Povratak   PC Ekspert Forum > Internet i mrežne tehnologije > ISP > Iskon
Staro 21.05.2018., 11:48   #4921
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,547
Broj za support im je iskljucen, a na 0800 1000 je poruka da je to globalni problem na razini Hrvatske.
Staro 21.05.2018., 12:57   #4922
RAUL
Lokacija: Worldwide
Postovi: 2,553
Proradilo.
Staro 21.05.2018., 17:31   #4923
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Četiri godine ovako:
Code:
    VDSL Training Status:   Showtime
                    Mode:   VDSL2 Annex B
            VDSL Profile:   Profile 8b
            Traffic Type:   PTM Mode
             Link Uptime:   0 day: 11 hours: 53 minutes
       VDSL Port Details       Upstream         Downstream
               Line Rate:      2.046 Mbps       20.479 Mbps
    Actual Net Data Rate:      2.047 Mbps       20.480 Mbps
          Trellis Coding:         ON                ON
              SNR Margin:        7.8 dB            6.7 dB
            Actual Delay:          0 ms              0 ms
          Transmit Power:       12.7 dBm          18.6 dBm
           Receive Power:        0.8 dBm           0.2 dBm
              Actual INP:       12.0 symbols      27.0 symbols
       Total Attenuation:       12.1 dB           18.4 dB
Attainable Net Data Rate:      2.263 Mbps       21.997 Mbps
      VDSL Band Status    U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB): 19.5     N/A     N/A     N/A    33.9    102.3     N/A
Signal Attenuation(dB): 19.5     N/A     N/A     N/A    31.5     N/A     N/A
        SNR Margin(dB):  7.8     N/A     N/A     N/A     6.7     N/A     N/A
   Transmit Power(dBm): 12.7     N/A     N/A     N/A    18.6     N/A     N/A
i onda ovako na novoj centrali.
Code:
                    Mode:   VDSL2 Annex B
            VDSL Profile:   Profile 17a
             Link Uptime:   0 day: 0 hour: 8 minutes
               Line Rate:      2.799 Mbps       23.999 Mbps
    Actual Net Data Rate:      2.800 Mbps       24.000 Mbps
              SNR Margin:       31.0 dB           27.3 dB
          Transmit Power:        1.9 dBm          10.0 dBm
           Receive Power:      -15.2 dBm          -9.9 dBm
              Actual INP:       54.0 symbols      51.0 symbols
       Total Attenuation:       18.0 dB           19.9 dB
Attainable Net Data Rate:     48.789 Mbps       81.531 Mbps
  Line Attenuation(dB):  6.5    21.3    31.9     N/A    13.1    27.2    40.6
Signal Attenuation(dB):  6.5    20.8    33.0     N/A     9.0    26.9    40.6
        SNR Margin(dB): 31.0    31.0    31.0     N/A    27.3    27.4    27.0
   Transmit Power(dBm):-10.1   - 0.5   - 0.4     N/A   - 1.5     7.9     5.2
I ne može preko 50 Mbps na VDSL-u, jer to je ograničenje paketa. Džabe što infrastruktura može. Da se ne može složiti neki individualni paket, ako ima puno lufta? Može li mi netko potkovaniji objasniti zašto?
karabaja je offline   Reply With Quote
Staro 21.05.2018., 17:45   #4924
johnsmith
Lokacija: vž
Postovi: 1,331
Vjerojatno vijeće mudraca mora vijećati i složiti brži paket od 50/10. Ili im nije napeto, jer ruku na srce, 1/10 korisnika probija tu granicu (random broj izvučen iz glave )
Staro 21.05.2018., 17:49   #4925
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Baš! Fleksibilni su ko dotrajale michelin gume.
Staro 21.05.2018., 18:27   #4926
johnsmith
Lokacija: vž
Postovi: 1,331
A gle, kak bude vise ljudi na FTTx, tak ce dizati brzine. Optika je bila prvo 80/40 pa eto ga na 200/100. Tak da sumjam da nece staviti od 10-100 paket na vdsl pa kolko vuče vuče
Staro 21.05.2018., 19:37   #4927
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Jest, u pravu si.
Ovo je komotno 'optička brzina' i rado bih im dao 200 i kusur kuna da me formalno stave na optiku, ali ne... VDSL i to je to.
