Staro 23.10.2018., 22:49   #4021
Strider
Nuclear Experiment
Strider's Avatar
Datum registracije: Aug 2009
Postovi: 650
Imam taj 3gb model i potvrdujem ima 0db opciju
For everything you gain,
You lose something else
Strider je offline   Reply With Quote
Staro 23.10.2018., 23:05   #4022
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,717
Autor Strider Pregled postova
Hvala!
Staro 23.10.2018., 23:56   #4023
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Neznam jel bilo ali:
Nvidia adds GDDR5X to its popular GTX 1060 line
Updejtana je i sluzbena stranica : https://www.nvidia.com/en-us/geforce...ce00c60a18050d
Najzanimljivije je ovo :
"GDDR5 and GDDR5X are not pin compatible, despite the similar names. GDDR5 comes in a 170-ball BGA format, while GDDR5X uses 190-ball BGA. There are other differences as well, like quad-data-rate vs. double-data-rate, and prior to this point it was assumed that only the GP104 and GP102 GPUs from Nvidia had the ability to interface with GDDR5X. That leaves two possibilities. First, Nvidia may have simply neglected to mention the option for using GDDR5X in the past on the GTX 1060 line. Maybe the functionality was always present, and it just wasn't used due to the higher cost and marginal gains. The second option is that Nvidia is using harvested GP104 chips—larger GPUs that couldn't pass the cores/clockspeed/interface requirements for a GTX 1070, but that will work if enough elements are disabled."
Staro 24.10.2018., 01:13   #4024
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,778
Mislim da je vec poznato da se radi o GP104 cipovima, naravno sa disejblanim cuda jezgrama. Ocito imaju velike zalihe pa se pokusavaju rijesiti. Na krivi nacin ako mene pitate, umjesto da spuste cijene (duh) oni "uvaljuju" polufunkcionalni cip iz gtx1080/1070/1070ti u 1060 koja ionako nije memory-restrained, samo da bi se rijesili zaliha.. Neki revieweri spominju mala poboljsanja performansi (unutar 5%), no nista wow... Dobro je jedino sto je cijena ostala ista no treba vidit kakva ce biti kad vendori izbace svoje verzije.
Staro 26.10.2018., 09:02   #4025
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,939
Okee... ja se ne igram pa ne znam ali sastavio konfu i pokrenio Sniper Elite 4, dok
sam se snasao ubili me 3 puta i dok sam naso di se sakrit cujem nesto zvizdi, skvici iz kucista ?
Izadjem iz igrice - mrtva tisina a 5 ventilatora u kucistu. Udjem opet i opet cijuce nesto... posumnjao na napajanje a novo...
izredam jos 3 napajanja na konfi u rasponu 500-750W i sve isto, guram nos u kuciste i hebalo misa iz grafe dolazi zvuk !
Tam negdje u zadnjem djelu malo dalje od konektora za napajanje grafe.
Eh sad, dam ja klincu da igra i pitam ga jel cuje sta ? Gleda me bljedo koda sam mu reko daj 100kn ma ni gleda u mene
neg trci po ekranu... ne cuje on nist jer je ceko 2 dana da isproba GTX 1080 Ti
Naso sam na netu taj neki Noise ali trebam li se brinuti ? Jel to spada pod garanciju kod Gigabyta i dali je to uopce neki problem osim sto se cuje ?
Decko di komp ide nece sigurno to cut jer bu nabio slusalice ali ono... malo mi glumpavo, ja bi izludil da to stalno cujem pa makar se i igrao
Sad citam i da 1070 i jos podosta grafi pati od toga, daklen sto se tice hw djela znaci da je to OK ?
trebaš seedbox?
Staro 26.10.2018., 09:14   #4026
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Ako je coil whine, upali vsync i nestane. Takoder ce se smanjiti ili nestati kod zahtjevnih igrica di su frejmovi blizu refresh ratea monitora. I moja ima kad u vice city iskljucim vsync i dobijem 5200 frejmova
Staro 26.10.2018., 12:58   #4027
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Uglavnom nije do tebe i/ili kvara, nego do grafe. Dali se i kako to reklamira nebih znao, neki kažu ne, neki da. Samo reci liku da mu gpu ima coil whine, što nije rijetkost, pogotovo kod jačih gpu
Staro 26.10.2018., 14:59   #4028
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Datum registracije: Sep 2012
Lokacija: 00001
Postovi: 2,536
to je feature :s
Sent from my Redmi 3S using Tapatalk
Staro 26.10.2018., 16:29   #4029
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,939
Autor xulos Pregled postova
Uf.. ko grom ali u driverima sam stavio na ON tako da sve igrice po difoltu ne pisce.
E sad, on ima Benq monitor 240Hz sto bi znacilo da ako je u driverima v-sync na ON po difoltu on ce uvjek imati maximalno do 240 fps-a ? U globalu nece mu padati broj fps-a radi tog synca ali nema preko 240, jel tak ?
