Staro 28.05.2019., 12:54   #3691
dani77
dani77's Avatar
Lokacija: Val
Postovi: 306
Trebao bih preporuku za bateriju za Lenovo ThinkPad R61i. Frend ga koristi za autodijagnostiku i baterija na njemu je otišla. Odgovara li baterija sa drugih modela?
Da li je ovo čemu:
https://tinyurl.com/y5j5hp6s
Hvala unaprijed
"You know, you come from nothing - you're going back to nothing. What have you lost? Nothing!"
dani77 je offline   Reply With Quote
Staro 28.05.2019., 13:27   #3692
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Provjeri o kojem se modelu R61i radi - bilo ih je 14" 16:10 i 4:3, 15" 4:3 i 15.4" 16:10. Baterije oblikom nisu iste.
Najbolje je da frend skine bateriju koja je krepucnula i prepiše "FRU" oznaku s nje.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 02.06.2019., 13:05   #3693
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
Staro 03.06.2019., 10:00   #3694
Dottore
Dottore's Avatar
Postovi: 7,735
Mrzin numeričke tipke. Zbog većeg prostora iskoristili za hlađenje.
Отправлено через Pixel 2 XL
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 13.06.2019., 13:08   #3695
thubanx6
thubanx6's Avatar
Datum registracije: Aug 2011
Postovi: 533
Kupio bi jedan polovni T480 ako netko ima nešto u prodaji...
Također me zanima da li je netko imao prilike isprobati hp Elitebook 830 G5?
Iako znam da se trackpoint koji dosta koristim, ne može uspoređivati s thinkpadima i da nema srednji klik za scrollanje,
činjenica je da je HP uspio u 1.3kg ugurati 2 slota za ram, x4 PCI slot za nvme disk i odlične zvučnike.
Dok lenovo sad nudi opciju T480 koji je na 1.63kg a PCI slot je X2, zvučnici su loši ali su zato tipkovnica i trackpoint vrhunski.
Ili T490 koji su radi 150g iskasapili. Zalemljen ram mi je potpuni dealbreaker....
Također ako nekoga zanima X230 ili P50 nek se javi. Nešto od to dvoje bi sad zamijenio s T480 pa uzeo P1 gen 2 ili gen 3 za koju godinu.
thubanx6 je offline   Reply With Quote
Staro 13.06.2019., 15:20   #3696
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Ja sam gledao potencijalno uzeti T495 sa AMDom, ali na lenovu imaju 3 modela, na svima pise 8Gb (onboard) RAM. Stvarno ne znam zasto to rade, napokon AMD izbaci nesto da valja, a oni jedinu seriju laptopa koja valja, tako osakate... meh.
Staro 13.06.2019., 15:25   #3697
thubanx6
thubanx6's Avatar
Postovi: 533
Autor GoGzS Pregled postova
Ja sam odmah odustao kad sam to vidio. T serija ove godine nema ni jedan model bez određene količine zalemljenog rama.
Meanwhile, HP u 1.33kg (13.3) elitebook stavlja 2 slota bez ikakve gužve unutra.
Nije mi jasno šta izvode... bar je P1 (x1 extreme) gen 2 i gen 1 zakon. Samo da riješe hlađenje još malo bolje...
T seriju više ne gledam ako nastave ovako. Osim nezamjenjivog trackpointa HP ih elitebookovima polako prestiže sa svim čini mi se.
T seriju bar... u zbookovima još uvijek imaju odvratne tipkovnice ako mi se dobro čini.
I dosta me zanima što će biti kada Zen 2 (7nm) dođe na mobilnu platformu. Ali to je tek iduće godine čini mi se.
Zadnje izmijenjeno od: thubanx6. 13.06.2019. u 15:33.
