Staro 02.04.2017., 00:53   #3031
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,431
Autor coconut Pregled postova
Ako netko hoće dobar flagship, a neće S8, neka pogleda G6. Cjenovno nešto povoljniji, hardver sitno slabiji od S8, ali kamera rastura.
http://www.gsmarena.com/lg_g6-review-1590p8.php
"As you can tell from both sets of samples, the newest in the G-series still takes great photos, despite a move to a smaller sensor which we ourselves almost called midrange a few paragraphs earlier. It resolves a lot of detail, but does have a rather heavy-handed approach to sharpening. Sure, you can see each and every tile and brick's outline, but it's a touch too much.
There's more than the average amount of noise that we're used to seeing - perhaps that's one area where the small-ish sensor can only do so much. It's no worse than Sony's own Xperias in this respect, not even close, but it's a little more telling where the sensor comes from than other phones.
Colors are vibrant, without being as warm as the G5's - a better struck balance between reality and consumer appeal, if you ask us. If you don't deliberately push it beyond its limits, dynamic range is quite good too, actually."
Paa...
Staro 02.04.2017., 01:19   #3032
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Da, na zalost su srozali kameru i nije vise ko na G4 i G5 sa kojima se donekle isplatilo slikat RAW. Sad se vise ne isplati. Zato je wide kamera najbolja od tih sekundarnih, bar meni. Software takoder i ima se sa cime igrat. S8 tu malo kaska ali vjerojatno radi bolje slike na kraju krajeva.. G6 puno bolji video nego prije i full kontrole zbog cega po meni ima prednost nad S8 u videu.
Staro 02.04.2017., 01:56   #3033
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Staro 02.04.2017., 02:02   #3034
listerstorm
Postovi: 1,431
Znam da je preuranjeno ali ako baterija ne bude značajnije lošija od S7, stavio bih soma kuna da će S8 opet biti najbolji all round uređaj.
LG ima čudnu politiku po pitanju dizajna, koncepta i dimenzija. Od plastikanera G3, preko kožnog G4, pa modularnog G5 (nikad izašli svi ti najavljivani moduli) do G6.
Svaki novi flagship izgleda kao potpuna promjena koncepta u odnosu na prijašnju generaciju. Kao da ne znaju što žele.
Staro 02.04.2017., 03:28   #3035
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Da, bolje je radit ko apple pa imat isti uredjaj tri godine :lol:
Ima video na youtubeu, "phone comparisons" ili tako nesto i usporedjen je G6 i S8 medju ostalim .
Iskreno, G6 bih rekao da ima prirodniju snimku
Staro 02.04.2017., 09:52   #3036
imart
Datum registracije: Feb 2013
Postovi: 1,167
Autor Gabre Pregled postova
Ocito prolazi. S7 i S6 su dosta slicni. Pogotovo sprijeda. Odozada skoro, jedino su bocni rubovi zaobljeni i deblji je malo S7. Inace na prvi pogled nema razlike. S8 ipak odskace izgledom jako..
imart je offline   Reply With Quote
Staro 02.04.2017., 09:58   #3037
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,765
Galaxy S8+ 4k video
Galaxy S8+ vs Huawei P10+ camera comparison
(napomena, s8 jos nema ispeglan software)
Sn4k3 je online   Reply With Quote
Staro 02.04.2017., 13:11   #3038
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Sto su izbacili telefon od 1000€ koji nema ispeglanu kameru ? Kakve su to gluposti ?! Nerazumijem , to se ljudi tjese ili? Ako za telefon trazis 1000 eura onda izvolis kao prizvodac osigurati u god dana da sve apsolutno na njemu valja kad ga izbacis. Ok nekakve sitnice u samom romu, podrazumjeva ss, ali izbaciti kameru koja kasnijim updateom bude dva koplja bolja mi je totalno nejasno.
Staro 02.04.2017., 13:12   #3039
Juice
Fresh Juice
Juice's Avatar
Postovi: 4,586
Autor xulos Pregled postova
Sto su izbacili telefon od 1000€ koji nema ispeglanu kameru ? Kakve su to gluposti ?! Nerazumijem , to se ljudi tjese ili? Ako za telefon trazis 1000 eura onda izvolis kao prizvodac osigurati da sve apsolutno na njemu valja kad ga izbacis.
