Staro 13.11.2019., 17:55   #541
d0X
Kostolomac
d0X's Avatar
Postovi: 1,578
Autor IHrvojeI Pregled postova
Jel gleda tko konju u jaja, jel se ona pravilno stisnu kad je hladno i pravilno opuste kad je toplo? Jel fercera taj fičr?
Samo kobile jašem jbg
Staro 13.11.2019., 19:37   #542
scarwin
scarwin's Avatar
Datum registracije: Sep 2014
Lokacija: Zagora
Postovi: 179
Zna li iko kako maknut ovu ikonu od miša u igri?
Par puta sam isključija miš i ponovno uključija pa bi nestalo ikone, ali više ne pomaže to.
scarwin je offline   Reply With Quote
Staro 13.11.2019., 19:43   #543
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
na fejsu su stavili u slike pa je malo nezgrapno
Staro 13.11.2019., 20:02   #544
MadManBD
MadManBD's Avatar
Postovi: 944
Autor scarwin Pregled postova
To je jedan od bugova koji neki imaju, rjesenje sam vidio na youtube, upali: "Display pointer trails" od opcijama misa u windowsima,
a neki kazu da kad upalis mouse smooting u opcijama igre nestane ta ikona, pa probaj.
Staro 14.11.2019., 09:56   #545
scarwin
scarwin's Avatar
Lokacija: Zagora
Postovi: 179
Autor MadManBD Pregled postova
Ovo funkcionira. Hvala
Staro 14.11.2019., 10:31   #546
tpm4
tpm4's Avatar
Postovi: 330
Graphics & Performance Fixes
Added an additional launch argument (-cpuLoadRebalancing) to rebalance workload on the CPU cores and avoid hitting an edge-case in certain NVIDIA graphics card drivers that causes significant stalls on 4-core and 6-core CPUs
For more information, please see this support page: https://support.rockstargames.com/articles/360038940333
Added improvements for performance and stability on graphics cards with 4GB of VRAM or less when using Vulkan
Fixed an issue that resulted in audio stuttering and sound drops on some CPUs when using Vulkan
Fixed an issue that resulted in graphics problems when using Fullscreen mode on systems with multiple displays
Fixed an issue that resulted in the game becoming stuck in Windowed Borderless mode instead of Fullscreen mode if the game lost focus or certain graphics settings were changed under DirectX 12
Fixed issues that resulted in the incorrect detection of devices and problems switching between SDR and HDR modes. Players who previously encountered these issues should enable HDR through the Windows Display Settings prior to launching the game
Fixed an issue that resulted in the game launching in a window larger than the maximum resolution of the attached display when using Windowed display mode
Improved the auto-detection of system hardware so that the recommended default graphics settings will provide higher performance
Fixed an issue that resulted in the game setting a default graphics preset that was unsupported by the amount of available VRAM on some graphics cards, preventing the game from launching
Fixed an issue that resulted in VRAM usage estimation for pending settings changes to be slightly different to the actual usage once the settings were applied
Added a separate option to enable tessellation on tree models within the Graphics settings menu
Fixed an issue that resulted in reduced performance when switching between different graphics settings presets without restarting the system
Fixed an issue that affected the brightness of Photo Mode images that were captured in HDR after editing them using the Social Club menu
Fixed issues with some full-screen effects and Photo Mode filters when using a display aspect ratio other than 16:9
Fixed an issue that resulted in graphics artifacts in mirror reflections when using Multisample Anti-Aliasing (MSAA)
Fixed an issue that resulted in graphics artifacts on the Pause Menu Map when using Multisample Anti-Aliasing (MSAA )
Fixed issues with rendering and lighting that occurred with some waterfalls
Fixed issues with rendering that occurred with a Story Mode character
Fixed an issue that resulted in flickering graphics artifacts on some systems using multiple graphics cards
Fixed an issue that resulted in graphical corruption during the theater shows in Saint Denis
Fixed an issue that resulted in graphics artifacts to appear when rendering some light reflections
Fixed an issue that affected the rendering of the Pause Menu background after changing the display resolution
Fixed an issue that resulted in reduced world detail at long distance when using items that allow zooming, such as scopes and binoculars
Fixed an issue that resulted in rendering issues with shadows on some parts of the terrain
Fixed an issue that resulted in graphics artifacts that could occur with some hair/fur rendering when using Multisample Anti-Aliasing (MSAA)
Improved the performance rendering some in-game particle effects
Improved the performance rendering of trails when in snowy areas of the game
Fixed an issue that resulted in the partial rendering of the Pause Menu while some graphics settings were active
