Staro 15.10.2018., 13:03   #31
chumaman
chumaman's Avatar
Lokacija: na brdu daleko
Postovi: 99
Autor SlavoS Pregled postova
Zašto AO kamenje nije adekvatno ?
Koja je " stvar u Karbidima " ?
vanadium carbide tear-out during sharpening
Vanadium & chromium carbides are actually first formed in the manufacture of the alloy, before it's ever heat-treated. Subsequent heat treat can change their properties somewhat (size, hardness to some small degree), but they exist in the steel from the time of it's manufacture, formed at temperatures up around 1000°C.
Different manufacturing processes, like the powder metal (PM) process, can make a difference in how large they get and how uniformly distributed ('desegregated') they are in the manufactured steel. PM-process steels produce carbides that are typically pretty small, usually 2 - 4 microns or smaller, and they're more uniformly distributed throughout the steel, which helps it remain strong and tough overall. Non-PM processes would tend to allow the carbides to cluster together in large masses, the effect called 'carbide segregation', during manufacture. In such cases, the carbides may end up being 50 microns or larger in size. So, they'd still be there, but at potentially much larger size, which makes grinding such steels more difficult, and also can negatively alter steel properties such as toughness (resistance to breakage). As an example, the difference in ease of grinding or sharpening can be seen in comparing conventionally-manufactured 'ingot' D2 with it's huge chromium carbides (making it harder to grind easily), versus CPM-D2 and it's much smaller chromium carbides (easier grinding/machining), made by the powder-metal process.
konspirativna je tema zašto - zato
chumaman je offline   Reply With Quote
Staro 15.10.2018., 17:04   #32
SlavoS
Datum registracije: May 2003
Postovi: 1,116
[QUOTE=chumaman;3238322]Fala momcima...osobno ne padam na Japansko kamenje, dotično ne radi na
praškastim čelicima a bogme ni D2....karbidi i abrazivi
Opet....sve zavisi šta režeš s čime i koliko..
možda malo gladiti finom keramikom ali to je za zelenjavu
A koji je trik s " praškastim čelicima " da ono gore spomenuto ne radi ?
SS
SlavoS je offline   Reply With Quote
Staro 16.10.2018., 09:11   #33
chumaman
chumaman's Avatar
Postovi: 99
A možda su u šumi
Staro 29.01.2021., 12:22   #34
Did58
Did58's Avatar
Datum registracije: Mar 2017
Postovi: 74
Za dobro oštrenje može poslužiti i dno keramičkog pijata (tanjura), šalice i sl. bitno da je od keramike.
Okreni pijat ili šalicu naopako (na krpu da ne kliže), malo vode i brusi diko.
Did58 je offline   Reply With Quote
Staro 15.12.2022., 12:28   #35
spiderhr
spiderhr's Avatar
Datum registracije: Jul 2021
Lokacija: Sesvete
Postovi: 1,272
Noževi
Namjeravan kupiti nož široki.
Kaj mislite o ovima iz Kauflanda?
P.S. nisam našao posebnu temu (osim za oštrač) pa ako admin misli da nije potrebna tema neka spoji sa nekom postojećom.
Edit: Eto to je tako kada samo pročitaš prvi dio naslova
Zadnje izmijenjeno od: spiderhr. 15.12.2022. u 13:41.
Staro 15.12.2022., 12:35   #36
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Hamm je online   Reply With Quote
Staro 15.12.2022., 13:20   #37
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,272
Autor Hamm Pregled postova
Trenutno mi se ne uklapa u budžet nažalost. Imam jedan veći izdatak za platit uskoro.
A i imam neki set sa stalkom doma ali bez ovak širokog noža.
Plus imam još jedan stalak zapakiran, odnekuda doletio prije godinu dvije.
Staro 15.12.2022., 13:31   #38
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor spiderhr Pregled postova
Dodao sam naknadno u naziv teme "i noževi". Tak da bude kompletna tema.
