Staro 16.08.2017., 00:11   #1711
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Znači ništa od cannonlakea na desktopu. Bilo je i ranije glasina o tome
@Dottore otkud ti to?
Ja sam u zadnje vrijeme čitao glasine da coffe kao ipak hoće ići na 1xx i 2xx čipsete, saznat ćemo uskoro
Staro 16.08.2017., 00:35   #1712
Dottore
Dottore's Avatar
Postovi: 7,706
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 16.08.2017., 00:36   #1713
Dottore
Dottore's Avatar
Postovi: 7,706
Negdje sam vidio da će podržavati.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 16.08.2017., 02:25   #1714
shar
Overclocker
shar's Avatar
Datum registracije: Nov 2016
Postovi: 523
Zar nisu asrock i... slagat ću, al mislim giga rekli da coffee neće ić na stare ploče, što zapravo tvoja linkana slika i pokazuje: kaby na 200, coffee na 300.
shar je offline   Reply With Quote
Staro 20.08.2017., 19:03   #1715
Postovi: 8,566
Canadian etailer publishes Intel 8th Gen Desktop CPU prices
  • INTEL BOXED 8TH GEN INTEL I7-8700K PROCESSOR [BX80684I78700K]: $484.44
  • INTEL BOXED 8TH GEN INTEL I7-8700 PROCESSOR [BX80684I78700]: $407.73
  • INTEL BOXED 8TH GEN INTEL I5-8600K PROCESSOR [BX80684I58600K]: $338.00
  • INTEL BOXED 8TH GEN INTEL I5-8400 PROCESSOR [BX80684I58400]: $237.58
  • INTEL BOXED 8TH GEN INTEL I3-8350K PROCESSOR [BX80684I38350K]: $233.41
  • INTEL BOXED 8TH GEN INTEL I3-8100 PROCESSOR [BX80684I38100]: $152.51
The release tomorrow should be a paper launch as there are no processors available or stock to be found anywhere. For more info on the specififcation of these coffee lake processors, have a look here.
Mind you these are CAD prices not listed at USD. So the 8700K at 484.44 would be 389 USD and 329 Euro. These prices would be exclusive of VAT.
PC Canada has not delivery ETA yet mentions that the procs are estimated to arrive on 2017-09-16.
Ryzen kompletno na stranu, ali Intel Core i7-8700K bi prema ovome imal istu cijenu kao i Core i7-7800X koji je u prodaji točno dva mjeseca.
Oba su 6C/12T, dok 8700K ima viši radni takt, 12MB L3 cachea, 95W TDP, ali samo dual-channel podršku i 24 PCI-E staze na raspolaganju.
Staro 20.08.2017., 20:06   #1716
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,836
/cut/
Ako bude kako je i najavljeno, mogao bi taj 8700K biti bolji procesor neko 7800x u većini benchmarka. Veća brzina jezgre donijet će dobar rezultat u singlethreadu a niti u multithreadu neće puno zaostajati.
Sinac je online   Reply With Quote
Staro 20.08.2017., 20:10   #1717
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Zbroji 6700K + 7350K multithread rezultate i to će biti otprilike rezultat 8700K
Staro 20.08.2017., 20:32   #1718
Sinac
Sinac's Avatar
Postovi: 2,836
Autor Smartic Pregled postova
Druga je arhitektura u pitanju, mislim da će rezultati biti bolji od 6700K i 7350K ali pričekajmo realne benchmarke.
Staro 20.08.2017., 20:55   #1719
markecSMB
Lokacija: Cro
Postovi: 1,041
Autor Sinac Pregled postova
Zašto bi zaostajao u multithreadu, pogotovo ako će imat veći IPC+veći takt i više cache.
