Povratak   PC Ekspert Forum > Računala > Kriptovalute
Staro 14.01.2018., 13:34   #361
PR3DA70R
PR3DA70R's Avatar
Lokacija: Yautja Prime
Postovi: 1,227
Ahh čekam i ja verifikaciju. Već dva puta odbili prvo oversaturated, a drugdje prošlo bez problema. Sad pak ne paše dokument jer se kao ne vidi pečat od banke. Lel
Isto sam u dilemi uzeti USD ili EUR. Još ću na kraju obje (netko je tu spomenuo da se može). xd
Staro 14.01.2018., 13:39   #362
warlock25
warlock25's Avatar
Postovi: 2,327
koje su privilegije verificirane advcash kartice?
Staro 14.01.2018., 13:50   #363
johnsmith
Lokacija: vž
Postovi: 1,335
Autor warlock25 Pregled postova
veci limiti i nemas lifetime ogranicenja. Ko neverificirani, imas neke smijesne ***LIFETIME*** limite, 250 balance, 100 atm i onda kartica u blok dok ne posaljes papire...
c/p:
Your Advanced Cash account is not verified yet. Because of this, there are certain limits concerning your plastic card transactions:
- total cumulative lifetime card funding/transaction limit: $250
Card funding
- max one-time funding: $250
- max daily funding: $250
- funding transactions: 1
Purchases
- transactions per day: no limit
- max daily spending: $250
- max total transactions: $250
- total card transactions: no limit
ATM withdrawals
- total withdrawal amount: $100
- max ATM transactions per day: 5
- max one-time withdrawal: $100
- total withdrawals per day: $100
When you successfully complete your account verification, we will set our standard limits to your card: $3,000 daily withdrawals, $10,000 total daily transactions, $3,000 total daily funding. Verification is a fast and easy procedure that unlocks all the Advanced Cash features and advantages for you.
Staro 14.01.2018., 14:12   #364
lit
Lokacija: hr
Postovi: 976
Autor PR3DA70R Pregled postova
Kod verifikacije imamo isti problem. Neću se gnjavit s bankom to šta traže, ako ne može izdat karticu onda čekam Wirex gdje nisu to tražili kao niti na jednom Exchangeu i sve je prolazilo bez problema. Sad samo ovi imaju posebne zahtjeve.
Pošalji im na support i reci isto da te to nitko drugi nije tražio od svih burzi nego samo oni i napomeni da ima kao i drugih kartica.
Što nas više ima treba im dat pritisak da brže prođe.
Inače, Wirex stiže za 3 tjedna.
lit je offline   Reply With Quote
Staro 14.01.2018., 14:15   #365
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,601
Ne kužim o kakvim vi bankama pričate?
Za verifikaciju na adv vam treba osobna i račun od telefona/struje/interneta i to je to. Ja sam slao od optime račun
Čak mi je kolegi prošla verifikacija sa prednjom stranom osobne za ID i stražnjom stranom osobne za adress, nije imao nikakav račun na svoje ime pa onda nije mogao to poslati
@ lit - kako to misliš da wirex stiže za 3 tjedna? Otkud ti informacija?
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 14.01.2018., 14:31   #366
lit
Lokacija: hr
Postovi: 976
Autor maXonja Pregled postova
Nisu na mene računi tako da mogu samo banku dati (izvod iz banke s adresom) što sam i davao svim burzama i bilo je sve ok.
Wirex support mi je rekao, lijepo sam pitao rekli su da moraju potpisati ugovor s novom kartičarskom kućom a već je sve u tijeku i da će biti gotovo za 3 tjedna.
A ima i drugih Bitwala koliko vidim nudi 60 altcoina, što je super. Ako je netko na Bitwali neka javi kakvi su.
