#61 |
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Chuwi Hi10 Air Tablet - Smoothness Is More Than Just Talk
Chuwi Hi10 Air Tablet is a cost-effective notebook which supports fingerprint recognition. Equipped with a 10.1 inch FHD display with full IPS screen, brings your photos and videos to life. Powered by Intel Core processor, featuring Gen 8 graphics processor, ensures high performance. 64GB huge hard disk storage brings you smooth using experience. 2.4GHz/ 802.11b/g/n WiFi supported, ensures you high-speed surfing. Main Parameters: OS: Windows 10 CPU: Intel Cherry Trail Z8350 GPU: Intel HD Graphics Gen8 Screen: 10.1 inch IPS capacitive screen with 1200 × 1920 resolution RAM: 4GB ROM: 64GB External Memory: TF card up to 128GB Camera: 2.0MP back camera and 2.0MP front camera WiFi: 2.4G 802.11 b/g/n wireless internet Bluetooth: 4.0 Battery Capacity: 6500mAh Product Features: ● Full Lamination Technology, Holds Glass Closely Chuwi Hi10 Air adopts OGS full lamination technology to reduce the air refraction between TP and glass significantly, making the picture more vivid. Thanks to OGS tempered glass, the Hi10 Air’s high density LCD pixel is only 0.7mm, creating stereoscopic effect. ● Productivity and Creativity Hi10 Air perfectly matches with the 10.1-inches soft keyboard, which is connected by docking port. Along with the Chuwi Hipen H2 Stylus, the Hi10 Air provides more comprehensive and effective usage for productivity and creativity. ● Delicate and Clear, Say "No" to Visible Pixels The combination of IPS display and OGS technology can show colors with unparalleled clarity, 178° viewing angle will give you an amazing experience for watching videos and browsing. ● Solid and Slim, Engineering Aesthetic Hi10 Air adopts the metal uni-body design which went through 64 manufacturing CNC processes, the extremely thin 8.5mm metal body only weights 562g and makes it suitable for everyday carry backpack. ● Robust Intel Chipset, Fluent Gaming Experience Equipped Intel's advanced Cherry Trail CPU(up to 1.84GHz) and Gen8 HD Graphics GPU (up to 500MHz), Hi10 Air possesses powerful performance and fast processing speed to guarantee everything to run smooth. ● The Daily Driver for Everything Hi10 Air comes with 4GB of DDR3L RAM and 64GB eMMC , reading and writing speeds up to 150m/s. With max up to 128GB TF card expandable storage, it meets your needs for movies, games as well as pictures. ● Official Windows 10 Pre-installed Windows 10 OS, Edge browser as well as Cortana will improve your work efficiency and give you the free choice between tablet mode and laptop, great for entertainment and productivity. ● 5V 3A Fast Charging Hi10 Air fully charges in just 3 hours thanks to USB 3.1 fast charging, and now supports data speeds of 10Gbps, you can charge it with a power bank without carring the big laptop A/C charger. ● Not Only A Tablet Hi10 Air's keyboard dock brings back that familiar laptop structure required for productivity, the Hi10 Air can also be connect via Bluetooth for wireless support even the Xbox One controller. If you are looking for a cost-effective tablet, you must not miss it. With the price of $169.99 on GearVita, it is value for money to get a such powerful tablet: https://gearvita.com/chuwi-hi10-air-...-64gb-rom.html Hot sale products: xiaomi mi pad 4 plus 4g redmi note 6 pro 64gb ![]()
Best Brand Consumer Electronics Provider GearVita |
#62 |
Lokacija: China
Postovi: 241
Wearing QKZ CK5 Earphones, Your World Is Only Music
QKZ CK5 earphones is a in-ear ear hook earphones which sounds good and have beautiful design. You can use audio control to answer the phone and control music. It's the newest sports ear-ear headphones which has transparent heavy bass. Product Features: ● Britain imported CSR master control chip, faster and more stable. ● Senior beryllium alloys diaphragm, adopt to senior headset custom meterials, voice more accurate, more pure. ● The import key components drive-by-wire, tactility is clear, long service life, high performance mic, ensure the quality of calls is clear. ● Smart noise reduction technology, filter out the noise environment, pure sound, music more clearly. ● The ergonomic design, nipple grade silicone ear muffs. ● Ear and tail pipe connection with oblique angle design, comfortable and easy to wear. ● Intelligent remote control, easy to operate. It is of $24.99 on GearVita, click here to learn more about it: https://gearvita.com/qkz-ck5-wired-h...-with-mic.html You may also be interested in: xiaomi poco f1 lte 64gb oneplus 6T 4g smartphone 128gb ![]()
#63 |
Lokacija: China
Postovi: 241
Lenovo Watch 9 Smartwatch Constellation Series - Represents Youth Fashion
The Lenovo Watch 9 smartwatch constellation series is the new color scheme of the Lenovo Watch 9, the exclusive pattern of each constellation is also drawn in the dial. It is a smart quartz watch with sapphire mirror glass and 5ATM waterproof technology, supports message reminder, gesture photo, sports sleep record and the sleep monitor function will tell you your sleep quality. Built-in high quality movement, no need to charge, the battery can be used for 8 months on standby. Libra - Designed for Beauty Libra is bom to pursue beauty, willing to be trivial, willing to be normal, but will not be willing to be mediocre. Ingenious design process, create a sense of security that belongs to you only, looking forward to noble and distant. Virgo - Meticulous Design Inspiration Virgo design inspiration, reasonable and diligent from Virgo, clear mind and the pursuit of perfection. Using a stylish cotof system, generous, calm, stylish. Intellectual, open, pursue your cwn inner beauty. Leo - True Temperament Design Ideas Passion, sunshine, confidence, generous starts design language of Leo, it is difficult to interpret the true nature of the lion. The world's evaluation is not the most important, my feelings are the most important, this is the last and the first reluctance of Leo. Product Features: ● Superb Skill The constellation is inspired by the stars, sapphire glass mirror material, steel case, silicone strap, luminous pointer, let the beautiful watch blend into the stars of the sky. ● Quality Chip, Long Battery Life Imported Citizen gearbox and Nordic imported smart chip, integrating technology with the stars, up to 12 months of battery life. ● Life Waterproof 5ATM grade waterproof sealing process, guarantee normal use under 50 meters water pressure. ● Information Never Missed Personalized hipsters, always master new information. After setting permissions, SMS, information (QQ, WeChat, etc.) including incoming calls will vibrate in the first time, and use the second hand to indicate the user, short press or shake your wrist to hang up. ● New Way to Take Pictures Intimately integrated into the gesture camera function, enter the camera interface of the watch app, short press or shake the watch to take a quick photo, tailored for your self-portrait, don't miss the meteor that is drawn every moment. ● Cares About Your Health Have a motion calculation, sedentary reminder function,let every day of vitality be traced, closer and moreintimate, always pay attention to your health. ● Sleep Monitoring Skin-friendly material straps and lightweight weights for watches, more suitable for sleep wear. More accurate sleep monitoring function, can pass the body movements when you sleep, ahfvays monitor your sleep duration and sleep quality. ● Data Synchronization When Bluetooth has paired your smartphone, you can synchronize your data with your Android phone and iOS phone. It gives you a real-time evaluation of your exercise throughout the day. This Lenovo Watch 9 smartwatch constellation series is designed for Libra, Virgo and Leo. Believe you are no stranger to Lenovo Watch 9, with four different color schemes of watch face and strap on GearVita, this series may be more eye-catching: https://gearvita.com/lenovo-watch-9-...on-series.html Hot sale products: xiaomi mi band 3 bracelet huawei honor band 4 wristband ![]()
#64 |
Lokacija: China
Postovi: 241
Xiaomi AirDots Bluetooth Headset Lets The Melodious Time Slow Down
