Staro 27.03.2018., 22:03   #10441
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Da, baš i ja gledam te Asrock cijene...previše je to i po meni...
Nadam se gigabyte i msi budu jeftinije...
Staro 27.03.2018., 22:44   #10442
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,631
na ovu B360 dodas jos 100-150kn i imaš Z370
ibme74 je offline   Reply With Quote
Staro 28.03.2018., 00:17   #10443
Filip98
Datum registracije: Oct 2017
Postovi: 50
Vjerojatno ce bit jeftinije u drugim ducanima kad dode
Filip98 je offline   Reply With Quote
Staro 02.04.2018., 15:44   #10444
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Molim preporuku konfiguracije do maksimalno 5000kn samo kutija
Hvala
timmy je offline   Reply With Quote
Staro 02.04.2018., 16:23   #10445
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x AMD Ryzen 3 1200, 3,1GHz, 10MB, AM4
1 x Gigabyte GA-AB350M-HD3,AM4,A350,D4,S3,U3,mA
1 x Crucial DRAM 8GB DDR4 2666 MT/s (PC4-21300) CL19 SR
1 x Gigabyte GF GTX1060 WF2 OC, 3GB GDDR5
1 x HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600)
1 x MS PHANTOM midi tower kućište
1 x Ventilator ARCTIC COOLING F12, 120mm, 1350 okr/min
1 x Fortron napajanje Hyper 500W
Ukupno: 5.088,00 kn -2% = cca 4.986,00 kn besplatno slaganje i dostava kroz 2 dana
Zadnje izmijenjeno od: FRipper. 02.04.2018. u 16:28.
Staro 02.04.2018., 17:29   #10446
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Matična ploča ASRock AB350M PRO4, s.AM4, 90-MXB520-A0UAYZ
Procesor AMD Ryzen 3 1200 BOX, 3.10GHz, 8MB Cache, s.AM4,
HDD 1TB Toshiba P300 High-Performance, 3.5", 7200RPM, 64MB Cache, SATA3, HDWD110UZSVA
MS HUNTER kućište Midi tower
DDR4 8GB (1x8GB) PC4-24000U 3000MHz CL16 G.Skill Aegis, F4-3000C16S-8GISB
Grafička kartica ASUS DUAL-GTX1060-3G, 3GB GDDR5, 192-bit, 1708/2000MHz, 90YV09X5-M0NA00
Napajanje 500W FSP Fortron/Source Hyper, ATX 2.31, HP500, PPA5005003
2x Ventilator Arctic F12 Silent, 120mm, 800rpm, 62.9m³/​h, ACFAN00027A
Ukupno: 5.027kn
Staro 02.04.2018., 18:17   #10447
BmwMPower
Lokacija: VG
Postovi: 1,128
Molim za prijedlog čim povoljniji ali do cca 4200 kn/ 550€
Kupujem sa ove stranice, https://www.agando-shop.de/xtlist.php?cat=172
Mogu se na svakoj izabranoj konfiguraciji izmjeniti komponente, uzeo bi bez hdd-a
Koristio bi se za nešto igranja, ništa više
Hvala
BmwMPower je offline   Reply With Quote
Staro 02.04.2018., 18:50   #10448
Smartic
Smartic's Avatar
Postovi: 2,707
Baš je bezveze što ne nude uopće dual-channel 2x4GB RAMa. Nema jeftinijih kućišta, a niti napajanja baš. I isključivo Corsair RAM... preskupo.
Gehäuse: Fractal Design Focus G - Gunmetal Gray
Netzteil: be quiet! System Power 450 Watt (80+)
Mainboard: MSI B350M PRO-VDH, AMD B350
Prozessor: AMD Ryzen 5 2400G 4x 3.6GHz
Cooler: Alpenföhn Sella
Arbeitsspeicher: 16GB DDR4-RAM PC-2666 (2x 8GB)
Grafikkarte: AMD Radeon RX Vega 11 Grafik
547€
Prozessor: AMD Ryzen 3 2200G 4x 3.5GHz
Arbeitsspeicher: 8GB DDR4-RAM PC-2666 (1x 8GB)
Grafikkarte: Nvidia GeForce GTX1050 2GB, Palit StormX
556e
Gehäuse: Bitfenix Nova schwarz
Netzteil: be quiet! System Power 350 Watt (80+)
Mainboard: MSI H110M ECO, Intel H110
Prozessor: Intel Core i3 7100 2x 3.9GHz
Cooler: Original Intel-Cooler
Arbeitsspeicher: 8GB DDR4-RAM PC-2133
Grafikkarte: Nvidia GeForce GTX1050 Ti 4GB, Palit StormX
526e
Ako imaš kakav drugi dućan, dalo bi se bolje složiti.
