Staro 12.06.2019., 17:56   #151
Mladenxy
Mladenxy's Avatar
Postovi: 4,473
Da su se te cijene od Škota te kartice bi bile čisti hit, po većim cijenama nebum ih ni pogledao.
Staro 12.06.2019., 17:56   #152
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Thnks Blue Spirt..
Ako je softversko rješenje, onda čemu ograničavanje samo na Navi ..? Tko će ga znati, vrijeme će pokazati
MojSkuter
Staro 12.06.2019., 18:21   #153
nickross
Budget gamer
Datum registracije: Nov 2017
Postovi: 909
Šta nije pisalo na slajdu da je to za sve gcn grafe?
nickross je offline   Reply With Quote
Staro 12.06.2019., 19:50   #154
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,211
Da.
Compatible with: AMD Radeon. GCN-based discrete graphics and newer. Supports Windows 7 and 10. DX 9 and DX 11 APIs.
* See endnote RS-295
/connect 185.107.96.125:28990
server rcon: oldschool
Staro 12.06.2019., 19:52   #155
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Znači dobit ću još jedan novi feature za 7 god. staru karticu?
Staro 12.06.2019., 19:57   #156
Blue Spirit
Postovi: 2,211
Vjerovatno da .
Nvidia says it has offered anti-lag settings like AMD’s for “more than a decade”
https://www.pcgamesn.com/nvidia/nvid...on-alternative
That’s the setting ‘maximum pre-rendered frames’ in the GeForce control panel, which controls the size of the Flip Queue.
The higher the number here, the higher the lag between your input and the displayed frame, while lower queue lengths result in less lag but increased strain on your CPU.
Too much either way and you could be looking at a stuttering mess.
Staro 12.06.2019., 20:51   #157
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,463
ma cek, nedavno sam procito da je taj flip queue postojao nekad u radeon/catalyst driverima i onda da su to iz nekog razloga makli. ko je tu lud.
Staro 12.06.2019., 23:10   #158
Manuel Calavera
Postovi: 14,589
Staro 12.06.2019., 23:50   #159
d0X
Kostolomac
d0X's Avatar
Postovi: 1,562
Nisam siguran, ali znam da se moglo namještati u RadeonPRO-u.
Staro 13.06.2019., 00:06   #160
DragonSlayer
DragonSlayer's Avatar
Datum registracije: Nov 2012
Postovi: 724
gleda san malo bia što se tiče cijene, i razlog za ove cijene je očit - 7nm je oko 50% skuplji nego 12/14nm po mm^2, yieldovi su niži, i razlog zašto je ryzen iako dere guzove jeftin a navi baš i ne je zbog monolithic dizajna.
Zen2 chiplet je oko 75mm^2, a na takvu veličinu imaju 70-ak % yield.
anyhoo, s obzirom da je navi 250mm^2, a TU106 (2070 i 2060) su po 445mm^2, bit će nešto iznad 5700 XT, samo bog zna kad. ako u to uračunamo ovaj gore yield sa manjim dimenzijama... za nekih 38 godina se čini otprilike točno.
pitanje, u slučaju da pokušaju grafe napravit chiplet based, kakvih problema bi bilo sa latencijom? nez jel se točno sjećan ali afaik prvi ryzen je imao latency issue neki koji ih je taslačio neko vrijeme.
anyhoo, iskreno, nije ovo toliko loše. vidit ćemo još benchmarkove i OCanje kad izađu. nije ni cifra previše loša, bu oko 3500-3600 ovdje?
https://forum.pcekspert.com/faq.php
DragonSlayer je offline   Reply With Quote
Staro 13.06.2019., 00:46   #161
Manuel Calavera
Postovi: 14,589
za 5700 - od 3200kn (best case scenario) i nadalje...
za 5700 XT - 3800kn (bcs) i nadalje...
RTX 2060 je već sad jeftinija, a s 2070 bude tu negdje...
Staro 13.06.2019., 03:05   #162
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,281
Vjerovatno da .
Na kraju super jer sad sigurno neću kupiti navi, nego je dovoljno da uzmem neki polaris.. ilii još ispada da to radi i na nvidia karticama.. lol
Novo a nista novo , koji smijeh ..ipak još ću pratiti, jer ovo je funkcija koja mi dobro dodje
MojSkuter
Staro 13.06.2019., 11:36   #163
Blue Spirit
Postovi: 2,211
http://www.pcekspert.com/clanak/amd-...-angeles/?pg=2
Nova tehnologija je Anti Lag, koja donosi 31% smanjenje kašnjenja grafičke kartice prema monitoru (mjerenje vidljivo na prvoj fotografiji).
Smanjenje kašnjenja znatno povećava iskustvo igranja eSports naslova jer se postiže se efekt povećanja FPS-a.
Tehnologija radi tako da mjeri i usporava CPU da ne ode previše ispred GPU-a, a efekt smanjenja kašenjenja je takav da s ovom funkcijom uključenom igrač odlazi jedan frame naprijed u odnosu na druge.
