#3031 | |
Datum registracije: Apr 2011
Postovi: 1,431
"As you can tell from both sets of samples, the newest in the G-series still takes great photos, despite a move to a smaller sensor which we ourselves almost called midrange a few paragraphs earlier. It resolves a lot of detail, but does have a rather heavy-handed approach to sharpening. Sure, you can see each and every tile and brick's outline, but it's a touch too much. There's more than the average amount of noise that we're used to seeing - perhaps that's one area where the small-ish sensor can only do so much. It's no worse than Sony's own Xperias in this respect, not even close, but it's a little more telling where the sensor comes from than other phones. Colors are vibrant, without being as warm as the G5's - a better struck balance between reality and consumer appeal, if you ask us. If you don't deliberately push it beyond its limits, dynamic range is quite good too, actually." Paa... ![]() |
#3032 |
Postovi: 5,997
Da, na zalost su srozali kameru i nije vise ko na G4 i G5 sa kojima se donekle isplatilo slikat RAW. Sad se vise ne isplati. Zato je wide kamera najbolja od tih sekundarnih, bar meni. Software takoder i ima se sa cime igrat. S8 tu malo kaska ali vjerojatno radi bolje slike na kraju krajeva.. G6 puno bolji video nego prije i full kontrole zbog cega po meni ima prednost nad S8 u videu. |
#3033 |
Xulos :)
Postovi: 7,581
http://www.nextpowerup.com/news/3493...ting-exchange/ Pa stvarno su smecari svoje vrste |
#3034 |
Postovi: 1,431
Znam da je preuranjeno ali ako baterija ne bude značajnije lošija od S7, stavio bih soma kuna da će S8 opet biti najbolji all round uređaj. LG ima čudnu politiku po pitanju dizajna, koncepta i dimenzija. Od plastikanera G3, preko kožnog G4, pa modularnog G5 (nikad izašli svi ti najavljivani moduli) do G6. Svaki novi flagship izgleda kao potpuna promjena koncepta u odnosu na prijašnju generaciju. Kao da ne znaju što žele. |
#3035 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
Da, bolje je radit ko apple pa imat isti uredjaj tri godine :lol: Ima video na youtubeu, "phone comparisons" ili tako nesto i usporedjen je G6 i S8 medju ostalim . Iskreno, G6 bih rekao da ima prirodniju snimku |
#3036 |
Datum registracije: Feb 2013
Postovi: 1,167
#3037 |
Lokacija: Zd
Postovi: 4,765
Galaxy S8+ 4k video Galaxy S8+ vs Huawei P10+ camera comparison (napomena, s8 jos nema ispeglan software) |
#3038 |
Xulos :)
Postovi: 7,581
Sto su izbacili telefon od 1000€ koji nema ispeglanu kameru ? Kakve su to gluposti ?! Nerazumijem , to se ljudi tjese ili? Ako za telefon trazis 1000 eura onda izvolis kao prizvodac osigurati u god dana da sve apsolutno na njemu valja kad ga izbacis. Ok nekakve sitnice u samom romu, podrazumjeva ss, ali izbaciti kameru koja kasnijim updateom bude dva koplja bolja mi je totalno nejasno. |
#3039 |
Fresh Juice
Postovi: 4,586
#3040 |
Xulos :)
Postovi: 7,581
A mislis da ce u ovih tjedan dana to popraviti? Pa S5 jos uvijek ima problema sa zaglavljivanjem focusa i stekanjem istog, nikad to nisu pooravili od prvog dana ima tih problema. Kolega zamjenio svog i dobio isto, ja na svom imao isti problem.Niie usko povezano s ovim S8+ ali mislim da je ovo softver jos nije ispeglan klasicno hvatanje za slamku, ne kolege snejka nego samsungovih opravdanja. |
#3041 |
Lokacija: Zd
Postovi: 4,765
