Staro 28.07.2017., 14:32   #391
Wuchko
Wuchko's Avatar
Postovi: 556
Autor Mihael Pregled postova
Jesam, međutim ja na listi nemam uopće taj drugi disk (/dev/sdb). Evo moje liste
Code:
1          1049kB   256MB   255MB   primary   ext2           boot
2          257MB    21.0GB  20.7GB  extended
5          257MB    21.0GB  20.7GB  logical                       lvm
I to je sve ovaj "prvi" disk. Nadalje, df -h mi daje sljedeće:
Code:
udev              2.0G     4.0K   2.0G   1%     /dev
tmpfs             396M    628K  395M   1%     /run
/dev/dm-0      15G      3.0G   12G    21%    /
none              4.0K     0        4.0K   0%      /sys/fs/cgroup
none              5.0M     0       5.0M   0%     /run/lock
none              2.0G     0       2.0G   0%      /run/shm
none             100M     0       100M   0%     /run/user
/dev/sda1      236M   74M      150M  34%    /boot
Autor cccp Pregled postova
Ovak na slijepo, je li to error pa komanda nije izvrsena ili samo upozorenje?
Sta ti je sada u '/etc/fstab' (`cat /etc/fstab`) i sta pokazuje `lsblk -a`?
Koliko vidim, samo upozorenje/informacija:
Code:
Information: You may need to update /etc/fstab.
u /etc/fstab imam ovo:
Code:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
/dev/mapper/graylog--vg-root /               ext4    errors=remount-ro 0       1
# /boot was on /dev/sda1 during installation
UUID=f3c82967-d226-4c5a-99bd-2ecb6a31adfc /boot           ext2    defaults     $
/dev/mapper/graylog--vg-swap_1 none            swap    sw              0       0
A lsblk -a mi daje sljedeći rezultat:
Code:
fd0                                         2:0    1     4K  0 disk
sda                                         8:0    0  19.5G  0 disk
├─sda1                                    8:1    0   243M  0 part /boot
├─sda2                                    8:2    0     1K  0 part
└─sda5                                    8:5    0  19.3G  0 part
  ├─graylog--vg-root (dm-0)     252:0    0  15.3G  0 lvm  /
  └─graylog--vg-swap_1 (dm-1) 252:1    0     4G  0 lvm  [SWAP]
sdb                                         8:16   0   100G  0 disk
loop0                                       7:0    0         0 loop
loop1                                       7:1    0         0 loop
loop2                                       7:2    0         0 loop
loop3                                       7:3    0         0 loop
loop4                                       7:4    0         0 loop
loop5                                       7:5    0         0 loop
loop6                                       7:6    0         0 loop
loop7                                       7:7    0         0 loop
Znači ovdje ovaj sdb od 100Gb "vidim"...
Zadnje izmijenjeno od: Wuchko. 29.07.2017. u 12:44.
Wuchko je offline   Reply With Quote
Staro 28.07.2017., 14:45   #392
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Bilo bi lakse citati da je u CODE tagovima.
Po meni samo trebas nastaviti. Disk je tu, ali nema particije i filesystem.
Code:
#kreiras particiju
$ sudo parted -a optimal -- /dev/sdb unit compact mkpart primary ext3 "1" "-1"
#kreiras fs
$ sudo mkfs.ext4 /dev/sdb1
Losa dokumentacija, ali samo nastavi. Kasnije ces kada napravis particiju, kopiras itd. dodati tu novu particiju u /etc/fstab.
cccp je offline   Reply With Quote
Staro 29.07.2017., 12:41   #393
Wuchko
Wuchko's Avatar
Postovi: 556
Puno hvala na odgovoru! Ispravio sam prijašnji post. U međuvremenu sam uspio, no na nešto drugačiji način (logiran sam kao root user):
Code:
$parted /dev/sdb
(parted) -a optimal /dev/sdb mklabel gpt
(parted) -a optimal -- /dev/sdb unit compact mkpart primary ext3 "1" "-1"
(parted) quit
$mkfs.ext4 /dev/sdb1
konstantno me je bunilo to što mi je prva naredba davala onu "info" poruku, uporno sam mislio da nešto nije u redu.. Znači bilo bi ok i da sam samo nastavio.. Tek sam počeo s Linuxom pa je i razumljivo da mi dosta toga nije jasno
Staro 29.07.2017., 14:16   #394
cccp
cccp's Avatar
Postovi: 1,030
Mislim da smo svi vise-manje na slijepo nabadali i s vremenom ucili. Iskristalizirat ce se to, samo naprijed.