The Xiaomi AirDots Bluetooth Headset comes with several features that ensure the user is satisfied with the sound output and the user experience is designed to be seamless. If the pair or one of them is taken out of the charging box, it boots automatically and pairs with the previously connected device. Placing it inside the charging box automatically disconnects and switches it off. There are touch panels on both sides of the earphone, which is used to pause of playing, answer and reject the calls, etc. Product Features: ● Elegant and Simple, Delicate Meterial The sleek and compact design eliminates the cumbersome elements, and the appearance is simple and full, which complements its simple operation. The charging box is made of high-difficult two-color injection molding technology, with translucent matte material, which is not only durable and wearable, but also has a sense of beauty, which makes people love it. ● Throw Away The Bondage, Feel The Agility of Music With TWS (True Wireless Stereo) technology, the binaural split body design, from now on without the headset line, enjoy the freedom of the melody. ● Take Out The Box and Automatically Boot Xiaomi AirDots Bluetooth Headset incorporates new technology, changing traditional manual operations and simplifying complicated paining steps. After being taken out of the box, it can be automatically turned on, automatically conneted and paired, and enjoy the song, it is so simple and easy. ● At The Touch of Button, Control by Heart The built-in touch panel of the headset is reponsive and can be used to complete your commands with a soft touch at your fingerprints. Avoid the pain of pressing with traditional buttons, and open a new era of touch with you. ● Hello, Xiaoai Classmates Tap twice to wake up the Xiaoai voice assiatant, no need to take time to pick up the phone. In a word, it helps you to solve the trivial things of life. ● Find Better, New Bluetooth 5.0 A new generation of Bluetooth 5.0 technology, compatible with various protocols such as Bluetooth 4.2 and below, achieves a comprehensive upgrade of performance, achieves long-distance transmission with ultra-low power consumption, has stronger anti-WiFi signal interference capability, and keeps the signal smooth, gives you a more smooth experience. ● Stereo Call, Hear More Clearly The Xiaomi AirDots Bluetooth Headset uses a new version of the chip to achieve two-channel stereo. Listen more clearly, and the call is close at hand. ● Double Bass, Make The Sound More Sensation The special 7.2mm strong magnetic moving ring speaker has wider bass range and more explosive sound. It is equipped with a rear cavity sounding structure and then optimized by the tuner to make the mid-low frequency more powerful and melody more sensation. ● 12 Hours of Battery Life, Happy and Uninterrupted The dual headphones are fully charged for 4 hours of continuous listening, and with the exquisite and compact charging box, it can provide about 12 hours of battery life, and the outdoor travel is not afraid of power failure, so that the songs accompany you all the way. ● Close to Both Ears, Comfortable and Endless When you wear it you dont want to take it off, listen to music, it should be so comfortable. Repeatedly calibrated curved arcs make the earphones fit the contours of the ears, the beveled ear structure is designed to comfortably penetrate the ear canal, three sets of soft silicone ear caps of different sizes are designed to create comfort for everyone. ● Work, There Is Also "Enjoy" Accompanied Both headphones can be used separately for easy office work, while allowing boring work to accompanied by misic. The Apple AirPods brought a true wireless headsets experience to the market and quickly became popular, but the new AirPods cost are overpriced for the average person. Never mind! The new Xiaomi AirDots Bluetooth Headset is priced only at $45.59 on GearVita. Thus, for the 1/3 of AirPods price, you can have the same true wireless experience: https://gearvita.com/xiaomi-airdots-...h-headset.html Hot sale products: xiaomi lyej05lm qcy q26 pro mini wireless bluetooth headset ![]()
#65 |
Lokacija: China
Postovi: 241
UMIDIGI A3 - Triple Slots, Dual 4G VoLTE, Worldwide Frequencies
Featuring 5.5 inch 720 × 1440 resolution display on the 2.5D curved glass body, the UMIDIGI A3 smartphone as technology fashion pioneer uses a 12.0MP + 5.0MP dual rear cameras setup to deliver excellent photos. It is equipped MTK6739 quad core 1.5GHz high-performance processor and Android 8.1 OS to handle your daily tasks with ease, offering a power boost compared to previous generation. 3300mAh battery with low consumption is for full-day use, two ways to unlock your phone just a glance, global LTE bands is available in most of world’s countries. Product Features: ● 5.5 inch Incell 18:9 Full-screen Display Thanks to the 18:9 format 5.5 inch advanced in-cell technology full-screen display, UMIDIGI A3 will fit your hand like a glove, delivering the perfect experience of one-handed operation. ● MT6739 1.5GHz High-performance Processor Powered by a MT6739 1.5GHz Quad-Core A53 64-bit processor, the UMIDIGI A3 is able to handle your daily tasks with ease. It offers a power boost compared to previous generation, while reducing power consumption. ● Stock Android 8.1 System Android 8.1 has an easy-to-use interface, bringing amazing features and having security at its core, the A3 offers great and smooth use speed without interruption. ● Dual SIM + Dedicated Micro-SD Slot With a triple tray, you don't have to choose between having 2 SIMs or 1 SIM and 2 Micro-SD. Now you can carry both your SIM cards and expand the storage of the phone up to 256 extra GBs using a Micro-SD card. Store more, delete less. ● 12.0MP + 5.0MP Dual Rear Cameras UMIDIGI A3 uses a 12.0MP + 5.0MP dual OV cameras setup, driven by a large F/2.0 aperture, 1.25 μm large pixels, OV12870 sensor, to capture shoots with richer colors and less noise. ● 8.0MP High-resolution Front Camera The 8.0MP selfie shooter offers the possibility to get nice selfies and make high quality video calls, either for having fun with friends. ● Fingerprint and Face Unlock Unlock your phone just a glance to capture your face features with face ID technology, combined with other unlocked way, fingerprint recognition, so conveinent and safe. ● Dual 4G VoLTE, Worldwide Frequencies Support UMIDIGI A3 is equipped with dual 4G VoLTE technology, which brings benefits such as a high data throughput performance, more reliable coverage, lower power consumption and a consistent HD call quality when you make calls via either cellular connection or using your datas. It supports more than 15 LTE bands, which means you can take it have a global round travel, 4G LTE signal will be available in most of world's countries. UMIDIGI also brings latest trends to the budget segment, delivering two amazing colors for UDIMIGI A3: Gold and Black, you can come to GearVita to choose, the price is also very beautiful, only at $79.99: https://gearvita.com/umidigi-a3-4g-s...-16gb-rom.html Hot sale products: xiaomi redmi note 6 pro xiaomi mi a2 lite smartphone ![]()
#66 |
Lokacija: China
Postovi: 241
Zealot B570 Bluetooth Headset - Strut Down The Street with Great Music
Never miss phone call with the new Zealot B570 headset vibration prompt feature, that will notify you to incoming phone calls. With the built in noise cancelling system, you’re able to listen to music without external sounds running your music track. Product Features: ● LED Colorful Display Simple user interface is the LCD screen to display the status of headphone and change modes for visual operation. ● Foldable Design After folded, the B570 becomes small and convenient to carry with when go out and can be storage in small space. ● Comfortable Wearing Experience The head beam made of environmental aviation rubber, which is coupled hardness with softness and can be extremely bended. With telescopic design, you can adjust the wearing tightness. Earmuffs are made of soft breathable protein leather and adopts the surrounding-ear style, providing you comfortable wearing-on experience. ● Shocking Bass With 30mm super big diaphragm and closed stereo sound field, the bass directly march into your heart. Whether listen to music or watch a movie, you will be fully immersed in the virtual reality. ● Built-in HD Mic The protruding mic is easily to break off, while the built-in mic effectively avoid it. Also B570 adopts noise canceling technology and makes you satisfied and easy to call and voice intercom. ● Built-in FM Radio Support FM radio local broadcast playback, you can listen to music, storytelling, financial and economics through the FM radio. ● Support TF Card and Breakpoint Continuing Playing Built-in intelligent decode technology, B570 supports playing music in main formats and breakpoint continuing playing. Micro TF card slot included, you can listen to music and audio you want using TF card, the max storage of TF card is 32G. ● HiFi Stereo Music Crystal clear and full-range sound let you feel the music coming with details realized through B570 40mm dynamic drivers. ● Steady Signal Transmission Compared with normal Bluetooth version, Bluetooth 4.0 is with faster transmission speed, longer transmission distance, more stable, lower power consumption. ● Wired Connection The design of audio line port makes it possible to switch freely between wireless and wired, any electronics audio equipment without Bluetooth can be easily connected. ● Detachable Battery B570 adopts detachable 600mAh battery, whether on a journey or outdoor, you can replace the battery with extra one. With the B570 bought from GearVita, you can take the best out of your playlist. Whether you are into pop, hard rock or jazz, there will surely be a perfect Zealot B570 Bluetooth headphones MP3 player for you: https://gearvita.com/zealot-b570-bluetooth-headset.html Hot sale products: xiaomi mi lyej02lm bluetooth headset xiaomi airdots headset ![]()
#67 |
Lokacija: China
Postovi: 241
Lenovo Z5 Pro - Slide Cover, 95.06% Screen, AI Quad Cameras