Bit će brži u apsolutno svemu
Staro 20.08.2017., 21:37   #1720
Manuel Calavera
Postovi: 14,589
Pa ista je arhitektura kao mainstream skylake, samo je više jezgri
Staro 20.08.2017., 21:49   #1721
Sinac
Sinac's Avatar
Postovi: 2,836
https://hothardware.com/news/intel-c...1-faster-7700k
Kako ista kad je Coffee Lake u pitanju? Vidi se razlika u potrošnji a performanse ostavimo za realne benchmarke, ovi preview rezultati su ionako banana od informacije.
Staro 20.08.2017., 22:13   #1722
Postovi: 8,566
U svakom slučaju izgleda obećavajuće, pogotovo Core i5-8400 6C/6T i običan Core i7-8700 sa 65W TDP-om + HD Graphics 630 iGPU.
Staro 20.08.2017., 22:42   #1723
Manuel Calavera
Postovi: 14,589
To su podaci od intela, vidjet ćeš kad izađu. Prema njihovim grafovima je i kaby kao 15% ispred skylake. IPC bi trebao biti isti skylake 1151, odnosno kaby, a singlehread kao takav može biti bolji samo povećavanjem clockova
Staro 21.08.2017., 10:09   #1724
Sinac
Sinac's Avatar
Postovi: 2,836
https://www.reddit.com/r/intel/comme..._core_i78700k/
Drugačije je raspoređen cache i drugačija je arhitektura, još uvijek ne znamo kako će se ponašati prodajni primjerci, za sada ovi rezultati koji cure s inženjerskih primjeraka izgledaju obećavajuće.
Evo nekih testova:
http://www.cpu-monkey.com/en/cpu-int...e_i7_8700k-763
Uzmimo te rezultate s rezervom jer nisu službeni.
Staro 21.08.2017., 11:21   #1725
Manuel Calavera
Postovi: 14,589
Ima neki leak za ove laptop ulv verzije, spominje se samo veći multithread zbog duplo više jezgri/threadova (2c4t vs 4c8t), no ni riječi o većem ipc-u niti singlecoreu općenito.
Što se tiče i7 7700K vs i7 8700K, ovaj drugi će izgleda imati 200mhz veći singlecore boost
Staro 21.08.2017., 12:00   #1726
shar
Overclocker
shar's Avatar
Postovi: 523
Baš me zanimaju temperature, pogotovo ako tvrdoglavo nastave sa korištenjem smeća od paste ispod IHS-a.
Staro 21.08.2017., 12:16   #1727
Manuel Calavera
Postovi: 14,589
Da, tu će po prvi puta biti hexa uz igpu, visoki clockovi (doduše osnovni clock je 3.7ghz naspram 4.2ghz kod i7 7700K) + ako stave pastu odnosno njihovu majonezu...
Zadnje izmijenjeno od: Manuel Calavera. 21.08.2017. u 12:27.
Staro 21.08.2017., 13:40   #1728
Postovi: 8,566
Možda postoji šansa, ali IMHO teško da budu nakon svih ovih godina odustali od svoje paste, posebice kad su namazali i kompletnu Skylake-X garnituru.
The first wave of processors based on Intel's new 14 nm Coffee Lake silicon will be 6-core parts in the Core i5 and Core i7 brands, which will be launched on 22 August; with Core i3 following on much later in the year, or even early-2018. The boxes confirm several things about these chips, beginning with the fact that their integrated graphics cores will be branded "Intel UHD Graphics 6xx," and that they will require motherboards based on Intel 300-series chipset, even though their socket is "LGA1151."
There doesn't appear to be a socket key difference between these processors and "Kaby Lake," so it's possible that while 300-series chipset motherboards support older "Kaby Lake" and "Skylake" processors, "Coffee Lake" will only work on 300-series chipset, and not older 200-series or 100-series. Intel making the bold move of branding its new integrated graphics "UHD" could hint at its credentials with hardware-accelerated decoding of new video formats such as 10-bit VP9 at 4K without breaking a sweat; and new display connector standards such as HDMI 2.0 and DP 1.4.