Staro 14.01.2018., 15:03   #367
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
pitanje oko trosenja preko kartica..je li tko trosio vece iznose? recimo 20-30k kn godisnje? je li bilo kakvih problema? jer par servisa sam pitao i rekli su da oni ne salju poreznoj izvode osim ako porezna trazi, ne znam na koji nacin bi se porezna mogla sjetiti traziti za pojedinca osim ako ne traze grupno...ja sam do sad trosio male iznose samo tj ukupno manje 10k kn pa sad je li ima tko iskustva sa vecim ciframa?
Staro 14.01.2018., 15:08   #368
renaTq
renaTq's Avatar
Datum registracije: May 2017
Postovi: 387
Meni isto odbili racun od American Expressa. Probat cu od interneta.
#propo
renaTq je offline   Reply With Quote
Staro 14.01.2018., 15:15   #369
buljaka
Datum registracije: Aug 2014
Postovi: 2,931
Autor renaTq Pregled postova
Meni prihvatili od vipa za homebox
Zadnje izmijenjeno od: buljaka. 14.01.2018. u 15:25.
Staro 14.01.2018., 15:23   #370
msantic
Lokacija: Sveti Ivan Zelina
Postovi: 55
Ja sam za sada sa virtualnom karticom u USD uspješno kupio neku sitnicu na AliExpress-u te platio 120 kuna račun u PROTIS-u.
Čekam da mi stigne plastična kartica u EUR.
Verifikacija je prošla sa osobnom iskaznicom.
Zadnje izmijenjeno od: msantic. 14.01.2018. u 15:29.
msantic je offline   Reply With Quote
Staro 14.01.2018., 16:03   #371
domy_os
domy_os's Avatar
Postovi: 18,879
Kod mene će onda biti veselo jer nemam nijedan račun na svoje ime kao ni izvode iz banke. Morat ću sa e-Građani skinuti potvrdu o prebivalištu, valjda će to uvažiti.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 14.01.2018., 18:35   #372
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
Autor domy_os Pregled postova
nece, probao sam...najlakse mi prolazio izvod od ziro racuna (taj jedini imam), racuni od interneta 50:50, a potvrda o prebivalistu niti jednom
Staro 14.01.2018., 19:04   #373
His Airness
His Airness's Avatar
Datum registracije: Aug 2012
Postovi: 144
Meni je Bitstamp uvaživao tu e-potvrdu o prebivalištu, još 2016.-te godine
Čudno da to ne prolazi
His Airness je offline   Reply With Quote
Staro 14.01.2018., 20:43   #374
QW47
QW47's Avatar
Datum registracije: Sep 2017
Postovi: 64
Imam pitanje u vezi Revolut kartice, nisam siguran jesam li to negdje na ovom forumu čitao ili negdje drugdje ne mogu naći. Ima li netko da ima tu karticu i da je probao tipa poslati devize na Revolut karticu.
Zamišljam si tipa prebaciti na neku burzu tipa GDAX, prodam tamo, šibnem nazad na Coinbase eure i onda SEPA transakciju koja je free btw na Revolut i trošim onda pare s Revoluta? Da li bi to funkcioniralo tako?
Čak i njihova premium opcija za 7 GBP nije uopće puno.
QW47 je offline   Reply With Quote
Staro 14.01.2018., 23:25   #375
johnsmith
Lokacija: vž
Postovi: 1,335
Autor QW47 Pregled postova
Imam pitanje u vezi Revolut kartice ...
Ukljucis si eur racun, imas UK iban, pa probaj sepom natociti pare gore. Ne trebas premium za to.
Staro 15.01.2018., 16:53   #376
Brut
Datum registracije: Dec 2015
Postovi: 263
friski info adv radi i na bankomatu samo su digli frei
Brut je offline   Reply With Quote
Staro 15.01.2018., 17:04   #377
buljaka
Postovi: 2,931
Autor Brut Pregled postova
Slušamo info...😂💪
Staro 15.01.2018., 17:10   #378
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Znači još 2 puta odbijen. Digo se i ravno u banku po potvrdu ili nešto. Ffs
I da odgovor na odgovor na moj post prije, ni jedan račun nije na mene.