Lenovo, which has long predicted the launch of the slide phone, has finally unveiled its Lenovo Z5 Pro smartphone after Xiaomi and Honor. The sliding front-facing camera module and massive 95.06% screen-to-body ratio are the core selling points of the device. Main Parameters: Display: 6.39 inch super AMOLED screen with 2340 * 1080 pixels CPU: CPU: Qualcomm Snapdragon 710 System: ZUI 10.0 is based on Android O Storage: 6GB RAM + 64GB ROM Cameras: 16.0MP + 24.0MP rear cameras and 16.0MP + 8.0MP front cameras Bluetooth: 5.0 Special Function: NFC SIM Card: dual Nano SIM, dual standby Battery Capacity: 3350mAh Product Features: ● Comprehensive screen innovation of 6.39-inch Samsung AMOLED has no bangs suspension full screen, hides the front camera under the screen. ● Fingerprint of the fifth generation photoelectric screen greatly improves the accuracy of fingerprint recognition. ● Uses a sliding structure to hide the front camera, just need to slide gently to meet your unlocking and self-timer needs. ● Traditional structure carries out the six-position gold fixation, the slide rails and the mobile phone screen are accurately positioned to ensure the stability of the sliding. ● 24 million (4 in 1) and 16 million pixels SONY AI rear dual-camera camera for a clearer, more delicate image quality services, smart photos. ● A 1.8μm (4 in 1) large pixel high-sensitivity imaging sensor effectively enhances the camera's imaging ability in dark light conditions, whether it is photos or videos. ● The front-facing 16-megapixel beauty camera is based on the beauty standard, star face deep learning and oriental aesthetic features of the self-portrait. ● The 8 megapixel fast infrared in vivo camera detects 4 times the resolution of an ordinary infrared camera for a safer experience. ● A unique AI algorithm, easy to switch between natural, temperament, tough, sweet, net red and other idol styles. Also provide an additional micro-shaping solution that can adjust the facial features of the five senses. ● Lenovo Air wireless Bluetooth music headphones, using IPX5 sports waterproof design. The AI smart antenna is not easy to disconnect, and it can cope with wireless interference in a variety of scenarios. ● Dolby Atmos has a good transient response and more realistic restoration of music sound effects. ● IntelliGo AI chips solve noise problems fully and efficiently for true HD call. ● Deeply optimized Snapdragon 710 AIE processor, with 6GB of running memory, and powerful performance. ● AI game acceleration engine, CPU acceleration, GPU acceleration, memory acceleration, reduce network latency. ● Built-in independent security chip gives you a lot of security protection. ● More advanced unlocking method, infrared face recognition, no fear of all black environment. ● Provide protection from the source of payment, seven-fold secure payment. ● 3350mAh battery capacity, longer battery life, farewell to frequent charging. ● Intelligently judge the user's attention to the timeliness of the message and the frequency of using the mobile phone to achieve intelligent frequency conversion power saving. ● AI smart recognition can quickly scan and identify ID cards, documents, QR codes, etc., it can also be quickly translated. ● The ZUI 10.0 system is fully upgraded to create a smart life of deep experience. As for pricing, the Lenovo Z5 Pro will be available for $349.99 on GearVita, that makes this one of the cheapest slider-type devices available: https://gearvita.com/lenovo-z5-pro-4...h-version.html There is also Lenovo Z5 Pro 128GB storage model costing of $399.99: https://gearvita.com/lenovo-z5-pro-4...h-version.html ![]()
#68 |
Lokacija: China
Postovi: 241
Xiaomi Hybrid Dual Drivers Earphones - Great Music with Sensory Fashion
Xiaomi hybrid dual drivers earphones adopt the coolest hybrid technology, the combination of dynamic driver and balanced-armature driver. The balanced-armature will be handling on high-frequency audio while dynamic driver will handle the low-frequency audio thus providing a more 3D surround effect. Product Features: ● Combine the dynamic and balanced drivers, sounds produced are resoundingly richer and fuller. ● Wire control microphone, easy to control, play music and make calls. ● Adopts graphene, thinnest, strongest, and most eco-friendly material able to transmit sound fast, more ductile under high frequencies, producing sounds that are rich, sharp, and crystal clear. ● High-elasticity TPE fiber wire provides an excellent resistance to pull and perspiration resistant ability. ● L-shape plug, no easy to break and wear. ● Comfortable fit with ergonomic contoured form. ● Come with 4 pairs of XS/S/M/L size soft silicone eartips for comfortable wearing experience. Price at only $19.94 on GearVita, it is really a earphone value for money: https://gearvita.com/xiaomi-qtej03jy...earphones.html You may also be interested in airdots headset lyej02lm bluetooth headset ![]()
#69 |
Lokacija: China
Postovi: 241
Siroflo I8S Wireless Earbuds Give You A Live Concert-like Listening Feast
Siroflo I8S is the true wireless earbuds with Bluetooth 4.2, 10mm × 2 Hi-Fi stereo with noise reduction, gives your perfect enjoyment of music. The portable charging box can provide a power supply while you out, wherever you go the music follow play. Product Features: ● True Wireless Design With no cable hanging on your neck, you will get a 100 percent wearing comfort when listing to music. The unique true wireless craftsmanship ensures you will be able to share the tune with your loved ones. ● Snug Fit Featuring ergonomic-shaped earplug, the earbuds offers comfort and flexibility. It will never slide out from your ears even when you are running or dancing. 3 sizes of ear caps included, suitable for all types of ear. ● One Touch Operation Adopting touch-sensitive button, you can easily and conveniently operate the earbuds when enjoying music. One button controls everything, including the power, pairing with Bluetooth enabled, receiving calls, volume control. ● Stable Connection Bluetooth V4.2 ensures the earbuds to connect quickly and seamlessly to all Bluetooth enabled devices up to 33 feet away, providing a stable signal. ● IPX5 Waterproof Protection Rated IPX level 5, the earphones can withstand drip and water, so you can work out in the rain freely wearing it to enjoy the sweet melody. ● Energy-saving The earbuds with 40mAh battery supports 3 hours of continuous music per full charge. If no connection enabled within 2 minutes, the unit will switch off to save energy. Furthermore, the battery level will be displayed on your iOS devices. ● High Fidelity Sound Quality Built-in 2 excellent HiFi 10mm horns and advanced CVC noise cancellation maintain a high fidelity sound quality, offering you crystal-clear calling and excellent music experience. ● Portable Charging Box Portable charging box with 800mAh and mini charging cable included. Just put the earbuds into the box, you can power it. Plus, the box offers a strong portability to carry the earbuds, virtually go with you anywhere you go. Furthermore, the charging box serving as a power bank can also charge other devices via a charging cable. Get the Siroflo I8S earbuds from GearVita, putting on the earbuds, just like enjoying a live concert. You will be able to enjoy the fantastic music even while you are taking a shower, also can share the tunes with your loved ones: https://gearvita.com/siroflo-i8s-wireless-earbuds.html Hot sale products: lenovo z5 pro 64gb xiaomi mijia aqara hub gateway ![]()
#70 |
Lokacija: China
Postovi: 241
Put on KZ EDR1 Earphone to Listen to A Better World
KZ EDR1 earphone adopts enthusiast material, TPE coated, has a strong anti-oxidation, anti-corrosion, anti-pull effect, the wire will not easily break. Built-in miniature moving coil unit, bass technology into a super widescreen, with ordinary mobile phone can drive out good music. Cavity with copper and anodized aluminum Hop materials, copper front chamber acoustic kit sound processing can be more delicate, more texture. Product Features: ● Intransigent Quality This earphone is designed for masses with a good quality, the high-end copper plating process front sound cavity, anodic oxidation aluminium alloy back cavity. ● Professional 6N PFC Cable 99.9% OFC cable, high strength, good toughness, heat resistant, high tensile strength, winding preventing. ● Fine Workmanship and Durability 2-3 times longer life than ordinary earphone. ● Sound Quality Paramount 8mm special driver unit with powerful bass, stable mids and clear treble. This KZ EDR1 earphone is famous for the perfect bass function and in a good price of $5.69 on GearVita. It will bring you top experience in music and never let you down: https://gearvita.com/kz-edr1-in-ear-earphone.html You may like: mi lyej02lm bluetooth headset xiaomi 70 minutes car dvr ![]()
#71 |
Lokacija: China
Postovi: 241
GearVita Black Friday & Cyber Monday - 10% Off, $1.11 Flash Sale, Add-on for $9.99
The Black Friday & Cyber Monday event of GearVita officially opened and the event lasted until November 30th. All event products will receive a 10% discount with the coupon code "Paypal10", except for flash sale and add-on products. But flash sale and add-on products are more cost-effective. The flash sale price is as low as $1.11, including the recent black shark smartphone from Xiaomi, the best-selling Huami Amazfit Bip smartwatch, are all presented to you at flash sale prices. The flash sale product will be changed every three days, and you can check if there is any product you like every few days. Any order over $50 will get a $9.99 redemption for add-on, with one unit per item and only one chance per order. In addition, smartphones, tablets and accessories, smartwatches, audio products, smart homes that everyone is interested in can use the coupon code to get discounts. For users in the United States, we also offer PayPal installment support. The promotion will be concluded on December 1st, so hurry up to choose and buy! For detailed event products, please check here: https://gearvita.com/black-friday-sale ![]()
