#511 | |
Lokacija: Čazma
Postovi: 1,728
baš sam primjetio da mi se sad brzina vrti oko 30 a prije išla preko 52... <mytubeelement id="myTubeRelayElementToPage" event="preferencesUpdated" data="{"bundle":{"label_delimitor":":","percentage":"%","smart_buffer":"Smart Buffer","start_playing_when_buffered":"Start playing when buffered","sound":"Sound","desktop_notification":"Desktop Notification","continuation_on_next_line":"-","loop":"Loop","only_notify":"Only Notify","estimated_time":"Estimated Time","global_preferences":"Global Preferences","no_notification_supported_on_your_browser":"No notification style supported on your browser version","video_buffered":"Video Buffered","buffered":"Buffered","hyphen":"-","buffered_message":"The video has been buffered as requested and is ready to play.","not_supported":"Not Supported","on":"On","off":"Off","click_to_enable_for_this_site":"Click to enable for this site","desktop_notification_denied":"You have denied permission for desktop notification for this site","notification_status_delimitor":";","error":"Error","adblock_interferance_message":"Adblock (or similar extension) is known to interfere with SmartVideo. Please add this url to adblock whitelist.","calculating":"Calculating","waiting":"Waiting","will_start_buffering_when_initialized":"Will start buffering when initialized","will_start_playing_when_initialized":"Will start playing when initialized","completed":"Completed","buffering_stalled":"Buffering is stalled. Will stop.","stopped":"Stopped","hr":"Hr","min":"Min","sec":"Sec","any_moment":"Any Moment","popup_donate_to":"Donate to","extension_id":null},"prefs":{"desktopNotification":true,"soundNotification":true,"logLevel":0,"enable":true,"loop":false,"hidePopup":false,"autoPlay":false,"autoBuffer":false,"autoPlayOnBuffer":false,"autoPlayOnBufferPercentage":42,"autoPlayOnSmartBuffer":true,"quality":"hd720","fshd":false,"onlyNotification":false,"enableFullScreen":true,"saveBandwidth":false,"hideAnnotations":false,"turnOffPagedBuffering":false}}"></mytubeelement><mytubeelement id="myTubeRelayElementToTab" event="relayPrefs" data="{"loadBundle":true}"></mytubeelement> |
#512 | |
Datum registracije: Jan 2017
Postovi: 283
#514 |
Postovi: 136
Zadnji dan u ovom mjesecu, potrošnja prvi put dosad danas /31.03/ mi prešla 100 gb. Učinio sam to namjerno da vidim kada budu turisti na brzini 1/1 mbps kako će to ići. Obavijestila me sekretarica /automat/ od vipa da sam prešao 100 gb. Čak i "ona stvar" radi na toj brzini ali iptv ne, tako i tako to gledam samo ja. Bit će im sasvim dovoljno za poslati/primiti koji e-mail, WhatsApp, viber, surfati - ali film si neće moći pogledati. To će biti za one u zadnjem tjednu mjeseca, ovim drugima prije mislim da će biti dovoljna potrošnja pola vip-ovog rezervoara /50 gb/, meni je dosta ona druga polovica. ![]() www.speedtest.net/my-result/a/2749239767 |
#515 |
Sandy!!!
Postovi: 1,695
Net za apartmane
Da ne otvaram novu temu, povezano je sa mobilnim netom za pokući ![]() Malo gledam što uzeti za apartmane, gdje nema parice/adsl/vdsl U prosjeku boravi 12-15 ljudi u kuci (preko ljeta,preko zime nema nikoga) Mislim da je 100Gb malo za 30 dana Naletih na ovo https://www.hrvatskitelekom.hr/visiting-croatia 7 dana 4G flat 80kn Znači misečno cca 350kn Apartmani puni 3 miseca , izadje 1050kn Ruter jednokratno nabavim za 500kn (koliko vidim router moze automatski slat sms svako 7 dana, al nisam siguran? ) A homebox turbo je 150kn, jel treba ugovorna obveza? tj svih 12/24 miseci placat? Prva opcija mi zvuči bolje, al malo kompliciranije, pogotovo oko slanja sms svako 7 dana. Jel neko zna dali se može to preko appa od tcoma ili preko weba? |
#516 | |
Datum registracije: Mar 2017
Postovi: 210
#518 |
Postovi: 3,552
Evo možda još nekome zatreba, kako rebootati ZTE MF283+ preko skripte. Ovo je za curl, ima i windows verzija lako se nađe na netu. Code:
curl -s -m 3 -d "goformId=LOGIN&password=moj_pass_hash" -e "http://192.168.1.10/index.html" "http://192.168.1.10/goform/goform_set_cmd_process" curl -s -m 3 -d "goformId=REBOOT_DEVICE" -e "http://192.168.1.10/index.html" http://192.168.1.10/goform/goform_set_cmd_process ![]() Možda bi se dalo i elegantnije napisati, ali za početak je ok, sad to lijepo ide u cron i jednom tjedno ili češće reboot radi onog primijećenog pada brzine veze nakon par dana. |
