Staro 19.09.2019., 14:28   #6931
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Staro 20.09.2019., 21:04   #6932
Manuel Calavera
Postovi: 14,584
Yup, pizdarije
Hi Everyone,
We are focusing on meeting the strong demand for our 3rd generation AMD Ryzen processors in the market and now plan to launch both the AMD Ryzen 9 3950X and initial members of the 3rd Gen AMD Ryzen Threadripper processor family in volume this November. We are confident that when enthusiasts get their hands on the world’s first 16-core mainstream desktop processor and our next-generation of high-end desktop processors, the wait will be well worth it.
Thank you
AMD Corporate
Staro 20.09.2019., 21:11   #6933
Postovi: 8,421
EPYC ima prednost ispred svega ostalog, pogotovo sad, Intel u desetom mjesecu izdaje sve svoje preostale 14nm adute, tak da studeni nije (pre)strašan datum, a osim toga nije baš sve crno kad je 7nm TSMC zaliha u pitanju.
AMD threw all its eggs into TSMC’s basket, and while not nearly as big as Apple or others, they are clearly a friend of TSMC. They have also signed on for wafer production so they already have secured their place in line.
The only issue here is that if AMD has huge share gains against Intel they may be supply limited as they likely signed up for a specific amount of production which was probably a conservative number.
Staro 20.09.2019., 21:39   #6934
Manuel Calavera
Postovi: 14,584
Na kraju će ipak falit propali GloFo 7nm node i double dipping AMD-a...
Radi količina se vjerojatno i čeka duže na slabije Navi gpu i threadrippere, a di su tu tek konzole
Imat će i samsung 7nm (ekvivalent 7nm+ od tsmc) samo navodno nisu skroz kompatibilni kao što je GloFo trebao biti sa tsmc, pa se mora dizajnirati oko istog tj. ne može se samo prebaciti sa jednog na drugog. Samsung se spominjao i u kontekstu next-gen nvidija
Zadnje izmijenjeno od: Manuel Calavera. 20.09.2019. u 21:46.
Staro 21.09.2019., 19:28   #6935
lobo64
lobo64's Avatar
Postovi: 1,346
Wccftech ima tablicu gdje se spominju R5 3500 za 129 i R5 3500x za 149$. Dali to znači da je ofišl i ako je, kada će se pojaviti na tržištu?
https://wccftech.com/amd-ryzen-9-395...cinebench-r15/
lobo64 je online   Reply With Quote
Staro 21.09.2019., 20:19   #6936
Postovi: 8,421
Je, izgleda da i ti modeli stižu u studenom.
Staro 21.09.2019., 21:26   #6937
lobo64
lobo64's Avatar
Postovi: 1,346
OK, ak 3600 ide za ~1500 Kn, onda bi 3500x išao za cca 1200 pa čak i manje a 3500 za cca 1000? Bi li to bila nekakva realna projekcija?
Postoji li šansa za nekakav 8C/8T model?
Staro 21.09.2019., 21:40   #6938
Postovi: 8,421
Da, cifre bi prema ovome bile tu negdje, a kaj se tiče 8C/8T modela - sve je moguće (R7 3750?) - mada ga dosad nije bilo, ali AMD može iskombinirati kaj god ih volja.
Staro 21.09.2019., 21:45   #6939
Manuel Calavera
Postovi: 14,584
8/8 bi bio dobar, ali mislim da neće postojati. Kanibalizirao bi prodaju postojećih R7-ica
Staro 21.09.2019., 22:14   #6940
lobo64
lobo64's Avatar
Postovi: 1,346
Možda griješim, ali 6/6 pa čak i 8/8 mi se čine kao čisti gamerski procovi (6/12 bi u produktivnosti sigurno popišao 8/8) pa mi ne izgleda da bi onaj tko sa kompom radi nekakav ozbiljan posao radije kupio proc bez smta, odnosno sporiji. A i Ryzene ne kupuju samo gameri.