Ako je samo jedan nož onda https://mehrzer.hr/proizvod/noz-santoku-17cm/
Da je malo više novaca ali noževi su kvalitetni. Za ove iz kauflanda nemam pojma kakvi su.
Staro 15.12.2022., 13:43   #39
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,272
A-ha... Kad si premjestio temu bio sam uvjeren da je pisao i noževi ali da sam pročitao površno.
Onaj široki kakav inače dolazi imam ali nije to to, htio bih baš ovaj još širi, santoku. Tako da mi treba samo jedan
Staro 15.12.2022., 14:27   #40
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,737
Otkad kupio santoku, set od pet komada Victorinoxa skuplja prašinu godinama.
Netreba dati više od 150kn za dobar nož.
Staro 15.12.2022., 14:31   #41
Ziiky
Ziiky's Avatar
Postovi: 2,883
Netko je u nekoj od tema svaštara nedavno bio stavio link na set kuhinjskih dick-ovih noževa?!
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 15.12.2022., 14:44   #42
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Bili su na akciji u kauflandu prije koji tjedan.
Staro 15.12.2022., 15:24   #43
spiderhr
spiderhr's Avatar
Lokacija: Sesvete
Postovi: 1,272
Evo ja bum išel kupit ovaj jeftin za prvu ruku pa ću vidjeti, koliko meni treba služil bu svrsi.
Staro 16.12.2022., 11:19   #44
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,042
Autor Ziiky Pregled postova
Ja. Imam Dick noževe doma i zakon su.
Oštrim na kamenu 1000/3000 jednom godišnje, redovito ih samo prođem na štrajher i žena ih u perilicu suđa uredno ubacuje. I nije im ni vraga.
https://www.allmall.hr/dick-85455000...66813/product/
Staro 16.12.2022., 13:43   #45
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,737
Koji kamen?
Moram se emancipirat od ovog čuda koje simultano oštri i otupljuje
Staro 16.12.2022., 17:30   #46
Roberto
Roberto's Avatar
Postovi: 2,673
Nakopovao sam se raznih, i podosta skupih noževa, santoku, chef's knife i drugih.
Svi stoje sa strane, rijetko ih koristim, a koristim u 90% slučajeva mož za meso Tramontina, koštao tričavih 40kn u šumoopskrbi pred desetak godina (moguće i više, vrijeme leti)
Ovaj:
https://kupialat.ba/proizvodi/vrt-i-...cm-tramontina/
Staro 16.12.2022., 18:14   #47
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,042
Autor kopija Pregled postova
Koji kamen?
Točno onaj iz yubito kanala ključ13
https://centar-alata.hr/japanski-kam...0x60x30mm.html
Staro 19.12.2022., 16:14   #48
pizdun
d(O.o)b
Postovi: 223
Koji kamen?
ako pitas za grit po meni najbolja zlatna sredina 1000
ako ides na kombinaciju onda 400/1000 ako imas tupe nozeve doma ili 1000/3000 ako imas malo ostrije pa hoces samo fino doraditi ostrinu
iznad 3000 za svakodnevnu upotrebu je nepotrebno imho jer se ta ostrina zatupi nakon prvih par koristenja noza
ako pitas za brand onda
low range amazon noname kineski
mid range king
high range shapton
pizdun je offline   Reply With Quote
Staro 19.12.2022., 17:17   #49
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,737
hvala koglega pizdun,
jednom godišnje odnesem nož majstoru na samurajsko oštrenje pa bi uzeo zlatnu sredinu za po doma tokom godine.
Možeš nabacit koji link za hr/zg dućan koji drži te kingove?
Staro 19.12.2022., 21:44   #50
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,197
Ako netko i dalje traži dobre noževe, mogu ove preporučiti.
https://barecookware.com
Trebali su mi noževi i naletio sam na njihovu Kickstarter kampanju. Svih 7 komada je bilo za 150 eura, što je bila super cijena za ono što je bilo pokazano.