#519 |
Datum registracije: Apr 2013
Postovi: 4
Pozdrav ekipa,danas su mi uključili homebox turbo,zanima me kakvi su vasi dojmovi,da li vam izdrži cijeli mjesec? Ja sam ga danas koristio 2-3 sata,skinuo sam oko 1gb preko torrenta a ostalo je bilo samo speed test i jedan video na youtube-u,i evo sad pogledam u ruter i pise potroseno 5gb cini mi se malo previse u tako kratkom vremenu.Brzina nije loša 50/25. EDIT(nakon daljnjeg testiranja shvatio sam da jedan test brzine interneta na stranici http://www.speedtest.net potroši oko 120mb,a ja sam ih danas odradio puno dok sam tražio pravo mjesto za ruter,mislim da je zbog toga potrošnja ogromna) Zadnje izmijenjeno od: jura249. 05.04.2017. u 19:15. |
#520 |
Postovi: 283
Naišao sam na odašiljač-lokaciju s kojeg primam 4g signal na homeboxu, evo uslikao sam kako to izgleda. Samo ne znam jel su te čelije na onome velikom širokom stubu, ili na onima malima stubovima pokraj, ima 3 manja ne znam za što su oni. Zadnje izmijenjeno od: selk. 29.12.2025. u 17:24. |
#521 |
Datum registracije: Apr 2017
Lokacija: Zabok
Postovi: 6
Poštovani, uzeo sam vip homebox turbo. Živim na rubnim dijelovina brzina mi je od 3 do 25 mbps downloada s tim da sam stavio modem na tavan na najvišu točku. Molio bih vas savjet koje antene mi dodatne preporučujete vanjske ili unutarnje koje bi lovile bolji signal.. Hvala unaprijed! |
#522 |
Lokacija: doma
Postovi: 2,924
Svi nesto nose na tavan Mada sam prije isprobao tavan, ljep je dan i reko ajd idem opet malo mrdati no ovog puta sam sa jednom stap antenom.Evo 2 mjerenja sacuvao ss. ![]() ![]() ![]() U kuci je 60/30 sada recimo... Evo setup kako je izgledao ![]() Inace na toj gredi nisam prije probao, jesam na prozoru i tamo je signal slabiji, oko -67/68 pa mi nije ni palo na pamet prije stavljati na gredu kada je zid. Ispod 80Mbps uglavnom s tog mjesta ne ide ali nema potrebe da ga radi toga drzim na tavanu, po noci kada je flat, 80Mbps dobijem i iz kuce a preko dana ne vidim sto bi mi trebalo brze od ~60Mbps.
trebaš seedbox? |
#523 |
Lokacija: Zabok
Postovi: 6
Poštovani našao sam neke antene na e bayu pa me zanima dali bi bile u redu da ih naručin, koja od ovih bi bila bolja za vipov homebox? http://www.ebay.com/itm/122183831864?redirect=mobile http://www.ebay.com/itm/4G-LTE-Dual-...257Ciid%253A33 |
#524 |
Datum registracije: Aug 2014
Postovi: 2,953
@silver_tip jesu ti ikada odgovorili iz vipa vezano za antene i konektore ? I mrzim te lol. Meni brzina pala na 18 / 26 Poslano sa mog SM-G930F koristeći Tapatalk |
#525 | |
Lokacija: doma
Postovi: 2,924
Nijedna, to su sve igracke, zali boze para... Citiraj:
Kad i ako nabavim uredjaj a da nije 500kn bice jasnije kad ga raskupusam ko svinjce na klanju, no 500kn ne dam za taj hoby. Utjecaja nekoga imaju ali ne onako kako bi to trebalo biti, pogotovo je nejasno zasto je sa 2 recimo stap antene ili njihovim lopatama prijem gori vs jedna stap ili lopata sa desne strane iskljucivo gledajuci od naprijed modem. Jedna ljevo ili 2 odjednom ne daju tako dobar rezultat kao samo jedna se desne strane, to je ono sto sam za sada utvrdio testiranjem. Jedna napomena da tko god isprobava sa tim stap antenama od routera, one su SMA zenski prihvat dakle nemaju PIN koji strsi kao na vip-ovim lopatama jer takav pin nalazi se na ulazu za prihvat antene na routeru kakvom. Treba uzeti od koaksilnog kabla za tv srednju bakrenu zicu u duljini 14mm te istu ugurati u stap antenu, ide malo teze ali ide i nece se sama iscupati jer konektor kod vip routera ili bilo kojega drugoga sa prihvatom sma muskog konektora/antene je izveden tako da se "stipaljka" unutra siri na prolaz PIN-a / zice. ![]() @buljaka Razlistalo se drvece, palo je i meni preko dana na 60Mbps sa 70Mbps... to je bilo ocekivano. Takodjer nocu sam vukao po 84/85Mbps a sada jedva dobaci 80Mbps. Pa evo, renatam ti ja svoj tavan Dobis zapravo za djabe, sam moras uzet 5GHz WiFi opremu za link do svoje kuce, naravno jedan LAN izlaz od tvog routera ide kod mene u komp ![]()
trebaš seedbox? |
#526 | |
Datum registracije: Aug 2013
Postovi: 4,361
Navedeni gain "Gain: 35 dBi" je uvreda zdravom razumu i svatko tko vjeruje tom podatku treba kupit takvu antenu za izljecenje ![]() |
#527 |
Sandy!!!
