Postovi: 12,433
PCE HandBrake Benchmark
Malo real life usporedbe procesorske snage za one kojima se da provjerit kako im prvenstveno CPU diše. Koristiti zadnji HandBrake za Windowse (1.0.2) Direct Download Link Testni video je Bennu’s Journey 2880x1080 mpeg-4 Download Link (456,2 MB) Testne postavke - Fast 1080p 30 mp4 izlazni file (trebao bi ujedno biti default čim se HandBrake instalira) Rezultat (average framerate) može se po završetku očitati sa Log fajla a može se uloviti i screenshot na cca 99% Pics or it didn't happen poželjno s CPU-z prozorom ![]() Evo na brzinu rezultat za X5650 na datim postavkama Xeon X5650 @3,54 GHz / 1600 MHz DDR3 - Avg FPS 41,6 FPS ![]() ______________________________________________________________________ - Rezultati - Xeon E5-2678 V3 @default - 90,7 FPS - e1ectra_one i7 5930k @4,40GHz - 72,7 FPS - happ i7 5820k @4,00GHz - 65,3 FPS - nino i7 6700k @4,50GHz - 60,5 FPS - realmadrid i7 7700k @4,50GHz - 60,4 FPS - DrugBrko i7 3930k @4,20GHz - 58,0 FPS - Rush xxx i7 6700k @default - 57,3 FPS - alengrosevic i7 6700k @4,20GHz - 57,1 FPS - realmadrid i7 4790k @4,50GHz - 52,5 FPS - Branx Xeon X5650 @4,40GHz - 50,2 FPS - Wolverine i5 6600k @4,60GHz - 49,9 FPS - lajchi i5 6600k @4,40GHz - 48,0 FPS - ti.le Xeon X5650 @4,00GHz - 46,7 FPS - Wolverine i7 2600k @5.00GHz - 46,5 FPS - Dean225 i7 3930k @3,50 GHz - 45,0 FPS - Lewis i5 6600k @4,40GHz - 44,8 FPS - spitfire83 Xeon X5650 @3,54GHz - 41,6 FPS - Wolverine FX-8320 @4,40GHz - 41,2 FPS - Flood FX 8300 @4,10GHz - 37,9 FPS - Necronomicon i7 4710MQ @2,50GHz - 37,1 FPS - darkydark i5 6500 @3,30GHz - 36,1 FPS - Bariarnil i5 2500k @4,70GHz - 35,6 FPS - Exy i5 2500k @4,40GHz - 32,7 FPS - Sn4k3 i7 930 @3,80GHz - 29,9 FPS - thezero i7 860 @3,67GHz - 27,7 FPS - Gigi1 i5 3570k @3,77GHz - 25,8 FPS - Pupo i7 930 @2,94GHz - 22,9 FPS - thezero Pentium G4560 @3,50GHz - 21,8 FPS - cro_ryder / Igneos Eructid i3 2120 @3,30GHz - 15,1 FPS - E-mil i5 5200U @2,20GHz - 13,7 FPS - dean225
''Of all the things I've lost I miss my mind the most'' Mark Twain Zadnje izmijenjeno od: Wolverine. 23.02.2017. u 22:07. |
Into my head it goes
Datum registracije: Feb 2004
Lokacija: space de luxe
Postovi: 779
FX 4.4 GHz work: average encoding speed for job is 41.219284 fps
...help me understand the best I can... |
Lokacija: Zd
Postovi: 4,772
Uff al Sendi Briđ ubija, pogotovo na 5Ghz ![]() Bez sale, i7 2600k je IMO najdugovjecniji consumer cpu ikada. Ni danas ga nema smisla minjati, pogotovo za nove i5-ice, iako je vec 5 generacija star... Zadnje izmijenjeno od: Sn4k3. 15.02.2017. u 22:09. |
DD9512
Postovi: 1,869
Ne planiram ga uopće mijenjati. Bez problema ga mogu voziti 24/7 na 5 ghz. Sumnjam da će riknut jer ne dobiva ludu voltažu kod mene a ploče imam 2. ![]() Odustao sam i od Kabya a i od Ryzena. Ukoliko bude potrebe za nekim upgradeom, onda ću lupit gtx 1080 unutra i to je to.. |
Postovi: 12,433
Tak jasno, kompletna da postava još uvijek ima dosta toga za pokazat. Da ne kažem da ekipa koja ima X58/X79 i dan danas imaju gro procesorske snage. Još da netko tko ima 6700/7700 ovo odvrti pa da vidimo koliko zaostaju ovi naši starkelje ![]()
Postovi: 12,433
Bilo bi poželjno da se objavi rezultat kao u prvom postu. Dakle CPU, takt i screen rezultata s cpu-z prozorom ![]()
#14 | |
cyborg
Datum registracije: Dec 2016
Lokacija: hills of SB
Postovi: 240
![]() G4560 @ 3.50GHz 2 x 4 Gb DDR3L 1600 MHz average encoding speed for job is 21.841574 fps |
Postovi: 12,433
#16 |
Datum registracije: Aug 2010
Postovi: 242
Zadnje izmijenjeno od: realmadrid. 16.02.2017. u 00:17. |
#17 |
kripl. ing.
Postovi: 291
#20 |
Postovi: 506
#21 |
Postovi: 12,433
Tak jasno da ima veze s radnim taktom memorije. Pa pogledaj koliko RAM-a zauzme za vrijeme obrade. Da vam oboma RAM radi na istom taktu razlika bi bila manja. Zato sam i stavio da se navede i takt memorije.
#22 |
Lokacija: Zd
Postovi: 4,772
#23 | |
Postovi: 506
Proces sve skupa zauzima cca 1gb rama. work: average encoding speed for job is 49.902367 fps |
#24 |
Postovi: 12,433
Da oko 1,2 GB RAM-a zauzme kod mene. Ovdje sam vrtio baš malo žešći test koji je Krešo stavio no mislim da se ekipi ne bi dalo baš buljit u komp preko sat vremena da odradi benchmark ![]() Taj uzme 2GB RAM-a ali je i file težak oko 3,5 GB U glavnom, zanimljivo je vidjet kako se 5-6-7 godina stari procesori nose s novim verzijama, posebice zbog manjka AVX instrukcija. Primjerice kod mene je nedostatak što nemam AVX set instrukcija koji recimo tvoj CPU koristi u ovom testu već se oslanja samo na SSE instrukcije. No ok, to nadoknadi s dvije dodatne jezgre. ![]()
''Of all the things I've lost I miss my mind the most'' Mark Twain Zadnje izmijenjeno od: Wolverine. 16.02.2017. u 15:52. |
#26 |
Postovi: 12,433
Taj cpu bi trebao praktički bez nekog osjetnog dizanja napona ići na 4 GHz a to je već dobar boost. Ili uzmeš heksacore pa staviš na tu ploču, sad su džabe ti procesori.
#27 |
Lokacija: Zd
Postovi: 4,772
#29 |
Postovi: 12,433
Treba se igrat s QPI naponom. Ide D0 na 4GHz s manje od 1,3V vCore osim ako nije baš loš primjerak. No velim, ako ti treba procesorske snage uzmi Xeon X5650 i stavi na tu ploču. Rade u rangu Haswell desktop i7-ica a koštaju punomanje ![]()
#30 | |
i to u dosta optimiziranom testu(naravno, postoje iznimke) ![]() |