#72 |
Lokacija: China
Postovi: 241
Massdrop x NuForce EDC3 Earbuds with Three BA Drivers Per Side
The Massdrop x NuForce EDC3 earbuds, with its warm sound signature and amazingly compact form factor, will surely be a hit with both new and veteran audiophiles alike, especially for those who are looking for an everyday piece of that sound signature. The midrange is absolutely the star of the show, bringing forth a beautiful combination of clarity and smoothness in the region that is almost unrivalled within the price range. A comprehensive range of accessories to support the unit is also a huge factor in increasing its allure towards all its potential buyers. It features three BA drivers per side and a mostly-neutral sound signature intended to show you your music just the way it was recorded. Product Features: ● Triple-Driver IEMs With a Neutral Sound Dynamic driver configuration, the EDC3 uses three balanced armature drivers per ear design in a single bass, dual mid/high configuration. ● High Sensitivity and Impedance The IEMs are matched to within a 2dB difference, and have a frequency response between 20 Hz and 40 kHz. Its sensitivity is rated at 100dB, give or take 3dB, at 1KHz paired with an impedance rating of 16 ohms and a maximum input power of 2mW. ● Easy to Drive It's fairly easy to drive and I had no trouble with it while using my mobile phone. ● Removable Braided Cable There are two removable cables, a braided cable for top-notch performance and a second cable with an inline remote and microphone. For a comfortable fit, both cables use a shrink-wrapped over-ear guide with a thin profile and a two-pin connector that won’t rotate as you move. ● Compatible with Apple and Android Devices Speaking of the mic cable, it is compatible with all Apple devices and most of the Android devices. The microphone sensitivity is rated at -42dB, and can be used for some basic player control and call control plus starting your voice assistants such as Siri, Google Assistant or Cortana. Get it from GearVita, the EDC3 is ready to go everywhere with you. Wear it at home, in the office, at the gym, or while traveling or commuting: https://gearvita.com/massdrop-x-nufo...r-earbuds.html In addition, there is the Black Friday promotion on our website now, prices are very affordable, you can go to see: https://gearvita.com/black-friday-sale You may also be interested in: redmi note 6 pro 32gb smartphone buy xiaomi mi a2 lite smartphone ![]()
#73 |
Lokacija: China
Postovi: 241
Meizu POP - Wireless Earphones with Wireless Charging
The Meizu POP earphone is the first true wireless Bluetooth earphones and wireless charging of Meizu especially designed for sports, no wires for a tangle-free experience. The set comes with a charging case for storage, which features a USB type-C charging, compatible with all mainstream wireless chargers for easy charging. The POP used touch control technology, gently touch to make phone call, adjust volume, make it easier and safer to use. Product Features: ● Wireless Earphones and Wireless Charging With no wires for a tangle-free experience, the set comes with a charging box for storage and wireless charging, delivering extreme simplicity and convenience. ● Ergonomical Design The ergonomically crafted in-ear earphones fit perfectly in your ears and won't fall out even during heavy exercise such as running and weight training. Various earphone sleeves and buds are provided so you can pick and choose based on what you need. ● Without Worrying About Sweat POP has a waterproof rating of IPX5 and is resistant to sweat and rain. ● 5.8g Compact Structure Each earphone weighs only 5.8g, which is lighter than a coin. The smooth, round body comfortably fixes in your ear for extended periods of time. ● One Touch Control POP uses a touch control to operate, with a touch you can listen to music, make calls and access Voice Assistant. ● Stereo sound for a pure experience Meizu POP offers crystal clear stereo sound, with audio data transmitted to both earphones. The sealed structure of the integrated microphone cavity and noise reduction technologies reduce background noise and echo, making the conversation effect as clear as face-to-face communication. ● Graphene Diaphragm for Balanced Tri-frequency Adopt a φ6.0mm Hi-Fi dynamic graphene diaphragm that provides extended low frequency, powerful sound and balanced tri-frequency. The front cavity employs an air-pressure balance design to minimize pressure in the ear canal for maximum comfort. ● Open-to-connect for Convenient Charging The earphone box integrates storage and charging and supports smart on/off using magnetic induction. The earphones automatically start when you take them out of the box, and automatically switch off and start charging when you put them back in the box. A Bluetooth device can be automatically paired when the earphones start up, so you can listen to music straight away. ● Secure Fit Each earphone is only 0.2oz, various earphone sleeves and buds are provided so you can pick and choose based on what you need. ● Wireless Charging for All-day Use The earphone box features a USB Type-C charging interface that's compatible with all mainstream wireless chargers for easy charging. A pair of fully charged earphones can operate for 3 hours continuously, plus an extra 12-hour capacity provided by the earphone box, more than you need for all-day use. With the Meizu POP on GearVita, you can enjoy the best wireless experience with the least amount of money: https://gearvita.com/meizu-pop-true-...earphones.html Hot sale products: xiaomi mi band 3 global version xiaomi mi mix 3 128gb smartphone ![]()
#74 |
Lokacija: China
Postovi: 241
Huawei FreeBuds - True Wireless, Auto Wearing Detection, Tap Control, 10h Playtime
The acoustically engineered Huawei FreeBuds earphone can produce vocals with detailed clarity. It features a wireless design that allows you to enjoy your favorite music without the clutter of wires. The ergonomically design make it a perfect fit for your ears and do not cause any discomfort even when used for long. With intelligent double tap control, it would provide you with the best music experience. Product Features: ● Bluetooth 4.2, True Wireless Experience Adopts the latest Bluetooth 4.2 technology, after a simple Bluetooth pairing, they will connect automatically once you open the case, you can listen to music or make phone calls when wearing them, tangle-free and handsfree. ● Auto Wearing Detection Infrared sensor can sense when the earbuds are in your ears and when you take them out. ● Double Tap Control Built-in G-sensor simplifies every operation into elegant and efficient double tap, which allows you to easily activate the voice assistant, answer an incoming call and end it, control music play/pause, etc. ● Purely Superior Sound Adopts balanced armatures and dynamic drivers with independent equalization (EQ) adjustment to achieve crisp treble, natural alto and deep bass. ● High Resolution, Realistic Sound Adopts AAC technology to improve transmission efficiency and present more details. ● Crystal Clear Voice Backed with ENC noise reduction technology and 4 mics, these earbuds improve your voice quality, thereby ensuring you enjoy clear conversations.. ● Unilateral and Bilateral Mode Two earbuds can be used separately or simultaneously, support freely switching between two modes, allowing you to share your favorite music with your loved one. ● Smart Compatibility Stable Bluetooth connection with up to 10m transmission distance, compatible with Android and iOS devices, no need to worry about missing calls when forget to take cell phone with you. ● High Performance Battery With built-in 55mAh Li-ion battery, these earbuds can seamlessly play your favorite music for 3 hours on a single charge. What’s more, the battery can provide 10 hours using time with charging box, so that you have enough time to enjoy yourself. ● Ergonomic Design Designed with ultimate precision to provide a perfect fit to your ears, keep you entertained with your favorite music without having to deal with the clutter of wires. The ergonomically designed earbuds will not cause any discomfort even when used for long. ● IP54 Rating Protection Waterproof, dustproof and sweatproof in accordance with IP54, Freebuds is able to bring you excellent listening experience whenever you are doing exercise or traveling in rainy days. ● Sleek and Compact Exquisitely crafted mini body, fits perfectly in pocket. A design combining fashion and convenience, also a great companion for daily life. There are white and black on GearVita for you to choose from, both colors are stylish and elegant. The touch-able and wireless design, shocked voice quality, noise reduction talks and 10h of using time with charging dock, make the Huawei FreeBuds outstanding in the same price earphone: https://gearvita.com/huawei-freebuds...rging-box.html You may also be interested in: xiaomi redmi note 5 4g global version buy xiaomi mi pad 4 plus ![]()
#75 |
Lokacija: China
Postovi: 241
Xiaomi Necklace Bluetooth Earphone Young Version Delivers Terrific Sound
