Staro 08.02.2017., 19:54   #2821
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Sok te jebo, kakvi su ovo nazivi
Poderu oči
Staro 08.02.2017., 20:20   #2822
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Overall, our estimate for Zen is fairly close to the score for Intel’s Ivy Bridge but short of Haswell’s and Skylake’s. AMD argues that the Intel products receive an unfair 5–10% boost because the company compiles to 32-bit x86 code, which is unrealistic for many applications. Adjusting by 10% would put Zen about halfway between Ivy Bridge and Haswell for SPECint_rate2006. Either way, Zen delivers a tremendous improvement in per-core performance.
Good for Servers But Not HPC
The Zen core does have some limitations that make it less suitable for scientific computing, which accounts for 15–20% of the server market. It sacrifices floating-point and SIMD throughput to reduce area and power—important metrics for this segment. As Table 1 illustrates, Zen offers more FP flexibility than Sandy Bridge and will deliver much better performance on SSE code. Haswell and Skylake, however, provide twice the flops per clock using AVX FMA instructions and, more importantly, twice the cache bandwidth to feed the FP and SIMD execution units.
The forthcoming server version of Skylake will further double the computational throughput using AVX512 and also increase the cache bandwidth. Practically, Zen will therefore struggle to offer competitive HPC performance both for classic scientific computing and for workloads such as machine learning that require dense computations. Fortunately for AMD, the bulk of the server market is running databases, web servers, and other tasks that fall outside scientific computing.
In servers, Zen could enable midrange and low-end designs with the right complementary components (e.g., L3 cache, memory, and PCIe controllers) in 2017. Most of the server market today comprises two-socket designs, and AMD has demonstrated a two-socket server employing the 32-core Naples processor. Given that Naples will arrive shortly after Summit Ridge, we suspect both products will use the same die, but the server product will use a multichip package, an approach AMD uses in its current Opteron products. The inherent latencies of a multichip approach would require customers to tightly control the locality of their workloads. That would make Naples a good fit for mega-data-center customers such as Amazon, Baidu, and Google.
Naples includes more cores than we expect from Intel’s 28-core Skylake-EP, but we think Intel will still have better performance and power efficiency. If AMD can come within 20% of Intel, however, customers will happily buy quite a few chips and reopen the server market. Given that AMD’s market share in servers is nearly nonexistent, even a few design wins at large data center customers could make a big difference—particularly in AMD’s revenue.
http://www.linleygroup.com/mpr/article.php?id=11666
Malo mi je prestručno za detaljnije čitanje, više n00b friendly ima na wccf (still datum članka )
Zadnje izmijenjeno od: Manuel Calavera. 08.02.2017. u 20:27.
Staro 09.02.2017., 00:33   #2823
Busola29
I opet oni donji segment Ryzena bez cijena , a baš taj segment ima dobre šanse za pobrati lovu... Mislim da se tu još nećkaju i vrte, a taj sredji segment im može najviše love donijeti.
Ovdje je to bolje malo posloženo
http://www.guru3d.com/news-story/amd...up-listed.html
Volio bi vidjeti ovaj R5 1300 ispod 1000 kuna (cca 800-900 kn ako danas i5 7400 koji je malo bolji košta 1500...) , e to bi bio onda pogodak ...
Zadnje izmijenjeno od: Busola29. 09.02.2017. u 00:39.
Staro 09.02.2017., 00:56   #2824
Amd_Shill
Datum registracije: Dec 2016
Lokacija: Sat
Postovi: 1,119
FX 9590 duplo skuplji od fx 8300, a isti čip...
Je ,ako mislis da je ista stvar high leak chip i low leak chip.
Amd_Shill je online   Reply With Quote
Staro 09.02.2017., 01:15   #2825
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,838
Autor Amd_Shill Pregled postova
hawker se izd'o
Staro 09.02.2017., 01:25   #2826
Amd_Shill
Lokacija: Sat
Postovi: 1,119
hawker se izd'o
Nisam siguran da te pratim.
Izrazi poput boldanog su uobicajeni.
Staro 09.02.2017., 03:53   #2827
Manuel Calavera
Postovi: 14,589
OK sokole, a to vrijedi duplo? Chip tj. arhitektura je potpuno ista.
Silikonska lutrija može posrat i takve modele... Misliš da se svaki 8370 OC-a bolje od fx 8300 recimo?
I've already played the silicon lottery. My FX-8300 happened to be ultimately faster than the 8320 8350 and 8370E counterparts which I happened to owned all of those listed there. On top of numerous other binnings. This 8300 was a flagship at my house. http://valid.canardpc.com/cih7iw
Truth of the FX matter is they all clock pretty close to the same. 100mhz difference between his and hers clock speeds while overclocking is a product of many variables.
To play the silicon lottery, you would buy the same CPU over and over and over to find the fastest one. Or pusrchase one that was proven on another joes rig which with all the variables is not a guarantee any ways.
Tako nebitno... Na te priče brije 7 i pol pr0 overclockera, te njihovih 14 fanova
Staro 09.02.2017., 08:51   #2828
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Bilo je pitanje cijene.
