#31 |
Datum registracije: Apr 2017
Lokacija: Cres
Postovi: 12
evo copy-paste što čovjek piše: I cant help you with the old package and guide , BUT I can maybe help you run android 5.1 or 6.0 on your device . A brief digression on why I am replying to your post at all : I recently got a Microsoft Surface Pro , wanted to dual boot Android alongside Windows on it , and had luck with 2 automated ways : 1. Remix OS installer (pretty straight forward installation, I'm recommending you to install it on a NTFS partition , as it allows you to create am data.img partition of desired size) 2. Using this tool : http://forum.xda-developers.com/windows-8-rt/win-8-development/winapp-android-x86-installer-uefi-t3225748 to install a .img 5.1 ( http://www.fosshub.com/Android-x86.html/android-x86_64-5.1-rc1.img ). Android to your PC/tablet/laptop from Windows enviroment (again , to a NTFS partition , as it lets you set a large enough data partition without you having to biold it via command prompt and copying that file to your instalation partition). Tried both versions , both worked , but since Wi-Fi didnt work ond that 5.1 image I was forced to use Remix , and i dont like how deeply customized it is ... I like to AOSP look of Android-x86.org images ... but i could not install any of those since my Surface has UEFI ONLY "BIOS" . THIS IS THE MAIN REASON FOR ME TO WRITE THIS POST ... I found a way to install any image to a partition of my choice and set up a custom EFI module to boot any OS you set it to boot . I Installed the latest 6.0 iso image from this link http://www.fosshub.com/Android-x86.html/android-x86-6.0-20160318.iso ( Android-x86.org ) like this : a) Download grub2win from https://sourceforge.net/projects/grub2win/ , install it and get to know how to use it . b) Download an Android image you would like to install to your HDD . c) Make a bootable USB drive from it (I use Lili http://www.linuxliveusb.com/ ) . d) Make a NTFS partition on your hard drive in a size you would like ... I made a 36 gigabyte one , because I did not know how much the installation would take and I wanted a 32 gigabyte data.img partition. e) Reboot your tablet/PC , and pres that button combo that makes it ask you for boot drive selection ... pick the USB you just created . Pick "Android installation entry from the menu that pops up ) . Pick the NTFS partition you created as the one you would like Android to be installed to ( !!! Be careful NOT TO PICK THE PARTITION YOUR WINDOWS IS INSTALLED TO !!! ) . Installer will ask you to format the partition , which you dont have to do if you just created it earlier . After it finishes copying the files , installer will ask you to install grub and grub 2 , install them . Next - installer will ask you to format the boot partition - DONT FORMAT it . Next - make the system R/W , and finally , create a virtual SD card in size that you need . f) Reboot to windows g) Start grub2win and install the module first http://prnt.sc/b6j1o6 then http://prntscr.com/b6j27h then http://prntscr.com/b6j2i4 then http://prntscr.com/b6j2qc then http://prntscr.com/b6j3p7 then http://prntscr.com/b6j48f then http://prntscr.com/b6j4df then http://prntscr.com/b6j7tk then click "apply" then click "o.k." at the bottom right on the main menu , then "close" and voila ... YOUR UEFI machine can now boot Android as well as Windows . Sry if i made mistakes or this sounds confusing ... ask questions if you need something . Zadnje izmijenjeno od: Zarko007. 14.04.2017. u 21:28. |
#33 | |
Lokacija: Cres
Postovi: 12
http://linuxbsdos.com/2015/03/26/and...n-a-usb-stick/ upsss, sad tek pažljivo čitam ovo uputstvo, treba imati dva usb sticka, jedan s kojeg se boot-a s iso datotekom, drugi za instalaciju.... Zadnje izmijenjeno od: Zarko007. 14.04.2017. u 22:29. |
#34 |
RESPECT MY AUTHORITAH
Postovi: 7,506
Zanimljivo da kada se baterija isprazni i želi se uključiti tablet dobijem Android animaciju da je baterija prazna; ![]() Btw što je opcija "Uštedi bateriju kada tablet osjeti da nisam blizu uređaja"?