The Xiaomi Necklace Bluetooth Earphone Young Version with a neckbud wireless design and dual drivers, giving you terrific sound. They are small thus less prone to falling out of the ear canal when you are working out, riding bikes, and anything else involving physical exertion. The cable is the safety mechanism, prevent losing or wrecking one of the pure wireless buds. Product Features: ● Continuation of the classic collar-type micro-arc design, the lines are smart, stylish and comfortable, youthful and energetic. ● Lightweight TPE material, better elasticity, automatic rebound. It has anti-slip skin-friendly properties, feels soft and comfortable, all-weather wear. ● End shell has good self-protection characteristics, which can relieve the external pressure when impacted, effectively protect the circuit board and battery components in the body, and provide long-term support for the headphones. ● The wonderful combination of composite diaphragm and large moving coil acoustic technology, co-resonance under the action of magnetism and electricity, restore music high-frequency bright, medium frequency full, low-frequency mellow and elastic, the sound details are more round and full, true and durable. ● Lightweight, only 35g, ergonomically designed for more comfortable wearing. ● 1 hour full charging, 7 hours of music playback time. ● Segmented button design is sensitive, half-ear earphones, and fits the ear. The color of the youth version is very suitable for the young of the moment. There are two colors on GearVita, Black is steady and textured, Orange is young and energetic, both are fashionable colors specially designed for young: https://gearvita.com/xiaomi-necklace...g-version.html You may like: shop xiaomi mi 8 lite 128gb xiaomi mi box s tv box ![]()
#76 |
Lokacija: China
Postovi: 241
Xiaomi YDLYEJ03LM Earbuds Reproduces A More Defined Sound
The Xiaomi YDLYEJ03LM earbuds feature a copper coil, which is attached to an ultra-thin diaphragm in order to reproduce a more defined sound and is also made of a metal that delivers a realistic audio experience. The equipped CSR8640 chipset and Bluetooth 4.1 technology enable it to pair with up to two devices simultaneously and bring more stable performance. With a sweat and water resistant construction, conforming to the IPX4 industry standard in this regard, they are engineered to survive the demands of your active life. Their lithium-ion battery is rechargeable via USB and will provide up to 11 hours of continuous playing time. Furthermore, an onboard microphone and inline remote allows you to manipulate volume, skip tracks, rewind, answer/reject phone calls, activate voice assistant Xiaoai and more. Product Features: ● Ergonomic Tilt Design, Not Easy to Fall out 58 degree tilt design accords with ergonomics, perfectly fitting ear contour, keeping earphone secure and stable in place, not easy to fall out. ● 360 Degree Rotating Ear Hook, More Comfortable to Wear User-friendly 360-degree rotating ear hook design, can be adjusted to the appropriate angle according to the shape of the user's ear, making the wearing more comfortable. ● 13.6g Lightweight Weighing only 13.6g, you can even feel that you are not wearing it. Just enjoy your sports and relax yourself. ● Long Lasting Working Hours The built-in 120mAh Li-Polymer battery offers up to 11 hours of music playback or 8 movies, standby time up to 260 hours on a single fully charging. ● Bluetooth 4.1 Technology It is compatible with 4G networks, allows pairing two Bluetooth devices simultaneously. ● Copper Voice Coil and Ultra-thin Speaker Film The metal composite diaphragm makes the sound effect more stable, effectively reducing the sound distortion and allowing you to experience more realistic music. ● In-Line Microphone and Controls When paired with your smartphone, you can use the in-line microphone and controls to answer/hang-up calls and activate your phone's voice assistant Xiaoai. The in-line controls also give you the ability to play/pause audio, adjust volume, sync, mute, and change tracks. ● IPX4 Waterproof It is waterproof in accordance with IPX4 rating, providing effective protection against rain and sweat. Thus, it is perfect for outdoor sports like running, hiking, climbing, etc. Music is really the best companion when you walk, run or take the subway alone. Priced at only $20.32 on GearVita, Xiaomi YDLYEJ03LM will be your best companion: https://gearvita.com/xiaomi-ydlyej03...r-earbuds.html Hot sale products: xiaomi mi max 3 smartphone huami amazfit 2 stratos ![]()
#77 |
Lokacija: China
Postovi: 241
Xiaomi Mini Subwoofer Wireless Speaker - Small in Size, Big on Sound
Xiaomi mini subwoofer is a super portable, round design Bluetooth V4.0 speaker, which make it easy to hear whatever is playing anywhere. 2W audio driver that produces sound louder than ordinary single speaker, giving you an extraordinary audio experience. CVC6.0 noise reduction system is suitable for using in the office, home, outdoors or party. Product Features: ● Mini and Portable Size in 52 × 52 × 25 mm, only 58g, exquisitely designed to fit in your palm. ● Perfect Balance The speakers are specifically customized to fit in a small form-factor, yet offering balanced sound with rich tones. ● Full Metal Casing The smooth metal housing has gone through metal stamping, polishing, sandblasting, anodized oxide coloring, and CNC diamond cutting to achieve its gorgeous exterior. This careful step-by-step process creates a structure robust enough to withstand various environments, while bringing you melodious notes at the same time. ● Clean and Simple Design Adopts seamlessly and elegantly designed with both the power button and the micro USB charging port neatly tucked at the bottom. ● CSR Bluetooth 4.0 Technology The new CSR Bluetooth 4.0 chipset ensures an energy-efficient, long lasting, stable listening experience. Enjoy high-quality calling experience whether you are at home, in the office, or outdoors with the CVC 6.0 noise reduction technology. Comes with a lanyard hole, you can also hang it up with a lanyard and free your hands. Buy it from GearVita, there are three colors for you to choose from, silver, gold and dark gray. Take it anywhere you go, you can enjoy the acoustic music even on the go: https://gearvita.com/xiaomi-mini-sub...h-speaker.html Hot sale products: yi 4k action camera floating grip xiaomi car charger double usb cc05zm ![]()
#78 |
Lokacija: China
Postovi: 241
Xiaomi LYXQEJ01JY Necklace Earphones - Dual Driver, CD Level Stereo Sound
Xiaomi LYXQEJ01JY necklace earphones, with dual drivers and ergonomic design, gives you a CD-grade music experience. Dynamic driver and balanced armature driver, more pure and mellow three frequency. High fidelity transmission, support AAC audio decoding and apt-X, rich immersive sound. Lightweight, only 40g, ergonomically designed for more comfortable wearing. Magnetic earbud, hang it around your neck without worry about dropping. Product Features: ● Dynamic Driver and Balanced Armature Driver More pure and clear three frequency, bringing you rich immersive sound quality ● CD-Level Stereo Sound Adopt CSR Bluetooth chip, support AAC decoding technology, and apt-X lossless transmission, provide you with high fidelity musical experience ● Hi-Fi Audio Driver The sound is adjusted according to the human auditory characteristics, the amplitude of low frequency is specially strengthened to make sound crystal clear and brings you stereo CD-quality sound. ● Built-in Microphone Seamlessly take phone calls and control media playback with built-in microphone and controls. Besides, with the incoming call vibration alert function, you will never miss a call. ● Go-Anywhere Media Companion Equipped with two wire clips, which eliminate the distraction of wires. When you wanna take a break from music, just take off the earbuds and they will be attracted to magnetic neckband, no more occasional drops and distortion. ● Extended Battery Life Built-in 137mAh battery, one charge gives 8 hours music playing and taking time, more than enough for your purpose. ● Bluetooth 4.1 Connection 3s quick connection range of up to 10 meters., compatible with the iPhone or any Bluetooth device. Even 2 mobile simultaneously. ● Neck Hanging Design Lightweight and comfortable, the ring-collar design ease the burden of ears and ensure the headset will stay securely in place during daily life. ● Magnetic Earphones The right and left side could be tick to each other by magnetic force so that you could hang it around your neck without worrying about dropping. ● Lightweight and Cozy for Wearing Ergonomically designed for comfortable wearing, the necklace made from high-quality soft materials and matte metal, use it for a long time without fatigue. The $48.43 Xiaomi LYXQEJ01JY on GearVita is small thus less prone to falling out of the ear canal when you are working out, riding bikes, and anything else involving physical exertion. The cable is the safety mechanism, prevent losing or wrecking one of the pure wireless buds: https://gearvita.com/xiaomi-lyxqej01...earphones.html Hot sale products: oneplus 6t 256gb yi 4k action camera floating grip ![]()
#79 |
Lokacija: China
Postovi: 241
QCY T1C Earphones - Auto Power On, Create Smarter Music Experience
