Staro 03.10.2017., 21:37   #2791
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Autor Gilbert5 Pregled postova
A u sta to mozes uloziti a da ti se vrati ulozeno kroz 12 mjeseci?
Više toga. Recimo 3d vizualizacije.
Ali napominjem; ulaže se vrijeme i trud.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je online   Reply With Quote
Staro 03.10.2017., 21:52   #2792
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Autor estugarda Pregled postova
U rudarenje se ulaze minimalno truda, pogotovo ako imas neko osnovno predznanje.
Meni 3d vizualizacije ne znaci nista. Imam milju kuna viska i hocu uloziti. U sta jos mogu uloziti da ima povrat sredstava u slicnom vremenskom intervalu?
Staro 03.10.2017., 22:06   #2793
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
U kupovinu coina umjesto majnanje?
Staro 03.10.2017., 22:21   #2794
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,604
Da FRipper, opiši nam to malo kako je to kod tebe
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 03.10.2017., 22:23   #2795
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
A to je sasvim 2. red veličina ako imaš milju viška. To je meni nešto nepojmljivo, kao i većini. Kad imaš milju viška, onda možeš ulaziti u razne priče, jer onda (ako nisi glup) rizik ionako znači nešto drugo; manje strašno.
Ne znam. Za sada, koliko sam naučio o rudarenju (vrlo malo), ne vidim kako bih mogao profitirati ni dugoročno. Rado bih naučio doduše.
EDIT:
Evo FRipperovih rigova, iz njegovih usta (odnosnu prstiju) kad nam neće sam reći. Neće se valjda ljutiti.
kako je išao redoslijed nabavke?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Zadnje izmijenjeno od: estugarda. 03.10.2017. u 22:45.
Staro 03.10.2017., 22:45   #2796
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Jednostavnije mi je ovo sve prekinuti, jer ne vodi nikamo...
Netko tko ima takvo razmišljanje, nije za ovaj težak posao...
Pa eto, prekidamo daljnje rasprave
Staro 03.10.2017., 22:58   #2797
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Šteta. Ne znam gdje sam pogriješio razmišljajući, ali prihvaćam odluku. U svakom slučaju zahvaljujem na uvodnom postu i pomoći.
Evo teme koja bi mogla biti od koristi početnicima; Slike vasih rigova (rig p0rn)
Vizualni sam tip pa mi je puno lakše sagledati cijelu priču kad vidim o čemu se radi. Ovaj rig na zidu je zakon!
"All in all it's just another rig in the wall"
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 03.10.2017., 22:58   #2798
gunther
Postovi: 1,368
...ali ipak, nesto bi nam mogao reci...
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 03.10.2017., 23:18   #2799
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Mogu samo reći da od previše razmišljanja boli glava. Treba krenuti, jer ako nas rudara ima toliko svuda po svijetu, onda valjda i ima u tome nešto profita.
Mislim vidite i po cijenama grafičkih, i po maloj dobavljivosti...
Sada nije bajno, ali opet nije niti minus. I bolje lova u dijelovima koje gledaš kako štancaju lovu, nego da stoji u ormaru/banci/itd...
Jedina mana u svemu tome od rudarenja, je onaj dio "nikada nije dosta" i nikada da prestaneš ulagati, jer ljudi su lakomi, i nikada nam nije dosta...
Staro 03.10.2017., 23:30   #2800
gunther
Postovi: 1,368
Wooooooww!!!!!
O, veliki si!!!!
Staro 04.10.2017., 16:42   #2801
Cooltywattor
Datum registracije: Sep 2017
Lokacija: Vršac
Postovi: 5
ASUS GTX 1060 Dual 6GB White, stara 3 meseca. Vredi li dati 160e za ovo?
Cooltywattor je offline   Reply With Quote
Staro 04.10.2017., 16:47   #2802
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,006
Autor Cooltywattor Pregled postova
naravno da vrijedi...nabavi i meni par komada
Staro 04.10.2017., 20:46   #2803
smurf
Lokacija: Cakovec
Postovi: 32
Napravio sam popis za rig za koji mislim da bi mogao biti solidan pa vas molim da prokomentirate/savjetujete ako ima nešto bolje/kompatibilnije za uskladiti, hvala!