#35 |
Lokacija: Cres
Postovi: 12
evo ukratko uspio sam dignuti android 6.0 64 bit verzija preko usb. Prvo što sam primjetio je da ne radi wifi...u rufusu je bitno izabrati gpt kod kreiranja bootabilnog usb-a |
#36 |
Postovi: 7,506
Koju točno verziju? Touch precizan? Radi li sleep/deep sleep, kamera, trg play, microsd, hdmi itd? Jesi probao još Android-x86 5.1-rc1 EFI image (64-bit OS) Android-x86 6.0 - Remix OS for PC - 64 bit (Legacy & EFI) http://www.android-x86.org/download Kako pri bootu odabereš Android, da li samo Live preview ili kako?
#37 | |
Lokacija: Cres
Postovi: 12
https://osdn.net/projects/android-x8...64-6.0-r1.iso/ iskreno, kad sam vidio da wifi ne radi nisam dalje istraživao...probat ću sad ove dvije...kod boot-a mi nudi 4 opcije, 1. je taj live preview ako se ne varam, 2. je nešto debug, 3. instalacija androida, 4. windowsi...izabrao sam 1. sad vidim da sam ovaj Android-x85 5.1-rc1 EFI image (64-bit OS) već skinuo, ali mi javlja nešto kao file corrupted i ne otvara ga.... Zadnje izmijenjeno od: Zarko007. 16.04.2017. u 22:24. |
#38 |
Postovi: 7,506
Si odavde probao 5.1? https://osdn.net/projects/android-x8...4-5.1-rc1.img/ Btw zašto instaliraš 64 bitnu verziju?
#39 | |
Lokacija: Cres
Postovi: 12
#41 |
Lokacija: Cres
Postovi: 12
#42 |
Postovi: 7,506
Onda osim Androida 6.0 64 bitnog ne ide? Nisi probao 64 bitnu tj koja radi 5.1? Probaj Android 5.1. (za Chuwi Hi10 PRO), ima isto sklopovlje kao naš ionik https://chuwiinnovationtechnologyshe...l4fbq353skonrp EDIT: Pokušavam baš ja preko rufusa staviti to na usb, može male upute kako je tebi pošlo za rukom?
. Zadnje izmijenjeno od: Ag008. 17.04.2017. u 21:09. |
#43 | |
Lokacija: Cres
Postovi: 12
#44 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,128
Moja debilna malenkost se rukom naslonila na tablet pri čemu je napuknuo ekran ![]() Točnije,puklo je staklo, ekran je čitav. Touch ne radi. Zanima me ima li netko ideju isplati li se uopće popravljati? Ako da, kak popraviti ![]() Mislio sam naručiti možda sa ebaya ili aliexpressa pa sam zamijeniti, ali ak netko ima prijedlog - slušam ![]()
#46 |
Postovi: 7,506
Imaš na Aliexpresu digitizer baš za ovaj ionik za 30$ https://www.aliexpress.com/item/Whit...047581015.html
#49 |
Postovi: 7,506
Do prije mjesec dana sve radilo normalno. No sada, ne radi utor za SD karticu, tj ne mogu otvoriti sd karticu. Umetnem sd karticu, pojavi se u Exploreru, no ne mogu otvoriti sadržaj. Ako pritisnem desni klik na SD-u sve se smrzne dok ne izvadim fizički karticu. ![]() Aplikacija koja je na SD-u nakon cca 30s piše "Umetnite disk u D uređaj". Nemam pojma je li do drivera ili čega, kada spojim istu sd karticu preko usb adaptera radi normalno. Više SD kartica probao, niti jedna neće. Ima tko ideju? Može tko provjeriti koje verzije drivera ima u Double driveru, jesu li starije od ovog ![]() vlasnici, otvorite dobule driver, SCAN drivers i poredajte po datumu te stavite sliku ovdje. Prije cca 3 tjedna se instaliralo ažuriranje 1607, ne znam je li do toga. Tek sam sada pokušao otvoriti app na D i primjetio to. Nemam više backup i ne mogu se vratiti na prethodnu verziju win 10. Ako bi netko mogao sa svog tableta koji nema Creative update USB Hub, USB 3.0 drivere. Meni nisu u backup-u jer su od Microsofta.