QCY T1C earphones adopt BT 5.0 technology, bringing high-speed data transfer speed, stable performance and low power consumption, offering real-time transmission of call and games, no voice delay. With TWS technology, left and right ear channel separation, you can use the headset solely, or used them in pairs. Auto fast pairing between left and right earbuds once taking out of the charging case, easy and quick to pair with BT-enabled audio devices. Equipped with a 380mAh charging box to charge the earbuds for about 4 times anytime anywhere, provides total 20 hours of working time. Built-in dual microphone with noise reduction function delivers clearer and more real talking sound. Its mini size and 4.6g weight of each earphone fit well to your ear canal, and guarantee stability and comfort when doing sports. Product Features: ● Bluetooth 5.0 Technology The transmission speed is twice that of bluetooth 4.2 technology, and the power consumption is reduced by half. Better anti-interference performance and more stable connection, to make sure each calling and game-playing is in real time, avoid sound delays. ● Automatically Pairing Auto power on and fast pairing between left and right earbuds once taking out of the charging case, easy and quick to pair with BT-enabled audio devices, effective distance is about 20 meters in open space. ● Great Sound Quality Supports SBC and AAC professional audio codec technology, T1C restores the original sense of dynamic, catches every details of sound, reveals sound with higher resolution. ● True TWS Wireless dual ear design, left and right ear channel separation, you can use the headset solely, or used them in pairs. ● Bilateral Calls Built-in mic on both earbuds, improved the shortcoming of TWS headset that only one side can talk, enabling binaural stereo talk. ● Excellent Call Experience CVC6.0 noise reduction technology and high sensitivity silicon wheat improve the recognition level of voice, and can easily communicate even in noisy environment, make the call clearer and more real. ● Premium Audio Components Independent cavity and 7.2mm horn deliver the crystal HD sound quality, bring you the excellent stereo and bass experience. ● Long Battery Life 43mAh battery in each earphone ensures 4-5 hours of working time. Charged automatically in the 380mAh charging box which enables dual headsets charging for about 4 times, which supports up to 20 hours playtime in total. ● Lightweight and Comfortable Single earbud weighs only 4g, small like the fingertips, invisible to wear. Ergonomically designed, the earbuds exactly fits the contours of the ears, and there is no tenderness over hours wearing. This is an intelligent age, we refuse to be cumbersome. Get QCY T1C from GearVita, it will simplify the operation steps and let you enjoy the pure music simply and quickly: https://gearvita.com/qcy-t1c-mini-wi...earphones.html You may also interested in: xiaomi mi box s global version xiaomi redmi 6a global version ![]()
#80 |
Lokacija: China
Postovi: 241
QCY M1C Earphones Holds Immaculate Sound
This QCY M1C earphones will bring you amazing and fabulous audio enjoyment. It features 12mm large dynamic driver, providing detailed analytical force, with independent sound cavity anti interference effect, showing low frequency wonderful tone and enriching the dynamic bass. Sweatproof and waterproof function makes you feel free when doing exercises. With a pair of headphones, it allows you to listen to music for approximately 7 hours in stereo. Product Features: ● Magnetic Switch The magnetic adsorption design of earplugs enables the wireless earphone to become a necklace instantly, secure behind your ears. It allows you to play/pause the music on your device or answer/end phone calls by attaching and separating the earbuds. ● Advanced Technology Adopts CSR8645 chip and advanced apt-X tech, more energy efficiency and less delay, offers pure CD-like quality sound that's on par with wired headphones. Deep bass and crystal clear treble bring you an extraordinary music enjoyment. ● Bluetooth 4.1 Bluetooth V4.1 technology provides good wireless signal, compatible with most Bluetooth-enabled devices, you can seamlessly sync to your favorite wireless devices, and more up to 10 meters. ● Vibrant Bass Diameter 12mm dynamic driver shows low frequency wonderful tone and enriching the dynamic bass. ● Sweatproof and Waterproof Premium soft smooth silicone gel surface helps sweat/dust proof. With ergonomic design and perfect sizes of ear tips, the necklace Bluetooth earphone makes you feel free when running, jogging, hiking, cycling and driving. ● Noise Reduction With CVC noise cancellation 6.0 technology, the background noise can be resuced, so you can get high quality and hands-free phone conversation even you are in a noisy environment. ● Long Battery Life Up to 7 hours of continuous play time and up to 200 hours of standby time on a full charge. Voice prompt allows notification of incoming calls and phone numbers, so never miss a phone call. ● Universal Compatibility Compatibility with smartphones and tablets, you can enjoy the music on different devices. The QCY M1C wireless Bluetooth headset is the ideal product for those who want to listen to music and make phone calls easily while walking and having special headphones. If you also have this need, just come to GearVita and buy it: https://gearvita.com/qcy-m1c-bluetooth-earphones.html Hot sale products: xiaomi mi mix 2s smartphone 64gb xiaomi mi portable mouse ![]()
#81 |
Lokacija: China
Postovi: 241
Bluedio TN2 - Your Sports Fellow
Bluedio TN2 earbuds is a sports bluetooth earphone which has refined and clear sound quality, HiFi high fidelity. It has many features like Tri-band equalization. With 13mm large speaker and dual microphone active noise reduction, It can create outstanding bass, mid-range, high-pitched sound. Product Features: ● Unique and Magic Magnetic Switch Magnetic attraction design on the back, intelligent magnetic switch. When the two earplugs are separated, the music play automatically, when they stick together, the music pause automatically. When calling in, you can separate two earplugs to answer the phone or combine them together to hang up. ● Active Noise Reduction Adopt the mic with high signal-to-noise ratio to eliminate 90% of the low-frequency noise, enjoy the world without noise. ● Pure Music Clear sound quality, classified audio frequency, HiFi, more delicate and clearer sound quality, balance of tri-frequency, 13mm big loudspeaker, double mic active noise reduction, make you enjoy outstanding low-pitch, accurate medium-pitch sound and stable high-pitch sound. ● Ear-intimate Material Lightweight and uneasy to fall off, easy to be sorted out and stored. Adopt ear-suitable materials and comes with large, medium and small ear caps optional for every pair of ears, suitable for normal size ears. ● Decorative Device Body Boldly adopt the color-contrast collocation, with high discrimination rate and low identical rate, the appearance is also the decoration of your charms. ● Innovative and Unique Design According to human mechanics, achieve innovative design of neck hanging and layout pattern of lines and balanced stresses of the the whole headset. When sporting, it is not easy to fall off and twined together. ● Long Battery Life Low power cost, after full charge, it withstands 12-hour display by Bluetooth, nearly 300 songs in total. No matter you are teenagers or business giants, you need the companion of music when sport or on the way to school or office. Bluedio TN2 is waiting for you on GearVita, it will be your good fellow: https://gearvita.com/bluedio-tn2-nec...g-earbuds.html You may like: cheap xiaomi mi a2 lite smartphone cheap xiaomi mi max 3 4g smartphone ![]()
#82 |
Lokacija: China
Postovi: 241
QCY Mini 2 Earphone - A Subwoofer Concealed in The Ear
Ergonomic wireless in-ear earbud design ensures a comfortable listening and calling experience without leaving your ear pain. You will no longer have to fiddle with cords. Adopts Bluetooth V5.0 technology, which features fast paring and transmission and stable connection. QCY Mini 2 earphone can snugly fits in both of your left and right ear, it is definitely the first choice for anyone who wants a Bluetooth earbud! Product Features: ● Mini and Invisible Like his brother QCY Q26, the Mini 2 looks quite compact. The size of whole body is even smaller than its predecessor Q26, only as big as the fingertip. With a modest size and a 100% plastic finish, the weight is quite light at about 4.9g, this makes wearing headphones for a long time easier and more comfortable. ● Great Wear Experience Accroding with ergonomically tilted designed, the body is curved in line with the inner contour of the ear, providing three sets of different ruler and inch silicone ear caps to ensure the wearing comfort and stability. At the same time, the earphone can effectively prevent people from dust and sweat. ● One Button Operation Features easy, single one-button control, double press to change to the next song, triple press to change to the previous song, one single press to pause/start music or hang off/answer. ● Bluetooth V5.0 Chip Adopts Bluetooth V5.0 technology, fast paring and transmission and stable connection, with transmission distance up to 10m. Truly wireless earphones, no more shackle of wire. ● 7.2mm Speaker Unit 7.2mm neodymium iron boron custom speaker with unique cavity structure design to reduce 2 times mixing, offers you fabulous sound effect, just as place yourself at real-time concert. ● Advanced Noise Isolation Technology Filters out background sound, all-around voice pick up for clear crisp sound instead of muffled sound, whatever you are doing, you can immerse yourself in virtual reality. ● 40mAh Battery Built-in 40mAh battery, gets fully charged with an hour, offers 4-hour cheerful enjoying time. ● Microphone Maintaining a sound quality, microphone is an integral part. The large design of the microphone and the direction of the person's mouth make it easier and more stable to acquire the sound. With the price of only $8.99 on GearVita, QCY Mini 2 aims to bring you the best music experience with the lowest price: https://gearvita.com/qcy-mini-2-sing...-earphone.html You may like: cheap xiaomi 70 minutes smart wifi car dvr cheap xiaomi mi 8 lite 64gb ![]()