No dobro, 8/8 je možda ipak moja utopija koja se neće ostvariti, makar sa 3500 mi izgleda kao pariranje na i5 9400 pa zašto nebi postojao pandan za npr. i7 9700?
Zadnje izmijenjeno od: lobo64. 21.09.2019. u 22:31. Razlog: dodavanje
Staro 21.09.2019., 22:27   #6941
Pa svi bi mi bili sretni sa 8/8 Ryzenom, ali Manojlo ti je rekao što bi se dogodilo.
R5 3600 - 1600 kn
R7 3700X - 2600 kn
I sad da tutnu R7 3650 8/8 za npr 2100... nit bi kupovali R5 3600 niti R7 3700X. Ubiješ 2 najprodavanija proca jednim... nema potrebe.
Ovi 6/6 koji će sad izaći su otpad pa da ih prodaju ali debelo nakon release datea.
Pa kad se sjetimo 02.03.2017 i prvih Ryzena. Launch je bio samo za 8/16 ekipu. 6/12 su došli 6 tjedana kasnije. A quadare još 3 mjeseca kasnije.
Staro 21.09.2019., 22:44   #6942
lobo64
lobo64's Avatar
Postovi: 1,346
Da, štima, nisam to gledao sa kapitalističkog stajališta.
Za kućnog korisnika kaj bi bilo bolje; 6/12 ili 6/6, naravno uzevši cijenu u obzir?
Jer ako ti 6/6 budu stvarno po tim cijenama, onda R5 1xxx, pa možda čak i neki R5 2xxx za po doma baš i nemaju nekog smisla osim ako im se cijena opako ne sunovrati.
Zadnje izmijenjeno od: lobo64. 21.09.2019. u 22:52. Razlog: izmjena
Staro 21.09.2019., 22:53   #6943
Pa to i je plan. Ionako tih procova nije ni bilo previše. Lagano to nestaje priča se zaokružuje na to da 6/6 izgaze i3 quadare i neke i5 lockane sixpackove.
Quadare pokrivaju sa 3200G i 3400G modelima koji imaju još i iGPU.
Staro 21.09.2019., 23:00   #6944
lobo64
lobo64's Avatar
Postovi: 1,346
Možda OT ali ipak: takav 6/6 plus jeftinjara R560 za neznatno više novaca lomi R3400G, ili?
Staro 22.09.2019., 04:17   #6945
Manuel Calavera
Postovi: 14,584
Naravno
Staro 23.09.2019., 10:26   #6946
sti
Lokacija: Lawl
Postovi: 1,379
AMD Ryzen 5 3500X 6 Core CPU Unboxed and Benchmarked – Faster Than The Core i5-9400F In CPU & Gaming Benchmarks
https://wccftech.com/amd-ryzen-5-350...nchmarks-leak/
Novi budget gaming kralj.
Staro 25.09.2019., 20:51   #6947
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
GLOBALFOUNDRIES Introduces 12LP+ FinFET Solution for Cloud and Edge AI Applications
Derived from GF’s existing 12nm Leading Performance (12LP) platform, GF’s new 12LP+ provides either a 20% increase in performance or a 40% reduction in power requirements over the base 12LP platform, plus a 15% improvement in logic area scaling. A key feature is a high-speed, low-power 0.5V SRAM bit cell that supports the fast, power-efficient shuttling of data between processors and memory, an important requirement for AI applications in the computing and wired infrastructure markets.
Other key features of 12LP+ that enable clients to capitalize on AI market opportunities are a design reference package for AI applications and design/technology co-development (DTCO) services, both of which allow clients to look at AI circuit designs from a holistic perspective in order to achieve lower power budgets and reduced costs. Another key feature is a new interposer for 2.5D packages, which facilitates the integration of high-bandwidth memory with processors for fast, power-efficient data processing.
Ovo mi se cini kao nesto sto ce koristiti AMD na I/O jezgri. Manja potrosnja, manje zagrijavanje i jos gore mogu stackati HBM.
