Staro 29.12.2005., 15:16   #1
pHero
Lokacija: Velika Gorica
Postovi: 59
tromi windozi
12/29/2005 2:52:15 PM pHero Marko ej
12/29/2005 2:52:17 PM pHero Marko si tu?
12/29/2005 2:52:26 PM Marko pHero jesam
12/29/2005 2:52:32 PM pHero Marko e onak
12/29/2005 2:52:55 PM Marko pHero ???
12/29/2005 2:53:02 PM pHero Marko windozi mi se sporo dižu....
12/29/2005 2:53:08 PM pHero Marko zašto?
12/29/2005 2:53:28 PM Marko pHero windowsi ili ti se cijeli komp sporo boota
12/29/2005 2:53:58 PM pHero Marko pa ono kad idu one 3 crtice na boot screenu, meni prolaze kojih 20 puta prije neg se starta
12/29/2005 2:54:33 PM pHero Marko to mi je od početka uvijek tak
12/29/2005 2:54:36 PM pHero Marko al ne bi trebalo bit
12/29/2005 2:54:42 PM pHero Marko a64 3200+
12/29/2005 2:54:48 PM Marko pHero samo windozi
12/29/2005 2:54:51 PM Marko pHero ili cijeli sistem
12/29/2005 2:54:55 PM Marko pHero od bootscreena
12/29/2005 2:54:57 PM Marko pHero pa nadalje
12/29/2005 2:55:17 PM pHero Marko windozi se brzo dižu
12/29/2005 2:55:24 PM pHero Marko samo na tom boot screnu
12/29/2005 2:55:31 PM Marko pHero ono kada ide loading
12/29/2005 2:55:34 PM pHero Marko da
12/29/2005 2:55:37 PM Marko pHero aha
12/29/2005 2:55:38 PM pHero Marko one 3 crtice
12/29/2005 2:55:38 PM Marko pHero hmm
12/29/2005 2:55:42 PM Marko pHero koji windozi
12/29/2005 2:55:45 PM Marko pHero xp pro
12/29/2005 2:55:48 PM pHero Marko da sp2
12/29/2005 2:55:51 PM Marko pHero obicni ili 64 bit?
12/29/2005 2:56:04 PM pHero Marko obični
12/29/2005 3:00:28 PM Marko pHero nei znao
12/29/2005 3:00:30 PM Marko pHero koliko rama imas
12/29/2005 3:00:34 PM Marko pHero i koliko particija na hardu
12/29/2005 3:00:40 PM Marko pHero i koliko hardova
12/29/2005 3:00:46 PM Marko pHero i koji sata ili ata
12/29/2005 3:00:49 PM pHero Marko 1gb corsair value
12/29/2005 3:00:50 PM pHero Marko sata
12/29/2005 3:00:54 PM pHero Marko wd 250gb
12/29/2005 3:00:56 PM pHero Marko 3 particije
12/29/2005 3:01:05 PM Marko pHero ovako
12/29/2005 3:01:15 PM Marko pHero desni klik na my computer
12/29/2005 3:01:30 PM Marko pHero properties
12/29/2005 3:01:31 PM Marko pHero advanced
12/29/2005 3:01:38 PM Marko pHero virtual memory stettings
12/29/2005 3:01:39 PM Marko pHero settings
12/29/2005 3:01:50 PM Marko pHero advanced
12/29/2005 3:01:54 PM pHero Marko ej ej
12/29/2005 3:02:06 PM Marko pHero kaj kaj
12/29/2005 3:02:10 PM pHero Marko di je virtual memory settings?
12/29/2005 3:02:17 PM Marko pHero aha
12/29/2005 3:02:21 PM Marko pHero to ti je performance setting
12/29/2005 3:02:40 PM Marko pHero pa advanced
12/29/2005 3:02:41 PM pHero Marko ...
12/29/2005 3:02:49 PM Marko pHero pa pod virtual memory
12/29/2005 3:02:51 PM Marko pHero change
12/29/2005 3:02:59 PM Marko pHero makni sa C:
12/29/2005 3:03:12 PM Marko pHero i stavi 1024-1024 na neku drugu particiju
12/29/2005 3:03:15 PM Marko pHero tj,
12/29/2005 3:03:28 PM Marko pHero makni virtualnu memoriju sa particije gdje je windows
12/29/2005 3:03:41 PM pHero Marko aha
12/29/2005 3:03:43 PM pHero Marko ok
12/29/2005 3:03:50 PM Marko pHero to je step 1
12/29/2005 3:03:52 PM pHero Marko kaj da stavim no paging file?
12/29/2005 3:04:32 PM Marko pHero da
12/29/2005 3:04:39 PM Marko pHero i onda set
12/29/2005 3:04:39 PM pHero Marko dalje..
12/29/2005 3:04:52 PM Marko pHero pa odaberes jednu particiju koja ima najvise gb
12/29/2005 3:04:55 PM Marko pHero i stamo stavis
12/29/2005 3:04:58 PM Marko pHero 1024-1024
12/29/2005 3:05:00 PM Marko pHero custom
12/29/2005 3:05:04 PM Marko pHero pa set
12/29/2005 3:05:08 PM Marko pHero pa restart
12/29/2005 3:05:12 PM Marko pHero to je step 1
12/29/2005 3:05:30 PM pHero Marko ok
12/29/2005 3:05:52 PM pHero Marko ajd idem...
12/29/2005 3:05:57 PM pHero Marko to napravit
pHero says:
jesam....
pHero says:
opet 29 puta prolazi...
