Staro 28.03.2018., 19:20   #1651
gunther
Postovi: 1,366
Nego, nikako da upogonim rudarenje Ravena s Radeonkama preko Simplemininga. S nvidiama radi sve ok.
Majna li netko Ravena s Radeonkama putem Simplemininga?
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je online   Reply With Quote
Staro 28.03.2018., 20:17   #1652
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,603
Pa jel vidiš što piše da ti fali?
Nije uopće problem u mineru, bat fileu itd.
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 28.03.2018., 20:18   #1653
Facelessone
Facelessone's Avatar
Postovi: 4,204
I opet bude ti bacio grešku jer ti fali file u windowsima. Vezano uz Microsoft Visual C++. Potraži nekakav update za to.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 28.03.2018., 20:57   #1654
Facelessone
Postovi: 4,204
Nisi pravi instalirao, a ima ih hrpa
Jel ti imaš amd ili nvidia rig? jer ccminer je za nvidiju.
a i setup za suprnovu ti ne valja
ccminer.exe promijeni u sgminer.......
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.03.2018., 21:07   #1655
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
a miša mu maloga! nekužim!
skinia sam miner za AMD, Ja imam amd rx570 karte,
sa https://rvn.suprnova.cc/index.php?page=gettingstarted
kreira sam bat fajl scminer-x64.exe -a x16r -o stratum+tcp://rvn.suprnova.cc:6667 -u RURhxZc4b496N5jiHSKJcWKQnavbbLmLSL -p x
alli uopce neotvara ništa?
daj malo pojednostavi? )
gledam ove upute sa supernove.cc
kaže sl: ccminer.exe -a x16r - stratum + tcp: //rvn.suprnova.cc: 6667 -u Weblogin . Radnik - Zaposlenik lozinka
kaže webloging! da tu upišem lozinku od sajta supernova? Radnik! tu moje nick, zaposlenik lozinka! di ide adresa od novčanika???
ajde daj te svoj batfajl? da cirnem?
MinigRig*H110-D3A*5*rx570nitro8GB OC.
Zadnje izmijenjeno od: gloginjaR. 28.03.2018. u 21:17.
gloginjaR je offline   Reply With Quote
Staro 28.03.2018., 21:20   #1656
Facelessone
Postovi: 4,204
Skinuo si od negdje SGMINER. U batu si namjestio da pokrećeš scminer-x64.exe. S tim da sgminer u nazivu još nigdje ni nema -x64.
Dalje, -a ti je za CCMINER, koji je na nvidiu, ti koristiš sgminer jer imaš AMD, bar se nadamo da imaš.
-o stratum+tcp://rvn.suprnova.cc:6667 ti je dobro.
Polsije ti ne ide wallet adresa nego ide u formatu -u Weblogin.Worker -p Worker password
Kaj ti i piše na stranici koju si linkao.
U novi red dodaj još pause
Moj bat file ti ne bude bio dobar.
Code:
sgminer.exe -k x16r -o stratum+tcp://rvn.suprnova.cc:6667 -u Weblogin.Worker -p Worker password
pause
edit:
GETTING STARTED GUIDE
1. Create account.
Register here, or login if you already have account
Create a worker that will be used by the miner to login
2. Download a miner.
GPU Miner NVIDIA Windows/Linux: Download here
GPU Miner NVIDIA Windows/Linux (Much faster): Download here
GPU Miner AMD: Download here
3. Configure your miner.
Settings for Stratum (recommended):
STRATUM: stratum+tcp://rvn.suprnova.cc
PORT: 6667
Username: Weblogin.Worker
Password: Worker Password
You then need to change "-u Weblogin.Worker -p Worker password" to reflect your own account. Eg, "-u Steve.StevesWorker -p StevesWorkerPassword"
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Zadnje izmijenjeno od: Facelessone. 28.03.2018. u 21:26. Razlog: dodatak sa uputama.....
Staro 28.03.2018., 22:23   #1657
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
neznam!
skinia sam ovi par scminera, ali nikako da krene,
probao sam i po ovim uputama za AMD RX, karticu http://1stminingrig.com/how-to-mine-...a-gpu-and-cpu/
ali mi baca onu grešku za Visual c++,
ako ko ima miner za amd rx kartice, neka posta link?
Hvala na dobroj volji Facelessone
dok nenadjem scminer (jer ima ih brdoooo i svaki batfajl se drugačije postavlja! ;(
dok to ne skontam, ostacu na etclasic.
