#4171 |
Postovi: 1,687
"Vi ste gold-ultra-premium korisnik, a i koliko vidimo možemo vam ponuditi i daleko veću brzinu" - Ali ja sam milijun kilometara od centrale. "Ne, koliko vidimo propusnost vaše parice je sasvim dovoljna i možete dobiti tu uslugu" Code:
VDSL Port Details Upstream Downstream Line Rate: 1.380 Mbps 8.420 Mbps Actual Net Data Rate: 1.381 Mbps 8.421 Mbps Trellis Coding: ON ON SNR Margin: 6.7 dB 6.0 dB Actual Delay: 0 ms 0 ms Transmit Power: 11.4 dBm 18.6 dBm Receive Power: 0.1 dBm 0.0 dBm Actual INP: 12.0 symbols 24.0 symbols Total Attenuation: 11.6 dB 18.6 dB Attainable Net Data Rate: 1.377 Mbps 8.377 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 27.6 N/A N/A N/A 47.1 102.3 N/A Signal Attenuation(dB): 27.6 N/A N/A N/A 45.1 N/A N/A SNR Margin(dB): 6.7 N/A N/A N/A 6.0 N/A N/A Transmit Power(dBm): 11.4 N/A N/A N/A 18.6 N/A N/A ============================================================================ ![]() |
#4172 | |
Postovi: 704
Code:
============================================================================ VDSL Port Details Upstream Downstream Line Rate: 1.195 Mbps 12.361 Mbps Actual Net Data Rate: 1.172 Mbps 12.286 Mbps Trellis Coding: ON ON SNR Margin: 6.0 dB 7.9 dB Actual Delay: 2 ms 4 ms Transmit Power: 11.5 dBm 18.6 dBm Receive Power: 0.9 dBm 0.1 dBm Actual INP: 0.5 symbols 1.0 symbols Total Attenuation: 10.8 dB 18.4 dB Attainable Net Data Rate: 1.232 Mbps 17.363 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 17.7 N/A N/A N/A 34.1 102.3 N/A Signal Attenuation(dB): 17.7 N/A N/A N/A 32.0 N/A N/A SNR Margin(dB): 6.0 N/A N/A N/A 7.9 N/A N/A Transmit Power(dBm): 11.5 N/A N/A N/A 18.6 N/A N/A
Sig-5 redova normalne veličine max ![]() |
#4173 | |
Postovi: 87
#4174 |
Lokacija: doma
Postovi: 2,895
trebaš seedbox? |
#4175 |
Postovi: 704
#4177 |
Postovi: 704
Code:
VDSL Counters Downstream Upstream Since Link time = 37 min 37 sec FEC: 295087 660 CRC: 235 83 ES: 169 76 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 6 min 24 sec FEC: 1216 2 CRC: 3 0 ES: 3 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 4960 0 CRC: 4 0 ES: 2 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 23 hours 21 min 24 sec FEC: 532748 2322 CRC: 690 286 ES: 316 263 SES: 3 0 UAS: 50 50 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Total time = 23 hours 21 min 24 sec FEC: 532748 2322 CRC: 690 286 ES: 316 263 SES: 3 0 UAS: 50 50 LOS: 0 0 LOF: 0 0 LOM: 0 0
#4178 |
super user
Lokacija: Houston, TX
Postovi: 1,805
Ja imam jos vecu brzinu nego sto pise max u ruteru ![]() Code:
============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 6 days: 19 hours: 59 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 10.236 Mbps 37.318 Mbps Actual Net Data Rate: 10.237 Mbps 37.319 Mbps Trellis Coding: ON ON SNR Margin: 6.0 dB 5.4 dB Actual Delay: 0 ms 0 ms Transmit Power: 6.7 dBm 18.6 dBm Receive Power: 1.8 dBm 4.3 dBm Actual INP: 12.0 symbols 28.0 symbols Total Attenuation: 6.0 dB 14.3 dB Attainable Net Data Rate: 10.290 Mbps 36.538 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 8.6 37.8 N/A N/A 18.6 47.9 N/A Signal Attenuation(dB): 8.6 37.1 N/A N/A 15.9 47.2 N/A SNR Margin(dB): 5.6 6.0 N/A N/A 5.6 5.2 N/A Transmit Power(dBm):- 1.3 5.9 N/A N/A 18.3 7.7 N/A ============================================================================ |
#4179 |
RESPECT MY AUTHORITAH
Postovi: 7,485
Kada ti se sinkao, brzina na 6db margine je bila ta. Ako ti padne ispod 5db, resinkati će ti se. Meni divljaju FEC-ovi. Code:
============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 19 days: 6 hours: 47 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 4.314 Mbps 22.527 Mbps Actual Net Data Rate: 4.315 Mbps 22.528 Mbps Trellis Coding: ON ON SNR Margin: 5.4 dB 11.3 dB Actual Delay: 0 ms 0 ms Transmit Power: 7.9 dBm 18.5 dBm Receive Power: 0.3 dBm 1.1 dBm Actual INP: 12.0 symbols 27.0 symbols Total Attenuation: 8.2 dB 17.4 dB Attainable Net Data Rate: 3.971 Mbps 29.789 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 14.3 53.6 N/A N/A 26.4 67.1 N/A Signal Attenuation(dB): 14.3 53.2 N/A N/A 23.5 63.6 N/A SNR Margin(dB): 5.5 5.4 N/A N/A 11.3 11.1 N/A Transmit Power(dBm): 3.4 6.0 N/A N/A 18.5 0.1 N/A ============================================================================ VDSL Counters Downstream Upstream Since Link time = 47 min 17 sec FEC: 3187161698 363 CRC: 1312 0 ES: 846 0 SES: 9 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 2 min 40 sec FEC: 1708356 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 9552949 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 6 hours 47 min 40 sec FEC: 259598802 0 CRC: 8 0 ES: 7 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 916933278 32 CRC: 106 0 ES: 67 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0