Staro 13.06.2019., 15:33   #3698
GoGzS
GoGzS's Avatar
Postovi: 979
Da, ja cu isto sacekati za sad Zen2 na mobilnoj platformi, a onda ce isto vjerovatno HP. Vec sam ga imao jednom prilikom, pa mi je falio srednji gumb za scroll, ali whatever, naviknut cu se
Staro 13.06.2019., 15:52   #3699
thubanx6
thubanx6's Avatar
Postovi: 533
Ja sam imao i zbook i 3-4 elitebooka.
Glavni problem je što su na nekim modelima tipkovnice bile grozne međutim od g3 revizije su se značajno popravili tako da mi je to sad okej. Ovi G5 izgledaju stvarno dobro a ima ih po njuškalu za odličnu lovu.
I dobije se X4 NVME slot tako da SSD leti kako spada.
Jedino što srednji scroll button ne mogu prežalit...
I kažu da su im nova aluminijska kučišta vrhunska ali me brine kakav će mi bit na terenu ako nisam pretjerano pažljiv. Thinkpad to podnese ko Jeep... ogrebotone mu izgledaju kao patina
Dell u drugu ruku teško da će dobiti još jednu priliku od mene. Lattitude e6540 i 7440, katastrofalni problemi s bugovima u driverima i biosu... ogromne DPC latencije itd... komad smeća po tom pitanju. Hardverski kvaliteta izrade im je bila dobra doduše. Bar ovim modelima koje sam ja imao.
Precision modele nisam probao a za XPS znam da je smeće.
Staro 13.06.2019., 17:57   #3700
Dottore
Dottore's Avatar
Postovi: 7,735
Nije HP ni Dell tema. Molim vas.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 13.06.2019., 18:00   #3701
thubanx6
thubanx6's Avatar
Postovi: 533
Autor Dottore Pregled postova
Uspoređivanje thinkpada s drugim strojem je još uvijek rasprava o thinkpadu... ono što konkurencija nudi direktno utječe na vrijednost i isplativost laptopa.
Staro 14.06.2019., 06:39   #3702
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,591
Firma u kojoj radim je otkantala Lenovo na globalnoj razini (cca 10.000 zaposlenih) , poceli su previse sranja radit (pricamo naravno samo o T,W i X serijama). Kolega je 2 puta mijenjao ekran na svom T570, na mom su 2 stuck pixela (od manjih problema). Zamjena? HP Elitebook. S druge strane sa T540 sam mnogo zadovoljan.
Staro 14.06.2019., 15:34   #3703
thubanx6
thubanx6's Avatar
Postovi: 533
Upravo mi preuzima kolega jedan 830 g5 u zagrebu pa mi ga šalje za koji dan... naletio na strava cijenu.
T serija je došla na kvalitetu izrade E i L serije nažalost. U doba T430 je to bilo drastično drugačije.
Srećom P serija je stvarno još uvijek vrhunac user experiencea na bilo kakavom laptopu po meni...
Staro 15.06.2019., 01:32   #3704
orson
Postovi: 129
Svaka serija može imati nedostatke koje nekome smetaju a nekome ne, ali tvrditi da su T, E i L serije iste kvalitete, svašta. Činjenica je da je na T seriji zadnje generacije previše toga zalemljeno te su razlike između modela jako male pa je izbor zapravo sužen. Prije se točno znalo kome je namijenjena X serija, kome X1 Carbon, kome obična T serija, a kome Ts. U sljedećoj će generaciji sigurno doći do velike reorganizacije.
orson je offline   Reply With Quote
Staro 15.06.2019., 12:01   #3705
thubanx6
thubanx6's Avatar
Postovi: 533
Autor orson Pregled postova
U doba T430 je T serija po razini kvalitete izrade bila u plafonu... vrhunski strojevi.
Trenutno, P serija i X1 carbon se ističu po kvaliteti izrade a T i E seriju se osim po osvjetljenju tipkovnice i garanciji jedva da razlikovat.
