Staro 14.11.2005., 22:16   #1
Brain32
Brain32's Avatar
Postovi: 498
Forceware v81.94
Da, da, opet novi driveri
Release notes:
Adds support for GeForce 7800 GTX 512 and GeForce 6800 GS
Improved performance for Quake 4
Improved performance and compatibility for Call of Duty 2
Mixed vendor support for NVIDIA SLI.
TV-Out/HD-out support for NVIDIA SLI.
Added support for VSync on Direct3D games when running NVIDIA SLI.
Performance enhancements for dual-core CPUs.
PureVideo high definition MPEG-2 de-interlacing support.
Usability enhancements when connecting to an HDTV.
GeForce 7800 GT/GTX, GeForce 6800: Corruption of ʺWidescreenʺ
great shot playback mode is corrupt with AFR2 mode set in Tiger
Woods 2006.
GeForce 7800 GTX/GT: Running OpenGL Games after Direct3D
hangs the system.
GeForce 6800: Incorrect rendering in Half Life 2 Lost Coast / Day of Defeat.
GeForce 6 Series: With the latest FarCry 1.33 patch, HDR mode may not work.
This is an issue with the application, and will be fixed in the next patch for the game.
Quadro FX 1300, Quadro FX 3400: Using GLSL
gl_ModelViewMatrixInverse generates warnings.
GeForce FX 5950 Ultra: Battlefield 2 intermittently fails to show fog
on some distant objects.
GeForce4 Ti, GeForce FX 5600: Java applications crash upon exiting.
Link(tu su i x64 i mobile): ftp://download.nvidia.com/Windows/81.94/
Brain32 je offline   Reply With Quote
Staro 14.11.2005., 22:31   #2
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Ajd ti meni sad kazi koji su najbolji drajveri za 6800 seriju??
Staro 14.11.2005., 22:58   #3
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Ja ću izgleda morat preći na te bete jer ovi sucksaju ruši se NFS:MW demo
Pošteni Trgovci: 1,2
Staro 14.11.2005., 23:42   #4
Daddy
The Kwisatz Moderach
Daddy's Avatar
Postovi: 921
Koje su se oni droge najeli?Nisam jos 89-ke probo a ono 94???
Staro 15.11.2005., 00:44   #5
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Ja ih sad skidam pa da vidim razliku u Quakeu 4 jel zna netko kako se pokreče onaj demo da mi izmjeri FPS u Quake 4?
Veki-os je online   Reply With Quote
Staro 15.11.2005., 00:55   #6
Brain32
Brain32's Avatar
Postovi: 498
Quake4 nazalost nema built-in demo, al mozes skinut sa hwspirit.com(samo prek torrenta - 50MB).
Cuj, meni su 81.89 najbolje sjeli, ali opcenito rokaj s 81.87 pa na dalje...
@SniperWolf u release notes-ima pod "unresolved issues" pise za artefakte(no ne i za rusenje:confused: ) u NFS:MW i da ce to bit rijeseno u sljedecim driverima...
Ja s tim na srecu nemam problema
Staro 15.11.2005., 02:13   #7
Veki-os
Veki-os's Avatar
Postovi: 3,996
Evo stavio sam ih i igra ide puno glađe,vide se poboljšanja,pošto nemam demo ne znam točno za koliko ali bolje je.
Zašto je FPS ograničen na 60?Imam NVRefreshTool i naređeno mi je da je na 1024x768 85Hz tako da zbog Hz-a nije.
Staro 15.11.2005., 11:39   #8
Brain32
Brain32's Avatar
Postovi: 498
Ne znam, al' evo ti objasnjenje i rjesenje
com_fixedTic [-1,0,1] - If set to 0 (the default) Quake 4's ticrate is capped at 60, meaning the game framerate cannot exceed 60FPS, except when running a timedemo. If you want to remove this cap, set "com_fixedTic to -1". Setting it to 1 removes the cap, but causes the game physics to go out of sync. Removing the FPS cap doesn't necessarily improve performance, and can lead to more variable framerates. Any frames over 60FPS will typically be duplicates and hence there is no real performance benefit.
Staro 15.11.2005., 22:48   #9
Crypt0
Crypt0's Avatar
Postovi: 174
ima li kakav link za forceware 81.89 posto ih nema na nvidia stranici Tnx
Crypt0 je offline   Reply With Quote
Staro 15.11.2005., 23:27   #10
Daddy
Daddy's Avatar
Postovi: 921
Staro 15.11.2005., 23:41   #11
Crypt0
Crypt0's Avatar
Postovi: 174
Tnx
Staro 16.11.2005., 03:28   #12
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,320
..opet ja sa svojim:dakle je li ima ovo smisla stavljati na karticu iz siga ?
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 16.11.2005., 10:46   #13
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Ja uvijek čekam i koristim samo Xtreme G modded drivere i nikad problema, a perfomanse bolje od normalnif drivera
Nemam više lema!!!
Staro 16.11.2005., 13:43   #14
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
ja koristim ove 81.94 par dana i nisu losi
igram NFS MW Demo i AA, sve super
ali isto tako nije ni neka velika razlika u odnosu na ostale 81. (barem ja nisam primjetio)
DeadMan+ je offline   Reply With Quote
Staro 16.11.2005., 15:11   #15
Vuco
Vuco's Avatar
Postovi: 9,505
Evo nasao preko google-a te xtreme G 81.89 pa cu si ih skinut...znaci ti su najbolji ?