#4180 |
Postovi: 704
![]() Code:
============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 0 day: 5 hours: 19 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 1.191 Mbps 12.361 Mbps Actual Net Data Rate: 1.168 Mbps 12.286 Mbps Trellis Coding: ON ON SNR Margin: 5.9 dB 7.5 dB Actual Delay: 2 ms 4 ms Transmit Power: 11.5 dBm 18.5 dBm Receive Power: 0.9 dBm 0.1 dBm Actual INP: 0.5 symbols 1.0 symbols Total Attenuation: 10.9 dB 18.3 dB Attainable Net Data Rate: 1.224 Mbps 17.006 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 17.7 N/A N/A N/A 34.1 102.3 N/A Signal Attenuation(dB): 17.7 N/A N/A N/A 32.0 N/A N/A SNR Margin(dB): 5.9 N/A N/A N/A 7.5 N/A N/A Transmit Power(dBm): 11.6 N/A N/A N/A 18.5 N/A N/A ============================================================================ VDSL Counters Downstream Upstream Since Link time = 19 min 41 sec FEC: 159425 675 CRC: 175 93 ES: 86 89 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 2 min 18 sec FEC: 592 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 14772 0 CRC: 13 0 ES: 9 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 18 hours 2 min 18 sec FEC: 368474 1787 CRC: 8213 242 ES: 303 223 SES: 60 0 UAS: 81 21 LOS: 1 0 LOF: 7 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 550622 2845 CRC: 712 362 ES: 332 330 SES: 3 0 UAS: 50 50 LOS: 0 0 LOF: 0 0 LOM: 0 0 Total time = 1 days 18 hours 2 min 18 sec FEC: 919096 4632 CRC: 8925 604 ES: 635 553 SES: 63 0 UAS: 131 71 LOS: 1 0 LOF: 7 0 LOM: 0 0 ============================================================================
#4181 |
Lokacija: Worldwide
Postovi: 2,553
Zna li netko kakp na Iskonovom VDSL postaviti da radi fax.Ima li mozda neka opcija na routeru da je treba ukljuciti?Dok sam bio na ADSL i splitteru sve je radilo ok, a na VDSL ne radi. Poslano sa ITT SINCGARS koristeci ACP125F Tapatalk |
#4182 |
Lokacija: vž
Postovi: 1,334
Probaj se ulogirat ko supervisor pa vidi, dal ima kakva opcija... Ili SZK gnjaviti |
#4183 |
Postovi: 7,485
Mislim da to imaš u opcijama SIP-a. Btw, ako niste, uključite si da dobivate gmail poruku kada imate propušten poziv (u routeru). ![]() ![]() Možete si isključiti mogućnost primanja anonymous poziva, možete uklj/isklj Echo Cancellation, razne modulacije pa Send Caller ID, Enable Call Waiting, uključiti nekakav "Hot line", "CBS" kada se stisne tipka 5 itd. I možete mijenjati glazbu na "Early media", nisam skužio što je to i kada je poziv na čekanju. Nego, kako na ovom telefonu staviti na čekanje? ![]()
#4184 |
Lokacija: vž
Postovi: 1,334
Ag008, jel si ti cura kojim slučajem? "Koji auto vozis? Veliki crveni" ![]() Uglavnom ak sam slucajno pogodil model telefona, na 12toj str imas upute http://panasonic.ae/en/manuals/KX-TG1611.pdf |
#4186 |
Vocna iglica u mudante
Lokacija: Beograd
Postovi: 2,837
carevi, imate li iskustva s preseljenjem usluge? imam internet 20mbit i iskon tv plus dodatne kanale.. bio sam kod zastupnika iskona u sl. brodu, oni nemaju pojma, kažu da zovem službu za korisnike, što ću napravit sutra ujutro.. ugl selim se, i trebam preselit uslugu.. da li je moguće razdvojit uslugu, tj meni treba samo internet, a da tv ostane ovdje gdje je.. tv sam uzeo samo zbog stare, i nenadano selim prije isteka ugovorne obveze (ostalo je cca 9 mjeseci) Zadnje izmijenjeno od: John Creasy. 10.02.2017. u 12:56. |
#4187 |
Lokacija: Čakovec / AT
Postovi: 1,782
kolko ja znam nema dijeljenja usluga, ja sam to htio napravit na t-comu dok sam bio, htio ostavit telefon, preselit samo maxadsl jer je i na drugoj adresi bio telefon... i rekli su ne.. pa sam morao: 1) prvo odjavit telefonsku liniju na lokaciji B 2) preselit telefonsku liniju + maxadsl sa lokacije A na lokaciju B 3) trazit da ostane prvotni broj sa lokacije B 10x vise posla, a isti drek... al dobro, nek im je.
