#4501 |
Datum registracije: Mar 2011
Postovi: 2,707
SSD ADATA 240GB SU650, ASU650SS-240GT-R, 2.5", SATA3, 36MJ CPU AMD Ryzen 5-1600X (3.6GHz do 4GHz, 19MB (3MB+16MB), C/T: 6/12, AM4, 95W), 36mj DDR4 16GB (2x8GB), DDR4 3000, CL16, DIMM 288-pin, G.Skill F4-3000C16D-16GISB, 36mj CPU COOLER ENERMAX ETS-N31-02, 1X FAN 92MM, AM4, S1151 MB ASRock B450 Gaming K4, AM4, ATX, 4x DDR4, AMD B450, S3 6x, DP, VGA, HDMI, 24mj (90-MXB8A0-A0UAYZ) HDD WD 1TB, Blue, (3.5", 64MB, 7200, SATA3), WD10EZEX Seasonic 520W M12II Bronze Evo SS-520GM2, ATX, 120mm, 80 plus Bronze, PCIe VGA 8p 2x, EPS, SATA 6x, Molex 5x, Modularno, 36mj VGA Inno3D GTX1070 iChill X3 V2, nVidia GeForce GTX 1070, 8GB, do 1771MHz, DP, DVI-D 2x, HDMI, 24mj (C107C3-3SDN-P5DSX) Monitor Acer 23.8", Nitro, RG240Ybmiix, 1920x1080, LCD LED, IPS, 1ms, 178/178o, VGA, HDMI 2x, Zvučnici, crna, Freesync, 24mj, (UM.QR0EE.009) Kućište Sharkoon M25-V, crna, ATX, 12mj (4044951019311) 8.563,99Kn |
#4502 | |
Postovi: 430
1 x Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) 1 x Maticna GIGABYTE B450M GAMING, 2xDDR4, S.AM4 2 x G.Skill Aegis 8GB DDR4 3000MhZ 1 x Inno3D Video Card GeForce GTX 1070 iChill X4 1 x SSD Adata 120GB SU650 SATA 3D Nand 1 x Toshiba P300 1TB, 64MB, 7200rpm 1 x Fortron napajanje Hexa 85+ 550W, 80+ Bronze 1 x Zalman S2 mid tower case 1 x Monitor Samsung LS24F350FHUX, PLS, FreeSync Ukupno: 8.754,00 Kn - 2% popusta = 8570kn, slaganje i dostava u cijeni. |
#4503 |
MiningMod
Postovi: 8,715
1 * Monitor Samsung LS24F350FHUX, PLS, FreeSync, 4ms 1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) 1 * Hladnjak Cooler ARCTIC COOLING Freezer 33 1 * MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX 1 * Kingston DDR4 HX Fury, 16GB (2x 8GB), 3200MHz 1 * SSD 256GB TS 110S M.2 2280 NVMe 1 * HDD TOSHIBA DT01ACA100 (3.5, 1TB, SATA III-600) 1 * XFX AMD Radeon RX 580 GTS Black Edition 8GB 256bit GDDR5, bulk + 2 Igre (The Division 2, Devil May Cry 5 ili Resident Evil 2) 1 * Fractal Edison M 650W, 80+ GOLD polu modularno 1 * Kućište Rampage Everest PRESTIGE s 4 plava ventilatora Ukupno: 8.422,00 Kn - 2% popust za članove = 8.250,00 kn ![]() |
#4504 |
Datum registracije: Sep 2015
Postovi: 5
Pozdrav, Kupujem računalo do 7.000,00kn ako može sve iz istog dućana i da je složeno. Već sam nešto složio pa me zanima jel se treba što promjeniti. Računalo je za igranje većinom. Kućiste netreba da svjetli previše. ryzen 5 + 1060 6gb bih želio. * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) * MSI X470 GAMING PRO, D4, U3.1, m2, AM4 * Inno3D GeForce GTX 1060 iChill X3 6GB GDDR5 192-bit HerculeZ X3 * G.Skill Aegis 8GB DDR4 3000MhZ * GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs, Retail * Zalman Z3 Midi-Tower ATX kućište, bez napajanja, crno * WESTERN DIGITAL WD10EZEX 1TB Blue * Hladnjak Cooler ARCTIC COOLING Freezer 33 * Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX To je zajedno malo manje od 7k. Hvala! |
#4505 |
Postovi: 430
Dobro je to složeno. |
#4506 |
Postovi: 2,707