Stability Fixes
Fixed issues that resulted in crashes during game startup and logo screen
Fixed issues that resulted in crashes when changing graphics settings or switching back and forth between presets
Fixed an issue that resulted in crashes during the initial boot of the game in the Windowed display mode
Fixed an issue that resulted in a crash when switching between Windowed and Fullscreen display modes on some graphics cards
Fixed an issue that resulted in a crash when the game window lost focus or as a result of using Alt+Tab
Fixed an issue that resulted in a crash when attempting to load an autosave on some systems
Fixed an issue that resulted in a crash when repeatedly transitioning between Story Mode and Red Dead Online
Fixed issues that resulted in crashes when attempting to quit the game
Fixed an issue that resulted in a crash on some systems when connecting and disconnecting input devices with the game running
Fixed an issue that resulted in a crash when attempting to switch weapons in Story Mode
Fixed an issue that resulted in a crash when opening the HDR Calibration screen with some combinations of graphics cards and displays
Fixed an issue that resulted in a crash when using the mouse to switch between categories in the Satchel menu
Fixed an issue that resulted in the game freezing when applying remapped keyboard inputs through the Settings menu
Fixed an issue that resulted in an infinite loading screen when exiting the Settings menu and returning to the Landing Page
Fixed an issue that resulted in a crash when playing Story Mode while offline
Fixed crashes and stability issues that resulted in the error “Red Dead Redemption 2 exited unexpectedly” during gameplay
Fixed an issue with attempting to join another player’s Red Dead Online session with a different control scheme or lock-on type that resulted in networking issues
Fixed an issue that prevented the Red Dead Redemption 2 desktop shortcut from correctly launching the game
Control & User Interface Fixes
Improved mouse support in some Store menus
Fixed an issue that resulted in a black screen during the initial boot of the game rather than the loading bar
Fixed an issue that resulted in players being unable to equip emotes in Red Dead Online while using the mouse
Fixed an issue that resulted in the Map in the Pause Menu being cut off when changing the game resolution
Fixed an issue that resulted in player overhead displays to appear in the incorrect position on displays other than 16:9 aspect ratio in Red Dead Online
Fixed an issue that prevented some keyboard inputs from being remapped
Fixed an issue that resulted in some incorrect text and warning screens to appear when when remapping keyboard inputs
Fixed issues that resulted in problems with scrolling in parts of the user interface
Fixed an issue that resulted in some menus not displaying input controls, including Safe Zone and Brightness Calibration screens
Fixed issues with keyboard text input when using some languages
Fixed issues that resulted in the red selection highlight disappearing while browsing through menus
Fixed issues that resulted in problems with mouse selection, or erratic cursor movement when browsing some menus
Fixed an issue with keyboard navigation of the Pause Map after selecting a blip/icon.
Fixed an issue that resulted in players being unable to complete some actions while inspecting weapons
Fixed an issue that resulted in save game information to be missing from the Load Game menu
Fixed issues with text input of non-Latin characters and added support for more input methods
Fixed an issue that resulted in the Pause Map moving position after placing a waypoint
Fixed an issue that resulted in difficulty aiming with a mouse, especially at low DPI settings
Fixed issues that resulted in incorrectly sized, overlapping or misaligned user interface elements under different display resolutions
Fixed an issue that resulted in the loss of previous selections when navigating back and forth between menus
Fixed an issue that resulted in redundant options in the Keyboard and Mouse submenu of the Controls menu
General / Miscellaneous
Improved the stability and result consistency of the in-game Benchmark Tool
Fixed an issue that resulted in players appearing underneath the world when in the lobby screen while playing some Red Dead Online content
Fixed an issue that resulted in incorrect performance of the ‘Tap and Hold Speed Control’ accessibility feature while using keyboard and mouse controls in First Person camera mode
Fixed an issue that resulted in camera stuttering when using the mouse to look around while sprinting
Fixed an issue that caused problems with the fishing minigame when running at high framerates
Pise da su rijesili s novim patchem smrzavanje s 4 i 6 core cpu. Treba dodat u launch options -cpuLoadRebalancing.