Nije da pravdam Samsunga i slazem se, ako traze astronomske cijene za svoj flagahip - ima da sve radi kako treba. Ali isto tako treba biti razuman, svi modeli koji su trenutno u rukama raznih rivjuera i jutunera su pre-production. Kad mobitel sluzbeno bude u prodaji, mislim da je to 20.04., onda treba testirati kameru i sve ostalo... Edit: Galaxy S8 & S8 Plus: In-depth Hands-on REVIEW by Erica SAMSUNG GALAXY S8+ vs GALAXY S7 EDGE - S8 ima generalno malo tamniji ali vidno kvalitetniji i ostriji video... Zadnje izmijenjeno od: Sn4k3. 02.04.2017. u 20:26. |
#3042 | |
Postovi: 100
Čisto info za nekoga kome se to možda desi. Stari router je bio Speedport W 724V Type Ci, ovaj drugi je ZTE ZXDSL 931. Hvala svima koji su pružili podršku. |
#3043 |
Postovi: 47
Galaxy S6 OTA Nougat update upravo stigao
Vidim da nitko ne spominje, primijetio sam prije dvadeset minuta notification, još uvijek se ažurira (1087 MB). HT mi je carrier. |
#3044 |
Lokacija: Beertopia
Postovi: 2,013
54' / 74' / 90' / 2014
I'm only here to see how the story unfolds. Any self-respecting leading man would do the same. |
#3045 |
Postovi: 1,167
#3046 |
Datum registracije: Nov 2010
Postovi: 1,942
#3048 |
Postovi: 34,109
Ne bih se kladio http://www.gsmarena.com/huawei_p10_p...iew-1596p3.php We also learned that both of these cameras are inconsistent in their performance - even more so in low light. Many of our low-light photo samples were simply not as sharp as the camera's best samples. And that's with a tripod and extra care to lock focus on one and the same spot before taking the photos. When shooting casually on the go, you might get even fewer keepers if you are not careful.
#3050 | |
Lokacija: Beertopia
Postovi: 2,013
Da su čipovi i OS ispeglanij i štedljiviji ne znam kak - toliko ispeglani i štedljiviji biti ne mogu. Barem ne u tak kratkom periodu. Ovo je wishful thinking u najboljem slučaju.
#3051 | |
Datum registracije: Dec 2015
Postovi: 1,052
#3052 |
Postovi: 34,109
Koliko se sjećam, G6 se pojavio na rumunjskim stranicama sa cijenom od 700€. Obzirom da se o S8 govori da će koštati oko 900€, mislim da je tih 200€ razlike dobar argument za kupnju G6. EDIT: 750€ u Švabiji http://www.mediamarkt.de/de/search.html?storeId=48353&langId=-3&searchProfile=onlineshop&channel=mmdede&searchParams=&path=&query=lg+g6 S8 za 800/900€ (+ verzija) http://www.mediamarkt.de/de/search.h...uery=galaxy+s8
"Dvije stvari su beskonačne - svemir i ljudska glupost. Za svemir nisam siguran." A. Einstein Zadnje izmijenjeno od: coconut. 03.04.2017. u 13:09. |
#3053 |
Postovi: 1,052
S8 je 6100kn kod nas u prednaruđbi https://www.elipso.hr/mobile/mobitel...%C4%86NO-CRNA/ Osobno mislim da nece G6 bit "toliko" jeftiniji. Jedno 5500kn po mom skromnom misljenju |
#3056 |
Postovi: 7,726
Na kome si poslao e-mail? Mađarska ili Srbija?
__________________ |
#3057 |
Postovi: 1,052
Hrvatska (a tko odg., nemam pojma) https://www.lg.com/hr/podrska/kontak...eposta/e-posta Koliko je to jeftino za mob, je jako upitno. Po meni previse. Mozes kupit smart tv, komp i mob za tu lovu. Al ako imas viska love, onda nema problema. Osobno sam ima g3, g4 i g5. Volio bi i g6, al ocu ga kupit? Tesko Jedino mi je zao sto sam vec dobio 3 maske za g6 za review, a mob jos nemam, a upitno je i ocu ga imat. Al nesto cu iskemijat Zadnje izmijenjeno od: android-split. 03.04.2017. u 14:04. |
#3059 |
Datum registracije: Jul 2015
Postovi: 326
Ja ću kupit ovaj skuplji model. Oću ga imat i baš me briga ako je skup, ja sam svoje pare zaradio i trošim ih gdje oću, a to je u ovom sučaju s8+. Nekako se između redak proteže misao da se trebaš nekom pravdat što si dao tolike novce. Ko hoće jeftinog kineza nek kupi jeftinog kineza, ko hoće Vivax smart tv nek kupi Vivax smart tv. Ja hoću s8+. |
#3060 |
Postovi: 1,052
Samo debil moze kupit/ne kupit sta mu neko drugi sugerira |
