Staro 30.11.2016., 00:52   #271
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Ajd perf. smo znali, ali wtf se dogodilo sa potrošnjom i temperaturom. Samo je 200mhz gore stock, ali je proces navodno mnogo zreliji... WTF kaby
Staro 30.11.2016., 01:07   #272
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,297
Prescott strikes again
Staro 30.11.2016., 01:18   #273
Manuel Calavera
Postovi: 14,589
Recenzija krene sa obećanjima
Intel says that taller transistor fins and wider gate pitch endow its 14nm+ process with an additional 300 to 400 MHz clock rate capability. That’s huge if it turns out to be true. As a motherboard reviewer, it’s also one of the first things I wanted to test!
We’re also told that process improvements will enhance efficiency, but there is no free lunch. Intel didn’t change the core micro architecture between Skylake and Kaby Lake, and our motherboard didn’t even read a voltage reduction for the Core i7-7700K, compared to the Core i7-6700K. Our motherboard set the Core i7-7700K to 1.30V at its 4.50 GHz max turbo, whereupon it behaved exactly the way we’d expect our Core i7-6700K to act when overclocked to 4.50 GHz at 1.30V.
Na kraju dobije 200mhz više za istu voltažu i veće temperature i potrošnju??
Pa se nadaju da je do ploče
Intel’s Kaby Lake efficiency pretenses are thrown out the window in the Core i7-7700K, at least when paired with this motherboard. Perhaps we have something to look forward to when Z270 finally gets here?
Kakve veze mbo ima ako:
- ga podržava službeno
- ista arhitektura
- oba testirana na istoj
Staro 30.11.2016., 01:47   #274
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,297
Jede govanca, nastoji ih opravdat.
Staro 30.11.2016., 08:21   #275
Zen, do come in.
Ovo je komedija. 200 MHz za 20°C više. Stvarno kamo to vodi. Čemu onda izbacuju svake godine novi CPU. Čemu? Kome? Toliko fanbojeva nema da prate taj destop/gejm segment.
Staro 30.11.2016., 08:53   #276
tiki66
tiki
tiki66's Avatar
Postovi: 2,776
Istina, treba im neka konkurencija i to pod hitno, ovo je i dalje recikliranje
tiki66 je online   Reply With Quote
Staro 30.11.2016., 09:10   #277
Dottore
Dottore's Avatar
Postovi: 7,725
Nisam fanboy, nego jesu li testovi službeni? Da nije možda procesor ES.?
Sent from my Nexus 6P
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 30.11.2016., 09:44   #278
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Ha, veli ovako
Editor's Note: Intel declined to comment on our general findings. Although the CPU we received is not marked as an engineering part, we cannot confirm with certainty that it is a retail sample.
Zvone2772 je offline   Reply With Quote
Staro 30.11.2016., 13:02   #279
Manuel Calavera
Postovi: 14,589
Zen, do come in.
Intelu treba dati isti savjet kao activisionu za call of duty - pod hitno prestat izbacivat cpu/igru svake godine. Prouzrokovat će si negativne posljedice, ako ne u financijama onda u reputaciji, a posljedično i u market shareu. Ovo fakat nema smisla
Iako igra nema veze sa hardverom, COD je možda najbolji svjetski primjer milkanja branda i propasti (kod njih se drastično vidi i u brojkama tj. finacijama)
Da testovi nisu od samog toms hardwera nego neki "leakovi" svakako da bi sumnjao u testove, ovako baš i ne. Kako lik hladno apologetski završi mini-review "možda je do ploče", bez ikakvog zaključka, osobnog mišljenja...
Kakva ploča, takva sranja bi mogao očekivati za zen jer je potpuno nova mbo platforma i arhitektura, vjerojatno će biti bugova i bios updatea ko u priči, ali ovo, maltene isti proizvod kao prošle generacije...
I da drugi testovi ne budu ovako loši po pitanju temp i potrošnje, poanta je ista.
Zadnje izmijenjeno od: Manuel Calavera. 30.11.2016. u 13:10.