Moram to isprobat danas, jedina stvar koja me zezala...
Inace skoro sve na ultra 1080p se vrti na 40-60fps, meni dosta posto je igra cijela malo usporena.
Patch notes:
Stability Fixes
tpm4 je offline   Reply With Quote
Staro 14.11.2019., 17:46   #547
thesaint255
thesaint255's Avatar
Datum registracije: Dec 2009
Lokacija: Graz
Postovi: 539
Zasada niti jedan crash i prije patcha sam imao prosjecno 50-55 fps, sada nakon patcha je prosjek 70-75 min pa do kojih 80.
7800X3D @ Scythe Fuma 2
ASRock B650I Lightning WiFi
32 GB Corsair Vengeance DDR5-6000
RTX 4070 ti Gamerock
Corsair SF750
Cooler Master NR200P
thesaint255 je offline   Reply With Quote
Staro 14.11.2019., 18:59   #548
tpm4
tpm4's Avatar
Postovi: 330
Mislim da su ti se postavke grafike resetirale nakon patcha.
Staro 14.11.2019., 19:47   #549
MadManBD
MadManBD's Avatar
Postovi: 944
Jesu da, nakon patcha sve bude kad upalis na low vise manje xD
Staro 14.11.2019., 22:19   #550
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 775
Pa jebo im pas mater ako je tako, baš imam živaca opet sve podešavati...
EDIT:
Je li se još nekome događa ovo? Svaki put kad ulazim u igru mi se ovo pojavi. Internet konekcija mi je stalna, nije da puca, tako da mi nije jasno wtf.
Zadnje izmijenjeno od: IGoR_2803. 15.11.2019. u 13:53.
Staro 16.11.2019., 01:22   #551
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
bome i meni je sad igra stabilna + dobio masu (15-20) FPS-a
Staro 16.11.2019., 03:12   #552
tpm4
tpm4's Avatar
Postovi: 330
Nisi dobio nista. Uveli su novu postavku u grafici i promjenili auto config grafike te su resetirali svima postavke.
Stabilnija igra je, nema vise smrzavanja.
Staro 16.11.2019., 03:48   #553
thesaint255
Lokacija: Graz
Postovi: 539
Istina je šta ste napisali, resetirati su postavke, pa sam vratio one preporučene s YouTubea šta ljudi kopiraju. Imam stabilnih minimum 60fpsa na 1440p s 1070ti. Najveći plus je šta igra se više ne ruši.
Corsair SF750
Staro 16.11.2019., 10:37   #554
killuminati
killuminati's Avatar
Datum registracije: Mar 2017
Postovi: 403
Staro 22.11.2019., 16:14   #555
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 775
Kako me igra nervira, to je strašno. Da se razumijemo, super je, ali ima toliko nelogičnosti da nekad poželim tipkovnicu razvaliti na koljenu. Dakle, fino jašem po divljini kad začujem zapomaganje nekog lika. Kao, uginuo mu konj pa treba prijevoz. Frajer izvuče pljucu i hoće me opljačkati. Smjestim tipu tri metka u čelo i to je to, odem svojim putem. Ali ne, dva tipa na konjima su svemu svjedočila i sad sam "wanted for murder". Ajde u kurac...
Staro 22.11.2019., 16:55   #556
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,257
Pa to je za pohvalu developera a ne za nerviranje, ajd ti ubij nekog pa da vidimo 😂
Ja bas volim takve detalje u igrama
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9,10
Zadnje izmijenjeno od: Omerta. 22.11.2019. u 17:02.
Staro 22.11.2019., 22:21   #557
Necto
Necto's Avatar
Postovi: 751
Arrow
Autor IGoR_2803 Pregled postova
Imaju vise ovih RDR skeceva
https://www.youtube.com/playlist?lis...yBOuX4hde5Vb9v
Necto je offline   Reply With Quote
Staro 23.11.2019., 10:54   #558
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,279
Evo kako se vrti na starim procezorima sa 2060
https://youtu.be/vjcZScPXWkA
Staro 23.11.2019., 11:18   #559
Postovi: 17,143
Ovaj 1080p low izgleda kao RDR1
Staro 28.11.2019., 12:26   #560
ODO
Datum registracije: Feb 2015
Postovi: 601
Na misiji Goodbye Dear Friends susreo se sa prvim erorrom, pokušao par puta, nakon par sekundi se ruši igra. Netko još ima problema s tim?