Ujedno, što je sistem više GPU limitiran, veći su benefiti, a to se povećava i s uključenim FreeSyncom. Tehnologija za sada ne podržava Vulkan i DX12 API-e, nego samo DX11 i DX9, i nije uključena po defaultu u sučelju drivera.
To me podsjetilo na program Timer Resolution koji neki koriste da poboljšaju FPS u igrama.
Nakon izlaska iz igre tj na desktop ga vracaju na Default.
https://timerresolution.soft112.com/
Timer Resolution Fixed FPS Drops
https://www.reddit.com/r/GlobalOffen...xed_fps_drops/
I don't know why but after looking at multiple optimization guides for CS to tackle my annoying performance issues I found one thing that has really helped.
When using a program called Timer Resolution, my fps drops almost vanish and give me a 30% increase in fps.
Zadnje izmijenjeno od: Blue Spirit. 13.06.2019. u 12:00.
Staro 14.06.2019., 18:26   #164
Manuel Calavera
Postovi: 14,589
Zadnje izmijenjeno od: Manuel Calavera. 14.06.2019. u 18:48.
Staro 14.06.2019., 19:20   #165
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,525
Cijena je fail i nista drugo high end full Navi dolazi kasnije jel bar je tako prica bila.
A znalo se sve i prije izlaska da je za mid range jedino se te cijene nisu znale.
Ko ima vrimena gledat te likove
Staro 14.06.2019., 19:30   #166
Full Throttle
Full Throttle's Avatar
Datum registracije: Dec 2009
Lokacija: Zagorje
Postovi: 873
Pogledal sam samo ovog zadnjeg.
Je, priča istinu, al opet je to na kraju samo bitching and moaning.
Cijene idu u zrak zbog potražnje (Nešto malo i zbog inflacije, al uglavnom zbog potražnje).
Gamerska generacija je odrasla, zaposlila se i nije ih strah potrošiti mjesečnu plaću na komad hardvera. I to je cijela priča.
A korporacije ko korporacije istražuju granice svojeg proizvoda.
Nitko ne štanca proizvod koji se ne prodaje.
Kad sam dobil prvi pc tam negdi 2000-e, već onda mi je štekal quake 2 na 800x600 rezi.
Tak da bil bi sretan kad bi neke top igre uopće pokrenul, a kamoli da igram na 60fpsa.
A danas sa svojom starom gtx 960, kladim se da bi bez problema pokrenul na low i na 1080p i neke novije igre.
Ak mi se baš sviđa igra, stavil bi makar na 720p rezu ak drugačije nebi išlo.
Tak da treba prestati srat i početi od sebe ko potrošača.
Ak je nekome preskupa komponenta, netreba je kupiti.
Još nisam čuo da se umire od nedostatka 60 fpsa
Full Throttle je offline   Reply With Quote
Staro 14.06.2019., 20:17   #167
Postovi: 8,555
Staro 14.06.2019., 20:18   #168
sti
Lokacija: Lawl
Postovi: 1,380
Jebiga dečki, učili su od konkurencije Sad je prilika, 7nm die je malen i jeftin za proizvesti, yieldovi su dobri, vrijeme je za uzeti lovu
Staro 14.06.2019., 20:31   #169
Alfa_R
Alfa_R's Avatar
Postovi: 2,927
Autor Full Throttle Pregled postova
Ja umirem.
Ne igram ako nije (skoro) svi detalji i minimum 60. Rade igra ceka par g kao što je i GTA I Witcher 3 cekao.....
Staro 14.06.2019., 20:48   #170
Mladenxy
Mladenxy's Avatar
Postovi: 4,473
Autor sti Pregled postova
Veli Škot da je skuplji za proizvesti od polarisa, ali da, uče od Nvidije i propuštaju priliku...u stvari nije ih ni briga previše. Na konzolama imaju zagarantirano stotinjak miliona prodanih chipova, i to samo na jednoj konzoli.
Ovo tko kupi dobro, tko ne opet dobro.
Staro 14.06.2019., 20:50   #171
Manuel Calavera
Postovi: 14,589
@sti
Prema AMD-ovom slajdu 7nm je duplo skuplji od 14/16nm... Naravno čak ni to ne opravdava ovoliku cijenu gpu (slajd na adoredovom zadnjem videu 27 min)
Ja sam očekivao da će Navi biti zadnja iteracija GCN-a, pa da će na temelju Ryzen moneya 2021 napraviti nešto osjetno bolje, tako da mome iznenađenju nije bilo kraja kad je Lisa rekla da će RDNA furati sljedećih 10 godina... Gotovi su...
