Staro 02.01.2006., 01:30   #1
Ziiky
Ziiky's Avatar
Postovi: 2,882
Java problem.........bluranje ekrana !!!
Pojavio mi se problem sa javom prilikom browsanja.
Kada god otvorim neku stranicu koja sadrzi javu ekran mi se zablura :confused: ....prvo sam mislio da je problem do flash plug-ina, ali sada sam 100% siguran da je do jave. To mi se desava u operi i firefoxu dok u IE ne.
Koristim zadnje verzije navedenih browsera i zadnju javu.
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 02.01.2006., 21:03   #2
Ziiky
Ziiky's Avatar
Postovi: 2,882
Rješeno....
MBO: MSI Mortal
RW: LG
MON: Acer 24"
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 03.01.2006., 09:40   #3
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,551
Originally posted by ziky
Rješeno....
Dobro da si podijelio sa nama rjesenje.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 16.11.2008., 20:55   #4
Traitorous_8
Traitorous_8's Avatar
Lokacija: Vž
Postovi: 81
Autor LAcy Pregled postova
A uistinu.... imam slican problem i mogao je napisat rjesenje
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore
Traitorous_8 je offline   Reply With Quote