Primjer,sa 9590 imaš tvornički zagarantiranih 4,7 ghz i 5,0 turbo
Sa 8300 imaš 3,3ghz i 3,6 turbo.
Zato je razlika u cijeni i svaki 9590 mora bit high leak.
Mnogima koji ne rade OC je bitna ta razlika, pogotovo u igrama.
Radi se o 1,4ghz razlike.
Nemoj me krivo shvatit,ja isto smatram 9590 i 9370 nepotrebnim što se mene tiče.
EDIT: razlika u cijeni nije duplo koliko vidim na Newegg.
EDIT: ovaj sa tvog linka, ne vidiš problem u njegovom validated rezultatu?
Zadnje izmijenjeno od: Amd_Shill. 09.02.2017. u 09:02.
Staro 09.02.2017., 09:33   #2829
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,109
Dakle.Najeftiniji X8 bude nešto preko 3000kn.Moze se očekivati da X6 bude oko 2000kn,a ovi X4 od 1000-2000kn ovisno o clocku i smt-u!
Ima smisla!Sad budemo vidjeli koliko su brzi!
Phil of the future!
Staro 09.02.2017., 10:35   #2830
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,765
Vidim ja, 2cores/2threads @2.076v
Staro 09.02.2017., 10:56   #2831
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Autor Sn4k3 Pregled postova
Da.
Lik radi suicide run na toj ploči pustajuci više od 2v kroz nju i to se prikazuje kao neki dokaz "nadmoci" 8300.
I uz to lik je sa više od 2v jedva uspio dvi jezgre gurnut na 7ghz.
Pravi primjer daily use :rofl:
Staro 09.02.2017., 11:17   #2832
thunderbird
Premijum AMDebil
thunderbird's Avatar
Lokacija: jastrebarsko
Postovi: 1,150
Realno, istu stvar možemo reći i za pentiuma G4560 vs i3 7300 ili neki drugi kaby i3. Isti čip, razlika u cijeni duplo. A vjerujem da ima još takvih primjera kod intela.
Da li vrijedi fx9590 duplo u odnosu na 8300 - po meni ne, ali nekom entuzijastu (za koje su ti procovi i namjenjeni) itekako vrijedi, posebno kad se uzme u obzir da može pričat po selu da ima proc na 5 gigaherca... Pa curicama gaće same padaju kad čuju to
X
Staro 09.02.2017., 11:59   #2833
Sam Fischer
Džabe si krečio!
Postovi: 5,191
Autor thunderbird Pregled postova
Da, na ovim prostorima curice i inače padaju na gigahertze, to je opće poznato
Anyway, sve ovisi 'ko kupuje.
Ako imaš volje i živaca sam tražiti i testirati, oveclockati, kombinirati - skoro pa je svejedno koji FX uzmeš
Ali ja nekako više nemam ni vremena ni živca toliko prtljat po svemu tome - dovoljno me ispotrošio ovaj moj FX, tako da bi mi bila i primamljiva opcija (da opet kupujem) neki FX95XX i btk
Staro 09.02.2017., 12:07   #2834
Manuel Calavera
Postovi: 14,589
Propuštaš poantu. Liku se od svih tih "higer binned" (fx 8350) i "low leak" (fx 8370) najbolje OC-ao fx 8300... Dakle ne radi se o tome što "luzer" nije mogao do 8ghz na tekućem dušiku sa svim modulima/jezgrama...
Za fx 9590 nasvirali voltažom ko nespašeni, tdp do 220w, za uvjet stavili high end mbo i vodeno i plati masno. U biti jedino što ti njime zagrantiraju je da nije loš primjerak (da ne može 4.7), no to ne znači da je nužno bolji primjerak od većine ostalih vishera kad bi se stavili na high end mbo i brutalan cooler (kako te posere tako ti bude)
Zadnje izmijenjeno od: Manuel Calavera. 09.02.2017. u 12:14.
Staro 09.02.2017., 16:24   #2835
sti
Lokacija: Lawl
Postovi: 1,381
Izgleda da su cijene za 8c/16t službene:
EU: http://www.guru3d.com/news-story/amd...-revealed.html
US: http://www.guru3d.com/news-story/us-...at-316-59.html
Koliko god mi je drago što za cijenu i7 7700K dobiješ punokrvni 8c/16t, opet mi je čudno da AMD baš toliko reže cijene, prema ovoj logici 4c/8t će koštati kao najjeftiniji i5
Staro 09.02.2017., 16:39   #2836
webstartm
Sandy!!!
webstartm's Avatar
Postovi: 1,695
8/16 za 240 funti / 380 eur
na forbesu se spominje 317$
Zadnje izmijenjeno od: webstartm. 09.02.2017. u 16:44.
Staro 09.02.2017., 16:40   #2837
emilblomsky
Lokacija: karlovac
Postovi: 2,109
Sa jednim 6core/12threads budeš vrtio sve kao i sa 8core/16 threads,barem to stoji za 90 % korisnika!Em će se dati i bolje klokat em će manje trošiti,tako da ako razlika u cijeni bude poveća,ne znam tko bude uzimao x8?