Staro 31.07.2017., 15:49   #395
Wuchko
Wuchko's Avatar
Postovi: 556
Evo mene opet. Dakle, sada bih na radne stanice trebao instalirati Graylog Collector Sidecar da bi Graylog mogao prikupljati logove. I sve to uredno radi dok je GCS upaljen i vidljiv na radnoj površini, no ono što me muči je - kako ga dodati kao Windows service, znači da se vrti neprimjetno u pozadini? Na ovom linku postoje upute no uopće ne kužim na koji način ovo riješiti, posebno ove dijelove:
Code:
$ C:\Program Files (x86)\nxlog\nxlog -u
$ collector_sidecar_installer.exe
Code:
$ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service install
$ C:\Program Files\graylog\collector-sidecar\graylog-collector-sidecar.exe -service start
Gdje unosim ove naredbe, u kojem programu?
Puno hvala!
Staro 31.07.2017., 16:56   #396
cccp
cccp's Avatar
Postovi: 1,030
All following commands should be executed on the remote machine where you want to collect log data from.
Pretpostavljam u Command promptu na remote masini/radnoj stanici.
Skini NXLog i instaliraj. Ugasi servis koji se automatski pokrece
Code:
Skini Sidecar paket i pokreni ga iz CMD-a
Code:
$ putanja/do/datoteke/collector_sidecar_installer.exe
Pratis korake za instalaciju i na kraju pokrenes servis
Code:
Nisam nikada instalirao ni koristio Graylog pa je moguce da sam omasio.
Staro 31.07.2017., 19:37   #397
Wuchko
Wuchko's Avatar
Postovi: 556
Uspio sam pokrenuti, no sada dobivam poruku "Access denied". Ništa, prespavat' pa sutra isprobavat ponovno
EDIT: šugavi AV je blokirao pokretanje, sad je sve ok (bar mislim).
Zadnje izmijenjeno od: Wuchko. 31.07.2017. u 19:51.
Staro 31.07.2017., 23:59   #398
Eladio
..starija garda
Eladio's Avatar
Postovi: 3,280
Pitanje je možda više za neki drugi dio podforuma, VM i slično, ali da probam tu.
Kupio sam 250hdd i stavio linux tek toliko da s vremena na vrijeme mogu ga malo probati. Stavio sam ZORIN OS u dual boot, i za sad sam zadovoljan.
Pitanje je, s obzirom da mi se neda izlaziti iz windowsa, da li se može iskoristi ta instalacija linuxa da se pokrene virtualna mašina pa da iz windowsa vrtim linux?
MojSkuter
Staro 01.08.2017., 00:44   #399
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,799
Autor Eladio Pregled postova
Imas VmWare Converter.
Vjerojatno ima neki export u OVF pa ga mozes vrtiti u bilo kojoj virtualki poslje.
Programer
Staro 01.08.2017., 00:45   #400
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,332
https://www.google.hr/search?q=conve...hrome&ie=UTF-8
Staro 12.08.2017., 22:44   #401
Libertus
Libertus's Avatar
Datum registracije: Jul 2017
Lokacija: Ramura
Postovi: 2,836
Od kada sam prešao s Linux Mint 17.3 na 18.2 (čista instalacija, nije nadogradnja), ne radi mi VPN.
Znači uredno, s istim openvpn datotekama napravim import openVPN veze kroz GUI. Sve prođe bez greške, uredno se spoji na VPN server, ali internet ne radi, tj. niti jedna stranica se ne može učitati.
Ima li tko ideju kako riješiti?
VPN server 100% radi, ako se spajam preko mobitela ili drugih računala radi bez greške.
Staro 27.08.2017., 19:52   #402
gnjepar
gnjepar's Avatar
Postovi: 642
"Niti jedna stranica se ne moze ucitati" nije bas neki podatak. Koji error dobijes? Jel ti resolva DNS ime u adresu? Jel imas spojivost kad pingas neku IP adresu npr. 8.8.8.8?
