Staro 26.07.2017., 14:46   #4861
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
none
Staro 26.07.2017., 15:13   #4862
Postovi: 34,105
Za tu lovu su jedino mogle 'ispasti iz kamiona'. Ili je lik na krivo mjesto stavio zarez.
Staro 26.07.2017., 15:16   #4863
FERRYS
FERRYS's Avatar
Postovi: 2,159
ja uhvatio jednu , u najgorem slučaju ostajem bez 350kn...
ima još i PowerColor RED DEVIL Radeon RX 580 8GB isto za 50 usd
none
Staro 26.07.2017., 15:24   #4864
Postovi: 34,105
Smrdi mi na skori refund
Ima i Zotac GTX 1060 6Gb za 40$.
Staro 26.07.2017., 15:29   #4865
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,531
m da. to nebi ni gledo. to ima napisano fake all over...
Staro 26.07.2017., 15:35   #4866
FERRYS
FERRYS's Avatar
Postovi: 2,159
Ma siguran sam 99.99% da je fejk ali uvijek ostaje ona sumnja da možda i nije.
a baš mi treba grafa..
rizik koji me ništa ne košta
none
Staro 26.07.2017., 15:51   #4867
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Samo te kosta odavanje adrese i privatnih podataka nepoznatoj osobi s nepoznatim motivima :-)
Staro 26.07.2017., 16:39   #4868
RAUL
Lokacija: Worldwide
Postovi: 2,553
This listing (**********) has been removed, or this item is not available.
    • Please check that you've entered the correct item number
    • Listings that have ended 90 or more days ago will not be available for viewing.
Staro 26.07.2017., 16:47   #4869
FERRYS
FERRYS's Avatar
Postovi: 2,159
none
Zadnje izmijenjeno od: FERRYS. 26.07.2017. u 16:58.
Staro 27.07.2017., 13:39   #4870
FERRYS
FERRYS's Avatar
Postovi: 2,159
We had to remove this listing from the site and you're not required to complete the transaction. If you've already sent payment, the sale should process as normal and you don't have anything to worry about. If you have any questions about delivery, please check tracking or contact your seller. If you run into any trouble along the way eBay is here to help. Please visit the Resolution Center to help resolve any problems you may encounter
none
Staro 28.07.2017., 10:35   #4871
prowler
prowler's Avatar
Lokacija: split
Postovi: 218
Kad kliklnes na njegove feedback odma vidis da je lik do sada iskljucivo kupovao, nikada prodavao. I sad odjednom prodaje grafulje ispod cijene...yeah right...Dakle, vjerojatno je liku hakiran račun.
U zadnje vrijeme ih je masu na ebayu, uglavnom prodaju sve ispod cijene i nemaju feedback, ali tu i tamo se nađe ovakav gdje ima feedback ali mu je hakiran account. Onda idem u detalje i uglavnom se ispostavi da lik ili nikad nije prodavao ništa ili je uvijek prodavao zubne paste a sad odjednom hrpu skupog hardware...
prowler je offline   Reply With Quote
Staro 28.07.2017., 12:06   #4872
Postovi: 34,105
Koja korist hackeru od toga? Jedino što mi pada na pamet je da hacker digne lovu, a ebay isplati refund iz svog džepa. To bi jedino bilo moguće ako je lik vezao PP na ebay account pa je hacker provalio i na njegov PP account.
Staro 28.07.2017., 14:44   #4873
prowler
prowler's Avatar
Lokacija: split
Postovi: 218
to sam i ja nedavno pitao jel mi nije bilo jasno i evo da ti kopiram odgovor kolege sa foruma:
Autor webstartm Pregled postova
+ paypal zadržava novac max 21 dan nakon transakcije. Kad prodje 21 dan, mali hacker povuće kesh na karticu, odspoji karticu/ugasi je u banci , i zaboli ga k za caseove koje će se otvarat tek nakon 30+ dana.
Onda eBay vraća pare iz svog đepa.
Staro 07.08.2017., 19:54   #4874
ALiEN17
ALiEN17's Avatar
Lokacija: Histria
Postovi: 1,279
stigao paket u roku od 10 dana, uz 5$ poštarine
ševa!