Staro 21.05.2018., 20:06   #4928
okarm
Postovi: 772
Autor karabaja Pregled postova
a valjda se negdje mora staviti granica. tak bi se i "opticari" mogli isto zaliti zasto im pustaju samo 200, kad optika moze propustiti vise
okarm je online   Reply With Quote
Staro 21.05.2018., 20:25   #4929
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Autor okarm Pregled postova
E, da, "mora se". Jedino što čovjek baš mora je umrijeti, sve ostalo u životu je po dogovoru. Dobro, neću filozofirati. Samo mi je to inercija svojstvena državnoj upravi, a ne protržišnoj firmi.
Pitao sam ih, kažu ne može. OK , tako je. Glupo je, ali nije moj problem. Mislio sam da postoji čisto matematički razlog, a ne "takvi su nam paketi".
Nek' pitaju.
Koliki je Attainable Net Data Rate na optici (ako toga uopće ima na optici), a koliko puštaju?
Zadnje izmijenjeno od: karabaja. 21.05.2018. u 20:49.
Staro 21.05.2018., 20:34   #4930
johnsmith
Lokacija: vž
Postovi: 1,331
na čistoj optici ide kolko svjetla uspiju nagurati nutra i koju tehnologiju koriste. Mislim da je 1G neki min, a 10G ili 100G uz opremu nije greda.
Staro 22.05.2018., 02:50   #4931
skalar
skalar's Avatar
Datum registracije: Apr 2015
Postovi: 1,699
problem nije u tome koliko može kroz optičku nit nego je problem u krajnjoj opremi odnosno skupoći 1G routera,odnosno modema,tek su se nedavno pojavili i trenutno su preskupi za široku upotrebu sa stajališta operatera(čitaj t-com/vip u nas),kako na optici tako i na kablu,ovo što reklamira t-com je trenutno pilot projekt i dok bude dostupan svim sadašnjim korisnicima optike mogu proteći godine,osim ako vip ne iznenadi sa docsis 3.1 pa ubrza stvari i kod t-coma ,o 10G i više ćemo vjerojatno razgovarati polovinom sljedečeg desetljeća
Staro 22.05.2018., 15:12   #4932
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,134
Se moze preko routera nekak blokirati tel i mob brojevi koje necu da me gnjave ili moram iskonovce zvat ili to ni ne nude ?
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 22.05.2018., 19:46   #4933
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Spojili me danas, zadovoljan sam. Nisam imao problema sa port forwardanjem na Innboxu V51. Jedino se osjeti manja kvaliteta IskonTV-a u odnosu na Bnet, ali je zato više programa uz 20kn manju cijenu.
EDIT: čini mi se da mi je veći ping u CSGO nego što je bio na Bnetu, ali barem je skroz stabilan.
Zadnje izmijenjeno od: d0X. 23.05.2018. u 11:43.
d0X je online   Reply With Quote
Staro 23.05.2018., 13:41   #4934
Stipest
Stipest's Avatar
Datum registracije: Jan 2010
Postovi: 2,132
Koji paket? Koliko novaca? Jeli razlika u slici samo na SD ili i na HD kanalima?
Hvala
Stipest je offline   Reply With Quote
Staro 23.05.2018., 14:14   #4935
johnsmith
Lokacija: vž
Postovi: 1,331
vjerojatno smart full paket
Staro 23.05.2018., 14:26   #4936
tomislav10
tomislav10's Avatar
Postovi: 289
Autor d0X Pregled postova
Koliko manja, samo SD kanali ili i HD? kako bi sliku usporedio sa EVOTV-ovom?
tomislav10 je offline   Reply With Quote
Staro 23.05.2018., 15:35   #4937
d0X
Kostolomac
d0X's Avatar
Postovi: 1,481
Nisam nikad gledao EvoTV, pa ti ne mogu reći. Ali SD kanali su kvalitetniji na Bnetu, HD nisam usporedio. Starci gledaju telku, mene i ne zanima baš.
Staro 24.05.2018., 10:08   #4938
tomislav10
tomislav10's Avatar
Postovi: 289
Inače, kakva je slika na Iskonu, SD i HD kanali? Ako netko nešto može reći o ovome...
