#4322 |
Datum registracije: Jul 2017
Postovi: 10
Evo kako ste mi predložili da ne kuoujem patriot za ryzen. naišao sam na https://www.instar-informatika.hr/me...bk-16/product/ Sad vidim da podržava intel xmp 2.0. Koja je svrha toga, čemu služi... |
#4323 |
Postovi: 14,589
Preskupo za takav ram. Ako uzimaš 16gb best buy ti je ovo: https://www.nabava.net/search.php?q=...9+DDR4+3000MHz daleko najbolja cijena, a ljudi nemaju problema sa 2933/3000mhz ni na raznim pločama AM4 platforme |
#4324 |
Postovi: 10
I evo ss cijelog builda. Kupujem sve na firmu. RAM - GSkill Aegis 16GB (2x8) DDR4 3000MHz https://imgur.com/a/IqVFCYd |
#4325 |
Datum registracije: Mar 2011
Postovi: 2,707
https://www.instar-informatika.hr/gr...8G_OC/product/ Uzmi radije ovo, imaš FreeSync na monitoru i uštediš 250kn ![]() |
#4327 |
Postovi: 10
Sve u instaru jer kupujem na firmu pa mi se neda jrbavat po razlicitim shopovima. Onda bolje da uzmem ovu rx 580 koja mi je preporucena |
#4329 |
Datum registracije: Feb 2018
Postovi: 26
1 * AMD Ryzen 5 1600, 6C/12T 3,4GHz, 19MB, AM4 Sifra: amd-r5-1600 - 1.249,00 Kn 1 * Asrock AMD AM4 Socket B350 Chipset (ATX) MB Sifra: ASR-AB350M-PRO4 - 628,00 Kn 1 * Corsair 1X8GB DDR4 2400 C14 LP Sifra: COR-CMK8GX4M1A24C14R - 751,00 Kn 1 * MSI Video Card AMD Radeon RX 580 GDDR5 8GB/256bit, 1366/8000MHz, PCI-E 3.0 x16, 2xDP, 2xHDMI, DVI-D, ARMOR 2X Cooler(Double Slot), Backplate, Retail Sifra: RX_580_ARMOR_8G_OC - 2.314,00 Kn 1 * Fortron napajanje Hyper 500W Sifra: fsp-nap-hyp-500 - 399,00 Kn Ukupno: 6.037,00 Kn Sent from my Redmi 4X using Tapatalk |
#4333 |
Postovi: 2,707
CPU AMD RYZEN 5-2600 (3.4GHZ DO 3.9GHZ, 19MB (3MB+16MB), C/T: 6/12, AM4, COOLER, 65W), 36MJ MB Gigabyte B450M DS3H, AM4, micro ATX, 4x DDR4, AMD B450, S3 4x, DVI-D, HDMI, 36mj DDR4 8GB (2x4GB), DDR4 2666, CL15, DIMM 288-pin, G.Skill Ripjaws 4 F4-2666C15D-8GVR, 36mj VGA XFX RX-580P8DFD6, AMD RX580, 8GB 256-bit GDDR5, do 1386MHz, DP 3x, DVI-D, HDMI, 36mj SSD Crucial 250GB, MX500, CT250MX500SSD1, 2.5", 7mm, SATA3, 36mj Jedinica napajanja Corsair 550W CX 550W, ATX, 120mm, 80 plus Bronze, 36mj 5.944,24KN |
#4334 |
Datum registracije: May 2005
Lokacija: Ankum
Postovi: 161
Poz, trebam preporuku za gaming konfiguraciju i dok ne igram da vrti BOINC... do 7500kna, s time da to kupujem u njemackoj, mediamarkt/euronic il nesto trece/cetvrto trebam sve osim tastature i misa i mislim da mi HDD ne treba, jer ne planiram neku veliku pohranu podataka monitor 24" kuciste nista fanci fala |
#4335 |
Datum registracije: May 2016
Postovi: 3
Trebam konfiguraciju za gaming do 7000 kn. Nije frka ako je i koja stoja preko. Trebao bi konfiguraciju sa jednim SSD-om i HDD-om. NE TREBA monitor, miš, tipkovnica. Hvala unaprijed. |
#4336 |
MiningMod
Postovi: 8,715