#50 |
Postovi: 7,506
Guglam i brojni imaju probleme uz intel Z8300 i sd card. Tj Chuwi Hi8 Pro SD card problem. Windows 10 Creators možda nije zeznuo već samo od sebe, mjesecima mi je radilo sve. Ne mogu ažurirati drivere, kaže da je već najnoviji kada i probam od Chuwija staviti stare. http://www.mediafire.com/file/34u54d...2D3_Hi8Pro.zip No, ja nemam kao neki problem da uopće ne očita SD karticu, meni je očita, kreira mi se mapa WindowsApps i WUDownloadCache, mogu nešto i spremiti, očitati (ispod 1mb, neki txt), no nakon 10s ne mogu više otvoriti ni jednu mapu, datoteku ni spremiti. Čitao 10 tema na forumima, nekima radi na sd karticama ispod 4gb. Da i ja to probam. Stavio svoju prastaru microsd 4gb class 2. H2testw uredno spremio i očitao svih 4gb. Spojio opet 16gb karticu, 32 gb i 8gb rekao je da je moram formatirati za korištenje, formatirao. H2testw započeo, na 1024Mb je zaglavio 30s i greška "Can not store- disk is not accessible" te je kartica nestala iz Explorera tj Explorer ima beskonačno čekanje u očitavanju Mojeg računala.
#51 |
Postovi: 34,104
Dokle ćeš se ti hebati s tim smećem od tableta? Skuri ga, prijavi RMA i traži povrat love pa si kupi pošteni tablet.
#54 |
Postovi: 104
Pokušaj downloadati SDI https://sdi-tool.org/download/ |
#55 |
Postovi: 7,506
Izvadio 4Gb i stavio 16Gb koje sam našao u starom fotiću. RADI Ta začudo radi. Iste oznake Transcend 16Gb ne radi, ni GSkill 32Gb evo, ali ova radi. Ali mali problemčić, postavio sam da je instalacija novih aplikacija iz WIN Store D drive, ali neće instalirati. Krene preuzimati, ali uvijek ne preuzme ni 1B i "Pogreška prilikom instalacije, pokušajte ponovo" tj Something happened this app couldn’t be installed. Please try again. Error code: 0x8007000B Zahebao sam se jer mi je Candy Crush Saga bila na onoj od 4Gb, pa nije imao što ažurirati kada je mapa prazna, sada sam je "deinstalirao" ali i dalje niti jednu app ne želi instalirati na D drive. S time da sam sada Libreoffice bez problema (ali exe, ne trgovina) instalirao na D preko instalacije.
#56 |
Postovi: 7,506
Update: Ova od 16Gb radi, nemam pojma zašto druge nisu a ova radi. Uspio riješiti problem i sa Windows Storeom. Formatirao karticu i tada je kreiralo Windows apps mapu kako treba a radi i ostalo. ![]() Još nisam skužio kako trebam snimiti na USB Linux da ga pokušam dignuti, Android očito ništa ali nisam uspio ni Linux. Ili ga nema uz GPT na popisu u BIOS-u ili ako ga ima, ne boota već opet ode na win. Zahvaljujem svima na ovom monologu i problemu iz 6mj te onima koji su mi rekli da je ovo smeće od tableta ![]()
#57 |
Xulos :)
Postovi: 7,581
Mozd nebitno, al ovo je jedini uredaj kojeg sam ispravnog bacio u elektronicki otpad. Ovakvo sfusano govno nisam imao jos od onog prvog tmobile touch uredaja na 1.6 androidu... Ovo ni poklonio nebi koliko je smece... |
#59 |
Postovi: 7,506
Imam problem prilikom punjenja, igličasti punjač mi prekida, puni samo u određenim položajima itd (igličasti od 2A) A USB punjenje je sporo (puni samo s 0.5A i više se prazni nego puni kada je taj način punjenja) Bi to bilo do samog punjača ili utora, ima tko kakav lijek?
#60 |
laser
Postovi: 2,356
Kakav clickbait potpis, umrijet cu! ))))))))))))))))))))))))))))))))))))))))))Ti si Trifon Ivanov Pce foruma! Sretno s punjenjem tableta. Citajuci ovaj topic ini se da je problem jednostavno u kvaliteti citavog uredaja. |