Staro 21.08.2017., 14:06   #1729
Manuel Calavera
Postovi: 14,589
Staro 21.08.2017., 17:41   #1730
tiki66
tiki
tiki66's Avatar
Postovi: 2,766
Znači ništa do negdje 10. mjeseca, taman da rasprodaju ovo što imaju.
Staro 21.08.2017., 19:35   #1731
Dottore
Dottore's Avatar
Postovi: 7,706
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Zadnje izmijenjeno od: Dottore. 21.08.2017. u 20:37.
Staro 21.08.2017., 20:37   #1732
bachvamix
bachvamix's Avatar
Datum registracije: Apr 2017
Postovi: 52
Šteta što sam potratio dvadesetak minuta na livestream. Za prijenosne su rekli 2 do 13 puta brži sistem u odnosu na sistem star 5 godina. I ostalo valjda dolazi u listopadu.
Zadnje izmijenjeno od: bachvamix. 21.08.2017. u 20:55.
bachvamix je offline   Reply With Quote
Staro 24.08.2017., 20:23   #1733
Manuel Calavera
Postovi: 14,589
Moglo bi ipak biti kao što Sinac kaže - coffee lake cca 6% IPC poboljšanje u cpu-z
http://wccftech.com/intel-coffee-lak...nchmarks-leak/
Kontam da bi onda coffee lake bio cannonlake arhitektura na 14nm kojeg nisu mogli spičit na 10nm
Kao što su prethodni linkovi pojasnili 8 generacija obuhvaća 3 vrste proizvoda - kaby refresh za laptope (zato su leakovi u zadnje 2 god. mislili da neće biti ipc poboljšanja) na 14nm +, coffee lake (14++) za desktop, te cannon lake za ultra low power cpu (10nm)
Mada treba uzet i u obzir da cpu-z nije najpouzdaniji bench na svijetu, pogotovo ako je usporedba sa različitim verzijama
Zadnje izmijenjeno od: Manuel Calavera. 24.08.2017. u 20:35.
Staro 29.08.2017., 21:43   #1734
Sinac
Sinac's Avatar
Postovi: 2,836
Nešto noviji benchmarci 8700K, dosta obećavajući:
http://wccftech.com/intel-core-i7-87...-8-core-ryzen/
Staro 29.08.2017., 22:46   #1735
Dottore
Dottore's Avatar
Postovi: 7,706
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 01.09.2017., 15:35   #1736
Manuel Calavera
Postovi: 14,589
First benchmarks and temps of the Intel Core i9-7980XE flagship processor; Intel Core i9-7920X tested as well with liquid cooler
The benchmark was conducted on a test setup that was running a water cooling setup (it is unknown whether it was closed loop) and showcases surprisingly good thermals. So good, in fact, that the user speculates that Intel might actually have used soldered as the TIM instead of the usual paste found in the rest of the Core-X lineup. He was able to reach an all-core clock speed of 4.8 GHz with temperatures staying below 90c (this would be decent temps for even the 7900X).
The vcore was set to auto and saw a peak of about 1.25v – which is once again pretty acceptable for an OC run. While we wouldn’t recommend a 4.8 GHz OC on any Core-X series processor, all of this information means that clocks like 4.4 GHz+ (at 1.18 vCore) should be very achievable by most users (depending on ambient temperature and the silicon lottery of course) and shows an incredible amount of horsepower tucked behind the surface of the 7980XE.
http://wccftech.com/intels-core-i9-7...st-benchmarks/
Staro 06.09.2017., 11:50   #1737
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Staro 07.09.2017., 14:42   #1738
Smartic
Smartic's Avatar
Postovi: 2,707
Staro 07.09.2017., 21:13   #1739
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,884
da dodam tablicu sa ubrzanjima
Staro 07.09.2017., 22:54   #1740
Lepac
Datum registracije: Apr 2014
Lokacija: Zg zupanija
Postovi: 107
Još kad bi i cijene takve bile kod nas
Lepac je offline   Reply With Quote