Nije krenuo u prodaju još.
Staro 02.04.2017., 13:16   #3040
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
A mislis da ce u ovih tjedan dana to popraviti? Pa S5 jos uvijek ima problema sa zaglavljivanjem focusa i stekanjem istog, nikad to nisu pooravili od prvog dana ima tih problema. Kolega zamjenio svog i dobio isto, ja na svom imao isti problem.Niie usko povezano s ovim S8+ ali mislim da je ovo softver jos nije ispeglan klasicno hvatanje za slamku, ne kolege snejka nego samsungovih opravdanja.
Staro 02.04.2017., 13:25   #3041
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,765
Nije da pravdam Samsunga i slazem se, ako traze astronomske cijene za svoj flagahip - ima da sve radi kako treba. Ali isto tako treba biti razuman, svi modeli koji su trenutno u rukama raznih rivjuera i jutunera su pre-production. Kad mobitel sluzbeno bude u prodaji, mislim da je to 20.04., onda treba testirati kameru i sve ostalo...
Edit:
Galaxy S8 & S8 Plus: In-depth Hands-on REVIEW by Erica
SAMSUNG GALAXY S8+ vs GALAXY S7 EDGE - S8 ima generalno malo tamniji ali vidno kvalitetniji i ostriji video...
Zadnje izmijenjeno od: Sn4k3. 02.04.2017. u 20:26.
Staro 03.04.2017., 00:00   #3042
Prolega
Postovi: 100
Autor kvaju Pregled postova
Imas opciju network settings reset, mozda pomogne, samo pazi, brise sve zapamćene wifi mreže i vjerovatno apn postavke.
Sent from my ONEPLUS A3003 using Tapatalk
Problem rijesen. Problem je bio u smecu od routera. Zamijenio za jos vece smece, al bar radi (odnosno odspaja se uredno).
Čisto info za nekoga kome se to možda desi.
Stari router je bio Speedport W 724V Type Ci, ovaj drugi je ZTE ZXDSL 931.
Hvala svima koji su pružili podršku.
Prolega je offline   Reply With Quote
Staro 03.04.2017., 00:35   #3043
emmeritus
emmeritus's Avatar
Postovi: 47
Galaxy S6 OTA Nougat update upravo stigao
Vidim da nitko ne spominje, primijetio sam prije dvadeset minuta notification, još uvijek se ažurira (1087 MB).
HT mi je carrier.
emmeritus je offline   Reply With Quote
Staro 03.04.2017., 02:14   #3044
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Autor listerstorm Pregled postova
0.7" veći ekran i ista baterija. Mhm, to će visit na punjaču 24/7
54' / 74' / 90' / 2014
Staro 03.04.2017., 07:34   #3045
imart
Postovi: 1,167
Autor emmeritus Pregled postova
HT mi je carrier.
Ide na novu verziju operativnog sustava. Kaj sad imas uopce?
Staro 03.04.2017., 10:57   #3046
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Autor panda505 Pregled postova
Dodaj u kombinaciju nešto "malo" ispeglaniji os, štedljivije čipove i dođe se na isto trajanje baterije.. Ili bi bar trebalo biti tako.
doky je offline   Reply With Quote
Staro 03.04.2017., 11:03   #3047
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,838
Huawei 10 ce ocitat lekciju S8 po pitanju kamere.
Staro 03.04.2017., 11:06   #3048
Postovi: 34,106
Ne bih se kladio
http://www.gsmarena.com/huawei_p10_p...iew-1596p3.php
We also learned that both of these cameras are inconsistent in their performance - even more so in low light. Many of our low-light photo samples were simply not as sharp as the camera's best samples. And that's with a tripod and extra care to lock focus on one and the same spot before taking the photos. When shooting casually on the go, you might get even fewer keepers if you are not careful.
Staro 03.04.2017., 11:23   #3049
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,670
Nigdje iskopat kad će doći i G6, koliko vidim svi hvale njegovu kameru. S8 je bar prema ponudi uz pretplate oko 2000kn skuplji nego Huawei P10 trenutno
brodjo je offline   Reply With Quote
Staro 03.04.2017., 12:48   #3050
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Autor doky Pregled postova
Da su čipovi i OS ispeglanij i štedljiviji ne znam kak - toliko ispeglani i štedljiviji biti ne mogu.
