Staro 26.08.2018., 14:53   #1
vmzagreb
Postovi: 65
SATA dodatni adapter
neznam da li to može tu ili negdje drugdje ali imam pitanje vezano uz PCIx1 adapter za SATA diskove.
uzeo bih ovo:
da li ti adapteri podržavaju botanje sistema u raid soluciji dakle da ova dva diska vidim u windowsima kao jedan te da tako podržan disk bude i botabilan da se sa njega diže sistem.
Ovo je kopirano sa stranice:
PCI Express SATA 3 Controller Card, 2 Port PCIe SATA III 6GB/s Internal Adapter Converter for Desktop PC Support SSD and HDD w
material: metal
Colour: Black
Support Interface: USB3.0 TO SATA 22PIN
Support System: WinXP/Vista/Win7/Win8 32-bit/64-bit LINUX
Meets Serial ATA 3.0 specification, backward compatible with SATA2.0 SATA1.0
Compliant with PCI-Express v2.0 specification, backward compatible with PCI-Express v1.0.
Supports communication speeds of 6.0 Gbps, 3.0 Gbps, and 1.5 Gbps
Support Gen 1i, Gen 1x, Gen 2i, Gen 2m, Gen 2x, and Gen 3i.
Supports two SATA
Support AHCI1.0 mode and IDE mode
Support native command queue (NCQ)
Supports FIS based on port multiplier switches or command switches.
Hot-swappable and hot-swappable.
Compatible with SATA6G, 3G and 1.5G Hard Drives
Bus interface
PCI-Express x1 slot
Extension ports
2 SATA3.0 interfaces
System Requirements
One available PCI Express X1 slot, supporting PCI-E X2 X4 X8 X16
Operating System: Windows 10/8/7 (32/64 bit) / Vista (32/64 bit) / XP/2003/2008/linux
System disk and PCIE to SATA3.0 adapter card connection conditions and solutions:
1, PCIE to SATA3.0 SATA interface mode is AHCI mode, if you want to insert the system disk in our card, the premise is that your system disk installed on the motherboard must be AHCI mode installation, otherwise it can not pass Our card adapter card boot system.
2. If it is determined that the system disk is inserted in the AHCI mode of the SATA interface mounting system on the mainboard, then the hard disk can be directly inserted into our card, and then the mainboard BIOS is set to start the system disk as the first boot.
3, the above two conditions are available, if you still can not start, or repeatedly restart, then the motherboard hard drive interface and our adapter card conflict, the solution is to enter the motherboard BIOS, the motherboard's hard disk interface options set to Disabled, save and restart to boot the system
Attention: Don't Support as System
vmzagreb je offline   Reply With Quote
Staro 26.08.2018., 15:53   #2
lobo64
lobo64's Avatar
Postovi: 1,345
Nije RAID podržan, dakle ništa od ovoga što tebi treba.
Staro 26.08.2018., 16:14   #3
vmzagreb
Postovi: 65
da li postoji takav adapter sa tom funkcijom jer bih uzeo 2x256GB ssd za sistem i programe, ako uključim raid na ploči spojit če mi sve sata ulaze u jedan veliki disk ili sam u krivu, ispravite me.
Staro 26.08.2018., 16:54   #4
Postovi: 23,484
Ovisi o pojedinoj mobo i pameti > napiši koja precizno + otvori manual pa pročitaj.
Staro 26.08.2018., 19:16   #5
lobo64
lobo64's Avatar
Postovi: 1,345
Staro 26.08.2018., 19:40   #6
Postovi: 23,484
Ne pitam za add-on karticu nego za matičnu.
Staro 26.08.2018., 20:48   #7
domy_os
domy_os's Avatar
Postovi: 18,809
Autor vmzagreb Pregled postova
Neće, i na najjeftinijem RAID kontroleru možeš birati koji diskovi će biti u polju.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 27.08.2018., 11:08   #8
vmzagreb
Postovi: 65
Autor domy_os Pregled postova
to znaci da na plocu spojim dva 256 ssd-a u raid polje a ovakav adapter iskoristim za prosirenje pohrane podataka. Ako bi to ovako islo super , pomozite smjernicama da ne zalutam.