1 * AMD CPU Desktop Ryzen 5 6C/12T 2600 (3.9GHz,19MB,65W,AM4) box, with Wraith Stealth cooler Sifra: YD2600BBAFBOX - 1.549,00 Kn 1 * LC-Power Cosmo Cool LC-CC-120, hladnjak za proces. Sifra: lcp-hlad-lc-cc-120 - 199,00 Kn 1 * MSI Main Board Desktop B350 (SAM4, 4xDDR4, 2xPCI-Ex16, 2xPCI-Ex1, 2xPCI, USB3.1, USB2.0 ,4xSATA III, M.2, Raid, VGA, DVI-D, HDMI, GLAN) ATX Retail Sifra: B350_TOMAHAWK - 671,00 Kn 1 * SSD Adata 120GB SU650 SATA 3D Nand Sifra: 0140880 - 199,00 Kn 1 * Western Digital HDD, 1TB, 7200rpm, Caviar Blue Sifra: WDC-WD10EZEX - 365,00 Kn 1 * Inno3D GeForce GTX 1070 X2 V4 Sifra: INO-N1070-4SDV-P5DS - 3.399,00 Kn 1 * Napajanje 550W, ANTEC True Power Classic TP-550C, ATX, 120mm vent. Sifra: 052.703.022- - 669,00 Kn 1 * Kućište Rampage Everest 66W Mesh Black Sifra: 123.000.161 - 329,00 Kn Ukupno: 7.380,00 Kn -2% = cca 7.230,00 Kn |
#4337 |
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
FRipper, gdje si to nasao ? |
#4339 |
Ape
Datum registracije: Jan 2012
Postovi: 157
Pozdrav, trebam preporuku/drugo misljenje za konfu bez grafičke i SSD/HDD-a jer to već imam. Ostalo kupujem. GPU koji imam je GeForce GTX 1060 Gaming X 6GB Mislio sam ovako: 1. Kućište Midi Fractal Design Define R5, bez napajanja, Black Pearl - 1.030,40 kn 2. Matična ploča Asus TUF B450M-PLUS GAMING - 848,00 kn 3. Procesor AMD Desktop Ryzen 5 6C/12T 2600X (4.25GHz,19MB,95W,AM4) box with Wraith Spire cooler - 1.933,86 kn 4. Napajanje 750W, CHIEFTEC A-90 Series, GDP-750C, modularno, 80+ Gold - 617,60 kn 5. Memorija Corsair 16 GB Kit (2x8 GB) DDR4 3200 MHz, Vengeance Black - 1.579,74 kn Ukupno: 6.010,00 kn Dali ovo gore valja i ako ne što ne? Mogu bolje za isto novaca? Ako treba neki cooler i dodatni ventilatori ako može preporuka i za to. Ovo je sve u jednom dućanu i uzimam na rate(diners), tako da može i preporuka oko ducana ako znate da je isplativije sa karticama.
Apekop
#4340 |
Postovi: 2,707
Može dosta bolje od toga. Ploča - slabo hlađenje i VRM Napajanje - ima boljih za slične novce s više garancije Procesor i RAM su preskupi, pa i kućište. Matična ploča Asus Prime X370 Pro, s. AM4, 90MB0TD0-M0EAY0 Procesor AMD Ryzen 5 1600X BOX, 3.6GHz 16Mb, AM4 DDR4 16GB (2x8GB) PC4-24000 3000MHz CL15 Corsair Vengeance LPX black, CMK16GX4M2B3000C15, CMK16GX4M2L3000C15 Napajanje Corsair TX650M 80PLUS Gold 650W ATX 2.4 (CP-9020132), TX-M Series modular Arctic Freezer 33, Socket: 1150, 1151, 1155, 1156, 2011, 2011-3, 2066, AM4, ACFRE00028A Ukupno: ~ 5000kn bez kućišta Zadnje izmijenjeno od: Smartic. 02.10.2018. u 14:49. |
#4341 |
Datum registracije: Sep 2017
Postovi: 1,433
Gdje god da to kupujes ne kupuj tamo jer je razlikapo 200kn izmedu komponenti... Evga 750w gold plus 700kn, proc isti 1700kn, odi na pcpartpicker i slozi tamo komp plus citaj usput sta ljudi pisu o komponentama... Zadnje izmijenjeno od: axo. 02.10.2018. u 14:52. |
#4342 | ||
Ape
Postovi: 157
A sto se tice kucista, nisam nigdje nasao bas nesto puno jeftinije, barem kad se kupuje na rate. Tako da i kad bi uzeo ovo gore plus kuciste ista bi bila cijena kao i moja. Citiraj:
Al nisam nasao nigdje jeftinije kako ti kazes, usporedivao sam cijenu istih ovih gore stvari u 6 dućana i ovo je bilo najjeftinije. Jedino ako si ti gledao cijenu za keš, ali na kartice ja nisam nasao da mogu proc bolje za po 200kn po komponenti. Ovaj procesor najjeftiniji sto ja vidim kod nas je 1812kn i to za keš.