Barem ne u tak kratkom periodu.
Ovo je wishful thinking u najboljem slučaju.
Staro 03.04.2017., 12:54   #3051
android-split
android-split's Avatar
Datum registracije: Dec 2015
Postovi: 1,052
Autor brodjo Pregled postova
U kontaktu sam sa osobom koja je "glavna" u lg hrv/bih i rekao mi je oko 5-og m. Danas sam bas posla mejl lg hrv i rekli su mi isto, s tim da su mi napisali da bi ubrzo trebala doc ponuda prednaruđbi u operatera. Znaci sve isto kao g5
android-split je offline   Reply With Quote
Staro 03.04.2017., 13:00   #3052
Postovi: 34,106
Koliko se sjećam, G6 se pojavio na rumunjskim stranicama sa cijenom od 700€. Obzirom da se o S8 govori da će koštati oko 900€, mislim da je tih 200€ razlike dobar argument za kupnju G6.
EDIT: 750€ u Švabiji
http://www.mediamarkt.de/de/search.html?storeId=48353&langId=-3&searchProfile=onlineshop&channel=mmdede&searchParams=&path=&query=lg+g6
S8 za 800/900€ (+ verzija)
http://www.mediamarkt.de/de/search.h...uery=galaxy+s8
Zadnje izmijenjeno od: coconut. 03.04.2017. u 13:09.
Staro 03.04.2017., 13:10   #3053
android-split
Postovi: 1,052
S8 je 6100kn kod nas u prednaruđbi
https://www.elipso.hr/mobile/mobitel...%C4%86NO-CRNA/
Osobno mislim da nece G6 bit "toliko" jeftiniji. Jedno 5500kn po mom skromnom misljenju
Staro 03.04.2017., 13:12   #3054
Postovi: 34,106
Samo 6k kn? Prejeftino. Očekivao sam bar 7-7.5k kn.
Staro 03.04.2017., 13:12   #3055
imart
Postovi: 1,167
znači sams je 50e skuplji. to je ništ
pa S7 edge je bio 6200kn kad je izašo a flat 5200kn.. kasnije su cijene pomalo išle dolje..
Staro 03.04.2017., 13:26   #3056
Dottore
Dottore's Avatar
Postovi: 7,726
Autor android-split Pregled postova
Na kome si poslao e-mail? Mađarska ili Srbija?
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 03.04.2017., 13:33   #3057
android-split
Postovi: 1,052
Hrvatska (a tko odg., nemam pojma)
https://www.lg.com/hr/podrska/kontak...eposta/e-posta
Koliko je to jeftino za mob, je jako upitno. Po meni previse. Mozes kupit smart tv, komp i mob za tu lovu.
Al ako imas viska love, onda nema problema. Osobno sam ima g3, g4 i g5. Volio bi i g6, al ocu ga kupit? Tesko
Jedino mi je zao sto sam vec dobio 3 maske za g6 za review, a mob jos nemam, a upitno je i ocu ga imat. Al nesto cu iskemijat
Zadnje izmijenjeno od: android-split. 03.04.2017. u 14:04.
Staro 03.04.2017., 13:52   #3058
imart
Postovi: 1,167
ja uvijek kupujem prošlogodišnje flagshipove, cijena pada i za 30% i više. 6000kn nebi dao ni u snu, max 3500kn..
Staro 03.04.2017., 17:03   #3059
acmevagabundo
Datum registracije: Jul 2015
Postovi: 326
Ja ću kupit ovaj skuplji model. Oću ga imat i baš me briga ako je skup, ja sam svoje pare zaradio i trošim ih gdje oću, a to je u ovom sučaju s8+.
Nekako se između redak proteže misao da se trebaš nekom pravdat što si dao tolike novce. Ko hoće jeftinog kineza nek kupi jeftinog kineza, ko hoće Vivax smart tv nek kupi Vivax smart tv. Ja hoću s8+.
acmevagabundo je offline   Reply With Quote
Staro 03.04.2017., 17:06   #3060
android-split
Postovi: 1,052
Samo debil moze kupit/ne kupit sta mu neko drugi sugerira