Postovi: 1,695
Može par linkova za antene koje stvarno valjaju i rade (vanjske)? Treba mi za TP-Link TL-MR6400 http://www.tp-link.com/sa/products/d...TL-MR6400.html , tj netreba mi još,al moguće da će trebati, kad odem na lokaciju i testiram brzine. Taj router ima svoje dvi antene. Ebay/aliexpress SMA |
#528 |
Postovi: 283
#529 |
Postovi: 4,361
#530 |
Postovi: 4,361
#531 | |
Lokacija: doma
Postovi: 2,924
pa vidi ...Evo pogledaj sliku, kolega predlozio TL-MR6400 pa pogledaj unutarnji ustroj pcb-a i kako ide sa konektora na GSM modem. ![]() Vidis i sam, cista veza izmedju konektora i modema. Pogledaj sad pcb ovog vipovog djubreta MF ![]() Pod prepostavkom da je kod MF u MPCIe isto modem cemu ovi dodatni pcb vodovi koji vode iz konektora ? Iz oba konektora za prihvat antena vode po 2 voda. Na desnom konektoru vod ide prema unutarnjoj WiFi anteni, ljevi vodi prema "kocki" na pcb-u sto bi mogla biti druga unutarnja pcb WiFi antena. Ono sto ja iz slike mogu zakljuciti jedino da je ovaj MF neki MIX tj. da kakve god antene bile prikopcane ne sluze iskljucivo za WiFi ili GSM modem a to bi i objasnilo sulude rezultate i status signala sa vipovim lopatama. Bilo bi zanimljivo vidjeti kakav je signal direktnim prikljucivanjem antena na MPCIe modem, ovaj MF definitivno nesto mixa, mislim cemu dodatni vodovi sa konektora ? Pogotovo sto se na ljevom vidi da je vod razdvojen od voda za MPCIe. Inace lakse slikom objasniti kakva stap antena treba za ovaj MF. ![]() Ako imate ljevu antenu onda u rupicu zica da bude ko desna
trebaš seedbox? |
#532 | |
Sandy!!!
Postovi: 1,695
Ova prva me zanima,nije skupa, 60 eur...ova druge je već van ikakvog buđeta. 10m kabela mi je sasvim dosta. Di ima u nas kupit ovu Iskrinu? Nemogu nać na guglu. I koliko je to bolje od ove dvi antenice sta su sad na routeru. Onako laički ![]() |
#533 |
Postovi: 4,361
#534 |
Postovi: 4,361
#535 |
Postovi: 283
Ona gore na linku od Kermana nije P56 kao ona iz Slovenije, ova dolje na linku je P56 i pokriva frek. pojas od 790 do 2700MHz http://www.kerman.hr/index.php?optio...5420&Itemid=64 Piše da se dobije kabal i SMA konektori. |
#536 |
Postovi: 136
Kabel i konektori su u kompletu na slo anteni Iskra p56 i instalirani su na samoj anteni, preostaje ti samo da je zašarafiš na ZTE modem, učvrstiš za stup i naravno okreneš di treba. https://www.4g-antennit.fi/product/3...in-kaapeleilla Antena je ista kao na ovom linku iznad: Ova od kermana nije takva, mala je razlika /post od selka/. Zadnje izmijenjeno od: tor. 11.04.2017. u 13:53. |
#537 |
Datum registracije: Apr 2008
Lokacija: Gračac
Postovi: 184
#538 |
Postovi: 136
dhalan - razlika je u tome što nije isti raspored članaka i drugi je konektor. Ova antena na linku od Selka a o kojoj vi govorite ima naziv LTE/UMTS Iskra P-56/TS9. Ja govorim o anteni Iskra P-56 UNICOM MIMO. Zadnje izmijenjeno od: Dusan. 11.04.2017. u 08:46. |
#539 | |
Lokacija: Gračac
Postovi: 184
http://www.kerman.hr/index.php?optio...5420&Itemid=64 nigdje ne piše TS9 "Priključni kabel: 50ohma, dužine 10m, SMA konektor" iste su i specifikacije i slike Jeste uzemljili antene? Kako? i da... kako napravit ovaj kut od 45? nije došlo ništa uz antenu... |
#540 |
Datum registracije: Mar 2015
Postovi: 258
Dal još nekome nakon što upali acestream/torrent ne radi uopće otvaranje stranica u browseru i općenito internet preko wifija na mobitelu? Brzina za acestream je ograničena na 6/6 MBIT. Tako da mu do 50 MBITA ostaje ohoho mjesta. |