Riseri - 6 komada, USB 3.0 kablovi 50cm
Matična ploča - Gigabyte H110-D3A, s.1151
CPU - Intel Celeron G3930 Celeron G3930, Socket 1151
Napajanje - Corsair PSU, 1000W, RMx Series COR-CP-9020094-EU
Grafulje - AMD Sapphire Radeon RX 570 Nitro+ OC, 4GB - 6 komada
RAM - 8GB
Hard disk - 120GB SSD
Zadnje izmijenjeno od: FRipper. 04.10.2017. u 20:52.
smurf je offline   Reply With Quote
Staro 04.10.2017., 20:54   #2804
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
8 rama ti ne treba, 4 je dosta.
SSD ti je dosta 60, ali i mislim da je bolje uzeti 16GB stick pa staviti linux, simple mining
Staro 04.10.2017., 22:00   #2805
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Simplemining nema dagfix. Winsi su za sad bolja opcija.
Staro 05.10.2017., 14:17   #2806
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Ima ima ... u download sekciji, odmah ispod linka dosadasnjeg RX OS-a
Staro 05.10.2017., 14:41   #2807
smurf
Lokacija: Cakovec
Postovi: 32
Moj dobavljac kaze da nema gore trazenih grafulja pa pita dal je ok ovo nize, a ja molim vas da pogledate pa me savjetujete da li da ih uzmem ili cekam Saphire ili neki drugi brand.
hvala puno!
XFX RS XXX ED RX 570 4GB OC+ 1284M D5 3xDP HDMI DVI
Staro 05.10.2017., 14:57   #2808
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ok je i to. Realno svejedno...bilo koja rx570 4gb je ok
Staro 06.10.2017., 00:06   #2809
Uzi84
Datum registracije: Jul 2017
Lokacija: Vinkovci
Postovi: 170
Sta par? Pardeset.
Uzi84 je offline   Reply With Quote
Staro 06.10.2017., 15:10   #2810
vulkan1
Datum registracije: Aug 2017
Postovi: 111
Evo jedno moje mišljenje iz velikog iskustva u investicijijama.
Prvo da objasnim čestu dvojbu zašto mining
a ne financijski ulazak?
Meni su sva financijska tržišta jako bliska (forex, fondovi, dionic),
1. uložiš u invest. tržište a sve se iz ne znam kojeg razloga uruši može doći i NULA ,
(na vlastitoj koži; vrhunske stvari došle u smiješne cifre i obratno; bez logičnog objašnjenja osim psihologije tržišta; pročitao o otme knjige i knjige)
2. ako uložiš u RIG sve je dosta sigurnije ali ako dođe do eksponencijalnog rasta
propustiti će se ŠLAG NA TORTI)
3. 50% U JEDNO % 50% U DRUGO (možda optimum)
p.s. osobnog sam mišljenja da svi koji prodaju i plaćaju troškove struje čine kardinalnu
grešku, osim ako nisu previše izloženi riziku koji ne mogu iinancirati drugaćije.
p.p.s. veliki skok cijene može sve okrenuti u jednu lijepu priću.
Ovo nije savjet na način ulaganja nego osobni stav autora ovog posta
Zadnje izmijenjeno od: vulkan1. 06.10.2017. u 15:17.
vulkan1 je offline   Reply With Quote
Staro 06.10.2017., 15:12   #2811
vulkan1
Postovi: 111
Hvala na pažnji....
Staro 06.10.2017., 18:43   #2812
snhelix
Datum registracije: May 2017
Lokacija: rijeka
Postovi: 76
stalno se provlači ista priča,a i iste pouke,eto vulkan1 opet sažeo smisao.oprezno ulagati,raspršiti rizik,ne riskirati preko mogućnosti.
čitajući forume mining zajednice stječem dojam da osim želje za čistom zaradom tu postoji i želja za učenjem,istraživanjem novih tehnologija,stječu se neka sretstva kojima se može trgovati(na taj način bezbolnije se educiramo o financijskim tržištima).
zapravo cijela jedna nova niša interesa.
ja ne vidim bitno veću razliku od gamera koji stalno ulažu u bolji hardware jureći više sličica u minuti po sve većim monitorima,pa čine to sebi za užitak a tako i mi mineri,ako uz to još štogod $$ i kapne gdje ćeš većeg veselja.
snhelix je offline   Reply With Quote
Staro 08.10.2017., 13:47   #2813
vulkan1
Postovi: 111
Sve sam podesio na 5 RX 570 rog(elpida)
Postavim brzinu na 1040 i 1900 (ako krenem na večim brzinama javi grešku za 10 minuta)
radi bez problema i nakon 2 i po sata jedna kartica ne radei, tj pool
prijavi da je možda previše overklikana.