Staro 28.03.2018., 22:46   #1658
rudi1
Datum registracije: Sep 2017
Postovi: 95
Autor Stormer Pregled postova
Jedno pitanje, gdje pratite to sto minat? ja sam dosad gledo samo whattomine al recimo tog RVN tu nema. Evo bas sam nakon sto sam procito ovdje na PCE upogonio svoje rigove na RVN i uspredborm i profitabilitijem dosta vise se zaradi na RVN.
http://jkcrypto.com/coin-to-mine-wit...a-gtx-1080-ti/
i pripadni forum.
rudi1 je offline   Reply With Quote
Staro 28.03.2018., 22:49   #1659
aka47
aka47's Avatar
Postovi: 37
instaliraj Visual C++ Redistributable for Visual Studio 2017 x86 and x64 versions, google je tvoj prijatelj
aka47 je offline   Reply With Quote
Staro 28.03.2018., 22:56   #1660
Facelessone
Postovi: 4,204
Gle ovo, sa tvog linka, samo pokrenut 3. bat za minepool... Meni nije jasno kaj ti to radiš da ti ne radi. Bat je svaki isti, i skoro su ti isti ko i za claymore. Za suprnovu ti je jedino user/password u malo drugačijem formatu, tj moraš se registrirati i napraviti worker, dodjeliti mu password i samo to uneseš u bat umjesto walleta.
I opet, nema tog sgminera koji ce ti raditi ak tebi fali file u windowsima koji mu treba.
Još na toj 1stminingrig.com stranici imaš i link ak ti to fali.
Download Visual C++ Redistributable for Visual Studio 2017 x86 and x64 versions: https://support.microsoft.com/en-us/...al-c-downloads
Imaš 3 bat filea za miner za 3 poola koja hoćeš, za suprnovu imaš za unesti podatke user/pass. Za druga 2 minera samo moraš promijeniti wallet i to je to. Sva 3 rade isprobano maloprije.
Znači u 2 bat filea imaš praktički samo za promijeniti adresu walleta i moraš instalirati taj visual c++ update koji ti fali i to je sve. Nikakve druge mudrosti.
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 28.03.2018., 23:02   #1661
rudi1
Postovi: 95
Autor Svemo Pregled postova
Meni na win10 3 x GTX1060 6G ccminer i minepool 11,5mh/s
RVN, 2 x 1060 6GB na suprnova
Zajedno 12 do 14 MH/s s ccminer enemy 1.03
81% power, gpu +64, mem 0.
Staro 29.03.2018., 08:40   #1662
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
budem proba ponovo, očigledno je da ce mo u buduće morat svako malo mjenjat novćice
i minere, kako je sve krenilo niizbrdo.
lp.
Staro 29.03.2018., 09:35   #1663
dukee
dukee's Avatar
Lokacija: vz
Postovi: 466
Nicehash ekipa je naviknuta na 1click rjesenja
dukee je offline   Reply With Quote
Staro 29.03.2018., 09:49   #1664
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Nisam probao nicehash . oni isplaćuju btc.
Baš cu probat 3-4 dana, da vidim dali je bolje od ethereuma.
Eve neki kalkulator
https://crypt0.zone/calculator/s/pautqnb0
Ima dosta shitcoina.
Staro 29.03.2018., 10:09   #1665
lit
Lokacija: hr
Postovi: 976
Da li je netko probao nove NVIDIA drivere (27.03.), da li imaju kakva mining poboljšanja?
lit je offline   Reply With Quote
Staro 29.03.2018., 10:32   #1666
Churta_Sia
Datum registracije: Feb 2018
Postovi: 54
Ekipa, nizam ziher u koju temo ovo pitanje postaviti… pa evo u svaštaru 
Imam priliku dobiti vrlo povoljno dvije gtx 1060 3gb.
Znam da je već nekih mjesec dana, nakon updatea, nemoguće s njima majnati ETH na win 10.
Trenutno imam rig sa gtx 1050ti i ne bi ga htio micati sa win i claymorea ako baš ne moram tj. uglavio bi ove dvije unutra… imam neku lite verziju win 10 koja je od prošlog ljeta, sa isključenim win updateom pa si mislim da bi mi možda i radilo….
Moje pitanje je da li ih netko ipak koristi na nekoj ne updateanoj verziji win 10?
Ili moram na Linux?
Thx unaprijed
Churta_Sia je offline   Reply With Quote
Staro 29.03.2018., 12:10   #1667
Los Sam
Los Sam's Avatar
Lokacija: Duga Resa
Postovi: 514
Do danas sam majnao s njima na win10 updateanom, danas je stalo na jednom rigu, ostali se jos drze...eres 0 ili 1 je trebalo ukljucit.
ima navodno neka shema, probamo danas, ako upali, javim...
takodjer mi se ne prelazi na neki stariji win....
Los Sam je offline   Reply With Quote
Staro 29.03.2018., 12:39   #1668
rudi1
Postovi: 95
Autor Churta_Sia Pregled postova
Ili moram na Linux?
Thx unaprijed
A pirl koji već dosta dugo parira eth po isplativosti? Meni radi na 2 GB karticama, win7.