Može se i bolje, samo 8GB RAMa u konfi od 7k? ![]() CPU AMD RYZEN 5-2600 (3.4GHZ DO 3.9GHZ, 19MB (3MB+16MB), C/T: 6/12, AM4, COOLER, 65W), 36MJ SSD ADATA 240GB SU650, ASU650SS-240GT-R, 2.5", SATA3, 36MJ SEASONIC 520W M12II BRONZE EVO SS-520GM2, ATX, 120MM, 80 PLUS BRONZE, PCIE VGA 8P 2X, EPS, SATA 6X, MOLEX 5X, MODULARNO, 36MJ KUĆIŠTE SHARKOON M25-V, CRNA, ATX, 12MJ (4044951019311) HDD WD 1TB, BLUE, (3.5", 64MB, 7200, SATA3), WD10EZEX VGA INNO3D GTX1070 ICHILL X3 V2, NVIDIA GEFORCE GTX 1070, 8GB, DO 1771MHZ, DP, DVI-D 2X, HDMI, 24MJ (C107C3-3SDN-P5DSX) MB ASROCK B450M PRO4, AM4, MICRO ATX, 4X DDR4, AMD B450, S3 4X, VGA, DVI-D, HDMI, 24MJ (90-MXB8F0-A0UAYZ) DDR4 8GB (2X4GB), DDR4 2400, CL15, DIMM 288-PIN, G.SKILL VALUE F4-2400C15D-8GNT, 36MJ 6.998,24KN Ili se može na RX 590, 16GB RAMa i bolju ploču. Zadnje izmijenjeno od: Smartic. 07.01.2019. u 11:55. |
#4507 |
Postovi: 430
Da, na prvu sam vidio da piše 2 x al to je zvjezdica. Uzmi obavezno još 8GB rama, a ako premašuje budžet smanji ploču na MSI B450 Tomahawk. |
#4509 |
Postovi: 5
Hvala na odgovoru. Možete samo staviti i tu konfiguraciju sa RX 590, 16GB RAMa i boljom pločom. |
#4510 |
Postovi: 430
1 x Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) 1 x MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX 1 x Kingston DDR4 HX Fury, 16GB (2x 8GB), 3200MHz 1 x XFX AMD Radeon RX 580 GTS Black Edition 8GB + 2 igre 1 x SSD 250.0 GB SAMSUNG 970 Evo NVMe M.2, MZ-V7E250BW 1 x Toshiba P300 1TB, 64MB, 7200rpm 1 x SAMA ARMOR 550W 80PLUS GOLD 1 x Chassis INTER-TECH C-3 SAPHIR Gaming Midi Tower Ukupno: 7.144,00 Kn -2% popusta = 7000kn, slaganje i dostava besplatni. |
#4511 |
Postovi: 45
#4513 |
Postovi: 23
pozdrav, molim desktop kombinaciju blize 6000kn i preporuku za neki od povoljnijih wide monitora (nije uključen u ovih 6k). ssd imam, makar je samo 120gb ne bih ga htio mjenjat jer mi je sve bitno za posao na njemu ali dolazi u obzir uzet još jedan u slučaju da se moze uklopit u ovu konfu i da nece usporavat rad jer su dva. jedna od namjena računala je vrtit nekoliko instanci emulatora od jednom s čime mi je prošla konfiguracija imala dosta problema i druge slicne multitasking zadaće, ne igram graficki prezahtjevne igre ali je zanimljivo da mi je na proslom kompu koji sam koristio za istu svrhu upravo grafa prva pregorila tak da bi i ona trebala vjerojatno bit donekle zadovoljavajuća. imam svu periferiju osim tipkovnice pa molim i neku relativno dobru tipkovnicu pokušat uklopit, po mogućnosti bezicnu ali u donjem rangu. imam i operativni sustav. hvala vam unaprijed ![]() |
#4514 |
MiningMod
Postovi: 8,715
Što točno misliš pod "wide" monitorom? Nešto tipa ovoga? https://www.lg.com/hr/monitori/lg-25...de-ips-monitor https://www.lg.com/hk_en/monitor/lg-29WK500 Konfa: 1 * AMD CPU Desktop Ryzen 7 8C/16T 1700 (3.7GHz,20MB,65W,AM4) box, with Wraith Spire 95W cooler Sifra: YD1700BBAEBOX - 1.630,00 Kn 1 * Gigabyte B450M DS3H AMD B450, AM4, 4xDDR4, DVI-D/HDMI, 2xPCIe x16, 1xPCIe x1, 1xM.2, 4xSATA, mATX Sifra: B450M_DS3H - 599,00 Kn 1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz Sifra: F4-3000C16D-16GISB - 1.000,00 Kn 1 * Gainward GF GTX1050Ti, 4GB GDDR5 Sifra: gai-1050ti-4g - 1.299,00 Kn 1 * Fortron napajanje Hexa 85+ 450W, 80+ Bronze, ATX Sifra: fsp-nap-hexa85-450 - 419,00 Kn 1 * Fortron CMT 110, 1x120mm, USB3.0, crno Sifra: fsp-cmt-110 - 299,00 Kn 1 * SSD SAMSUNG 860 QVO Basic, 1TB, MZ-76Q1T0BW, SATA 3, 2.5, 550/520 MB/s Sifra: 051.400.626- - 1.139,00 Kn Ukupno: 6.385,00 Kn -2% = 6.250,00 Kn |