Staro 02.04.2018., 19:00   #10449
BmwMPower
Lokacija: VG
Postovi: 1,128
Evo ovdje mi nude isto amazon pay tako da može i ovo, možda je veći izbor?
Uzeo bi možda intel jer imam hdd sa win 7 gore, ryzin je samo win 10?
https://www.rhino-computer.de/index.php?cPath=8
Hvala na trudu, danas nešto moram naručiti
Staro 02.04.2018., 19:11   #10450
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,086
Ide rxzen i na 7-icu.Samo pogledaj da ploča ima drivere za ryzen!
Mislim da samo raven ridge nije podržan!Ovi novi apui!
Phil of the future!
Zadnje izmijenjeno od: coconut. 03.04.2018. u 07:06.
Staro 02.04.2018., 19:22   #10451
Smartic
Smartic's Avatar
Postovi: 2,707
Sharkoon VG4-W
Netzteil: 600 Watt Xilence XP600R6 Netzteil (80+)
Mainboard: MSI B250M PRO-VDH USB3.0
Arbeitsspeicher: 8GB DDR4 PC-2400
Grafikkarte: Nvidia GeForce GTX1050Ti 4096MB
Ne da se HDD, DVD-RW niti dodatni cooler maknuti, ali je malo bolje sveukupno. Vjerojatno ide za oko 490e(550 sa ovim trima komponentama).
Staro 02.04.2018., 20:01   #10452
freerock0
Datum registracije: Apr 2014
Lokacija: tu i tamo
Postovi: 218
Pozdrav,
pitanje je bilo postavljeno u temi "Preporuke za nadogradnju konfiguracije ili pojedinačnih komponenti" a sad me kolega forumaš uputio na ovaj topic...
Samo da ponovim da sam truba za te stvari i da se nimalo se ne kužim u ovu tematiku.. pa molim za pomoć.
Komp bi uglavnom služio za surfanje , youtube , malo Autocad i SolidEdge ,igre baš i ne primarno -pošto klinci imaju svoje laptope ,no ako bi poželio igrati neku noviju igru bilo bi dobro da je komp može "odvrtjeti".
Moje "želje" :
- sa novim kompom i ugrađenim komponentama htio bih biti miran sljedećih 10-tak godina - ako je moguće ...(kao što sam bio sa dosadašnjim)
- trebao bih minimalno 2 x USB3 priključka ( za vanjske HDD) i nekoliko USB2 na stražnjoj strani + 1÷2 na prednjoj strani
- SSD bi htio barem 250 gb
- HDD 500÷1000 GB
- orginalni windowsi ? - ako može preporuka DA ili NE ...
- pržilica tek toliko da je ..
- monitor , miš , tipkovnicu i zvučnike ne trebam
Ako može i neka preporuka shopova (Hrvatska ili EU) koji bi mogli sve to sklopiti ...
Razmišljam o max. cijeni cca.5500 kn.
Molim za savjete i preporuke te hvala unaprijed .
Pozdrav !
Zadnje izmijenjeno od: freerock0. 02.04.2018. u 20:04. Razlog: Dodana pržilica
freerock0 je offline   Reply With Quote
Staro 02.04.2018., 21:42   #10453
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x Intel CPU Desktop Core i3-8100 (3.6GHz, 6MB, LGA1151) box
1 x Asrock LGA1151 H310M-HDV M.2
1 x Gigabyte GF GTX1050 Ti D5, 4GB GDDR5
1 x SSD AD 256GB SU800 SATA 3D Nand
1 x Zalman Z1, 2x120mm
Ukupno: 5.308,00 kn -2% = cca 5.200,00 kn besplatno slaganje i dostava kroz 2 dana
+ pržilica cca 130kn ako je baš potrebna
Staro 02.04.2018., 22:27   #10454
BmwMPower
Lokacija: VG
Postovi: 1,128
Autor Smartic Pregled postova
Sharkoon VG4-W
Ovo naručeno, hvala na pomoći
Staro 03.04.2018., 05:00   #10455
ibme74
ibme74's Avatar
Postovi: 1,631
Autor freerock0 Pregled postova
Pozdrav !