Ne zato što je E serija strašno dobro napravljena nego je T serija pala u kvaliteti izrade... sad još ovo s micanjem sistema sa dvostrukom baterijom i lemljenjem pola rama... Izdržljivo kučište i trackpoint im polako ostaju jedini aduti ako nastave ovim putem
Staro 15.06.2019., 15:09   #3706
orson
Postovi: 129
Radio sam do nedavno na X230, sada na T480s, kvaliteta izrade na oba je odlična. Kolega ima T470, nema zamjerki. Imamo u firmi i E i L thinkpade, govoriti da je to ista/slična kvaliteta je .
Staro 15.06.2019., 17:54   #3707
Doom
Émile Flournoy
Doom's Avatar
Lokacija: Chicharija
Postovi: 1,538
Ima netko cooler ( može i bez venta ) za S1 Yogu 12 ?
Modeli koji bi trebali odgovarati su: 00HT721 00HT722 00HT723
Kod mene je lap došao raskopan, sa razmonitiranim coolerom.
Izgleda da ga je netko rastavio za očistiti od prašine i nikad sastavio, a cooler u međuvremenu nagazio klompom.
Ugl heatpipe je na dva mjesta gadno nagnječen. Lagano sam ispravio koliko ide, sve sastavio nazad i na kratko testirao.
Unutra je i7-5500u:
U idleu je na 50-ak °C i vent ugašen.
Lagani load digne na 70 °C
Par minuta 4k youtube demoa i eto ga na 94 °C
ID:	21247   Click image for larger version
Zadnje izmijenjeno od: Doom. 15.06.2019. u 18:42.
Staro 15.06.2019., 18:35   #3708
Dottore
Dottore's Avatar
Postovi: 7,735
To je oštećeno. Normalno će biti veća temperatura jer je savinut
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 15.06.2019., 18:45   #3709
Doom
Émile Flournoy
Doom's Avatar
Postovi: 1,538
Da, ovaj je za otpis pa lokalno tražim takav za zamjenu. Da ne čekam sa eBaya...
Sada vidim da sam zadnji dio gornjeg posta napisao nejasno pa ide edit.
Staro 22.06.2019., 18:30   #3710
Router
Hejter
Postovi: 6,521
Koristi li netko T580 malo duze?
Imam ponudu za ok cijenu,tvornicki obnovljeni modeli,valjda pokvareni u jamstvenom roku pa vraćani na slaganje.
EDIT : Za 4500kn nisam mogao fulati , i7 sa 512gb ssd , neka ga na stolu
Zadnje izmijenjeno od: Router. 23.06.2019. u 13:38.
Staro 24.06.2019., 14:37   #3711
Danzig
Datum registracije: Nov 2017
Postovi: 1
Poštovani, kupujem laptop za studij, dvoumim se izmedju t450s i t440p, točnije:
t450s // 1800KN
Procesor: Intel Core i5-5300U 1.9 GHz
Ekran: 14" LED HD+ Anti-Glare (1600x900)
Memorija: 4GB 1600MHz DDR3L
Hard disk: 180 GB ssd + M.2 SSD slot
Graficka karta: Intel® HD Graphics 4400
ili
T440p // 1700KN
14.0" Full HD (1920 x 1080)
Intel® Core™ i5-4200M (Up to 3.10 GHz, 3MB)
Intel® HD Graphics 4600
RAM:8GB DDR3L @ 1600MHz (2 x 4GB)
Disk Drive: SSD Patriot Burst 120 GB
OS: Windows 10 Pro (x64)
Ramovi mi nisu bitni jer imam još jedan keks od 4gb DDR3L, primarno me zanima razlika između rezolucije između ova dva, koliko je razlika oku vidljiva?, te jeli bolje ići na na neki sa IPS panelom zbog dužeg gledanja u display?