#83 |
Lokacija: China
Postovi: 241
QCY M1 Pro Earphones - Smart Magnetic Switch, Three Wearing Angles
This QCY M1 Pro earphones will bring you amazing audio enjoyment. It features 10mm large dynamic driver, providing detailed analytical force, with independent sound cavity anti interference effect, showing low frequency wonderful tone and enriching the dynamic bass. Ergonomic design makes it comfortable for a long time wearing. Product Features: ● Magnetic-absobing Design The magnetic adsorption design of earplugs enables the earphone to become a necklace instantly. It allows you to play/pause the music on your device or answer/end phone calls by attaching and separating the earbuds. ● Ergonomic Design With ergonomic design and three eartip options, you can choose the perfect one fitting yourself to makes you feel free when wearing it. ● Triple Adjustable Wearing Angles By adjusting the angle, you can find the perfect angle for yourself. ● Advanced Technology CSR8645, Bluetooth 4.1 and APT-X. More energy efficiency and less delay, provides HD sound and good wireless signal and is also compatible with most Bluetooth-enabled devices. ● 10mm Large Dynamic Driver Delicate and pure sound quality will show the essence of each song. ● IPX4 Water Resistance Premium soft smooth silicone gel surface helps sweat and dust proof, no worry about the rain and sweat, perfect for using when running. ● Noise Reduction CVC noise cancellation 6.0 technology, reduce background noise, you get high quality and hands-free phone conversation even in the noisy environment. ● Long Battery Life 100mAh Lithium battery provides up to 7~8 hours of continuous play time and up to 180 hours of standby time on a full charge. ● Universal Compatibility Compatibility with all iOS devices, Android cell phones and Windows phone devices. With the 10mm dynamic driver, funny magnetic switch and three wearing angles to adjust, you will definitely love it, particularly the price on GearVita is very cheap: https://gearvita.com/qcy-m1-pro-blue...earphones.html You may also interested in: best xiaomi huami amazfit bip smartwatch best xiaomi redmi note 6 pro ![]()
#84 |
Lokacija: China
Postovi: 241
1MORE Dual Driver BT ANC In-ear Headphones Provide More Tranquility
In addition to its excellent sound quality, the 1MORE Dual Driver ANC In-ear Headphones provide more freedom and tranquility for listening to music in a variety of settings. It ensures rich, pure music even in noisy environments. Product Features: ● Active Noise Cancelling (ANC) Feature a self-schemed TiinLab A2 chip for superior noise cancellation, which uses a wider frequency range EQ adjustment to counteract bandwidth. ● Low Distortion Balanced Armature Applied a proprietary low distortion balanced armature in which the high frequency signals are sent to your ears directly rather than through the ANC driver. This results in no signal loss, reproducing abundant details and a more complete listening experience. ● Patented Titanium Composite Diaphragm With 1MORE’s patented sandwich driver structure, the titanium composite diaphragm produces stunning clarity in the midrange and bass. The titanium layer is responsible for treble, while the dual PET layers producedeep punchy bass. ● Environmental Noise Cancellation (ENC) ENC technology has a precise microphone array that efficiently filters out background noise so communication remains crystal clear no matter which environment you are in. ● Flexible Ergonomic Neckband A comfortable neckband with silicone cover provides a natural,ergonomic fit during prolonged use. The flexible material features a foldable design for easy storage. The magnetic rear earbud covers provide a necklace like shape for convenient storage around your neck when not in use. ● Bluetooth 4.2 with Hi-Res Transmission Technology Enjoy a meticulous wireless listening experience with Bluetooth 4.2 and a wireless range of up to 30ft. ● Wired and Wireless Mode Switch between wireless listening or wired playback using a Type-C to 3.5 mm connection, allowing you to enjoy your listening experience in any environment. ● Fast Charge A 3C battery allows for 3x faster charging speed, take advantage of fast charge capabilities, with 10 minutes of charge time giving you 3 hours of use. ● Convenient Controls Play/pause music, control volume, and take calls using the conveniently located buttons located on the left side of the neckband. Environmental Sound Enhancement and Active Noise Cancellation can also be controlled with a simple click of a button. Get this ANC earphones from GearVita, enjoy the tranquility music and communication that belongs to you alone anytime anywhere, no longer disturbed by the outside world: https://gearvita.com/1more-dual-driv...s-e1004ba.html Hot sale products: xiaomi yeelight yldp06yl smart light bulb xiaomi mi 8 pro 128gb ![]()
#85 |
Datum registracije: Sep 2018
Lokacija: China
Postovi: 241
Divoom Tivoo Retro Mini Bluetooth Speaker Sparkles Your Everyday Life
The Divoom Tivoo speaker is what’s known as a "personal pixel art assistant". It is shaped like a retro television scaled down and featuring a full-spectrum color LED display with 16 × 16 pixel. The latest audio technology and unparallel tuning experience enable it to deliver the finest audio to you. More importantly, the cloud-based mobile App gives you access to the essential functions like music play, daily weather report, smart alarm, voice messenger and more, paired with fun features like DJ mixer, voice memo, pixel maker and so on. Product Features: ● 256 Full RGB Programmable LED Powered by the 3rd generation programmable LED, it will provide you with an incredible lighting experience. ● 360 Degree Full Range Speaker with Bass Port Adopting the latest audio technology and 6W DSP-Tuned full range speaker, it can bring you a superb audio quality, the bass port design is for bass enhancement. ● Mobile APP Application The Divoom smart app gives you access to the full functionality of the Tivoo, including music player, DJ Mixer, Voice Memo, pixel maker and pixel art animation maker. ● Pixel Art Creation Create pixel art has never been easier, draw anything at your fingertip. ● LED Editor With professional LED editing program, you can create your own custom lightings. ● Online Gallery Upload and share your amazing creations and meet with other pixel art fans around the world. ● DJ Mixer For the true music enthusiasts, you can create a remix with the professional DJ mixer function. ● Different Light Effects Different built-in lighting effects will enhance your visual sensation. ● Smart Alarm With 14 refreshing alarm profiles, it supports highly customizable settings and self-recorded alarm. ● Sleep-Aid With 24 professional sleep-aid profiles. It supports HQ alpha wave audio tracks and Melatonin inducing lighting. ● Voice Memo You can record a voice message for your family and friend and even set your message as the daily alarm. ● Social Media Notification Never miss an important message with the visual notification. Tivoo now supports the most popular social media applications. ● Daily Convenience Packed with many convenient daily tools, Tivoo is more versatile than your imagination. Portable speakers Divoom Tivoo is a stylish retro with a modern sound and an unusual bright screen. With this bluetooth speaker on GearVita, you get a whole entertainment center, equipped with many interesting and useful features. At home, at a party or during outdoor recreation, your favorite music and good mood will always be with you: https://gearvita.com/divoom-tivoo-re...-soundbox.html Hot sale products: cheap xiaomi mi 8 lite 64gb cheap xiaomi mi band 3 smart bracelet heart rate monitor ![]()
Best Brand Consumer Electronics Provider GearVita |
#86 |
Lokacija: China
Postovi: 241
1MORE MK801 Headphone - Release Your Passion