Ako je tako pa to je onda super... jer grafa se ne cuje uopce ili ventilatori stoje a i kad vrte ne cuje se to nist... temp oko 48/50c u loadu.
trebaš seedbox?
Staro 26.10.2018., 19:57   #4030
tun3
tun3's Avatar
Datum registracije: Oct 2018
Lokacija: Matulji
Postovi: 357
...dok sam naso di se sakrit cujem nesto zvizdi, skvici iz kucista ?
Dakle danas mi je došla inno3D 1080ti... ja sam dosad samo slušao o coil whineu, evo sad ga imam čast imati u svom kućistu
tun3 je offline   Reply With Quote
Staro 26.10.2018., 20:13   #4031
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,566
welcome to the club. he he. nakon nekog vremena samo odlucis ignorirat lol.
geronimo_2 je online   Reply With Quote
Staro 27.10.2018., 03:36   #4032
Manuel Calavera
Postovi: 14,589
Staro 27.10.2018., 04:08   #4033
trpi
kucista orijentirana tisini (izolacija, zatvorenost, primjeri poput serija fractal define-a ili ms black widow) primjetno pomazu minimiziranju cujnosti coil whinea.
Staro 27.10.2018., 08:11   #4034
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,939
Sto se tice coil whinea sa grafickih do sada nisam bio upoznat sa tim niti sam imao prilike cuti, nesto slicno znao sam cuti u pojedinim
napajanjima ako sam recimo encodirao nesto sa procom na 100% ali ovo vise "grebe" dok je iz napajanja zvuk vise potih ali piskutaviji kada se ono cuje.
E sad, nisam ja imao mira pa jos 2 napajanja probao, pa dvi cabl sa feritnim jezgrama, display port itd..
1. Display port ili hdmi cabl - nema razlike.
2. Goli dvi bez ferita - isto.
3. Dvi sa feritom 25% se sigurno manje cuje.
Sa 4 napajanja zvuk dolazi sa graficke i ujedno se cuje i u napajanju ! Dakle oboje proizvode taj zvuk.
S jednim napajanjem zvuka gotovo nema tj. tu je on ali je tako tiho da zbilja moras gurnit uho na napajanje ili graficku.
V-sync rijesava to ali recimo u FC3 i dalje se cuje sa ona 4 napajanja ali vrlo, vrlo tiho ! COD-ovi sve ok sa V-sync, Hitman nesto mislim da je igra, isto ok sa V-sync.
Ono sto je najzanimljivije u svemu tome je to da Gigabyte preporuca 600W napajanje za 1080 ti 11G pa sam sa takvima i testirao.
Fractal, Chieftec, Colermaster x 2 i svi 650w osim Cf koji je 700W.
Nijedan od njih se ne izdvaja, bez V-sync brisi kuci - propalo.
Neda mi vrag mira i reko idem na kratko iako je svega 500W probat jos ovo koje imam:
https://www.pcpowerandcooling.com/wp...MK3S500-R3.pdf
https://www.pcpowerandcooling.com/product/mkiii-500w/
Skoro mrtva tisina al ono... skoro i kada se zaklopi kuciste cujem samo po noci !!
Sa graficke ne dolazi apsolutno nikakav zvuk, samo jedva iz njega, naravno V-sync iskljucen !!
E sad, zasto je to tako ? Zasto se to jeftinije i slabije napajanje 90% izbori sa ovim nepopularnim ficurom a
ova jaca a bogme i skuplja napajanja ne ? Ocito je da postoje napajanja koja su otporna na ovaj feature ili bar dobrano ga priguse itd...
Jos uvjek nemam info dali ce se to cuti ako je monitor 240Hz i ako fps-i ne prelaze 240, navecer su znati, u globalu ako os hebacku graficku moras uzeti i hebacki monitor i sve na ultra da ne predju fps-i frekvenciju osvjezavanja.
trebaš seedbox?
Staro 27.10.2018., 19:38   #4035
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Taj stari odron je kvalitetniji od Fractala i Chifteca, a vjerojatno i od ta dva Kuleršmajsera
Stara Sissa kuca unutra braco, a ti noviji isprdci šta si ih naveja vjerojatno neće doživit toliku starost ispravni
FYI
http://www.realhardtechx.com/index_a...s/Page1418.htm
Pomelo mi sig -.-
Staro 27.10.2018., 21:27   #4036
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,939
Autor Drvoje Pregled postova
Lako moguce, uzeo ga 2017 godine tu na forumu za 250kn a cisto da imam za po kuci kada testiram konfe jer je polumodularno i ono...
sta trebam to prikopcam. Nevjerojatno mi je da se to napajanje pokazalo kao najbolje za 1080 ti koja pisci, bice da je unutra neka opaka filtracija struje
trebaš seedbox?
Staro 30.10.2018., 01:42   #4037
Manuel Calavera
Postovi: 14,589
Staro 30.10.2018., 08:46   #4038
Tajl3r
Dobro je sve.