Evo, skoro godinu dana kasnije, besprijekorni su. Vrijede novaca.
CPU: Intel Core i7 8809G
MBO: Intel NUC8i7HVK
RAM: 2x16GB Crucial DDR4 2400
GPU: Radeon™ RX Vega M GH
LCD: BENQ PD3200Q
OS: Windows 10 Pro x64
Staro 20.12.2022., 13:42   #51
conan
conan's Avatar
Lokacija: Bjelovar
Postovi: 116
Autor 1v@n Pregled postova
Zanimljivi su...
Jesi ih brusio i s čime?
From tapatalk with love
conan je offline   Reply With Quote
Staro 20.12.2022., 15:43   #52
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,197
Zašto bi ih brusio?
Nema još naznake da bi mogli otupiti, a da su otupili unutar godine dana, vjerojatno bi ih vratio.
LCD: BENQ PD3200Q
Zadnje izmijenjeno od: 1v@n. 20.12.2022. u 15:49.
Staro 20.12.2022., 15:57   #53
c-shadow
c-shadow's Avatar
Postovi: 3,568
Ak nož ne moraš brusiti nakon godine dana onda ga niti ne koristiš
Staro 20.12.2022., 17:56   #54
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,197
Nisam chef u restoranu ili mesar, pa da ga baš toliko koristim
Od ovih 7, najčešće koristim 3 komada. Još nisam skužio da režu slabije nego prvog dana.
Imao sam prije nekakva sranja od noževa (ovdje je lakše nabaviti teške droge nego nož, a dobar nož je misija nemoguće) i uzeo sam ovo za oštrenje
https://www.thekitchn.com/anysharp-k...eview-23325396
Bio sam skeptičan zbog cijene, ali stvar je odlična. Svaka 2-3 tjedna sam trebao provući noževe kroz to jer su stvarno bili loši, ali već nakon dva prolaska ih je vratilo u život.
Najčešće režem baš ovakve male paradajze kao u članku i na njima odmah vidim kad je vrijeme za oštrenje
LCD: BENQ PD3200Q
Staro 20.12.2022., 17:57   #55
celavicro
Ja imam yaxell
Zen santoku,utility i chef knife
I jos jedan posebni utility knife super gou ypsilon 193 layer damascus
Staro 20.12.2022., 18:06   #56
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,586
Zanimljivo. Išao baš pogledat i neke recenzije. Kolko vidim hvale ih.
Čak je čovjek i godinu nakon napravio osvrt i kaže da su i dalje oštri i da ih također nije oštrio u međuvremenu. Sve u svemu hitio si mi bubu u uho
Autor celavicro Pregled postova
Ja imam yaxell
Uff, ovo je bomba. A s takvim bi mi došlo žao išta radit, trančirat pile ili nešto slično
Staro 20.12.2022., 18:55   #57
Getriba94
Getriba94's Avatar
Datum registracije: Jun 2016
Postovi: 1,052
Zašto bi ih brusio?
Jedini noz koji ne tupi je onaj koji se ne koristi.
Sent from my motorola edge 20 pro using Tapatalk
Staro 20.12.2022., 19:06   #58
GRdiamond9A
GRdiamond9A's Avatar
Datum registracije: May 2020
Postovi: 60
Pozdrav,
Koji santoku do 200-300 kuna preporučate
GRdiamond9A je offline   Reply With Quote
Staro 20.12.2022., 19:13   #59
celavicro
Autor Juice Pregled postova
Ma nije..
Imam ja jedan set ovih viska pa ako kome treba
Staro 20.12.2022., 19:58   #60
c-shadow
c-shadow's Avatar
Postovi: 3,568
Ajoj, nemoj time brusiti noževe ako ti je stalo do njih.
Takav alat ti samo napravi sitne zubiće po oštrici. Druga je stvar da li ti to vidiš ili ne.