#4515 |
Postovi: 2,707
Ovisi koje emulatore koristiš, ali za veliku većinu su bitne single-thread performanse, tako da ne bih baš stavio Ryzen 1700. Prije bih stavio 2600X, a možda i i5 8400. GSkill Aegis 16GB (2x8) DDR4 3000MHz AMD Ryzen 5 2600X - boxed Intel SSD 660p Series (1.0TB, M.2 80mm PCIe 3.0 x4, 3D2, QLC) Retail Box Single Pack Zalman S2 Midi-Tower ATX kućište, bez napajanja, crno be quiet! System Power 9 400W Gigabyte GA-AB350M-DS3H V2 (rev. 1.1) ZOTAC GeForce GTX 1060 3GB AMP! Edition 6.274kn s 3% popusta 25" ultrawide nikako, visina je premala. Zadnje izmijenjeno od: Smartic. 06.02.2019. u 22:33. |
#4516 |
Datum registracije: Feb 2019
Lokacija: Trogir
Postovi: 10
Pozdrav svima Trebao bi confu do 7k moze i minimalna odstupanja. Namjena gaming 1080p . Jedini zahtjev da je kuciste Thermaltake versa h17 s prozorom il nesto slicno ako nema navedene u webshopu. Hvala unaprijed |
#4517 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,635
1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) box, Wraith Stealth Sifra: YD2600BBAFBOX - 1.358,00 Kn 1 * Hladnjak LC-Power LC-CC-120, Intel/AMD + AM4 Sifra: lcp-hlad-lc-cc-120 - 180,00 Kn 1 * Matična GIGABYTE GA-AB350M-DS3H (S.AM4, 4xDDR4, RAID) mATX Sifra: GA-AB350M-DS3H - 509,00 Kn 1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz Sifra: F4-3000C16D-16GISB - 1.000,00 Kn 1 * Palit GF RTX2060 Gaming Pro OC, 6GB Sifra: pal-2060-gpr-6gb - 3.100,00 Kn 1 * GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs, Retail Sifra: GP-GSTFS31240GNTD - 289,00 Kn 1 * Tvrdi Disk Toshiba P300 1TB 3.5 Sifra: 0140635 - 349,00 Kn 1 * Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX Sifra: fsp-nap-hexa85-550 - 469,00 Kn 1 * Kućište Thermaltake Versa H17 s prozorom Sifra: 0151463 - 330,00 Kn Ukupno: 7.584,00 Kn (-2%=7.430kn) Besplatno slaganje i dostava |
#4518 |
Postovi: 23
hvala vam obojici. što mislite o opciji da uštedim na ssdu pošto ga već imam (moj prvi post) i uzmem hdd za skladištenje igara pa da pojačamo nešto drugo? ima li to smisla? @FRipper da, mislim na tak nešto što se tiče monitora. jesu li to dva koje predlazes? @smartic "25" ultrawide nikako, visina je premala." što točno misliš pod ovim? svakako sam mislio 30+ dijagonalu, dva koja je posto prije tebe mozes birat dijagonalu koristim nox i momo za android Zadnje izmijenjeno od: pezo. 07.02.2019. u 00:53. |
#4519 |
Lokacija: Trogir
Postovi: 10
Pc parts izbacuje da nije kompaktibilna mb i cpu. Ako moze blize 7k |
#4522 |
Lokacija: Trogir
Postovi: 10
Hvala puno ekipa. Moze link odakle je slozena pa da narucim danas sutra. |
#4523 |
Lokacija: gornja stubica
Postovi: 8
pozdrav, trebao bih racunalo za igrice...znaci samo kuciste i monitor....do 6000 kuna...odmah mi dajte link s stranicom s koje da narucim ako nije problem...hvala unaprijed. |