Kad si spojen na VPN pogledaj si rute (netstat -r) i napravi ping pa traceroute na neku IP adresu za koju znas da bi trebala ici preko VPN-a. Moguce da je nesto s firewallom isto, mozda drugacija defaultna pravila na 18.2.
The Truth
gnjepar je offline   Reply With Quote
Staro 27.08.2017., 22:16   #403
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,836
Autor gnjepar Pregled postova
1. Error ne dobijem nikakav. Spoji se na VPN server uredno. Da napomenem, radim sve preko GUI-a.
2. Kada radim ping, npr. na pcekspert.com, uredno mi se pojavi:
Code:
ping pcekspert.com
PING pcekspert.com (185.103.217.199) 56(84) bytes of data.
Znači, dobio je IP za pcekspert.com, ali ne može pingati, tj. 100% packet loss.
3. Ne mogu pingati 8.8.8.8, 100% packet loss.
4. netstat -r
Code:
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
default         10.4.0.1        0.0.0.0         UG        0 0          0 tun0
default         unknown         0.0.0.0         UG        0 0          0 enp3s0
10.4.0.0        *               255.255.0.0     U         0 0          0 tun0
link-local      *               255.255.0.0     U         0 0          0 enp3s0
185.189.112.10  unknown         255.255.255.255 UGH       0 0          0 enp3s0
192.168.1.0     *               255.255.255.0   U         0 0          0 enp3s0
Ovo dalje ne mogu, jer koliko ja znam, niti jedan IP neće proći.
Inače, VPN je podešen automatski, samo sam napravio import .ovpn datoteke, i inače je to radilo bez problema, ali evo, sada ne. Pokušao mijenjati razne postavke u GUI, ali ništa nije urodilo plodom, pošto ukoliko idem ručno po .ovpn datoteci i provjeravam sve u GUI, izgleda mi da je sve uredno postavljeno.
Staro 09.09.2017., 23:21   #404
gnjepar
gnjepar's Avatar
Postovi: 642
Meni se cini da je ovo visak:
Code:
Ovaj unknown se mozda kolje sa ovo linijom iznad. Ako je cilja da sav promet ide preko VPN-a onda ova boldana linija to sprecava. Ajde postaj izlaz od
Code:
netstat -nr
naredbe molim te.
The Truth
Staro 10.09.2017., 00:05   #405
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,836
Ajde postaj izlaz od netstat -nr naredbe molim te.
Code:
0.0.0.0         10.4.0.1        0.0.0.0         UG        0 0          0 tun0
0.0.0.0         192.168.1.1     0.0.0.0         UG        0 0          0 enp3s0
10.4.0.0        0.0.0.0         255.255.0.0     U         0 0          0 tun0
169.254.0.0     0.0.0.0         255.255.0.0     U         0 0          0 enp3s0
185.189.112.10  192.168.1.1     255.255.255.255 UGH       0 0          0 enp3s0
192.168.1.0     0.0.0.0         255.255.255.0   U         0 0          0 enp3s0
Staro 10.09.2017., 01:43   #406
gnjepar
gnjepar's Avatar
Postovi: 642
Probaj obrisati tu rutu sa
Code:
route del -net 0.0.0.0 gw 192.168.1.1 netmask 0.0.0.0 dev enp3s0
The Truth
Staro 19.09.2017., 11:15   #407
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,274
Imam dva pitanja.
1) dali postoji koji program bolji/brži od firefoxa, a opet jednako funkcionalan, troši mi dosta rama?
2) di mogu u linux mintu pogledati hardware specs koji se nalaze u mojoj konfiguraciji?
ševa!
Staro 19.09.2017., 11:37   #408
Postovi: 17,143
Za hardware pročitaj ovo.
Ja osobno koristim Chrome, ali korsiti još više rama.
Probaj Operu.
Staro 19.09.2017., 11:46   #409
Libertus
Libertus's Avatar
Lokacija: Ramura
Postovi: 2,836
Code:
Nije pomoglo.
Staro 21.09.2017., 13:46   #410
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Autor Libertus Pregled postova
Code:
ova ruta 0.0.0.0 10.4.0.1 ti radi problem. Nju moraš maknuti.