The 1MORE MK801 is a wired over-ear headphone that tick all the boxes of music listening: sound, design, comfort, durability and beautifully. It comes with superior diaphragms and fit, provides a perfect union of comfort and vibrant sound quality. The lightweight, yet durable design creates a powerful and transparent listening experience like having nothing between you and your music. Product Features: ● Durable and Ergonomic Headband Made using TR-90 steel, the headband can be bent and twisted to some degree without any damage, resistant to high temperature, corrosion and sweat. Lightweight and ergonomic design suits most head sizes with pressure-relieving silicon inside. ● 4D Rotated Ear Cups Closed-back ear cups block ambient noise and prevent sound from escaping. The 4-dimensional rotation nature allows ear cups to slide up and down with a snug fit to your ear canal. They are well padded and wrapped by soft protein leather and PU. ● Dual In-Line Control The intelligent in-line remote controls are compatible with both Apple iOS and Android. The three-button control box allows easy volume up/down, track switch and phone control. MEMS microphone achieves clear communication. ● Advanced Composite Diaphragm The headphones use advanced aerospace-grade titanium diaphragm with triple-layer polymer resin for balanced sound signature from crisp highs to deep bass. With the well-optimized mid-range, vocals are rendered with all details. ● Kevlar Core Cables PE enhanced detachable cable with high strength Kevlar core and soft tangle resistant exterior. These 1.2m cables are made with enameled copper wire, ensure a hassle free experience and durability. ● Tuned for Perfection Luca Bignardi, Grammys awarded mixer and recording director, adjusts the tunes for perfection. This makes you hear what artists intend you to hear with warm sound style. You listen not only music, but also stories. ● Bold Design Inspired by the design of supercar, having a matte finish with better tactile sensation. The color options of red and black are bold to highlight your personality and energy. Get the MK801 from GearVita and put it on, your world changes with pure and powerful music, every note sound is clear: https://gearvita.com/1more-mk801-ove...headphone.html You may like: xiaomi huami amazfit bip nes classic mini game console ![]()
#87 |
Lokacija: China
Postovi: 241
GearVita Christmas Promotion Combines Xiaomi and Huawei Brand Sales
Christmas is coming! From December 5th, GearVita Christmas Promotion will be officially launched with the Xiaomi and Huawei brand sales. The event will last until December 15th, and all participating products will enjoy 10% discount with the coupon code "XMASGV10FF". Any order over $50 will get a $9.59 redemption for add-on, with one unit per item and only one chance per order. In order to better welcome the upcoming Christmas, we also offer a lot of Christmas gifts under $40 for you, and it is also a good choice to buy for family and friends. This time, we have selected a lot of hot-selling smartphones, tablets and accessories, smart watches, audio products, smart homes and other products on our website to participate in this promotion. The all products on the event pages can get the 10% discount by use the coupon code, except for add-on. In addition, all Xiaomi products on our website can get a 10% discount with the coupon code "MISALE10". Similarly, all Huawei products can get a 10% discount with the coupon code "HUAWEI10". All Xiaomi and Huawei products, ALL! It is really attractive, right? The promotion will end on December 16th, hurry to choose and buy! For detailed event products, please visit: https://gearvita.com/christmas ![]()
#88 |
Lokacija: China
Postovi: 241
1MORE Stylish Dual-dynamic Driver Earphones - Listen in Style and Freedom to Attract
With meticulous craftsmanship, 1MORE stylish dual-dynamic driver earphones let you listen to your music in style. Engineered for premium sound, it combines a graphene and titanium dual-dynamic driver with a coaxial design for a vibrant and detailed soundstage. The streamlined design ensures a comfortable, fatigue-free listening experience. Product Features: ● Meticulous Design The sound chamber is made of ABS material and is vacuum plated for a glossy finish. Soft, skin-friendly silicone eartips provide a comfortable fit during prolonged use as well as a tight seal to prevent sound leakage. A frosted PE SR tube under the housing provides added durability to handle any condition. ● Dual-dynamic Driver A dual-dynamic driver featuring one Titanium diaphragm and one Graphene diaphragm in a coaxial design with two outer layers of PET deliver superior sonic detail with sizzling highs, clear mids, and deep bass. ● Lightweight and Comfortable Ergonomically designed earbuds with a 45° oblique angle provide a comfortable and secure fit, while 3 sets of additional ear tips ensure you get the proper seal in your ear. ● Convenient In-line Controls Skip songs, answer calls, and control volume all at the simple touch of a button. A superior MEMS microphone ensures crystal clear communication without background static or cross-talk. ● Expect Craftsmanship A soft and silicone wrapped cable is flexible, yet durable, allowing for easy storage in your pocket or case without getting tangled or stuck. A gold-plated L plug provides added security when plugged into your phone and in your pocket vs. the normal 3.5 mm cable that can easily bend when not careful. ● Loseless Bluetooth Audio Bluetooth V4.2 with a wireless range of up to 30 ft. allows you to listen to your favorite music anytime, anywhere. ● Fast Charge + 3C Battery Fully charged, it is capable of 6 hours of use. Fast Charge capabilities give you 3 hours of use with only 10 minutes of charge time due to a 3C battery that is capable of 3x faster charging speed. ● Perfected Ergonomics A soft and flexible neckband with a skin-like silicone material offers more comfort during prolonged use. A built-in memory steel wire allows the neckband to fold for easy storage in your pocket or travel case. Choose between 4 stylish color options from GearVita to match your personal preference: rose pink, platinum gold, spearmint green, and midnight black. The sound chamber, cable, and ear tips all feature the same color scheme for a timeless aesthetic: https://gearvita.com/1more-stylish-b...e-e1024bt.html Hot sale products: black shark gaming smartphone 64gb huami amazfit verge smartwatch ![]()
#89 |
Lokacija: China
Postovi: 241
HFD-Q1 Bluetooth Speaker - Booming Powerful Bass at Crystal Clear Loud
The HFD-Q1 Bluetooth speaker is a high quality performance that gives you powerful sound and volume quality, equipped with a passive subwoofer. Bluetooth support makes it truly versatile and you can take it anywhere, music will always accompany you. Product Features: ● Portable compact design with silicon housing and sturdy ABS body for excellent build. ● Adopt Bluetooth true wireless chipset. ● IPX6-rated waterproof. ● Faster connection with the latest Bluetooth V4.2, compatible with mobile phone/PC/tablet and other Bluetooth devices. ● TWS connection will start automatically after first time pairing, and allows pair two speakers, real wireless stereo sound. ● 2600mAh large rechargeable battery, playing time up to 10 hours at medium volume. ● High sensitivity microphone inside, hands-free call supported. ● Auxiliary in for external media devices. ● TF card supported, enjoy music without your phone. ● Auto idle shutoff in 40mins to save power. Double shock your ear by a pair of HFD-Q1 speakers on GearVita, each speaker has 8 watts of total output power that makes loud and excellent sound, also bring you the true stereo experience: https://gearvita.com/hfd-q1-bluetooth-loudspeaker.html You may like: buy xiaomi 70 minutes smart wifi car dvr buy xiaomi mi band 3 smart bracelet heart rate monitor ![]()
#90 |
Lokacija: China
Postovi: 241
Huawei Honor FlyPods - Out of The Ear, Out of The Fun
Huawei Honor FlyPods with a minimilistic and simple design, Bluetooth 5.0 allows them easily connect to Huawei smartphones. The FlyPods come with touch controls, the left earbud can be used to activate the voice assistant and the right earbud controls media playback while both earbuds can be used to answer and reject calls. They have the battery capacity of 420mAh, last 3 hours on a single charge and up to 20 hours with the charging case. Product Features: ● Double Click on The Touch Music and calls completed by double-clicking on the headset. ● Comfortable to Wear The body is ergonomically designed with a semi-in-ear style and a "swan neck" design for a comfortable and secure fit. ● The Sound of Heaven Support HWA HD Bluetooth audio transmission protocol, bringing a more pure and translucent sound quality, the 13mm dynamic speaker design create a more entertaining listening experience. ● Bluetooth Connection Bluetooth 5.0, low power consumption, compatible with many other Bluetooth transmission protocols. ● Wireless Charging With the wireless charging stand, charging is more convinient, the charging box supports Type-C USB cable charging at the same time. ● Call for 15 Hours Listen to music for about 3 hours on a single charge, listen to music for about 20 hours with the extra stored in the charging box. ● Open Box Self-pairing Turn on the headset and pair it quickly with the last linked phone. When you open the charging case for the first time, tap the headphone link pop-up on the phone screen to complete the link and get started. At the same time, the pop-up window will diaplay the power of the headset and the charging box. ● Call Noise Reduction A single headset has two MEMS microphones that match the call noise reduction technology, effectively reduce ambient noise and bring high quality calls. ● IP54 Dustproof Splash Design Be free and enjoy your self, and easily deal with moisture, sweat and light rain. ● Reset Reconfiguration If you accidentally lose a headset, even if you encounter another one that is not the original one, press the box for more than 10 seconds until the red light flashes to reset, then you have a bunch of FlyPods. The Honor FlyPods has a similar design to the Apple AirPods and GearVita provides three color for you to choose from: https://gearvita.com/huawei-honor-fl...s-headset.html You may like: cheap xiaomi mi pad 4 plus 4g cheap qcy q26 pro mini wireless bluetooth headset ![]()