ALiEN17 je online   Reply With Quote
Staro 09.08.2017., 21:03   #4875
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
zadnjih par dana pri pokušaju kupnje uključujući od nekih od kojih sam već kupovao sustav odbija bid/kupnju
" seller not authorized to sell to European buyers"
Munjara je offline   Reply With Quote
Staro 24.08.2017., 22:03   #4876
Los Sam
Los Sam's Avatar
Lokacija: Duga Resa
Postovi: 516
Arrow
Jeste kada imali slucaj da vam je netko u "carinskom" postanskom uredu potpisao i podigao paket? Ovo zadnja adresa prije lokalnog postanskog ureda, pa vlastite adrese...
Dugo paket nije dolazio, isao provjerit...na neku foru jos imam vremena da se zalim...
Jel se netko uspjesno zalio nakon ovakve situacije kada je isporuceno, ali ne i na prijavljenu adresu?
Sutra zovem carinski ured...
Los Sam je offline   Reply With Quote
Staro 28.08.2017., 23:46   #4877
vranjba
vranjba's Avatar
Datum registracije: Aug 2009
Postovi: 613
Ja imao slučaj. Ispostavilo se da je bilo krivo upisano, moj paket stigao koji dan poslje.
Pokreni potražnicu
CPU: AMD Phenom II X2 545 @X4 B45 + AC Freezer 64 Pro PWM
MBO: Asrock a780GXH @ bios 1.70
RAM: Kingmax 2x2GB PC2-8500
VGA: Sapphire HD5570 1GB
Zvučna: Asus xonar d1
HDD: WD6401AALS + WD2000JB + WD3200AAJS
PSU: Corsair cx400W
Case: Gigabyte GZ-X6
Keyboard: Logitech mk520 + Microsoft Natural Wireless Mouse 6000
Daljnski: Mce ir
Zvučnici: Swans d1080mkii 08
Monitori: Philips 220SW + HP L1950g
TV: Panasonic TX-P50C3E
AIO: HP Deskjet F4280
OS: Windows 7 x64
HP Compaq nx7010
CPU: Pentium centrino 2.0 GHz
RAM: 1gb + 512mb PC2700
VGA: ATI Mobility Radeon 9200 32mb
HDD: wd 40 GB
OS: Win XP SP3 x32
CPU: Pentium 3 1.0 GHz + Glacialtech igloo 2520
MBO: Intel D815EFV
RAM: 2x 256mb PC133
HDD: Maxtor 80gb + Seagate Barracuda 7200.7 160gb
PSU: Codegen 400W
OS: Win XP SP3 x32
PCI Lan: Linksys cisco gigabit EG1032 v3
Routher: Thomson ST780i WL
Net: T-com Flat
Acernote lite 350pc
CPU: Pentium 100 MHz
RAM: 8 mb edo onboard
VGA: chips&tech f65545
HDD: ibm 540 mb
OS: win 95
CPU: pentium 166 MHz
MBO: ga 586vx rev 3.37
RAM: 4x16 mb edo ram
VGA: Ati 3D rage II +dvd 4 mb
HDD: quantum fireball se2.1a 2.1 gb
PSU: seasonic ssa-200g
Monitor: Acer 13"
OS: dos 6.22
vranjba je offline   Reply With Quote
Staro 04.09.2017., 12:55   #4878
karabaja
The Zappa
karabaja's Avatar
Postovi: 596
Sve strahujem: Dogovorena suradnja Hrvatske pošte i DHL-a u dostavi paketa.
Sad kad uhljebi stave šapu i na privatnu dostavu, pa krenu naplaćivati 'male pakete'. Strepim! Valjda u DHL-u znaju s kim se pačaju.
karabaja je offline   Reply With Quote
Staro 04.09.2017., 13:11   #4879
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Ne traje li ta suradnja već malo dulje? Barem od početka godine mi DHL pošilje dostavlja naša pošta.