Mislim, nikada nisam imao modane drajvere vec uvijek origigi...
Staro 16.11.2005., 15:52   #16
LorD ClockaN
od LemilicE
Postovi: 4,712
Ne znam ako su najbolji, ali ja ih koristim već jako dugo.
Pazi da ne skineš mobile forceware. www.tweaksrus.com je homepage
Nemam više lema!!!
Staro 16.11.2005., 20:39   #17
Crais
Crais's Avatar
Datum registracije: May 2005
Lokacija: Zgb - shpaolin
Postovi: 641
Komp mi je poludio s ovim novim driverima. Odjednom crni ekran, i na njemu samo miš (može se micat). Na bilo koju kombinaciju tipki na tipkovnici ne reagira. Otvorim cd rom i slika se vrati!! I onda se nakon 2 sekunde potpuno smrzne, tak da ga moram resetirat na gumb. To mi se danas 2 puta dogodilo, a nikad prije.
Crais je offline   Reply With Quote
Staro 16.11.2005., 23:55   #18
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
ja stavio ove 81.94 i stvaraju mi p***arije u ssamu2...
edit; i u aoe3
none
Zadnje izmijenjeno od: FERRYS. 17.11.2005. u 13:38.
Staro 17.11.2005., 14:21   #19
Beren
PC Ekspert šerif
Beren's Avatar
Datum registracije: Feb 2002
Lokacija: Vječno u labu...
Postovi: 1,496
Ja sam ih rabio i nisam imao apsolutno nikakvih problema.
Za sve one koji imaju problema, da li ste maknuli i očistili stare drivere prije instalacije novih drivera?
Beren je offline   Reply With Quote
Staro 17.11.2005., 15:16   #20
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Beren, sve sam radio ok sa driver cleanerom i sva ta sranja nakon uninstalla starih drivera - i opet isto. Smrzava Most Wanted demo i nekak mi je CoD2 počeo štekati kada ima puno vojnika (nakon D-dana misije):confused: eh da, driveri su oni od lorda extreme modani
Staro 17.11.2005., 15:33   #21
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Ja sam radio sa službenim driverima i nisam imao problema, čak ni nakon šaltanja ATI/NV grafičkih kartica.
Staro 17.11.2005., 16:23   #22
LorD ClockaN
od LemilicE
Postovi: 4,712
Meni Xtreme G nikad nisu radili problema, niti se ne siječam kad sam zadnji put imao referentne drivere.
Nemam više lema!!!
Staro 17.11.2005., 17:52   #23
p5ych0p4N
Postovi: 18
Šta točno znači ovo?
"PureVideo high definition MPEG-2 de-interlacing support."
AMD Athlon 64 X2 5000+ Black Edition
MBO DFI, s. AM2, LAN PARTY DK 790FX-M2RS
RAM, 4 GB (2GB + 2GB), DDR 2, PC-6400
VGA PCI-E POINT OF VIEW, 9600 GT Extreme
580 W ATX 2
p5ych0p4N je offline   Reply With Quote
Staro 17.11.2005., 21:13   #24
Hrubi
Hrubi's Avatar
Datum registracije: Sep 2004
Postovi: 817
nakon uninstala starih drivera dovoljno je pobrisati samo nv4_disp.dll file i potom instalirati nove.Ja tako radim stalno i sve je ok
Hrubi je offline   Reply With Quote
Staro 20.11.2005., 22:01   #25
Kurtz
Kurtz's Avatar
Postovi: 84
Da li ima netko instalirane 81.85 i ima li s njima problema?
Kurtz je offline   Reply With Quote
Staro 21.11.2005., 00:34   #26
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Ja sam imao na testnom stroju i nisam imao problema. Doduše, bijah na kavi u subotu s jednim od programera iz Croteama i on mi je rekao da nVidia ima zajeban bug u svim driverima iz serije 8x.xx. Neki k. s računanjem oclussiona - ako igra rabi određeni algoritam, u jednom se trenutku sruši zbog infinite loopa. Jedna od takvih igara je i SS2. Čudo...meni se to pri testiranju nije događalo. :confused:
Staro 21.11.2005., 00:48   #27
Daddy
Daddy's Avatar
Postovi: 921
Ja ih imam sad, nemam nikakvih problema s njima.Malo su mi smanjili rezultat u 3DM05 ali zato igre idu gladje i to dosta (osim ako fraps ne laze)
Inace koristio sam te Extreme G neke 78.** i to je bio cisti uzas, performanse desetkovane, riva divlja, pokazuje neke sulude frekve jezgre od nekih 200-tinjak MHz a da se dici do kud ti srce zeli ali nema utjecaja na performanse, u biti nema utjecaja na nista tek toliko da pise.
Grafa o kojoj se radi je 7800GTX
Staro 21.11.2005., 00:51   #28
Veki-os
Veki-os's Avatar
Postovi: 3,996
Izgleda da se meni zato SS2 ruši.Kako oni to opisuju,mislim kako se sruši?Ja npr. igram pola sata normalno i onda najednom slika bude ala matrix theme pa moram sa ALT+F4 izlaziti
Staro 21.11.2005., 11:52   #29
Beren
PC Ekspert šerif
Beren's Avatar
Postovi: 1,496
Pa mislim da je to nešto takvo.