Staro 24.05.2018., 10:21   #4939
okarm
Postovi: 772
Koliko sam ja vidio, bnet preko coaxa ima bolju sliku od bilo kojeg naseg iptv providera, jednostavno pustaju veci bitrate i slika bolje izgleda
Staro 24.05.2018., 10:26   #4940
the chosen one
the chosen one's Avatar
Postovi: 730
Autor tomislav10 Pregled postova
Na optiki, 42" FullHD TV - MaxTV sa novim prijamnikom imao mi je nešto bolju SD sliku nego trenutno IskonTV.
HD je zadovoljavajući na Iskonu, imam samo HBO. Njega baš ne mogu usporediti pošto sam na MaxTV-u imao Arenu HD koju nisam gledao (ja i sport ko krava i balet )
Uglavnom, žena ne primijeti razliku, ja kažem da je nešto lošija kvaliteta. (koju kompenziram puuuno manjim računom )
Staro 27.05.2018., 16:14   #4941
igiskor
Datum registracije: Sep 2010
Postovi: 39
Ovako, trenutno sam jos na bnetu ali s iskonom se natezem evo ima vec tri mjeseca kako sam potpisao zahtjev s njma za prelazak. Pisao sam im i u reklamacije al evo traje i to. Optiku su mi postavili u stan prije malo vise od tjedan dana. Tek u petak sam prvi put vidio da je tel. broj u stanju prijenosa. Da li ja jos uvijek mogu ostati na bnetu nakon tog silnog natezanja bez obzira sto sam dobio poruku da tehnicar dolazi iduci tjedan da me spoji? Da mi ne izmisle jos da sam ja njima duzan neku lovu a navlace me ko budalu...
igiskor je offline   Reply With Quote
Staro 30.05.2018., 14:23   #4942
Froxie24
Datum registracije: Feb 2015
Lokacija: Sisak
Postovi: 825
Evo ako je nekome promaklo da ne bi bilo joj meni ne radi.
Od 29.05. do 07.06.2018 svaku noć u periodu od 03:00 - 05:00 sati vršiti će se nadogradnja softwarea na Iskon.TV prijemnicima (STB).
Posljedično tome Iskon.TV primjemnik će se restartati.
Restart će trajati oko 30 sekundi te za to vrijeme Iskon.TV neće biti dostupan.
Zahvaljujemo na strpljenju i razumijevanju.
Vaš Iskon.
Froxie24 je offline   Reply With Quote
Staro 31.05.2018., 20:59   #4943
the chosen one
Postovi: 730
Hmmmm, danas skužim da je WLAN na routeru upaljen (bio je zgašen) i ne mogu se ulogirati u router sa defaultnim user-om i pass-om. Resetirao router i nulla bodova.
Izgleda da su ga oni resetirali na nullu ne znam ni ja kad, ali mi je veći problem što ne mogu u router ući :/
Može netko provjeriti jel kod vas sve OK?
Staro 01.06.2018., 02:45   #4944
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
User je i dalje 'Administrator', ali je šifra sad, nakon upgradea, ono što piše na routeru u polju 'wireless key'.
Staro 04.06.2018., 15:45   #4945
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,134
oni koji dobiju Enkom ruter, lozinka vam ja kao i user name: Administrator
Zadnje izmijenjeno od: HumWeed. 04.06.2018. u 15:56.
Staro 04.06.2018., 16:24   #4946
Xenon
Postovi: 1,542
Jel ima netko Iskonovu uslugu na optici net i TV? Koji se uređaji dobe?
Xenon je offline   Reply With Quote
Staro 04.06.2018., 17:10   #4947
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,134
joj mi netko moze objasnit zasto ovaj glupi enkom
nemoze da mu radi wifi
sve je podeseno // dobra lozinka, AES // wpa2-psk
al nemogu niti jedan mobitel spojit stalno sere autentication problem
Staro 04.06.2018., 17:25   #4948
Xenon
Postovi: 1,542
stavi AES+TKIP
Staro 04.06.2018., 17:30   #4949
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,134
nece ni sa AES-TKIP
evo mojih postavki ako nesto znaci
Staro 04.06.2018., 17:32   #4950
Xenon
Postovi: 1,542
Stavi fiksni kanal i AES+TKIP pa napravi reset
