Datum registracije: Nov 2011
Postovi: 104
(riješeno) Gigabyte GA-AB350M-Gaming 3 krepala?
Evo ukratko: flashao sam bios sa f6 na f10 njihovim APP centerom, vjerojatno je nešt pošlo krivo jer je jedna verzija biosa između F7a, a ovaj vrag je skinuo odmah f10 verziju. Uglavnom nakon flashanja i restarta sve vrti, svjetli, ali nema signala na monitoru i rgb tipkovnica ne svjetli.. Probao sam clear cmos vađenjem baterije, probao sam reset preko jumpera, vadio keks memorije, probao samo s jednim i ništa.. Ploča i proc su kupljeni u Linksu i sad mi je frka to nositi kod njih jer sam garant mjesec dana bez kompa. Proc je r5 1400, memorija je uredno radila na 2.666Mhz, znači prije flashanja nikakvih problema nije bilo od prvog dana, bios sam redovito nadograđivao i sve je bilo o.k. Ima još kakvih trikova ili nosim na reklamaciju, i ako nosim uzimam i memoriju ili samo ploču i proc koji su kupljeni kod njih? Zahvaljujem unaprijed!
All my life I fought this fight The fight that no man can never win Every day it just gets harder to live This dream I'm believing in Thunder Road.. |
Datum registracije: Oct 2013
Lokacija: Vukovar
Postovi: 22
Posto ploca ima dual bios, probaj : Method #1: 1. Shut your PC down (if you're reading this guide, than your PC isn't working anyways) 2. Hold the power button until the PC starts and shuts down again 3. Press the power button again, your backup BIOS should kick in now and should re-flash the main BIOS if there's anything wrong with it. Method #2: 1. Shut your PC down 2. Hold the power AND the reset button for about 10 sec, than release. 3. Backup BIOS should kick in anytime soon now. Method #3: Had to use this one in order to get my 990FXA-D3 working again. Backup BIOS kicked in using method #2, but I was back to the good ol' no signal state once the procedure finished.. 1. Short out pins 1 and 6 on the main BIOS chip (pin #1 should be marked with a red dot or whatever) 2. Tell a friend (or a relative) of yours to press the power on button 3. Remove the ghetto-like jumper you're holding between pins 1 and 6 as soon as you hear a beep. 4. Backup BIOS should kick in again and everything will (hopefully) be fine. Preuzeto : http://forum.gigabyte.us/thread/1356...gaming-useless http://www.overclockers.com/forums/s...byte+dual+bios Lik kaze da mu je sa metodom 2 proradilo. |
#4 | |
Postovi: 104
Isprobana metoda 1 i 2 i ništa.. Fakat ne kužim, ako imam dual bios koji jarac ne mogu loadati backup bios.. Jedino kaj mi kod metode 2 pada na pamet je da mi možda reset switch ne radi, kolko čitam svima je ta metoda dala rezultat. Sve je spojeno uredno, provjereno x puta.. Se može kako ručno uključiti reset i stisnuti power button a da sve ne ode u k...?
Postovi: 12,613
Ja na svojoj imam jumper za drugi bios, pa provjeri. Edit: da li beepa ako upalis bez ram-a? mob
Postovi: 3,788
Meni se b85 gigabyteica tako zbrikala. Metoda 3 mi je pomogla. Taj dual bios nekad ne uskoci jer mu primarni ne javi da je zbrikani. Tako sam negdje procitao objasnjenje. Ugl metoda 3 ce ti 99,9% pomoci. Samo potrazi pomoc nekoga da upali komp dok ti drzis kratko spojene pinove. Edit: onda moras opet flashati primarni bios sa novijim. Jer backup pregazi primarni sa svojim koji je tvornicki napucan, kod mene je bio ver 1.0. |
#7 | |
Postovi: 104
Evo isprobana i metoda br. 3 i ništa. Bum danas sve povadil iz kištre pa na stolu probam uz precizniji pristup. Ako ništa nosim sutra u Links pa sam kroz GO od dva tjedna bez kompa..divotica.
