Staro 04.03.2019., 19:13   #1
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Advoli TA6 Performance HDBaseT Video Card
Kao sto naslov kaze, HDBaseT graficka kartica.
Salje signal na 6 odvojenih monitora na preko 100m.
Sa stranice:
AMD Ultra High-Performance Embedded GPU
A modular HDBaseT™ graphics card that comes with AMD Embedded Ultra High-Performance E9550 MXM Module:
Polaris Architecture
36 Compute Units
5.8 TFLOPS.
8GB GDDR5
Memory; 256bit wide
<95W GPU Thermal Design
Support for 4K hardware-accelerated decode and encode (HEVC/H.265 and AVC/H.264)
Microsoft DirectX® 12, OpenGL 4.5, and OpenCL™ 2.0 capable
Support for up to 6 outputs
Designed to allow you to upgrade the AMD embedded module in the future without the need to purchase a whole new product from us.
http://www.advoli.com/ta6performance/
I jedan review o tome :
https://www.youtube.com/watch?v=Kk5TTjxHwGY
Mene zanima koja je realna primjena ovoga osim slanja slike na velike udaljenosti koristeci PoC ?
Staro 04.03.2019., 19:48   #2
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
PoH Video-zid
Staro 05.03.2019., 10:25   #3
Postovi: 8,235
Praktički svaka trgovina ili nešto tko vrti oglase na hrpi monitora, nešto kao cinestar što ima. Autobusni kolodvori, aerodrom i sl.
Fakat je moguće primjeniti na dosta mjesta, samo je pitanje da li će netko ići na tu soluciju ili će vrtiti nekakav NUC na svakoj telki pa mu pristupiti remote.
Staro 05.03.2019., 10:41   #4
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,138
Zašto bi netko kupovao takvu karticu kad ima all in one rješenje tipa BrightSign, a profesionalni displayi imaju daisy chain mogućnost s jednim inputom.
Android boxovi vrte 4k bez problema, a kad im se malo čovjek poigra sa softverom, dobiva pristojno digital signage rješenje za dosta nisku cijenu.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 09.03.2019., 18:00   #5
Psycho
Master Of Disaster
Psycho's Avatar
Datum registracije: Nov 2002
Postovi: 1,271
Po tebi su onda HDbaseT matrice nepotrene.. Samo nagruvas 16 android boxova.. Jer dig signage suustavi su jedini gdje vidis ovu primjenu?
Staro 31.07.2019., 14:11   #6
tskarda
tskarda's Avatar
Postovi: 1,128
HAH! volio bih vidjeti tko će prvi održavati android boxove, sa 16 komada koji rade 24/7 to je posla za 2 osobe puno radno vrijeme
