Postovi: 65
SATA dodatni adapter
neznam da li to može tu ili negdje drugdje ali imam pitanje vezano uz PCIx1 adapter za SATA diskove. uzeo bih ovo: ![]() da li ti adapteri podržavaju botanje sistema u raid soluciji dakle da ova dva diska vidim u windowsima kao jedan te da tako podržan disk bude i botabilan da se sa njega diže sistem. Ovo je kopirano sa stranice: PCI Express SATA 3 Controller Card, 2 Port PCIe SATA III 6GB/s Internal Adapter Converter for Desktop PC Support SSD and HDD w material: metal Colour: Black Support Interface: USB3.0 TO SATA 22PIN Support System: WinXP/Vista/Win7/Win8 32-bit/64-bit LINUX Meets Serial ATA 3.0 specification, backward compatible with SATA2.0 SATA1.0 Compliant with PCI-Express v2.0 specification, backward compatible with PCI-Express v1.0. Supports communication speeds of 6.0 Gbps, 3.0 Gbps, and 1.5 Gbps Support Gen 1i, Gen 1x, Gen 2i, Gen 2m, Gen 2x, and Gen 3i. Supports two SATA Support AHCI1.0 mode and IDE mode Support native command queue (NCQ) Supports FIS based on port multiplier switches or command switches. Hot-swappable and hot-swappable. Compatible with SATA6G, 3G and 1.5G Hard Drives Bus interface PCI-Express x1 slot Extension ports 2 SATA3.0 interfaces System Requirements One available PCI Express X1 slot, supporting PCI-E X2 X4 X8 X16 Operating System: Windows 10/8/7 (32/64 bit) / Vista (32/64 bit) / XP/2003/2008/linux System disk and PCIE to SATA3.0 adapter card connection conditions and solutions: 1, PCIE to SATA3.0 SATA interface mode is AHCI mode, if you want to insert the system disk in our card, the premise is that your system disk installed on the motherboard must be AHCI mode installation, otherwise it can not pass Our card adapter card boot system. 2. If it is determined that the system disk is inserted in the AHCI mode of the SATA interface mounting system on the mainboard, then the hard disk can be directly inserted into our card, and then the mainboard BIOS is set to start the system disk as the first boot. 3, the above two conditions are available, if you still can not start, or repeatedly restart, then the motherboard hard drive interface and our adapter card conflict, the solution is to enter the motherboard BIOS, the motherboard's hard disk interface options set to Disabled, save and restart to boot the system Attention: Don't Support as System |
Postovi: 1,346
Nije RAID podržan, dakle ništa od ovoga što tebi treba.
Dabogda ti Chris Bangle radio facelift. |
Postovi: 65
da li postoji takav adapter sa tom funkcijom jer bih uzeo 2x256GB ssd za sistem i programe, ako uključim raid na ploči spojit če mi sve sata ulaze u jedan veliki disk ili sam u krivu, ispravite me. |
Postovi: 23,622
Ovisi o pojedinoj mobo i pameti > napiši koja precizno + otvori manual pa pročitaj. |
Postovi: 1,346
Postovi: 23,622
Ne pitam za add-on karticu nego za matičnu. |
Postovi: 18,947
Neće, i na najjeftinijem RAID kontroleru možeš birati koji diskovi će biti u polju.
#8 | |
Postovi: 65
Imam plocu gigabite ga 970 am3+ |
Postovi: 23,622
Jel to ova mobo > https://www.gigabyte.com/Motherboard...ming-rev-10#ov Ako je, manual > http://download.gigabyte.eu/FileList...0-gaming_e.pdf Imaš 6 sata portova, ako sam dobro shvatio šta piše u manualu, kada prebaciš u Bios - u Sata kontroler u Raid na Port 4 i 5 (zadnja 2, vidi manual), bi se trebali moći postaviti kao "obični" AHCI za DVD / std. data za hdd. Po tome ti dodatna add-on kartica nebi trebala. Ostaje ti da odlučiš: - hoćeš Raid 0 ili Raid 1 (sigurnost ili brzina, pitaj Google) - hoćeš li UEFI Raid ili Legacy Raid (ovisi koji os dižeš) |
#11 | |
Postovi: 65
Gigabyte GA-970A-DS3P 6 sata konektora i svi zauzeti 4 diska + 2 dvd biče dva ssd-a u polju (operativni sistem i programi) a ostali pojedinačno(storage). dakle SSDi u radi 1, a ostali JBOD tj. samostalno. Zadnje izmijenjeno od: vmzagreb. 29.08.2018. u 19:52. |
Postovi: 23,622
Ok, dodaj add-on sata kontroler karticu, na nju prebaci 1 - 2 hdd i 1 dvd (bude tih kartica sa 2 ili 4 sata porta). Poanta da 1 dvd ostaviš na mobo kontroleru je radi boot - a (os install ili repair). |
Postovi: 65
mislim da bu prvo išlo kloniranje, iovako nebotam sa DVDa več USBa, napravio sam win10 USB boot SD karticu. ako ću uzeti adapter sa 4 onda idu oba DVDa na karticu a dva diska ostaju na MBu, nego kako mi preporučaš RAID1 na 0/1/2/3 ili RAID1 na 4/5, neznam da li onaj prvi uzme sva 4 SATA porta ili samo koje izabereš, kod 4/5 samo su ta dva u RAID polju ovi ostali nisu. jesam dobro razumio, inače ona koju si ti stavio i moja razlika je u boji i tome da ona tvoja ima naziv gaming a ova moja je DS3P. i daj mi objasni koja je razlika između ver.1 i ver.2,1, imam ovu drugu. jel bu ova OK https://www.ebay.com/itm/PCI-e-to-SA...IAAOSw7U9bVaVi Zadnje izmijenjeno od: vmzagreb. 29.08.2018. u 23:10. |
Postovi: 23,622
Po opisu bi odgovarala, kakva je / jeli valja nemam info. Možeš očekivati nešto malo lošiji transfer nego sa on-board kontrolerom. Ne zaboravi inst. drajver, provjeri kod kineza jeli ima za W10. Support za mobo tražiš točno po verziji koju imaš, znači DS3P ver. 2.1. Ovo prvo ćeš morati sam pogađati. Pretpostavljam da nakon ssd - ova u Raidu ostali bi trebali biti vidljivi kao JBOD. Možeš očekivati kakav zaheb ako misliš klonirati jer je prije bio ahci vulgaris a po novom preko Raid polja + drugi (Raid) drajver. |
Postovi: 65
Trenutno kloniram c disk i na 75% sam, kad to odradim odspojit cu dvd jer su mi oni na 4/5 ulazu radi raid polja a onda u nabavku adaptera. brzo to prošlo ali stvaranje raid polja je sranje, ima tko da mi pomogne da me vuče za rukicu ili ušence to tako to tako jer očigledno nešto ide krivo. Zadnje izmijenjeno od: vmzagreb. 30.08.2018. u 16:43. |
#16 |
Vocna iglica u mudante
Lokacija: Beograd
Postovi: 2,838
ako ti se ne da zajebavat s adapterom, s obzirom da su cijenom preko 100kn, jel ti odgovara možda kupnja vanjske dvd pržilice? cijenom su oko 200kn, a spajaju se preko usba |
