Staro 20.11.2016., 22:38   #31
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,835
Da. Nekad zna raditi probleme, bilo je već spominjano po forumima, ne tvrdim da će pomoći u tvom slučaju ali vrijedi probati.
Staro 20.11.2016., 23:02   #32
thubanx6
thubanx6's Avatar
Datum registracije: Aug 2011
Postovi: 533
Autor Sinac Pregled postova
Pokušam pa javim
thubanx6 je offline   Reply With Quote
Staro 24.11.2016., 18:08   #33
thubanx6
thubanx6's Avatar
Postovi: 533
Izgleda da je bilo do toga.
Gigabyte z87m-d3h.
Tek kad sam u biosu isključio gpu problemi nestali.
Hvala!
Staro 24.11.2016., 21:55   #34
Sinac
Sinac's Avatar
Postovi: 2,835
Super. Hvala i tebi što si javio da je riješen problem, možda pomogne i nekom drugom.
Staro 28.11.2016., 20:21   #35
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Novi 376.09 - WHQL
http://www.nvidia.com/download/drive...x/111830/en-us
Game Ready Drivers provide the best possible gaming experience for all major new releases, including Virtual Reality games. Prior to a new title launching, our driver team is working up until the last minute to ensure every performance tweak and bug fix is included for the best gameplay on day-1.
Game Ready
Provides the optimal experience for Watch Dogs 2
Glavas_ZG je offline   Reply With Quote
Staro 07.12.2016., 00:03   #36
Glavas_ZG
Postovi: 218
GeForce 376.19 WHQL driver download
http://www.guru3d.com/files-details/...-download.html
Game Ready
Provides the optimal VR experience for Oculus Touch launch titles
We have a discussion thread open on this driver right here.
Application SLI Profiles
No SLI profiles were added with this version.
Windows 10 Fixed Issues
[SLI] No Man's Sky with Foundation Update 1.10 shows severe texture corruption if
SLI enabled.
Notebook G-SYNC flickering.
Notebook G-SYNC pendulum demo issue.
3D Vision Profiles:
Added or updated the following 3DV profiles:
DeadRising 4 - added 3DV profile
Mars 2030 - added 3DV profile
Serious Sam - added 3DV profile
SuperHot - added 3DV profile
3D Compatibility Mode Profiles:
No compatibility mode profiles were added with this version
Staro 27.01.2017., 20:27   #37
alen.s
alen.s's Avatar
Postovi: 1,441
samo da javim da mi zadnji 378.49 WHQL baca error 43;
https://www.drivereasy.com/knowledge...rted-problems/
stari driveri rade...
Staro 02.02.2017., 22:51   #38
denied
denied's Avatar
Postovi: 1,193
Koga zanima 376.80 Vulkan developer beta driveri - ljubitelji Dooma.....
denied je offline   Reply With Quote
Staro 15.02.2017., 19:57   #39
realmadrid
realmadrid's Avatar
Datum registracije: Aug 2010
Postovi: 239
Napravio update na nove 378.66, odvrtim Valley i umjesto prijašnjih 93 FPS dobijem 98 FPS (sve max, 1080p, default postavke u Nvidia CP)
realmadrid je offline   Reply With Quote
Staro 16.02.2017., 14:44   #40
alen.s
alen.s's Avatar
Postovi: 1,441
sa 378.66 opet dobivam error 43
Windows has stopped this device because it has reported problems. (Code 43)
sad se vec mislim da je prob kod mene jer drugi ocito nemaju ovaj problem. Zanimljivo kako grafa radi najnormalnije sa svim prijasnjim driverima osim ova 2 najnovija...
Staro 16.02.2017., 15:17   #41
Autor realmadrid Pregled postova
Sa kojih drivera si radio update?
Ja sam sa predzadnjih 378.49 na 378.66.
Ovo su razlike, skoro pa ništa:
Staro 16.02.2017., 17:17   #42
Bariarnil
Valley je single thread uvijek botleneckan, probaj vrisnut viši OC pa ćeš vidjet kako ide više. Uostalom, on ima 6700k
Staro 16.02.2017., 18:31   #43
Kakav viši oc, na 4500 MHz beše
Staro 16.02.2017., 19:45   #44
realmadrid
realmadrid's Avatar
Postovi: 239
Isto tako, s predzadnjih 378.49. Nisam siguran da CPU ima veze s ovim, jedino što sam od prethodnog testa mijenjao su GPU driveri.
Evo screen od friškog testa - nešto je niši rez od onog prvog što sam vrtio. Svakako poboljšanja s novim driverima ima. BTW ne šljaka mi baš postanje slika pa moram ovako u linku.
https://postimg.org/image/v2vrpbtb9 - 378.66
https://postimg.org/image/7gq1mknsn/ - 378.49
Zadnje izmijenjeno od: realmadrid. 16.02.2017. u 20:14. Razlog: Screen novog testa
Staro 17.02.2017., 05:36   #45
realmadrid
realmadrid's Avatar
Postovi: 239
Skužio sam u čem je fora bila - inače uvijek u Nvidia control panelu imam postavljen V-Sync na Fast jer tako nemam coil whine kad FPS ode u neke lude cifre (npr. u meniju). Nakon što sam napravio clean install drivera opcija vratila na default odnosno Use the 3D application setting i odatle tih 5-7 FPS-ova viška u benchmarku.