Staro 25.09.2019., 21:03   #6948
Mladenxy
Mladenxy's Avatar
Postovi: 4,392
Autor sti Pregled postova
Bumo vidli. i5 9400F je 1143 kn, H310 mbo je 400 kn i sa njom i5 9400F drži sve jezgre na 3.9 ghza, 2666 mhz ram je 270 kn za 8gb...
Kad dođe taj ryzen stavi se sve na papir, pa se lako usporedi tko je budget gaming kralj.
Staro 25.09.2019., 21:18   #6949
Manuel Calavera
Postovi: 14,584
Ma treba bježati od čistih hexi, osim ako je budžet jako uzak. Eno R5 3600 ide i za 1436kn
Staro 26.09.2019., 00:11   #6950
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Round 2... Fight
Inače i hexe bez HT-a znaju jako pasti u 1% low FPS-u bez dual-channela. PUBG je jedan primjer: frend sa i5 8400 je slučajno stavio 2x8GB u single-channel i žalio se na padove FPS-a dok ja nisam imao nikakvih problema s 8GB RAM-a, ali u dual-channelu. Kad sam mu rekao, posložio je i min. FPS na istim mjestima u borbama mu je s oko 50 porasao na 80.
Staro 26.09.2019., 00:29   #6951
sti
Lokacija: Lawl
Postovi: 1,379
9400f je prošlo svršeno vrijeme, anemični zaključani plavac na mrtvom socketu.
Preporučuju ga samo vlasnici istog da bi nabili cijenu polovnom.
3500X je za istu cijenu brži u single core, multi core i gamingu, na socketu koji će još godinama biti podržan.
Staro 26.09.2019., 01:08   #6952
Mladenxy
Mladenxy's Avatar
Postovi: 4,392
Nebi ga ni spomenuo da nisi linkao tu usporedbu...sad odjednom ja ga preporučam jer imam prikrivene motive
Istina, to je anemični zaključani plavac na mrtvom soceketu ali koga briga ako platiš taj socket 400 kn i prodaš ga za par godina za 200. Trošak minimalan, gubitak minimalan, problemi minimalni ili ih ni nema.
U gamingu po ovim usporedbama koje si linkao su podjednaki, uz cijenu memorije i ploče koju sam naveo. Netko radije bira jeftino i dobro, pa za par godina novu DDR5 platformu i sl. Nisu svi emocionalno vezani uz matičnu ploču.
EOD kaj se mene tiče, ne namjeravam se svađati, prepucavati ili tupiti svoje.Ako tko treba kakvu direktnu usperdbu, snimljeni video ili sl. kako radi 6/6 proc u današnjim igrama, tu sam.
Staro 26.09.2019., 02:23   #6953
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
9400f je skroz ok izbor, ima svoje kupce.. i to dosta njih..
Nije da bi netko propao dodavsi koju kunu vise za r5 3600, ali definitivno nije ni neki zajb uzeti tog intelica.. svatko zna za sebe koji mu je argument prioritetniji, a svi ti argumenti stoje.
Nekad je AMD preživljavao na takvim modelima, gdje se gledala svaka kuna, a evo sada se intel sverca na desktop tržištu gdje u cijelom lineupu samo nekoliko modela ima kakve-takve preporuke i to ovisno o kombinaciji i potrebama..
MojSkuter
Zadnje izmijenjeno od: Eladio. 26.09.2019. u 02:29.
Staro 26.09.2019., 09:20   #6954
lobo64
lobo64's Avatar
Postovi: 1,346
Pričekajmo cijenu 3500x. Ukoliko u startu bude jednak ili jeftiniji od 9400f, bit će def. bolji izbor od Intela bez obzira na to što će 9400f možda biti brži u nekim igrama. A tu je i 3500 (ako se pojavi) koji će sigurno biti još jeftiniji.
Izgleda da Amd sjedi na hrpi otpadnih 6c12t silikona pa će još malo zagorčati život Intelu u tom segmentu, što se meni kao korisniku jako sviđa.