Net mora ići kroz 192.168.1.1. Kad si tu rutu obrisao, naravno da nije pomoglo
dakle 0.0.0.0 - sav ostali promet guraj kroz lokalnu mrežu koja ima gateway 192.168.1.1 koristeći interface enp3s0
10.4.0.0 mrežu idi kroz gateway 0.0.0.0 koristeći interface tun0 koji je tvoj vpn
Staro 21.09.2017., 22:38   #411
gnjepar
gnjepar's Avatar
Postovi: 642
@Mihael - da ali cilj je da sav promet ide preko VPN-a, ne samo ta mreza. Moguce i da sam ja krivo shvatio.
The Truth
Staro 21.09.2017., 23:04   #412
bertone
bertone's Avatar
Datum registracije: Mar 2010
Postovi: 2,063
Autor ALiEN17 Pregled postova
Imam dva pitanja.
- Abrowser - koristio sam ga davno dok sam koristio Trisquel
- Palemoon - nisam ga nikad probao ali znam par ljudi koji su bili jako zadovoljni njime
Jedan tekst na Hr gdje autor razmišlja što koristiti ako FF ode u bananu.
- terminal i upišeš naredbu
Code:
lshw
- ako misliš na GUI onda instaliraj hwinfo (trebao bi biti u bazi softvera ili kak' se već to zove)
Zadnje izmijenjeno od: bertone. 22.09.2017. u 01:04.
bertone je online   Reply With Quote
Staro 22.09.2017., 00:39   #413
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,332
Imam dva pitanja.
1 - http://midori-browser.org/
2 - lshw
Staro 10.10.2017., 22:22   #414
apekop
Ape
apekop's Avatar
Datum registracije: Jan 2012
Postovi: 157
Bok, danas sam se odlučio prebaciti s "prozora" na Linux u potpunosti tako da ću malo visiti ovdje od sada . Ja sam web developer (također na početku karijere) i do sada sam imao Linux samo u VM-u i probao sam ih par kroz sad nekih cca 10mjeseci (Mint / Ubuntu / Elementary / CentOS / Fedora / Debian itd ..). Izabrao sam Mint KDE za glavni distro. Ja stvarno nisam stručnjak za Linux, znam osnovne stvari koje moram znati za posao, čak ni s tim još nisam na ti baš pa oprostite ako imam glupa pitanja.
U svakom slučaju, imam sharkoon tipkovnicu i miša, i TP-link wi-fi adapter za PC, ništa od toga ne radi u Mintu. Jel se to može kak složit jer ovak mi je totalno propao plan prebacivanja, mogu upalit komp i gledat desktop
P.S. imam i laptop lenovo thinkpad t420, na njemu sve normalno radi
Apekop
apekop je offline   Reply With Quote
Staro 10.10.2017., 22:30   #415
bertone
bertone's Avatar
Postovi: 2,063
Autor apekop Pregled postova
A da li možeš (ako nije tajna zbog koje bi nas morao ubiti) napisati koji model tipkovnice, koji model miša i koji model WiFi kartice? Znaš, to bi nam puno pomoglo
Staro 10.10.2017., 23:09   #416
apekop
Ape
apekop's Avatar
Postovi: 157
Autor bertone Pregled postova
mogu mogu Sharkoon Skiller je tipkovnica, a miš je Sharkoon Drakonia, adapter je TP link - model: TLWN823N
Apekop
Staro 10.10.2017., 23:27   #417
bertone
bertone's Avatar
Postovi: 2,063
1. ništa pametno nisam našao
2. ništa jednostavno nisam našao
3. https://forums.linuxmint.com/viewtopic.php?t=233212
Staro 11.10.2017., 00:07   #418
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,293
Da tebi ne treba neki driver za plocu, tocnije usb kontroler na ploci?
Staro 11.10.2017., 00:31   #419
bertone
bertone's Avatar
Postovi: 2,063
Nije jedini koliko sam vidio sa tom tipkovnicom i mišem koji ima problema na Linuxu. Imao sam i ja problem sa nekom backlight Genius tipkovnicom koja je malo radila malo ne na Linuxu pa sam se vratio na IBM mod.M i sa njom nikakvih problema
Staro 11.10.2017., 01:19   #420
apekop
Ape
apekop's Avatar
Postovi: 157
Ma vidim, trazim cijelo popodne neko rjesenje ali neuspjesno. Najbolje mi otic po drugu tipkovnicu i mis ako mislim vec koristit linux skroz. Malo me to odbija moram priznat.
A kad prikljucim mis i tipkovnicu na laptop rade normalno
Apekop