Staro 15.01.2018., 17:11   #379
Facelessone
Facelessone's Avatar
Postovi: 4,204
The new fees are:
International Visa/MC cards: $/€/Ł 6 + 2.95%
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 15.01.2018., 17:17   #380
Brut
Postovi: 263
Autor buljaka Pregled postova
Slušamo info...😂💪
a ne isplati se bas dizat sitno s bankomata, a velike cifre po mojoj racunici bolje se isplati izvuci preko zlata, sad tko se nadje izmedju
Staro 15.01.2018., 17:30   #381
maymun
maymun's Avatar
Lokacija: zadar
Postovi: 192
Ček, znači povećali su fee na adv??? taman mi jutros prošla verifikacija i naručio je.....
Kaže:
  • €0 monthly fee
  • 0% for any EUR transactions
  • €1.99 EUR withdrawals, €2.99 other currencies
  • €90 000 monthly ATM withdrawal limit
  • €3 000 daily ATM withdrawal limit
  • €3 000 daily card funding limit
  • 2.95% currency exchange
Prebacio sam preko baksmana doge u eur (5000 DOGE = 47,14€)
Znači ako dižem sa bankomata skida 1.99€ + 2.95% ? I plaćanje na POS ista priča?
maymun je offline   Reply With Quote
Staro 15.01.2018., 17:51   #382
PR3DA70R
PR3DA70R's Avatar
Postovi: 1,227
Koriste fino situaciju. Nisu ni oni glupi.
Staro 15.01.2018., 17:54   #383
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
The new fees are:
Ne kužim, fee je 8.95%?
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 15.01.2018., 18:01   #384
Brut
Postovi: 263
fixno 6$ +3% cifre koju dizes
Staro 15.01.2018., 18:02   #385
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,601
O nabijem ih na postotak
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 15.01.2018., 19:27   #386
buljaka
Postovi: 2,931
https://www.advcash.com/en/solutions/card/
Kako onda tu kaže 2.99 za druge valute ili 1.99 za euro plus 3 %?
Staro 15.01.2018., 19:58   #387
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Nisu izmjenili tu , u obavijestima imas da je sad fee 6€+3%
Sent from my iPhone 7+ using Tapatalk
Snowrider je offline   Reply With Quote
Staro 15.01.2018., 20:34   #388
msantic
Postovi: 55
Čini se da obavijest nema veze sa podizanjem gotovine na bankomatu...
Withdrawals to Bank Cards: Fee Updates
Please note that starting today we update the fees applied to sending funds to existing bank cards around the world.
Staro 15.01.2018., 21:53   #389
goran047
goran047's Avatar
Datum registracije: Nov 2016
Postovi: 142
Ja od uquid-a dobio nakon par mjeseci novu karticu par dana prije nove godine, ovog puta mastercard iz bugarske. jedva prebacio tih 150eur koji su mi ostali na uquidu i potrosio vec skoro sve. imam jos 10-ak eur.
I eto danas mi dodje mail iz bugarskog Paynetics-a da do 26.01.2018. moram potrosit sve sto imam jer raskidaju ugovor sa nekakvim Cocsi Ltd koji trguje sa uquidom. tako da svi koji su bili ili milse u uquid bjezite glavom bez obzira jer cudim se da vec nisu propali.
vise ne mislim narucivat nikakvu karticu jer vidim da su poceli svi polako nesto kemijat
goran047 je offline   Reply With Quote
Staro 15.01.2018., 22:57   #390
lit
Lokacija: hr
Postovi: 976
Koja je računica? ja samm gledao i vidim da uzimaju oko 10% ako hoćeš odmah prodati da dobiješ cash. Onda me isto dođe kod da odem na onaj BTC bankomat.
Autor goran047 Pregled postova
Samo što umjesto toga?