Marko says:
ok
Marko says:
to nije ni trebalo pomoci
pHero says:
fino:9
Marko says:
jel si instalirao drivere sve
Marko says:
kak se spada
pHero says:
valjda
Marko says:
to valjda znas
Marko says:
maticna
Marko says:
jooooooooj
Marko says:
cek
Marko says:
znam
Marko says:
i neznam
pHero says:
u device menađeru niš ne javlja
Marko says:
znam da ima veze da se nes treba iskljuciti
Marko says:
u biosu
Marko says:
a neznam kaj jer nemam sck 939
pHero says:
u biosu imam milju opcija...
Marko says:
odi na pce
pa sad....
keep it comin'
pHero je offline   Reply With Quote
Staro 29.12.2005., 15:21   #2
nino
nino's Avatar
Postovi: 12,613
Di si Marrrrrkkkkkooooooooooo?:clap:
Staro 30.12.2005., 13:45   #3
pHero
Postovi: 59
aj dosta spama....
instaliro sam onaj bootvis i optimiziro i opet ništa, 0% brže.....ništ od toga
di vidim, isključujem procese na bootu?
keep it comin'
Staro 30.12.2005., 13:47   #4
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
START/RUN/MSCONFIG i tamo na onoj zadnjoj kartici su ti procesi
Staro 30.12.2005., 13:49   #5
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
start,raun i upuiši msconfig pogasi sve nepotrebno
Isključi fast user switch, izbriši nepotrebne account,skeniraj sa antivirusom,spywareom...
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 30.12.2005., 14:07   #6
pHero
Postovi: 59
ovak... na startupu imam:
NVMixer tray
NvCpl
nwiz
NvMcTray
SOUNDMAN
zlclient
NeroCheck
jusched
DevDetect
KHALMNPR
MsnMsgr
Adobe reader speed launch
Logitech Setpoint
Microsoft Office
kaj tu ni dobro?
kaj da smaknem?
keep it comin'
Staro 30.12.2005., 14:13   #7
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
Makni ono kaj ne koristiš
ja ti mogu reć da ti netreba
NeroCheck
MsnMsgr
Microsoft Office
Također upiši fiksni IP ako koristiš mrežu da ne traže windowsi sami svaki put
Network connections/lan conection/propereties/internet protocol/propereties i upiši 192.168.000.1
Subnet mask 255.255.255.0
Staro 30.12.2005., 14:19   #8
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
nwiz
NvMcTray , imaš ga u mišu...
NeroCheck
jusched
DevDetect ,KHALMNPR - jel ko zna šta je ovo ??
MsnMsgr
Logitech Setpoint
Microsoft Office - ovo dvoje nisam siguran jer neznam način na koji ih ti koristiš
stuc je offline   Reply With Quote
Staro 30.12.2005., 14:26   #9
pHero
Postovi: 59
defragmentiro.....
ad-awareo, spyboto....
smakno sam nwiz, juscher, adobe..., nerocheck, nvmctray, msnmsgr....
i...
nula bodova, ista troma uber spora brzina bootanja...
keep it comin'
Staro 30.12.2005., 14:30   #10
nino
nino's Avatar
Postovi: 12,613
Pukni na viruse HiJackthis log pa ce Costa ili Atha prozborit sta da maknes i killash
Staro 30.12.2005., 14:32   #11
pHero
Postovi: 59
šta costa, atha?? reci na hrvatskom
keep it comin'
Staro 30.12.2005., 14:37   #12
nino
nino's Avatar
Postovi: 12,613
U svezi narečenog, postaj u podforum Virusi, log od programa Hijackthis, s kojim si prethodno izvršio provjeru na svom kompu, pa će taj log pregledati dva cijenjena ćlana PCE foruma, pod nickom Costa ili Atha, te će ti reć koje servise treba ugasiti, izbrisati, ubiti, masakrirati, kako god oni kazu, kapiši:confused:
Staro 30.12.2005., 21:13   #13
pHero
Postovi: 59
sve je ok...
ma komp je nov, nema virusa i inih gamadi....
a64 3200+ oc na 2.8ghz
2x512 corsair value
WD 250gb
7800gt
trebalo bi se brzo bootat....
brijem da tromost nije zbog procesa il takvih stvari....možda u biosu nešto??
bubajte bezveze kaj bi moglo bit, il drajveri - kak da provjerim ak neki driver koči??
keep it comin'
Staro 31.12.2005., 00:30   #14
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,537
Pa di si phero
Evo znam ja sto te muci, koliko sam shvatio tebe muci onaj dio kad se win jos ne podignu. Tako je meni isto bilo na jednoj abitici sa prelaskom na winxp.
Rjesenje je bilo rucno iskljuciti ATA diskove kojih nema, jer win uporno pri bootanju pokusavaju naci disk a njega nema.
To se nalazi u Device Manager-> IDE ATA/ATAPI controllers-> pa tamo ces vec naci parallel controler i samo tamo gdje nema diska stavi no device ili sto vec. Kod mene nvidida ni ne daje tu opciju.
Btw koji chipset imas, meni je to radio via chipset.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 02.01.2006., 09:36   #15
Cataphract
Cataphract's Avatar
Lokacija: Constantinopolis
Postovi: 1,002
DevDetect.exe is a process associated with Device Detect software from ACD Systems. It detects any digital imaging products that belongs to ACD Systems. This is a non-essential process. Disabling or enabling this is down to user preference.
KHALMNPR.exe is a proces installed alongside Logitech mice which allows for advanced configuration and diagnosts of their range of multimedia products. This program is non-essential process to the running of the system, but should not be terminated unless suspected to be causing problems..
Cataphract je offline   Reply With Quote
Staro 03.01.2006., 04:05   #16
stuc
stuc's Avatar
Lokacija: Online
Postovi: 2,404
Fala lipa , no sad ću bar 5 dana provest na toj stranici sa servisima jer sam vidio brdo zanimljivih savjeta