ODO je offline   Reply With Quote
Staro 02.12.2019., 22:39   #561
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 775
Ovaj rockstar mi sad već stvarno testira strpljenje... jedva da nađem malo vremena za igranje navečer kad mi malena zaspi, ali ne, faking jebeni update mi ne prolazi... naravno, debilčine iz rockstar supporta tvrde da mi net ne radi... matere im se najebem
Zadnje izmijenjeno od: IGoR_2803. 03.12.2019. u 09:12.
Staro 03.12.2019., 09:12   #562
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 775
Izgleda da me nešto jebe s vezom prema rockstarovim serverima... uninstalirao sam igru i pokušao ponovno skinuti, sad ne mogu ni faking rockstar launcher skinuti... s posla normalno skida... firewall mi je isključen, ne znam kaj bi moglo biti
EDIT: sorry na duplom postu, pobjeglo mi. ugl. riješio sam, stvar je do routera bila, resetirao ga i sad sve radi... dobro da sam panj uninstalirao igru prvo tak da moram skidati 100+ GB opet.
Zadnje izmijenjeno od: IGoR_2803. 03.12.2019. u 09:41.
Staro 12.12.2019., 12:39   #563
Immortalis
Slobodan leni seronja
Immortalis's Avatar
Postovi: 852
Gdje najjeftinije kupit igru?
Planiram se oko Bozica zavalit za PC i ne izlazit dok ne pređem igru
Staro 12.12.2019., 12:45   #564
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,611
pa eto pričekaj oko božića bit će sigurno većih saleova, trenutno je rupa, 40ak eura je key
Staro 12.12.2019., 12:48   #565
Dragonchaser
Datum registracije: Apr 2016
Postovi: 79
Ja sam kupio na plati.ru i radi sve savršeno
https://www.plati.market/itm/red-dea...ce-key/2726467
Samo treba pratit instrukcije za aktivaciju (ruski VPN je potreban za aktivaciju)
Dragonchaser je offline   Reply With Quote
Staro 12.12.2019., 14:11   #566
Immortalis
Immortalis's Avatar
Postovi: 852
30$ nije puno na ovom plati.ru
Thanks
ali svakako, pricekat cu jos oko Bozica
Staro 12.12.2019., 15:00   #567
sti
Lokacija: Lawl
Postovi: 1,381
Autor Dragonchaser Pregled postova
Dakle, ključ se može kupiti za $29 bez VPN-a, ali je VPN potreban za registraciju na Rockstar Launcher? Nakon toga samo promijeniš adresu i to je to?
Staro 12.12.2019., 15:41   #568
Dragonchaser
Postovi: 79
Tako je, ključ sam kupio bez VPN-a.
Za aktivaciju je potrebno u Rockstar Launcheru prebacit regiju na Rusiju i upaliti VPN. Nakon što se ključ aktivira normalno se vrati regija na koju želiš i igra se može igrati bez VPN-a
Staro 17.12.2019., 15:02   #569
sti
Lokacija: Lawl
Postovi: 1,381
Prešao par misija u Chapter 2 i već vidim o kakvoj igretini se radi. Nevjerojatno koja megalomanska produkcija, vidi se da su developeri imali beskonačni budžet. Od svih igara izašlih u proteklih nekoliko godina, jedino Witcher 3 sa svim ekspanzijama može direktno konkurirati ovome. Scenarij, gameplay, grafika - vrhunski.. Već vidim da nakon ovoga ništa neće biti dovoljno dobro, barem do izlaska Cyberpunka.
Sa tehničke strane, mjesec dana nakon izlaska igra radi perfektno. Sa HW Unboxed preporučenim postavkama imam između 55 i 70 FPS na 1440p rezoluciji. Ni jedan crash, glitch, bug, ništa.
Staro 19.12.2019., 16:54   #570
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,631
Uzeo i ja preko plati.ru, skida se
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