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 06.09.2017., 16:53   #4880
aurelio
Datum registracije: Jan 2010
Lokacija: Slavonija
Postovi: 284
http://www.townandcountrypramcentre.co.uk
izgleda da sam platio cipele u fake trgovini. postoji li kakav način da storniram preko banke isplatu. radi se o uplati internetom preko revolving maestro kartice.
aurelio je offline   Reply With Quote
Staro 06.09.2017., 17:50   #4881
nino
nino's Avatar
Postovi: 12,613
Autor aurelio Pregled postova
Zasigurno nije fake trgovina ako prima karticno placanje. Ne moze to sa bankom ugovoriti bilo tko.
A sad, dali su fake proizvodi, to sam otkrij.
Staro 07.09.2017., 07:19   #4882
aurelio
Lokacija: Slavonija
Postovi: 284
Staro 07.09.2017., 09:22   #4883
acmevagabundo
Datum registracije: Jul 2015
Postovi: 326
Fake je i trgovina, a ne samo proizvodi. Nemoguće je da su svi proizvodi bili 100 funti a sad su 50. Pa čak i oni kojima je redovna cijena ispod 50 funti.
acmevagabundo je offline   Reply With Quote
Staro 07.09.2017., 09:35   #4884
aurelio
Lokacija: Slavonija
Postovi: 284
ma proizvoda niti nema najvjerovatnije.
Staro 12.09.2017., 17:16   #4885
triki555
Lokacija: VŽ
Postovi: 322
4.9. mi je poštar u sandučiću ostavio papirić da imam pošiljku. nisam bio na toj adresi pa sam tek danas isti vidio međutim u pošti su mi rekli da su paketić vratili nazad. što mi je sada najbolje činiti?
triki555 je offline   Reply With Quote
Staro 12.09.2017., 18:04   #4886
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
ovisi tko ti je slao. pravit se blesav i reci da ti nije stiglo traziti novo slanje ili povrat...
generalno ti si kriv
Staro 17.09.2017., 21:36   #4887
prowler
prowler's Avatar
Lokacija: split
Postovi: 218
Lik iz E.U. prodavao jednu stvar na aukciji sta mi treba i pitao ga ja na private moze li za Hrvatsku...on kaze aj moze tolika i tolika postarina..ja ok...pitam ga eventualno i za buy it now cijeni i ispali neku brutalnu cijenu, ja mu se zahvalim i kazem da cu ipak okusati srecu u bidanju. Proslo bidanje i nekim cudom ja dobijem ali po cijeni dosta manjoj nego sto mi je bila maximalna jer iz nekog razloga nije bilo puno drugih biddera. E sad ta cijena nije bas skroz niska, recimo da sam dobio item za 200 eura a realna cijena mu je 320 eur. I naravno kako nakon sto sam pobjedio morao sam mu slati zahtjev da mi posalje ukupnu cijenu, dakle i sa postarinom, jer mu drugacije ne mogu platiti, ni traga ni glasa od njega...pretpostavljam da je lik razocaran cijenom koju je postigao i odlucio se da ne odgovara nista.
Mene zanima pretpostavljam da mu ne mogu nista osim los review? Imam dokaz u private da je pristao na postarinu i ostalo ali naravno ne mogu ga prisiliti da navedeni item posalje?
Usput, da i pisem ebayu da je lik u najmanju ruku mutan o dokazem sve ovo sta pisem, kakve uopce sankcije takvi dobiju?
E i zaboravih napomenuti govorim o liku sa preko 100 trgovina, mislim sa jednim do sada losim reviewem.
Zadnje izmijenjeno od: prowler. 17.09.2017. u 21:41.
Staro 18.09.2017., 01:36   #4888
Mirkopoter
Mirko, a ne Harry
Mirkopoter's Avatar
Postovi: 5,527
Pa ne znam kako to ide s aukcijama, no trebalo bi biti da on MORA poslati item, što ne? I ako ne pošalje da ebay uskače?
Hala Madrid!
Staro 18.09.2017., 10:19   #4889
android-split
android-split's Avatar
Datum registracije: Dec 2015
Postovi: 1,052
Meni se desilo da sam dobio jedan mob ispod cijene i fino je stavija da se mob ostetija i da nema sta poslat i to je bilo to
android-split je offline   Reply With Quote
Staro 18.09.2017., 10:42   #4890
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
prodavač ima navedenu mogućnost i ne možeš mu ništa osim ostaviti loš feedback