Kao što sam ranije napisao razlog čekanja "big navi" je čekanja 7nm+ nodea, da barem nekako uguraju 60CU u 300w, mooožda 64CU. Jebena katastrofa
Uglavnom ona dvojica što sam ranije linkao + Adored su jednoglasni u tome da je Radeon jednostavno odlučio oguliti maksimalno svoju stalnu fanbase od 20-ak % ... Undercuttanje im se u prošlosti nije isplatilo, pa su odlučili guliti... Kao što onaj Irac što sam linkao reče - propustili su veliku priliku, jer Nvidija nikad nije bila omraženija, gro ljudi je bilo spremno prijeći na AMD. Na jednako vrijedne ili skuplje radeonke sigurno neće
Staro 14.06.2019., 20:52   #172
Mladenxy
Mladenxy's Avatar
Postovi: 4,473
Nisu gotovi nego su napravili nekaj za nove konzole a to im je posao od 6-7 godina. Na PC gaming platformi su u GPU segmentu bili zadovoljni sa pozitivnom nulom.
Staro 14.06.2019., 20:58   #173
Manuel Calavera
Postovi: 14,589
Gotovi su u tehnološkom smislu na gpu polju i nema im povratka... Oni sa naprednijim nodeom ne mogu konkurirati nvidiji u high endu na last gen nodeu, te su pri tom još manje efikasni na tom istom naprednijem nodeu i NOVOJ arhitekturi koju misle gurati 10 godina... Poraženi su do koljena na gpu polju i s tim su se pomirili.
Staro 14.06.2019., 21:00   #174
Mladenxy
Mladenxy's Avatar
Postovi: 4,473
Kao što rekoh nije ih više ni briga, ovo tko kupi dobro, tko ne opet dobro. Ne ovise više o našem gamesrkom pc gpu tržištu. Imaju osiguran posao za 6-7 i više godina....na obje konzole to je barem 150 miliona chipova...jednostavno ih nije briga da bi riskirali.
Za 6-7 godina, tko zna kakvo bu tržište....
Staro 14.06.2019., 21:03   #175
gil
Member
Lokacija: Kutina
Postovi: 979
Manuel, zar misliš da će desktop u narednih 10 godina opstati? Mislim da nema šanse. Sve ode na mobilnost.
Plus sve u oblaku, tu im je google pružio ruku.
gil je offline   Reply With Quote
Staro 14.06.2019., 21:06   #176
High_End
Datum registracije: May 2019
Postovi: 100
Pa manji je proces pa je manji trosak proizvodnje, logicno ne
Stvarno se moze poklopiti usima a ide nekoga prozivati za znanje :facepalm:
Inace, ja sam bas bio uvjeren da ce AMD propasti sa proizvodnjom CPU-a, a sa grafama drzati bitku, kad ono bas kontra
Mada prodali su oni vagone i vagone Polarisa, narocito tokom mining ludila
High_End je offline   Reply With Quote
Staro 14.06.2019., 21:11   #177
Manuel Calavera
Postovi: 14,589
To stoji. Ovo što ogule fanbase na desktopu dobro im dođe i to je to. U biti se slažemo, nisu gotovi u poslovnom (financijskom) smislu, nego tehnolološkom...
Autor gil Pregled postova
Ma hoće, što ti je. Gpu su sve skuplje i skuplje, a prodaja high enda je sve veća i veća...
Doduše AMD se mudro udružio sa samsungom i ući će na mobilno tržiše, malo prodaja u laptopima, kroz APU, malo desktop gpu i radeon instinct i opstat će gpu divizija. Pogotovo što će im zaleđinu držati nikad jača cpu divizija.
Dakle ne pričam ja o nikakvom financijskom propadanju, nego su banana s arhitekturom barem još desetljeće...
Staro 14.06.2019., 21:14   #178
Thundercool
Plebium
Thundercool's Avatar
Lokacija: Sisak
Postovi: 156
Naricali su propast desktopu zadnjih deset godina pa se nije dogodilo takvo nešto . Štoviše ljudi su samo nabavili još uređaja da bi još više bili "connected" ali ništa nemože zamjeniti desktop. Tu mogućnost unaprijeđivanja i dugotrajnost samih platfromi, da i ne počnem o performansama te omjeru uloženo/dobiveno. Uvijek sam gledao na mobilne uređaje kao nešto što je tu da ti pomogne u škripcu. Živi bili pa komentirali propast desktopa sa naših stolnih računala još deset godina.
Thundercool je offline   Reply With Quote
Staro 14.06.2019., 21:30   #179
gil
Member
Lokacija: Kutina
Postovi: 979
Ali ako zaživi gaming u oblaku, nema potrebe za jakim grafičkim karticama kod kućnih korisnika. Samo veliki streaming tv i periferija.
Staro 14.06.2019., 21:39   #180
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,390
Mislim da nas ima previše (u svijetu, ne u hr) sa presporom internet vezom za tako nešto. A i ja prvi nebi to nikad koristio. Hoću svoj komp da na njemu radim što hoću i da igram npr quake 2 xp, brutal doom i slično...
Slobodno me dodajte na PSN
Disco je online   Reply With Quote