1x Intel CPU Desktop Core i5-8400 (2.8GHz, 9MB, LGA1151) box
1x Asrock LGA1151 H310M-HDV M.2
1x Kingston 8GB 2400MHz DDR4 Non-ECC CL17 DIMM 1Rx8, EAN: '740617259643
1x Grafička kartica MSI nVidia GeForce GTX 1050 Ti 4GB, 4GT OC
1x SSD TS 240GB SATA SSD220S
1x HDD Desktop TOSHIBA DT01ACA100 (3.5", 1TB, 32MB, SATA III-600)
1x Fortron napajanje Hyper 500W
1x Zalman Z1, 2x120mm
Ukupno: 5.622kn (-2%=5.509kn)
Besplatno slaganje i dostava
Staro 03.04.2018., 21:23   #10456
freerock0
Lokacija: tu i tamo
Postovi: 218
Hvala na pomoći i ponudama kolegama "ibme74" i "FRipper".
Naletel sam na ovaj shop , imate kakva iskustva s njim ? Na prvu , izgleda mi povoljno.
Ako netko ima volje ,zamolil bi ako mi možete složiti konfiguraciju na njihovoj stranici ali sa Core i5-8400 .... probal sam ali se ne snalazim u "kombinacijama" ...
Ili sa neke druge provjerene i cijenovno povoljne stranice...
Sorry na zanovjetanju ...
Zadnje izmijenjeno od: coconut. 06.04.2018. u 06:57.
Staro 03.04.2018., 21:47   #10457
ibme74
ibme74's Avatar
Postovi: 1,631
iPon i EDigital su mađarski shopovi, iako su povoljni odnosn prema kupcima je dno tako da se reklamacije "rjesavaju" po 4+ mjeseca - bjezi od njih.
Prijedlozi gore su iz povoljnog i pouzdanog shopa, moj prijedlog ti je sa i5 8400 tako da su ti svi uvjeti ispunjeni, ne znam sta jos trazis. Pozdrav.
Staro 03.04.2018., 21:47   #10458
Postovi: 17,143
ipon je mađarski dućan koji ima ok cijene zbog niskog PDV-a kod njih. Šalju u RH, obavio par shopinga kod njih, dođe za 3-5 dana, sve ok. Sve ok kada radi, kod mene još nije bilo problema. Reklamacija je malo zajebanija kod njih, kad moraš slati natrag...
Staro 03.04.2018., 22:05   #10459
nino
nino's Avatar
Postovi: 12,613
Ke? 27% je tebi nisko?
mob
Staro 03.04.2018., 23:35   #10460
Postovi: 17,143
Zabrijal sam da oni imaju 19 ko i švabi... Moj bed. Onda imaju jebene cijene
Staro 05.04.2018., 17:50   #10461
freerock0
Lokacija: tu i tamo
Postovi: 218
I ja sam već kupoval sa EDigital i sve je bilo OK.
Cijene su dobre ili ...?
Ako netko ima volje , zamolil bi ako mi možete složiti konfiguraciju na iPon stranici ali sa Core i5-8400(prema preporuci kolege ibme74) ....
Zadnje izmijenjeno od: coconut. 06.04.2018. u 06:58.
Staro 05.04.2018., 17:56   #10462
neci43
Datum registracije: Apr 2018
Postovi: 4
Savjet neki, mišljenje...
Dugo sam vremena na konzolama, pa eto u zadnje me vrijeme dosta vuče PC gameing...
Razmišljao o nekom kombou i3 8100+1050ti...imam 2x4 GB DDR3 RAM, mali SSD 60 GB i HDD500 GB, znači trebam sve ostalo...periferija nemam, pa tako ni monitor...zamišljao na početku dok ne skupim neke novce i prodam laptop i PS4, igrati na TVu...