Imam plocu gigabite ga 970 am3+
Staro 27.08.2018., 11:43   #9
Alister
Alister's Avatar
Datum registracije: Aug 2009
Postovi: 1,484
Koliko diskova imaš? Koji ti je smisao RAID polja ? pa da krenemo u nekom smjeru
Staro 27.08.2018., 12:06   #10
Postovi: 23,484
Jel to ova mobo > https://www.gigabyte.com/Motherboard...ming-rev-10#ov
Ako je, manual > http://download.gigabyte.eu/FileList...0-gaming_e.pdf
Imaš 6 sata portova, ako sam dobro shvatio šta piše u manualu, kada prebaciš u Bios - u Sata kontroler u Raid na Port 4 i 5 (zadnja 2, vidi manual),
bi se trebali moći postaviti kao "obični" AHCI za DVD / std. data za hdd.
Po tome ti dodatna add-on kartica nebi trebala.
Ostaje ti da odlučiš:
- hoćeš Raid 0 ili Raid 1 (sigurnost ili brzina, pitaj Google)
- hoćeš li UEFI Raid ili Legacy Raid (ovisi koji os dižeš)
Staro 29.08.2018., 18:38   #11
vmzagreb
Postovi: 65
Autor Nikky Pregled postova
Gigabyte GA-970A-DS3P
6 sata konektora i svi zauzeti 4 diska + 2 dvd
biče dva ssd-a u polju (operativni sistem i programi) a ostali pojedinačno(storage).
dakle SSDi u radi 1, a ostali JBOD tj. samostalno.
Zadnje izmijenjeno od: vmzagreb. 29.08.2018. u 18:52.
Staro 29.08.2018., 20:32   #12
Postovi: 23,484
Ok, dodaj add-on sata kontroler karticu,
na nju prebaci 1 - 2 hdd i 1 dvd (bude tih kartica sa 2 ili 4 sata porta).
Poanta da 1 dvd ostaviš na mobo kontroleru je radi boot - a (os install ili repair).
Staro 29.08.2018., 22:02   #13
vmzagreb
Postovi: 65
mislim da bu prvo išlo kloniranje, iovako nebotam sa DVDa več USBa, napravio sam win10 USB boot SD karticu.
ako ću uzeti adapter sa 4 onda idu oba DVDa na karticu a dva diska ostaju na MBu, nego kako mi preporučaš RAID1 na 0/1/2/3 ili RAID1 na 4/5, neznam da li onaj prvi uzme sva 4 SATA porta ili samo koje izabereš, kod 4/5 samo su ta dva u RAID polju ovi ostali nisu.
jesam dobro razumio, inače ona koju si ti stavio i moja razlika je u boji i tome da ona tvoja ima naziv gaming a ova moja je DS3P.
i daj mi objasni koja je razlika između ver.1 i ver.2,1, imam ovu drugu.
jel bu ova OK
https://www.ebay.com/itm/PCI-e-to-SA...IAAOSw7U9bVaVi
Zadnje izmijenjeno od: vmzagreb. 29.08.2018. u 22:10.
Staro 29.08.2018., 23:50   #14
Postovi: 23,484
Po opisu bi odgovarala, kakva je / jeli valja nemam info.
Možeš očekivati nešto malo lošiji transfer nego sa on-board kontrolerom.
Ne zaboravi inst. drajver, provjeri kod kineza jeli ima za W10.
Support za mobo tražiš točno po verziji koju imaš, znači DS3P ver. 2.1.
Ovo prvo ćeš morati sam pogađati.
Pretpostavljam da nakon ssd - ova u Raidu ostali bi trebali biti vidljivi kao JBOD.
Možeš očekivati kakav zaheb ako misliš klonirati jer je prije bio ahci vulgaris a po novom preko Raid polja + drugi (Raid) drajver.
Staro 30.08.2018., 13:30   #15
vmzagreb
Postovi: 65
Trenutno kloniram c disk i na 75% sam, kad to odradim odspojit cu dvd jer su mi oni na 4/5 ulazu radi raid polja a onda u nabavku adaptera.
brzo to prošlo ali stvaranje raid polja je sranje, ima tko da mi pomogne da me vuče za rukicu ili ušence to tako to tako jer očigledno nešto ide krivo.
Zadnje izmijenjeno od: vmzagreb. 30.08.2018. u 15:43.
Staro 30.08.2018., 15:42   #16
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,834
ako ti se ne da zajebavat s adapterom, s obzirom da su cijenom preko 100kn, jel ti odgovara možda kupnja vanjske dvd pržilice? cijenom su oko 200kn, a spajaju se preko usba
John Creasy je online   Reply With Quote
