Staro 13.12.2016., 14:11   #1
Žak Onanis
Datum registracije: Jul 2015
Lokacija: Vukovar
Postovi: 288
Ne može se logirat na facebook
Let's Check Your Device for Malicious Software
Hi Maria, we're continuously working to keep your account secure. We've noticed that this device may be infected with malicious software. To continue to use Facebook, you can either use other devices or clean this device by downloading the scanner provided by Facebook and Trend Micro.
Clean This Device
Download Scanner
Please download ttie recommended scanner fiom Facebook and Trend Micro to
clean your Infected device
By doing Download, you agree that Faceoook and Trend Micro can access your device in order to collect, analyze and remove files that may be malicious and use and snare the colected data to improve security on and off Facebook
Download
Run Scanner
Your download will begin shortly. When you're ready. follow these steps to start Trend Micro scanner Once you start the scanner, you'll be able lo use Facebook and otner sites
1 - Find a file named Trendmicro_T10211755447349430T_ exe
2 - Open Trendmicro_T10211755447349430T_ exe
3 - Until scan completes you'll be able to use Facebook In read-only mode
Od jučer, sestra mi nikako se ne može logirati na facebook
Nakon upisivanja svojih podataka pojavljuju se ova 3 upozorenja (redom)
Clean This Device
Download Scanner
Download
Run Scanner
Žak Onanis je offline   Reply With Quote
Staro 13.12.2016., 16:11   #2
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,087
Paaaaaaaaaaa, jel si probal očistiti komp od virusa?
Ryzen 7 5700G
AsRock B550 Pro4
Kingston A2000 1TB NVMe
Intel 660p 1TB NVMe
Fortron Hexa 400W
Random PC case
Proxmox VE
Fujitsu U7311
Intel i5 1135G7
16GB DDR4 3200MHz
SK Hynix P31 Gold 1TB
13.3" FHD IPS
Staro 13.12.2016., 16:25   #3
Žak Onanis
Lokacija: Vukovar
Postovi: 288
Jesam s:
MalwareBytes-AdwCleaner
Malware bytes-anty malware
RegClean Pro
Wise Disk Cleaner
Staro 13.12.2016., 16:29   #4
spitfire83
spava mi se
spitfire83's Avatar
Datum registracije: Nov 2013
Postovi: 329
Mislim da ćeš morati skinuti to gofno, proskenirati I onda će će pustiti unutra
spitfire83 je offline   Reply With Quote