Staro 29.03.2018., 14:25   #1669
Churta_Sia
Postovi: 54
Autor rudi1 Pregled postova
Nije ETH svetinja... ako se pokaže da ne ide drugačije lako se prebacim na nešto drugo, iako sam na hodl modu pa mi nije bitno da izvlačim tjedno/mjesečno lovu
Staro 29.03.2018., 14:37   #1670
Bezimeni777
Datum registracije: May 2017
Postovi: 129
Ode ETH, majner trenutno samo svoju struju placa
Bezimeni777 je offline   Reply With Quote
Staro 29.03.2018., 15:06   #1671
gunther
Postovi: 1,366
Autor Bezimeni777 Pregled postova
Bitno da on zaradi za sebe, a ne da je tebi na grbaci
Staro 29.03.2018., 15:08   #1672
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
U vezi nicehasha! Jel se isplati čekirat i CPU? Pored 5 RX kartica?
I vidim da mi nudi sam CryiptoNight?
Treba li još šta pogledati?
EDIT:
Evo odradio mi je probni bench! Dvi tri ure..
Počela je minat, ali mi se povećala potrošnja struje!! SAD se vrti od 800 do 950w
Prije mi je etc trošia oko 600-630w.
SAD budem vidio koliko ce izrudarit za dan, pa ako se isplati, nek stoji.
Zadnje izmijenjeno od: gloginjaR. 29.03.2018. u 18:26.
Staro 29.03.2018., 19:46   #1673
Los Sam
Los Sam's Avatar
Lokacija: Duga Resa
Postovi: 514
Arrow win10 dag fix -eth - 3gb
Evo nacina kako mozete na updateanoj verziji win10 koristiti gtx 1060 3gb za kopanje ETH:
1. uninstall svih GPU drivera sa DDU + brisanje nvidia foldera
2. install nvidia drivera verzije 376.33
3. skidanje/koristenje claymore's dual v10.3
4. dodavanje u skriptu -lidag 1 -eres 0
koliko dugo...vjerojatno privremeno rjesenje, ali najmanje 104h ove epohe ste mirni
p.s. fala frendu
Staro 29.03.2018., 21:10   #1674
Booster
Booster's Avatar
Datum registracije: Nov 2017
Lokacija: Virovitica
Postovi: 45
Kako su stvari krenule uskoro fakat vise nece biti isplativo, vec sada vise ode za struju nego sto ostane
Booster je offline   Reply With Quote
Staro 29.03.2018., 21:15   #1675
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Evo mali update za nicehash! Baš mi se i nesvidja kako izgleda!!
Kopa mi ETH+decret
ETH mi daje 137mh/s (a kad sam kopao samo ETH imao sam 147mh/s ??
Dcr mi daje 4212 MH/s. ???
Kako vam se to čini???
Dvi kartice su mi 70-72° ostale tri oko 60°
I da resetira mi se miner svako uru vremena? I krene iz početka??
Može koji komentar?
Poslano sa mog A0001 koristeći Tapatalk
Staro 29.03.2018., 21:24   #1676
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,603
Jesi mjerio potrošnju solo ETH i ETH+DCR?
Čisto sumnjam da ti se isplati dual mining u odnosu na povećanu potrošnju
A što se tiče hashratea, nebi smjela biti velika razlika između solo i dual mininga, očito ti nešto nije dobro namješteno (ili intensity - neznam jel ga možeš mijenjati u nicehashu, ili ti kartice throttlaju tj. trebaš povećati power limit)
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 29.03.2018., 22:17   #1677
gloginjaR
gloginjaR's Avatar
Lokacija: st
Postovi: 596
Pa neznam.. Nisam koristio dual, pa neznam! Jesam jednom kratko pokrenuo ali sam brzo odustao tako da neznam kolika je potrošnja.
Mislim da cu se vratit na solo, kopati etc
Par mogu svako malo prebaciti iskopano na bittrex i probati trejdat, ili zamjeniti za teter i trustUSA token (ako pada btc
Još SAD neću bit doma za blagdane! Pa mi je najsigurnije i najstabilnije etc (solo)
Staro 29.03.2018., 22:35   #1678
Booster
Booster's Avatar
Postovi: 45
Autor gloginjaR Pregled postova
Kopa mi ETH+decret
Može koji komentar?
Jel imaš kakav uređaj za mjerenje koliko ti struje vuče iz zida? Kada sam ja počeo kopati ETH prvo sam samo za probu pokrenuo dual miner koji sam skinuo, kopao je ETH + SIA, power consuption mi se gadno digao i isto mi se resetitrao miner, čak mi se i rig gasio, onda sam išao gledati koliko vuče iz zida kad ono 35W više nego što je napajanje deklarirano, maknuo SIA i opet sve 5. Mislim da taj dual mining nema smisla s obzirom na potrošnju.
Staro 29.03.2018., 23:24   #1679
Kamby
Kamby's Avatar
Datum registracije: Oct 2013
Postovi: 133
Ima smisla za ljude koji ne plaćaju struju. Ili ju imaju jeftinije nego Hrvatistan
Kamby je offline   Reply With Quote
Staro 30.03.2018., 00:13   #1680
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,603
Prije je imalo smisla, sad više nema kako su izašli SIA/DCR ASIC-i
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
