Postovi: 9,067
seed je onaj koji ima kompletni file i dijeli ga. leecher je onaj koji je samo u postupku skidanja, i dakle, nema cijeli file. a peers su svi oni koji skidaju, znaci zbroj seedova i leechera.
___________ Just atha x |
Postovi: 6
....ps....bitno ti je imati što više seedera i to onih sa što boljim uploadom.... |
Kinesiss
Datum registracije: May 2005
Lokacija: Đakovo
Postovi: 40
bilo bi ti dobro prije skidanja s torrenta skinut program peer guardina jer češ inače imati spor download i |
Postovi: 4,190
Postovi: 4,190
ma da....mučim se tu... ![]() |
Kinesiss
Lokacija: Đakovo
Postovi: 40
ja sam probao nekolio torenta i veza mi je uvijek bila spora kad sam instalirao peer guardian počelo je raditi puno stabilnije , više seed-ova i leecher-a, moram probat ovaj bitlord |
Postovi: 18,916
Šta je taj Peer Guardian uopće? Neki plug-in za Azureus?
#12 | |
Lokacija: Zgb
Postovi: 1,108
http://www.utorrent.com/ tezak je tek 105 kb, ima super GUI i opcije i free je:clap: |
Postovi: 18,916
PeerGuardian is a powerful yet petite firewall application especially designed for P2P users and anyone else who wants to protect his or her computer from unauthorized searches instigated by private agencies and corporations. PeerGuardian works by blocking and logging all TCP/IP connections to and from known IP ranges used by known P2P foes, such as the RIAA, MPAA, MediaForce, MediaDefender, BaySTP, Ranger, OverPeer, NetPD, and more. To make sure that the block-list used to block malicious connections is up to date; PeerGuardian uses an on-line block-list Database that is continuously updated on a daily basis -- so your privacy will remain safe while swapping files. PeerGuardian is compatible with all TCP/IP based file sharing applications, such as Kazaa, iMesh, LimeWire, eMule, Grokster, DC++, Shareaza, and more. In short, PeerGuardian is the must have tool for any file swapper. PeerGuardian is not advertising supported, nor does it require registration, and no information is collected from or about product users.
Postovi: 18,916
Koristim Azureus jer ima jako puno opcija, stabilan, brzina (download) uglavnom solidna, spoji se na više peerova nego ostali klijenti,... Jedina mana je što je pisan u Javi.
Kinesiss
Lokacija: Đakovo
Postovi: 40
On blokira per-ove koji ti šalju smeće i time dobiješ stabilniju i bržu vezu. Dok ga nisam imao imao sam malo peer-ova i brzina mi je bila oko 10kb/sec a sad mi je gotovo uvijek ful brzina 128 kb/sec. Probaj nemaš šta izgubit |
#16 |
Postovi: 6
BitSpirit također odličan program. Mogu se porihtat portovi, full smanjit upload, a skida do 80-90% teoretske brzine. ![]() |