Staro 01.12.2016., 12:01   #280
windfucker
Ja sam milimetar od odluke o zanavljanju glavnoga stroja (CPU/MBO/RAM) i jučer sam prelomio, analizirajući ove zadnje izvještaje, da je došlo vrijeme i da neću čekati ovu novu generaciju već idem na Sky, dosta je bilo ove Ivy konfe, odslužila je svoje, a i ja sam upao u neku paru, pa da to iskoristim dok mene nisu iskoristili, jel'...(čitaj: skvo)
Eno, gledam Links, digli sve cijene na Sky proceve, i odmah mi sine ovaj Manuelov proročanski post
Fakat presmiješno, u osvit izlaska nove generacije, staroj cijena- raste
I nije dolar u pitanju (barem mi tako ne izgleda), jer drugi su artikli (koje gledam i pratim, konkretno ploče) zadržali staru cijenu, ali Sky (i to ciljano i5 & i7 serija)- ne
Malo jeste OT, ali i- nije baš.
Kako ono ide?
"Dobar glas daleko se čuje, a loš..."
Staro 01.12.2016., 12:33   #281
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
ja sam vec odustao od kaby-ja i sutra idem po sky.
Staro 01.12.2016., 12:45   #282
dean225
DD9512
dean225's Avatar
Postovi: 1,869
ja cu svejedno uzeti Kaby ako budem uzimao Intel. Cisto jer je zadnji chip i opet sam miran 5 godina. Potrosnja me ne zanima a OCat cu ga onoliko koliko ga budem uspio ohladiti i dobro.
dean225 je offline   Reply With Quote
Staro 01.12.2016., 13:11   #283
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Svi vi s nafrljenim Ivy i Sandy Bridgeom, ja ne bih kupovao Skylake/Kaby Lake niti išta novo sad, barem dok se ne vidi što će Zen ponuditi.
Staro 01.12.2016., 13:13   #284
Autor Smartic Pregled postova
Govorimo to već više od pola godine, ali postoje sfere koje garantiraju skokove od više desetaka odsto pa jel...
Staro 01.12.2016., 13:13   #285
Manuel Calavera
Postovi: 14,589
Ajd da je kaby novi socket, pa da će dulje ploče biti u opticaju, ali ako nekome krepa i 1xx chipset ploča moći će komotno uzeti 2xx chipset za skylake
Kome nije hitno (ima sada OK konfu) fakat nebi bilo loše pričekati zen. Čak i da ne kupi amd možda se sruše cijene intelu, ako ne izgubit ćete samo vrijeme (par mjeseci) i nikom ništa
Staro 01.12.2016., 13:37   #286
windfucker
To što Manuel kaže u prvome dijelu posta...
+ kome i za koju lovu prodati procesor kada mi matična prdne?
Drugu (Z chipset za Sandy/Ivy) mogu samo sanjati da ću nabaviti već sada, a kamoli za dogledno vrijeme...
RAM isto...sve je sada na "četvorki".
Mislim da je pametnije riješiti se postojećega sada, i prijeći baš na Sky.
AMD mi implicira masu novoga što nisam spreman riskirati, prvo još čekanja, zatim potpuno nova platforma sa previše nepoznanica, a i na AMD-u (izuzev ovoga s.AM1 koji je u službi HTPC-a) nisam bio doslovno od ADM x2 4200+ s.939 (i sada ste me natjerali da se opet osjećam staro, sunce vam....).
I to je još jedan razlog zašto treba(m) ići na Sky...premator sam da čekam revoluciju i obećane promjene.
Sky it is, i to najjakiji, nema više zezanja
Ufff...neću više, sada sam čisti OT. Sry.
Staro 01.12.2016., 13:42   #287
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,764
+1
Meni je u planu bilo za blagdane pocastit se skylakeom i odgovarajucom mbo + ddr4 ramom te umiroviti starog Sandya... Ali definitivno cu pricekati Zen. Ako se pokaze uspjesnim i jeftinijim od Intela, mozda se i vratim u crvenu ekipu
Staro 01.12.2016., 13:49   #288
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,834
Tako je.. Ivy i Sandy su još odlični a i dalje će bit dok god razlika će bit nezamjetna, a dok će razlika bit viša od 40-50% na svim poljima, e onda će bit vrijeme za novu konfu, a kolko vidim, do tad, ko živ ko mrtav.. Intel nema konkurencije, a ovo sve kaj izbacuju je mizerno po pitanju performansi, za radikalan odmak od starije generacije (Ivy-Sandy) će se još pričekat..
Ili lupit kontru Intelu i otić na Zen
Staro 01.12.2016., 13:50   #289
Manuel Calavera
Postovi: 14,589
Moja neka pretpostavka je da sve aktualno intel prodaje sa predebelom maržom.