Staro 26.03.2017., 21:45   #46
Glavas_ZG
Postovi: 218
Staro 06.05.2017., 08:41   #47
Glavas_ZG
Postovi: 218
Staro 06.05.2017., 16:11   #48
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Ajde veceras cu probat. Mozda vise nece biti rušenja u cutscena iz Mafie 3.
Staro 01.12.2017., 00:44   #49
Glavas_ZG
Postovi: 218
GeForce 388.43 WHQL driver download
Staro 01.12.2017., 01:04   #50
To je već 3. iteracija 388 drivera u ni mjesec dana. Fušaju li ga fušaju
Sent from my SM-A500FU using Tapatalk
Staro 01.12.2017., 10:35   #51
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,830
Pozdrav, jučer (vlc, mpc) pokrenem film u FHD na 55" telki u extended modu, naravno primary je monitor, slika (video stutter) zatrzava, prebacim samo da mi prikazuje sliku na telki, radi sve bez greške..
Ak stavim da je primary na tv onda je čak ok..
Jel primjetio taj problem ko od vas, a da imate komp povezan s telkom putem hdmia?
Ovaj problem je raširen diljem neta i očito pogađa redovno korisnike nvidia kartice..
Onaj ko ima izvježbano oko primjetit će taj iritantni problem, dok postoji mogućnost da pojedinci neće ni primjetit to..
Staro 01.12.2017., 10:45   #52
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,424
jesi probo namjestit monitor na osvjezenje videa?
daklem ak je video 23.9xx fps, namjestis ga u playeru na toliko.
ja to uvjek radim u MPHC, akli i onda znam imat trzaje. jednostavno mi se neda po tome drkeljat vise. ima puno rjesenja, drugih codeca itd. samo neki mi iskljuce OSD pa me to nervira...
i ukljuci da ti vrti preko grafe, ako nisi...
edit: il sam ja nest kriv shvatio pa ti je ovaj problem tek na ovom novom driveru?
geronimo_2 je online   Reply With Quote
Staro 01.12.2017., 10:50   #53
Autor zvonac Pregled postova
To je do 1709 windowsa.
Sent from Mobara
Staro 01.12.2017., 11:50   #54
zvonac
zvonac's Avatar
Postovi: 5,830
Sent from Mobara
Moguće.. 1709 16299.64 tu verziju imam.. Probao tri prethodna drivera od nvidije i ništa..
Kollko se sjećam, taj problem nisam imao prije reinstalacije winsa, doduše bila je starija verzija OSa..
A ček, jel to konkretno neki update zafrkava ili isključivo ta verzija winsa?
Kak je kod vas ostalih?
Izgleda da ovaj put nvidia nije kriva
@geronimo, ak je do winsa, onda nema drugog rješenja osim na ić na nižu verziju ili čekat da se ekipa pobuni i prijavi ovaj issue, mada sumnjam da će bit kaj od toga..
Staro 01.12.2017., 13:06   #55
Moš se karat. Ili 1703 ili MPC HC + madVR + Smooth motion za filmove. VLCu otpjevaj pjesmu od neprežaljene Đurđice Barlović "Zaboravi me Gorane".
Ja to napravio pred koji dan, nađi moje postove u Windows 10 info temi i Koji media player kupiti. Imaš linkove i tutorial. I kao što rečem, radi.
Sent from Mobara
Staro 01.12.2017., 13:15   #56
Postovi: 8,544
I da stvar bude bolja, Microsoft je iz Fall Creators Update odlučil maknuti HEVC dekoder, samo da bi ga nudili kao zasebnu aplikaciju.
Staro 01.12.2017., 14:16   #57
zvonac
zvonac's Avatar
Postovi: 5,830
Nije samo problem u trzanju videa, neg sam primjetio lag (ghost recon wildland) u igri i trzanje uz pad fpsa na momente. Izgleda da cu se vratit na 1703..
Staro 02.03.2018., 14:51   #58
Evo mali heads-up kako ne instalirati sav crapware/bloatware/spyware iz nVidia drivera:
1. Skinuti najnoviji driver za karticu/OS sa nVidia stranice
2. Skinutom fajlu promjeniti ekstenziju iz .exe u .7z
3. Raspakirati drivere u folder
4. Izbrisati sve iz tog foldera sve osim prikazanog na slici ispod
5. Instalirati klikom na setup.exe
Sebi sam ostavio Fiziks i HD audio jer to koristim, ali ako vam ne treba, možete i to maknuti.
Staro 02.03.2018., 15:53   #59
sti
Lokacija: Lawl
Postovi: 1,380
Pa može se i custom instalacijom. Ja uvijek instaliram driver+fiziku. Osim ako ne postoji baš neki crapware kojeg ne možeš preskočiti.
Staro 02.03.2018., 16:01   #60
geronimo_2
geronimo_2's Avatar
Postovi: 4,424
ja to tak gore opisano radim vec par mjeseci. sve 5. kome netrebaju ona gofna naravno...
masu toga iz paketa nemozes preskociti nego se ugnjezdi.