Kada to pol prijavi usporavam na bilo koju brzinu sve kartice
ili samo tu koja zeza i opet isto.
Jeli netko zna u čemu je kvaka.
p.s. detektirao sam karticu jer sam mjenjar risere položaje i
slično i greška se javlja baš na jednoj kartici.
Sada sam smanjio POWER -48 da vidim dali će to pomoć jer sam iscrpija sve mogučnosti
dok ne počme zezat radi oko 134 Mh/s-a temperatura od 58 do 71.(5 kartica)
Pošto mi jedna kartica koja je na ploči najhladnija
Hvala
Zadnje izmijenjeno od: vulkan1. 08.10.2017. u 13:53.
Staro 08.10.2017., 14:09   #2814
silasara
Postovi: 67
Jedno pitanje jer bi i ja malo probao trading na burzama.
Dali mogu na nasoj stranici bitcoin-mjenjacnica kupit odredenu svotu bitcoina i za adresu upisat adresu koju mi je kraken burza dala za deposit od mog konta?
znaci sjedne mi na kraken odredena svota pa onda mogu izvrsit prodaju ili zamjenu za druge coine?
silasara je offline   Reply With Quote
Staro 08.10.2017., 14:15   #2815
grudobran
Unregistered user
grudobran's Avatar
Lokacija: Dwarfpool
Postovi: 119
Možeš
grudobran je offline   Reply With Quote
Staro 08.10.2017., 15:14   #2816
silasara
Postovi: 67
Autor grudobran Pregled postova
Možeš
Znaci samo upisem adresu na koju sjeda bitcoin, uplatim pare i cekam da sjedne ili moram jos sto napravit?
Staro 09.10.2017., 17:58   #2817
cryptmax
Datum registracije: Oct 2017
Postovi: 9
Jedno pitanjce.
Majnam eth već par mjeseci sa msi gtx 1070 8gb (x6).
Razmišljam o još jednom rigu sa 6 grafičkih pa me zanima vaša preporuka za grafe do 3000kn.
Naletio sam na ovo Sapphire Nitro RX580 4GB - 2399kn
Jedino me sad kopka zašto je baš ova grafa dostupna a skoro sve ostale RX580 od 4gb i 8gb su nedostupne. Ima li koja kvaka za koju ja neznam?
Naravno, bilo kakva preporuka za grafičku je dobrodošla. Ne mora biti rx580 (to sam naveo kao neki primjer). Cijena između 2000-3000kn.
Nije mi bitno da bude najjeftnija nego nakvalitetnija u tom cjenovnom rangu.
Ne želim da mi rig rikne nakon par mjeseci ako je u igri razlika od parsto kuna po kartici.
Sa ovim gtx-icama imam cca 30.5-31 mh/s po kartici sa klokanom memorijom.
Zadnje izmijenjeno od: FRipper. 09.10.2017. u 19:32.
cryptmax je offline   Reply With Quote
Staro 09.10.2017., 19:34   #2818
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Sapphirke su po meni najbolje, pogotovo ako je Elpida gore onda računaj da to ide 30MHs.
Evo baš slažem rigove sa Sapphire Nitro 570 i Sapphire Nitro 580, sve idu preko 30 sa modanjem biosa.
Sve u svemu za tu lovu je najbolji izbor. A da li će riknuti, tak svejedno jel bila najjeftinija ili najskuplja, sve ovisi kako te potrefi ali zato imaš garanciju pa si bez brige.
Staro 09.10.2017., 20:58   #2819
cryptmax
Postovi: 9
Thx...jel' mi se isplati uzeti 4gb ili da idem na 8gb?
Btw...gdje da vidim dal' je Elpida memorija?
Gledao sam u nekoliko naših web dućana, ali nigdje ne piše proizvođač memorije.
Staro 09.10.2017., 21:09   #2820
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
4GB, ne vidim razloga uzimanja 8GB jedino ako je cijena blizo...
Ne možeš vidjeti dok ne dobiješ grafu, instaliraš ju i vidiš u GPU-z.
