Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Peticija za povratak CP-a
Naletio sam na techpowerup-u na ovo... It's time to boycott purchases of ATi products until the old control panel is brought back. We want the option of the old control panel back. I am an outraged customer of a Sapphire ATI Radeon 9500 Pro. The last set of drivers to support the old (good) control panel has disappeared in Catalyst drivers 5.12 and 5.13 and you are forced to use the CATALYST .net Control Panel. Bring back the old control panel. Catalyst 5.11 drivers were the last to be bundled with the old control panel. At least with 5.11, there was an option between the old control panel and the new CATALYST .net control panel. The new Catalyst Control Center, is 1. Slow 2. Memory hogging 3. Unresponsive 4. Crash prone 5. Requires the Microsoft .net Framework which is a 23.1MB download from microsoft 6. Takes longer to download than the old control panel. 7. Loads unneccary processes to your system (CLI.exe) which can't be disabled anywhere in the new Control Panel, no for reason at all CLI.exe is loaded twice. 8. Killing CLI.exe process, the new Control Panel does not load at all, no error message or anything. 9. CLI.exe required by the new Control Panel, This increases boot time, and memory usage while it is not in use. Signing this petition is telling ATi to cut the crap and give us the old control panel back. I was considering upgrading my graphics card, and ATi has forced my hand to go to Nvidia unless of course the old control back comes back. Sincerely, The Undersigned Više: http://www.petitiononline.com/ctrlpanl/petition.html |
Caught Somewhere In Time
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
ah nije da da sjajan ali nakon kaj sam ga koristio mjesec dva nije toliki problem uostalom vjerojatno svi imaju još nekaj instalirano tipa att pa se već snađeš |
#4 | |
Lokacija: Kutina
Postovi: 1,208
Postovi: 18,819
I ja dižem ruku. ![]()
#7 | |
dr. sc. tech. dipl. ing.
Lokacija: Rijeka-Opatija
Postovi: 3,164
Nije to dobro. CCC je ogroman u usporedbi sa CP. IMHO, bolje bi bilo da tu razliku u velicini iskoriste za bolje specificne optimizacije u driverima. I sad je nVidia pocela radit sve gore i gore drivere, jos samo fali da i ATi krene istim putem.. sta cu onda kupit sljedece? S3? ![]() ![]()
Pouzdan i pošten trgovac! (ima još puno novijih primjera, nisam ni pratio jel me još tko stavljao u temu.. slobodno pretražite novije postove na temi) StarCitizen refferal code: |
#8 | |
Postovi: 1,606
za mijenjanje opcija koristim ikonu u trayu tako da CCC uopće ne "palim"... dva CLI-ja, tj. tri, mi u idleu zauzimaju 7MB, to im mogu oprostiti ![]() a što se tiče podizanja Windowsa, nisam primijetio da se boot time povećao :confused: edit: 3 CLI-ja max 15MB... ![]() ![]() Zadnje izmijenjeno od: Mailman. 27.12.2005. u 12:34. |
#9 | |
Propali Amigaš
Lokacija: Nin
Postovi: 6,996