Npr. jedan blast from the past
The mainstream Core 2 Quad Q6600, clocked at 2.4 GHz, was launched on January 8, 2007 at US$851 (reduced to US$530 on April 7, 2007). July 22, 2007 marked the release of the Q6700, and Extreme QX6850 Kentsfields at US$530 and US$999 respectively along with a further price reduction of the Q6600 to US$266.
I sa ovom zadnjom cijenom su ziher ostvarivali profit. E sad koliko zen može utjecati na cijene intela (i dali će) otom potom.
Staro 01.12.2016., 13:55   #290
rock00
Datum registracije: Feb 2011
Postovi: 324
nije mi jasno kak se moze grijat toliko pri naponu 1.30v? pa to je p.dim....uzevsi u obzir da je ista generacija 14nm
Onda ispadne da skylake mozes drzat na 1.4v i imat 4.9,uz istu tu temperaturu 80 na vodi
nadalje. ako je to krivo s temperaturama i on s 1.30 radi na 4.8,a prije 1.4 probija 5.0 stabilnih,onda kaby i nije losa stvar naspram skylake
rock00 je offline   Reply With Quote
Staro 01.12.2016., 15:51   #291
Bariarnil
Autor rock00 Pregled postova
Kada bude Intel poslo Kaby testerima, tj.kad padne embargo, onda ćemo zaključivat. Ovako od proizvođača ploča pa do pola prave recenzije proca koju inače Tomy radi, nije za skroz zaključit da je ili nije Kaby u banani.
Staro 01.12.2016., 16:37   #292
Manuel Calavera
Postovi: 14,589
Malo je čudno, ali vidjet ćemo. Inače toms hardware je cpu nabavio svojim putevima, ali nije inžinjerski primjerak (potvrđeno)
Procesori su davno gotovi, pa onaj azijci su objavili i5 7600K recenziju ima nekoliko tjedana (vjerujem da je legit), release date je strateški određen
Staro 01.12.2016., 22:43   #293
Dottore
Dottore's Avatar
Postovi: 7,725
Ja ću pričekati sa Kabyem (nakon proljeća) i potvrđenim testovima. Jedino meni upada Asus Strix Z270G Gaming (microATX ploča)
Iskreno, ne volim svjetlucave neonke u kučištu. Gledam isključivo USB-C priključak, SATA priključci su malo previše ali taman. Meni taman bi sjela postojeća zvučna Xonar DSX.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 02.12.2016., 19:29   #294
Manuel Calavera
Postovi: 14,589
Pcperovci tvrde da toms hardwareu procesore šalju proizviđači mbo. Kažu čija se prva recenzija Z270 ploče pojavi na njihovom siteu - ti su poslali.
Staro 02.12.2016., 22:37   #295
Manuel Calavera
Postovi: 14,589
Testirano na Z270 mbo
Što se tiče potrošnje izgleda isti vrag kao skylake, barem u ovome benchu (ono je bio prime)
Malo se jače grije
http://www.expreview.com/51056.html
Staro 02.12.2016., 22:48   #296
Dottore
Dottore's Avatar
Postovi: 7,725
Ne radi slike.
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
RAM: 64GB DDR5
Staro 03.12.2016., 01:03   #297
windfucker
Mda. Sada i Tom piše da je dobio nižu potrošnju sa novim BIOS-om na Z170-ici.
Još uvijek je to 25W više, ali i clock je viši...i ja mislim da je to isti racq (Sky vs Kaby).
Staro 03.12.2016., 01:10   #298
Manuel Calavera
Postovi: 14,589
Ali i skylake manje troši na toj drugoj ploči, tako da dođe skoro na isti kuki kao prvi test
http://www.tomshardware.com/news/int...ate,33119.html
A temp. ima baš ono neugodno veću u loadu (za razliku od kineske recenzije na Z270, gdje je nešto ispod 2C topliji, ali nije prime95)
Staro 03.12.2016., 16:20   #299
alengrosevic
alengrosevic's Avatar
Postovi: 3,793
http://www.guru3d.com/news-story/int...-platform.html
Z270 i 7700k protiv z170 i 6700k. Sky je brži na istom clocku
Staro 03.12.2016., 16:25   #300
Manuel Calavera
Postovi: 14,589
To je onaj kineski review što sam gore linkao. Ma nije skylake brži to su sve razlike u prvu ili drugu decimalu, razina statističke greške. Jednostavno se radi o istoj arhitekturi i istom IPC-u