Ali pričekajmo prvo bencheve.Još je zec u šumi!
Phil of the future!
Staro 09.02.2017., 16:51   #2838
sti
Lokacija: Lawl
Postovi: 1,381
Osnovni model 8/16 (R7 1700) ima TDP od 65 W
Staro 09.02.2017., 17:07   #2839
R5 Pro 1500 mi se smije ako bude 1300-1500 kuna
Staro 09.02.2017., 17:07   #2840
Amd_Shill
Lokacija: Sat
Postovi: 1,119
Te cijene možda znače da Zen ipak nije toliko dobar niti u rangu Intelove ponude.
EDIT: sorry, sad vidim da je flagship 600 eura.
Staro 09.02.2017., 17:11   #2841
thunderbird
Premijum AMDebil
Postovi: 1,150
Te cijene kaj su napisali je samo lijep sastavak napisan na temu tablice koju je netko stavio par postova prije...
Po meni trla baba lan i pretakanje iz šupljeg u prazno
I dalje se ne zna dal će uopće biti 6c12t procesora ili 8c8t
X
Staro 09.02.2017., 17:12   #2842
DragonSlayer
DragonSlayer's Avatar
Datum registracije: Nov 2012
Postovi: 724
ili samo da amd ne želi pljačkat ljude koliko i intel lol.
mene zanima kakav će bit R5 1300/Pro 1300 (btw koja je razlika između pro i amater verzija?)
DragonSlayer je offline   Reply With Quote
Staro 09.02.2017., 17:16   #2843
Wolverine
Wolverine's Avatar
Postovi: 12,433
Meni ta tablica i dalje performance-wise nema nikakvog smisla. Kak su zamislili da će 8/16 proc imat u jednoj varijanti performanse ko 4/8 i7 7700, u drugoj kao 6/12 I7 6800K, a u trećoj kao 8/16 i7 6900K i to sve s navodno istim rasponom radnog takta :/
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 09.02.2017., 17:35   #2844
de.fang
de.fang's Avatar
Datum registracije: Mar 2009
Lokacija: Sk-Zg
Postovi: 1,097
Ni meni tablica nema smisla. Ali sve mi miriši po onome što je do sada objavljeno da amd izlazi sa dobrim proizvodom. Najviše me zanima kakav je odnos performansi po jezgri i na kojoj frekvenciji. Tdp im je izgleda jako dobar.
de.fang je offline   Reply With Quote
Staro 09.02.2017., 17:41   #2845
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,462
Kad je izlazio bager intel nije ni mrdnuo, a sada je izbaci i3 K procesor i dodao jos par ekstra procesora ''da se nadje'', tako da mi se cini da bi ovo stvarno moglo biti nesto.
A mozda se i varam...a mozda su u sumi
Slobodno me dodajte na PSN
Staro 09.02.2017., 17:57   #2846
DragonSlayer
Postovi: 724
ma to je imena radi, i7 vs R7 itd, lakše je tako objasnit glup naming scheme lol
Staro 09.02.2017., 18:19   #2847
Manuel Calavera
Postovi: 14,589
A što se točno promjenilo od jučer-prekjučer? Samo su i drugi portali prenijeli istu vijest. No kažem, i da je fejk takve cijene se poklapaju sa mojim očekivanjima (osim ovog trećeg i najjeftinijeg 8c16t). Znači leak je tobože prema španjolskoj, tamo kaže i7 6900K košta 1200€, a zen flagship 600 eura, što bi kod nas bilo 4450kn (pola od 6900K jel), ovaj srednji 3560kn, ovaj najjeftiniji bi bio oko 3000kn...
Istina za gaming. Doduše đokac kaže da mu i7 6800K na 4.3ghz watch dogs 2 optereti do 90% sa gtx 1080, također i po ovome pa možda i nije suludo za nekakav high end gaming build, naravno ako razlika u cijeni ne bude velika između hexe i octe.
Zadnje izmijenjeno od: Manuel Calavera. 09.02.2017. u 18:25.
Staro 09.02.2017., 19:06   #2848
emilblomsky
Lokacija: karlovac
Postovi: 2,109
Ako taj fleg bude imao takvu cijenu spram intelovog,onda se brinem za njegove performanse.Jer ako amd zna da ima zvijer u ladici,onda bi i cijena bila zvijerska.Samo moje razmišljanje,ne!
Phil of the future!
Staro 09.02.2017., 19:13   #2849
John Creasy
Lokacija: Beograd
Postovi: 2,838
pa davno je govoreno da intelovi procovi ne vrijede toliko koliko vrijede (s obzirom na cijenu proizvodnje).. zar nam treba još kapitalizma? ionako vidimo da svi jedemo ista govna, samo nam fale još amd procovi od 1200 eura
Staro 09.02.2017., 19:15   #2850
Wolverine
Wolverine's Avatar
Postovi: 12,433
Možda igraju na sigurno, no opet...
Sjeća li se itko ovoga?
Misliš kao što su nekad bili FX57 i FX60
Mark Twain
2x 8GB DDR3
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