Tajl3r's Avatar
Lokacija: 00001
Postovi: 2,536
Kriva tema
Zadnje izmijenjeno od: Tajl3r. 30.10.2018. u 08:52.
Staro 04.11.2018., 22:06   #4039
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,279
Koji softver da utisam asusu gtx 1060 turbo u windowsima...imam dojam da vent radi 100% cijelo vrijeme....asus program uz graficku i nije nesto( kad odem silent mod) i dalje je glasna
Staro 04.11.2018., 22:10   #4040
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,370
Autor microsoft66 Pregled postova
MSI Afterburn i tamo stavis custom fan krivulju/profil kako zelis da na kojoj temperaturi dize kolko okretaja.
Staro 04.11.2018., 22:29   #4041
trpi
msi afterburner, pokrenes program furmark (przi graficku na max) i rucno fiksiras u msi afterburneru ventilator na odredenu vrijednost odnosno nastelavas da dobijes podatak koliko je okretaja ventilatora potrebno da graficku drzi na recimo 75c (ili neku tebi prihvatljivu temperaturu) zatim u settingsima napravis krivulju od 60c sa minimalnim okretajima do 75c sa gornjim podatkom
Staro 04.11.2018., 22:52   #4042
microsoft66
Lokacija: VK
Postovi: 1,279
Tnx probat.cu
Staro 11.11.2018., 23:27   #4043
slavonac90
slavonac90's Avatar
Postovi: 1,537
Što kažete na Gainward gtx 1060 6gb Phoenix GS? imam u planu svoju rx 580 4gb zamjeniti tom, navikao na zeleni tabor
slavonac90 je offline   Reply With Quote
Staro 11.11.2018., 23:44   #4044
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,708
Imaš FreeSync monitor i RX 580...
Ima barem više garancije? Ako ne, nikako ne bih mijenjao.
Staro 12.11.2018., 00:18   #4045
slavonac90
slavonac90's Avatar
Postovi: 1,537
Ma slaba mi ova od 4 gb za FHD postaje (u FH 4 se pati, a vidim video memorija na knap), pa bi na zeru jače išao,Freesync mi nije bitan, nvidia manje troši, manje se grije i sve. Garanciju ima još nešto manje od godinu dana.
Staro 12.11.2018., 10:25   #4046
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,186
Autor slavonac90 Pregled postova
Forza Horizon 4? Ne čini mi se da je 4GB VRAM-a tu problem.
https://www.techspot.com/review/1716...pu-benchmarks/
Neš' drugo mi tu ne štima.
Jedino ako FH4 ne znači neš drugo, onda my bad
Staro 12.11.2018., 10:45   #4047
slavonac90
slavonac90's Avatar
Postovi: 1,537
Jep Forza Horizon je u pitanju, ali vjeruj mi taj benchmark ne znači apsolutno ništa,jer sam na laptopu sa gtx 1060 imao u prosjeku 10 fps-a više nego nego sa ovom konfom iz potpisa. S tim da sam u laptopu imao i5 7300hq, a ovaj ryzen je jači od njega tako da nema što drugo biti u pitanju.
Ali opet kako god bilo gtx 1060 6gb je u svakom slučaju jača od rx 580 4gb, ova od 4 gb je u rangu gtx 1060 sa 3gb V-ram, dok su verzija od 6 gb i rx 580 8 gb u istom rangu.
Doduše imam priliku uzeti umjesto ove svoje, ili već navedenu gtx 1060 6gb, ili Asus rx 580 8 gb(ali vidim da se neda clockati skoro pa ništa, a poigrao bih se i s tim malo), tako da je odluka opet pala na zeleni tabor.A gledam još je hladnija i manje troši.Ispravite me ako griješim, dok još nisam definitivno odlučio
Staro 12.11.2018., 14:15   #4048
Gigi1
Postovi: 2,138
maknut se sa free synca i jos na slabiju grafu u FH4 i nije bas neki potez, amd osjetno bolje radi u FH4 od nvidijinih pandana istog ranga...čru dx12 naslov
tebe nesto drugo muci, ili u settingsima ili eventualno ako si kupio rabljenu grafu koja je bios moddana
Zadnje izmijenjeno od: Gigi1. 12.11.2018. u 14:20.
Staro 12.11.2018., 14:23   #4049
slavonac90
slavonac90's Avatar
Postovi: 1,537
A meni ne radi bas fh 4 sa radeonkom, bolje mi je radila na laptopu sa gtx 1060 pa si kontam da je zbog nedostatka vrama, tako je i pala odluka za zamjenu. Imam priliku uzeti ili gtx 1060 ili asusovu rx 580 8 gb(ne strix) za jednaku razliku u cijeni, ali gledam da nije ta asusica bas neka, pa zato pitam za gtx 1060. Ili da bolje uzmem rx asusovu?
Staro 12.11.2018., 14:27   #4050
Gigi1
Postovi: 2,138
jesi probao reinstalirati drivere, onak kak spada, ulaskom u safe mod pa koristenje DDU?
da li je grafa koju sad koristis rudarila i ima moddan bios?