Apekop
#4344 |
Postovi: 2,707
#4345 |
Ape
Postovi: 157
Ajmo onda ovak, posto cu inace sam ocito napravit glupost i potrosit previse novaca. Sto mi je najbolje uzet za gaming i po mogućnosti da ne moram mijenjat iduce godine ako uzmemo u obzir da imam SSD i GPU. budzet 6000kn, plaćanje kartica. Znaci potrebno je kučište, matična, procesor, ram, cooler. Kučište ne morate birat ak Vam se neda, samo ostavite neku razumnu cifru za njega. EDIT: mogu ici do 7 ako je ulozeno/dobiveno razumno
Apekop
Zadnje izmijenjeno od: apekop. 02.10.2018. u 17:29. Razlog: dodan EDIT |
#4346 |
Postovi: 2,707
Moja kombinacija ostaje... naravno da gledam na uloženo/dobiveno. Jedino gdje je malo podebljano je ploča na kojoj ćeš moći nadograđivati procesor još dulje vremena. Za kućište, Fortron CMT 330(479kn, cca. 510 na rate). |
#4347 |
Datum registracije: Dec 2012
Postovi: 69
Jel može netko prokomentirati konfiguraciju? Budžet mi je tu negdje, možda još koja stotica gore ako je potrebno. Hvala! 1 * AMD Ryzen 5 1600x 3.6GHz, Sck. AM4 + Hladnjak LC-CC-95 Sifra: YD160XBCAEWOF1 - 1.349,00 Kn 1 * MSI B350 Tomahawk, AM4, DDR4, U3, m.2, ATX Sifra: msi-b350-thawk - 699,00 Kn 1 * XFX Video Card AMD Radeon RX 580 GTS 8GB XXX Ed OC 1366 Mhz GDDR5 8GB 256bit Dynamic 22 Blade fanDP HDMI DVI Sifra: RX-580P8DFD6 - 2.327,00 Kn 1 * Memorija Adata DDR4 8GB 3000MHz XPG GAMMIX D10 Sifra: 0704631 - 619,00 Kn 1 * Fortron napajanje Hexa 85+ 550W, 80+ Bronze, ATX Sifra: fsp-nap-hexa85-550 - 450,00 Kn 1 * Kingston SSD 240GB A400 SATA3 2.5 SSD (7mm height), TBW: 80TB, EAN: 740617261219 Sifra: SA400S37/240G - 349,00 Kn 1 * Toshiba P300 1TB, 64MB, 7200rpm Sifra: to-hdwd110uzsva - 339,00 Kn 1 * Kućište Rampage Everest 66W Mesh Black Sifra: 123.000.161 - 329,00 Kn Ukupno: 6.461,00 Kn |
#4348 | |
Postovi: 1,433
Ja imam phanteks p400s i sve stane unutra. Moja ploča je asus b350 f gaming. |
#4349 | ||
MiningMod
Postovi: 8,715
Sifra: YD2600BBAFBOX - 1.599,00 Kn 1 * MSI B450 Tomahawk, AM4, DDR4, U3, m.2, ATX Sifra: msi-b450-thawk - 869,00 Kn 1 * Hladnjak MSI GAMING Core Frozr L, Intel/AMD + AM4 Sifra: CORE_FROZR_L - 399,00 Kn 1 * Memorija GSkill Aegis 16GB (2x8) DDR4 3000MHz Sifra: F4-3000C16D-16GISB - 1.299,00 Kn 1 * Napajanje Seasonic FOCUS Plus 650 Gold Sifra: 0151480 - 739,00 Kn 1 * Kućište SilentiumPC Pax M70 Pure Black Crno bez napajanja Sifra: 29150651 - 550,00 Kn Ukupno: 6.060,00 Kn -2% popust = 5.940,00 Kn na diners do 36 rata Citiraj:
#4350 | |
Postovi: 14,589