Danzig je offline   Reply With Quote
Staro 24.06.2019., 15:33   #3712
Dottore
Dottore's Avatar
Postovi: 7,735
Dao bi glas za T440p zbog snažnog procesora. Još može nadograditi storage na dva mjesta (mali m.2 slot i DVD caddy)
T450s ima štedljiv procesor i time bi baterija duže trajala. Mala rezolucija i još ograničen prostor. Pod time nisam još susretao takav model, tj. vidio kako izgledaju
Nigdje ne vidim u opisu IPS. Što se toga tiče, ja nemam IPS i niti zamara oči.
Отправлено через SM-G975F
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 27.06.2019., 00:06   #3713
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 2,129
Autor Danzig Pregled postova
t450s // 1800KN
ili
T440p // 1700KN
T440p, ima normalan mobilni procesor... Ovaj i5-5300U je sporudin zesci, imao sam to u Yogi 900, nije to za koristit bas...
Nego, gdje si nasao po tim cijenama? Te cijene mi se cine jako jako niske, u kakvom je to stanju?
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4-2666
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 27.06.2019., 04:03   #3714
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,068
Pa nije stvar u zamoru očiju nego u prikazu boja i kutu pod kojim možeš gledati monitor a da još uvijek vidiš više manje sve elemente onoga što gledaš
Staro 27.06.2019., 08:32   #3715
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,138
Autor calypso Pregled postova
Zadnjih nekoliko dana gledam cijene tih starijih Thinkpada i vidim da su kod nas dosta više nego npr. na eBay-u. T440p ide za kojih 1500kn pa nadalje na njemačkom eBay-u, dok T450 je ipak mrvu skuplji.
Zato više nit ne gledam naše cijene nego gledam da naručim neki izvana
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 27.06.2019., 11:13   #3716
orson
Postovi: 129
Istina, stare krame su kod nas po oglasima preskupe, ali tko ima cash može naći jako povoljnih ponuda za skroz nove, pogotovo skuplje modele, samo treba redovito pratiti i brzo reagirati.
Staro 30.06.2019., 18:11   #3717
chillout23
Your God is in your mind.
chillout23's Avatar
Datum registracije: Jun 2017
Lokacija: Planet Earth
Postovi: 642
Bok
Jel idu u t540p 2 SSD diska? Ne m2, nego baš SSD...uz sistemski da se tutne još jedan u ladicu ili negdje drugdje?
Mjesto rođenja: Zemlja, Rasa: čovjek, Politika: sloboda, Religija: ljubav
chillout23 je offline   Reply With Quote
Staro 30.06.2019., 19:59   #3718
bertone
bertone's Avatar
Postovi: 2,068
Autor chillout23 Pregled postova
Bok
Idu, dapače imaš za kupiti baš ladicu za T440p/540p/W540p/541 seriju pa ti u kompletu dolazi sa limićem kroz koji prolazi šaraf za učvršćivanje ladice i prednjim maskom koja prati liniju/kosinu bočne stranice laptopa... jedina mana je što koliko sam vidio sve imaju plavu ledicu indikatora (zelena bi bila primjerenija )... evo jedan link da znaš što da tražiš.
Zadnje izmijenjeno od: bertone. 30.06.2019. u 20:06.
Staro 30.06.2019., 22:50   #3719
chillout23
chillout23's Avatar
Postovi: 642
Hvala ti na odgovoru. Ladica za T420 osto mi ima plavi led hahaha
Btw..na mobu ne vidim link...budem sutra na lapu...jedino ak nisi zaboravil stavit
EDIT: evo me na lapu i sad vidim link thx btw...našo doslovno duplo jeftiniju ladicu
Zadnje izmijenjeno od: chillout23. 30.06.2019. u 23:31.
Staro 01.07.2019., 00:30   #3720
bertone
bertone's Avatar
Postovi: 2,068
Ma normalno da ima i jeftinije od one čiji sam link stavio no njega sam odabrao jer se lijepo na slikama vidi bezel ladice ... mislim da sam i ja svoju platio negdje oko 7-8$ i radi bez problema već 2-3 godine.