@Mladenxy
Što se tiče prodaje rabljenih za par godina, moglo bi se dogoditi isto što i sa c2d(xeon); postojat će hrpa procova na tržištu za koje neće biti matičnih ploča ili će rabljene biti duplo skuplje od procova.
Staro 26.09.2019., 09:57   #6955
Manuel Calavera
Postovi: 14,584
Autor lobo64 Pregled postova
Pa uvijek je tako s intelom. Ne samo c2d, nego i od xeona novijih arhitektura, HEDT, 1150 socketa i nadalje. Procesora ko pljeve sa dobrim cijenama, a mbo nigdje... Zato je AM4 platforma veliki plus, ne samo dugotrajnost, nego i nadogradivost na jače cpu
Staro 26.09.2019., 10:39   #6956
sti
Lokacija: Lawl
Postovi: 1,379
https://www.guru3d.com/news-story/65...hz-coming.html
Stiže i 3900, vjerojatno škart koji je ostao nakon binnanja 3900X.
Staro 26.09.2019., 14:59   #6957
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
Rumor : AMD Zen 3 Architecture to Support up to 4 Threads Per Core With SMT4 Feature
https://wccftech.com/rumor-amd-zen-3...-smt4-feature/
Nadam se da će ovo bit i za nadolazeći Ryzen 3, a ne samo za Epyc Milan i 4.gen TR.., bilo bi nice vidjet 6C/24T za desktop..))
Staro 27.09.2019., 09:37   #6958
Postovi: 8,421
AMD server market share expected to break 10% in 2020
AMD's second-generation EPYC server processors have landed significant orders from major IT players such as Dell, IBM and Nokia recently, with the chip vendor standing a good chance of gaining more than 10% of the server market by the end of 2020. So far, AMD has obtained an over 5% share of the server market. AMD's second-generation EPYC 7002 series processors, manufactured using Taiwan Semiconductor Manufacturing Company's (TSMC) 7nm process, are priced only between US$500-6.950, making them much price-friendlier than their same-grade counterparts from Intel and scoring them orders from several major IT players. AMD has recently announced that Dell's five new EMC PowerEdge systems are powered by AMD's second-generation EPYC CPUs, while France-based Atos has announced Genci is using the CPUs to expand the use of supercomputing for the benefit of French scientific communities. AMD is also cooperating with IBM and Nokia for their solutions featuring the EPYC processors. AMD has also announced a new member, the EPYC 7H12 processor that features 64 cores, 128 threads and 2.6GHz of clock speed, to its second-generation EPYC series family.
Izvor: DigiTimes
Staro 01.10.2019., 14:58   #6959
Old.machine
Old.machine's Avatar
Datum registracije: Feb 2016
Lokacija: ______
Postovi: 1,457
AMD "Raise the Game" Bundle Makes a Comeback
AMD's flagship Ryzen 9 series and Ryzen 7 3800X includes both games - "The Outer Worlds" and "Borderlands 3," - and the 3-month Xbox Game Pass. The Ryzen 7 3700X, 3600X, 2700X, and 2700 include one of the two games - "The Outer Worlds" or "Borderlands 3," and the 3-month Xbox Game Pass. The Ryzen 5 3600, 3400G, and Ryzen 5 2000-series include just the 3-month Xbox Game Pass. Over in the GPU front, buyers of Radeon RX 5700-series, RX 590, RX 580, and RX 570, get to choose one of the two games - Tom Clancy's "Ghost Recon: Breakpoint" or "Borderlands 3," and also receive the 3-month Xbox Game Pass. The Radeon VII, Radeon RX Vega series, and Radeon RX 560 stocks include 3-month Xbox Game Pass. You also get to choose either of the two games when you buy a qualifying pre-built desktop or notebook powered by AMD Ryzen or Radeon products.
https://www.amdrewards.com/terms
Old.machine je offline   Reply With Quote
Staro 05.10.2019., 20:37   #6960
Manuel Calavera
Postovi: 14,584