slow is smooth, smooth is fast... |
#4188 | |
Lokacija: Beograd
Postovi: 2,837
selim se u stambene zgrade, šteta što rijetko tko više koristi wep enkripciju ![]() |
#4189 |
Datum registracije: May 2014
Lokacija: istra
Postovi: 3,504
i h1 ti ima akciju, 149kn max brzinu parice bez ugovorne obveze |
#4190 |
Postovi: 2,222
#4191 |
Lokacija: Worldwide
Postovi: 2,553
Danas bio kod mene tehnicar od Iskona, malo prevrtio kucnu istalaciju, promjenio profil na 8b i sve radi odlicno.Prije sam imao dosta greska. VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 2 days: 3 hours: 2 minutes ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 8.191 Mbps 37.887 Mbps Actual Net Data Rate: 8.192 Mbps 37.888 Mbps Trellis Coding: ON ON SNR Margin: 12.0 dB 9.4 dB Actual Delay: 0 ms 0 ms Transmit Power: 6.6 dBm 18.6 dBm Receive Power: 0.3 dBm 5.1 dBm Actual INP: 12.0 symbols 28.0 symbols Total Attenuation: 7.1 dB 13.5 dB Attainable Net Data Rate: 11.071 Mbps 45.736 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 9.5 31.9 N/A N/A 17.6 39.1 N/A Signal Attenuation(dB): 9.5 31.3 N/A N/A 14.8 38.8 N/A SNR Margin(dB): 12.2 12.0 N/A N/A 9.3 9.4 N/A Transmit Power(dBm):- 1.3 5.9 N/A N/A 18.3 7.4 N/A |
#4193 |
Lokacija: Worldwide
Postovi: 2,553
I dalje ne radi, zaboravio sam pitati tehnicar za taj fax.Imao sam hrpu gresaka.Nije se moglo surfati poslije 19 sati.Sada sve radi ok.Jedino je prije bio malo manji download a veci upload.Rekao mi je da je ova brzina najvise sto se moze dobiti jer ako se postavi veca brzina da bi se promjenila margina i da bi opet bilo problema. |
#4194 |
Lokacija: Novi Zagreb
Postovi: 979
Mene zadnja 2 tjedna muci sto mi se konekcija reconnecta svako malo, prije je bilo normalno, svaka 24 sata, a sad gledam ispis spajanja za 2. mjesec. Najduza konekcija je trajala 3 sata, a ima I hrpa po 15-20-30 minuta. U drugom mjesecu mi za sad pise: Ukupan broj spajanja: 110 Nisam bio puno doma ovih dana pa nisam previse paznje posvetio tome. Ali sad opet pocinje iritirat kad 2-3 puta tokom online gaming vidim reconnecting. Ili gledam livestream (nedavno simple session) i svako malo pukne stream etc... jel imao tko slicnih problema? Pretpostavljam da je savjet "zovi SZK"? |
#4196 |
Lokacija: istra
Postovi: 3,504
dal još nekom šteka / ne radi njuskalo? problem mi je samo na desktop browserima, mobile radi normalno. i to samo na iskonu. kad se prebacim na tcom ili metronet, onda radi. samo na iskonu ne. |
#4197 |
Lokacija: Dalmacija
Postovi: 247
Iskon (optika), Win10, Chrome browser... otvara mi njuškalo i idem kroz kategorije bez problema. |
#4198 |
Lokacija: Kloštar Podravski
Postovi: 1,019
@jp_rv Štekao jučer, šteka i danas, na mahove. Ja sam na T-Comu, pa je vjerojatno do Njuškala.
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen! |
#4199 |
Lokacija: istra
Postovi: 3,504
#4200 |
Postovi: 979
Moja saga se nastavlja, danas posebno gadno zadnja dva sata: http://imgur.com/a/FKeZO Znaci pukne net, nestane na 30ak sekundi, i onda opet proradi. I tako svakih 5-10 minuta kao sto se vidi na popisu spajanja. |
