računala u ostalim aplikacijama i rezultati su nažalost poražavajući. |
|  13.11.2019., 11:48 | #326 | |||
					Postovi: 8,373
 Izvor: BleepingComputer, OC3D i Phoronix Zadnje izmijenjeno od: The Exiled. 13.11.2019. u 21:03. | |||
|  17.11.2019., 01:47 | #327 |
| #erase startup-config Datum registracije: Nov 2001 Lokacija: Zagreb
					Postovi: 3,729
				 | Ispada da su Intelovci žrtvovali sigurnost da bi imali brže procesore. Sad će softwaresko i microcode krpanje usporit procesore puno više nego što su dobili na brzini time što nisu staviti hardware checkove kao AMD.  Imam neki feeling da još nismo vidjeli sve i da će biti još toga... |
|  17.11.2019., 10:57 | #328 |
					Postovi: 3,638
				 | Te zvijeri još uvijek nisu s whitehatovskih papira pobjegle "in the wild". Neznam šta čekaju ti zli blackhat momci, još če ispast ko bura u čaši vode. |