Nemoj se dalje zejebavat. Odnesi u Links na RMA i bok. Ako ti je problem čekat novu ploču, odma kupi neku drugu ili istu takvu, a onda prodaj novu zapakiranu sa novim jamstvom kad dobiješ povrat. Spušit ćeš 100 kuna. Ili tako ili čekaj. Ploča je rikavela. Meni je tako P5Q-E prdnula 31.12.2008 prilikom postavljanja playliste za novogodišnji party. Poslao sam ju u Links dan dva nakon nove godine i dobio drugu 31.01.2009. Mjesec dana je na statusu pisalo "testiranje robe / utrvrđivanje kvara". Ne znam koliko su se ubrzali po tom pitanju od onda. Sent from Mobara |
Postovi: 104
Evo jučer vraćena ploča sa servisa, piše da je izvršen update biosa i da je test o.k. Sve ja to fino opet složim i rezultat je isti kao i prije. Svi ventilatori rade, ledice na matičnoj svjetle, grafa vrti, ali nema signala na monitoru i na tipkovnici. Probao sam po jedan keks memorije šaltati po svim utorima ali ništa. E sad, ploča bi trebala biti o.k. prema Asbisu. Moguće da je proc u pitanju? Nažalost nemam komponente za provjeru i sad sam u banani.. Ima netko kakvu ideju? Znaći sve to se dogodilo nakon flashanja biosa, do onda je sve radilo perfektno..
All my life I fought this fight The fight that no man can never win Every day it just gets harder to live This dream I'm believing in Thunder Road.. Zadnje izmijenjeno od: pilgrim_23. 10.01.2018. u 09:00. |
tiki
Postovi: 2,760
A ne preostaje ti drugo nego isprobati s drugim komponentama, izvaditi M2 disk i "ogoliti" ploču pa tako probati itd. Za početak ja bih isprobao s nekom drugom grafičkom |
Postovi: 104
Budem probal gore navedeno, a i uspio sam nabaviti drugu grafičku pa popodne sprobam..šteta kaj proc nema integriranu grafičku, sad bi mi puno pomoglo.. Zahvaljujem!
#14 | |
Postovi: 104
Je moguce da je proc? Sent from my SM-G903F using Tapatalk
#16 |
Postovi: 104
Pošto ostajem bez ideja na pamet mi je palo da prva verzija biosa podržava samo ryzene 7, sa drugom verzijom F4 je dodana podrška za ryzene 5. E sad kaj su ovi u servisu apdejtali iz njihovog radnog naloga se ne vidi, samo piše izvršen update biosa, test o.k. Budem ih probal nazvati ili im poslati mail..
#17 |
tiki
Postovi: 2,760
Pa piše upgrade biosa, nisu radili downgrade ![]() Nazovi ih i pitaj jesu li uopće vidjeli grešku. Moguće da su vidjeli, flashali, da je radilo neko vrijeme i da je opet crklo. Možda najbolje da odeš tamo osobno sa procesorom i mbo i napomeneš da je ovo reklamacija reklamacije i ako je serviser tamo da pokuša to odmah upaliti pred tobom |
#18 | |
Postovi: 104
Poslal sam im mail, poslije ih budem zval i ako treba odmah popodne pičim do njih..
#20 |
Postovi: 104
Evo ovg trena sam ga upalio napokon.. Uglavnom, bio sam na servisu, ploča radi, bios F10 gore, proc radi, memorija ne radi..ni jedan keks.. Sad sam otišao u dućan i kupio 8 giga memorije 2400MHz i konačno ga bootao. Stara memorija nema šanse da je samo tak krepala i to oba keksa, vjerojatno se u biosu nekaj pošemerilo pa ju ne prepozna.. Sutra bum se poigral s tim.. Eto, nakon 3 tjedna konačno sam za svojim kompom..kakvo olakšanje ![]() Edit: Nije mi vrag dal mira, otišal sam u bios i uključioXMP profil kak je bilo i prije, ubacim svoju memoriju i radi.. U 6 p.m. I sad ovu memoriju kupljenu danas moram na njuškalo staviti ili probati vratiti u web shop..
All my life I fought this fight The fight that no man can never win Every day it just gets harder to live This dream I'm believing in Thunder Road.. Zadnje izmijenjeno od: pilgrim_23. 11.01.2018. u 20:21. |