Koliko je ovo OK ideja, dal' je taj DDR3 RAM dostatan dok ne dodje 4 u sistem?
Takodjer, u idućih par godina ako bih išao na 4k, naravno ako financije dopuste, koliko se komponenti u ovakvom sistemu treba mijenjati?
Srry na noobovskom postu.
neci43 je offline   Reply With Quote
Staro 05.04.2018., 18:09   #10463
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ne možeš koristiti ddr3 ram u konfi 1151v2 socketa koja ti treba za i3 8100
Staro 06.04.2018., 01:46   #10464
Filip98
Postovi: 50
Treba ti ddr4 ram. 8gb minimalno
Staro 06.04.2018., 03:39   #10465
neci43
Postovi: 4
To mi je novost, znači automatski 700 kn gore!
A opcija gameanja na Vega grafi od Ryzena 2200 i 2400?
Koliko je tu onda bitna brzina RAMa?
Pa štednja za buduću 1060 ili 980 ako se nadje polovna?
Staro 06.04.2018., 10:40   #10466
Postovi: 17,143
Ajmo redom. Generalno nemaš ništa. Ovaj SSD od 60GB ti može biti samo za OS, jer svaka igra danas ima preko 30GB (pa čak do 60GB). Znači ako želiš igrati kvalitetno i brzo, moraš i novi SSD uzeti.
HDD može poslužiti.
Ako pak želiš pričati o 4k gamingu, pričamo o kompu od 10 000+ kn.
Tvoj Ryzen 2200 ili neki ekvivalentni intel ne može pratiti performanse jedne 1080 ili 1080Ti u 4k gamingu, tako da to po meni nije nikakva opcija.
Po meni ti trebaš cijeli komp (jedino taj HDD možeš iskoristiti, mada bi ja uzeo neki 1TB WD Blue za 300kn, pa da bude sve novo).
Razmisli o kvalitetnom FHD gamingu na PC-u i na miru si. Nema grafe koja će danas u 4k gurati sve naslove na ultra bez problema, tako da radije gledaj FHD ili 1440p. Ali kažem, pričamo o skupljim konfama.
Gejmanje na APU je moguće ako nisi zahtjevan korisnik. Fallout nekih 30-35FPS-a, CS:GO možeš igrati bez beda, LOL isto tako, Skyrim radi super (nekih 60FPS-a) itd. Nešto zahtjevnije i novije ne dolazi u obzir. FC5 radi na 25 FPS-a na high detaljima (po meni neigrivo).
Želiš kvalitetan build? 1060 minimalno, probaj potegnuti do ryzena 5 1600 (1200kn) i bar 8GB DDR4 rama + minimalno 120GB SSD. Umjesto da kupiš 2200g i šparaš za grafu, stavi novce sa strane i kada skupiš kupi cijeli build.
Uglavnom, što želiš igrati?
Staro 06.04.2018., 11:36   #10467
HrvojeJ
HrvojeJ's Avatar
Lokacija: Zgb
Postovi: 123
Na 1080p ne može pratiti takvu grafičku, ali na 4k bi radilo više manje isto kao i jači procesori.
HrvojeJ je offline   Reply With Quote
Staro 06.04.2018., 12:00   #10468
Postovi: 17,143
Želiš reći da Ryzen 2200G će na 4k raditi isto kao npr kaby i7?
Staro 06.04.2018., 12:07   #10469
Manuel Calavera
Postovi: 14,589
Da. Mommistake ti nekad kao da si s marsa pao
Pričamo o 4K rezoluciji gdje uloga procesora opada odnosno gdje si 99% gpu bound. Vidjet ćeš to na svakom cpu benchmarku igre gdje imaš po rezolucijama
Dakle na 1080p - velika razlika između 2c4t (recimo g4560) i 6c12t (recimo i7 8700K), na 4K - gotovo identični
Staro 06.04.2018., 12:32   #10470
Postovi: 17,143
Nisam pao s marsa, učim
Hvala na ovome, znam da je 4k čisti GPU trottle, ali nisam znao da je tako mizerna razlika.