#4524 |
Postovi: 1,635
2 * Ventilator ARCTIC COOLING F12, 120mm, 1350 okr/min Sifra: 050.908.169- - 90,00 Kn 1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) box, Wraith Stealth Sifra: YD2600BBAFBOX - 1.358,00 Kn 1 * Matična GIGABYTE GA-AB350M-DS3H (S.AM4, 4xDDR4, RAID) mATX Sifra: GA-AB350M-DS3H - 509,00 Kn 1 * Patriot Viper4, 3000Mhz, 8GB (2x4GB), CL16 Sifra: pat-pv48g300c6k - 586,00 Kn 1 * SAPPHIRE AMD Radeon PULSE RX 580 4GB GDDR5 + 2 Igre (The Division 2, Devil May Cry 5 ili Resident Evil 2) Sifra: 11265-09-20G - 1.469,00 Kn 1 * GIGABYTE SSD 120GB Sifra: GP-GSTFS31120GNTD - 169,00 Kn 1 * Tvrdi Disk Toshiba P300 1TB 3.5 Sifra: 0140635 - 349,00 Kn 1 * Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX Sifra: fsp-nap-hexa85-550 - 469,00 Kn 1 * Zalman S3, 1x120mm, USB3.0 Sifra: ZAL-S3 - 250,00 Kn 1 * Monitor Samsung LS24F352FHUX PLS AMD FreeSync Sifra: 0222994- - 899,00 Kn Ukupno: 6.148,00 Kn (-2%=6.025kn) Besplatno slaganje i dostava U temi se ne smije o trg pa ak te zanima gdje je primjer slozen javi se na PP |
#4525 |
Postovi: 2,707
Zašto zujalice od 1350rpm i to po 45kn komad ![]() Ovo promijeni: 1 x MS PC COOL 12cm crni ventilator za kućište 1 x Memorija 8GB (2x4) 2666MHz G.SKILL Ripjaws 1 x GIGABYTE SSD 240GB, 2.5, SATA III, 500MBs/420MBs, 1 x Napajanje SilentiumPC Supremo L2 Gold 550W Ispada samo 10-15kn skuplje. |
#4527 | |
Postovi: 1,635
To su beet buy ventovi u tom nizem cijenovnom rangu i daleko od toga da su glasni. Sto je jos jace napises to i onda stavis 2 najgora MS venta. BTE zasto sporiji RAM na Ryzena? |
#4528 |
Postovi: 2,707
Hm, bazirano na nekoliko modela ventova koje sam imao/imam i kako zvuče na 1000rpm, a kako na ~1400rpm. Zujalica je možda pregrubo Ako znaš iz prve ruke za oba venta, u redu.RAM je sporiji samo na papiru jer gore su malo bolji čipovi, a jeftiniji 70kn. |
#4529 |
Postovi: 17,143
U svakom slučaju bi preporučio bar 240GB SSD. Danas igre imaju i po 100GB, a uvijek je nekako kvalitetnije pokretati igre s SSD-a. |
#4530 |
Postovi: 8
2 * Ventilator ARCTIC COOLING F12, 120mm, 1350 okr/min Sifra: 050.908.169- - 90,00 Kn 1 * Procesor AMD Ryzen 5 2600 (6C/12T, 3.9GHz,19MB,65W,AM4) box, Wraith Stealth Sifra: YD2600BBAFBOX - 1.358,00 Kn 1 * Matična GIGABYTE GA-AB350M-DS3H (S.AM4, 4xDDR4, RAID) mATX Sifra: GA-AB350M-DS3H - 509,00 Kn 1 * Patriot Viper4, 3000Mhz, 8GB (2x4GB), CL16 Sifra: pat-pv48g300c6k - 586,00 Kn 1 * SAPPHIRE AMD Radeon PULSE RX 580 4GB GDDR5 + 2 Igre (The Division 2, Devil May Cry 5 ili Resident Evil 2) Sifra: 11265-09-20G - 1.469,00 Kn 1 * GIGABYTE SSD 120GB Sifra: GP-GSTFS31120GNTD - 169,00 Kn 1 * Tvrdi Disk Toshiba P300 1TB 3.5 Sifra: 0140635 - 349,00 Kn 1 * Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX Sifra: fsp-nap-hexa85-550 - 469,00 Kn 1 * Zalman S3, 1x120mm, USB3.0 Sifra: ZAL-S3 - 250,00 Kn 1 * Monitor Samsung LS24F352FHUX PLS AMD FreeSync Sifra: 0222994- - 899,00 Kn Ukupno: 6.148,00 Kn (-2%=6.025kn) Besplatno slaganje i dostava znaci konfiguracija dobra...? jos umjesto 120 gb ssd stavim 240 i dobro... znaci zadovoljavajuca konfiguracija??? jer ga danas onda kupujem.... |
