Staro 21.11.2016., 00:20   #1
telefunken
telefunken's Avatar
Datum registracije: Apr 2015
Postovi: 718
QNAP i VPN
želio bih upost VPN i spojiti se sa QNAP-om no nešto sam čitao po forumima da qnap ima problema s openvpn-om pa me zanima ako netko ima takav setup da mi kaže jel su to glasine ili uistinu nemogu koristiit openvpn na qnap-u
Pošten trgovac
Trgovine: 1, 2, 3, 4, 5, 6, 7
telefunken je offline   Reply With Quote
Staro 21.11.2016., 11:40   #2
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,281
Imam to u planu upogonit u sljedecih par dana tako da cu se javiti kad to sredim (cekam nas da stigne).
Koliko sam vidio po netu, nebi smjelo biti problema. Treba podesit openvpn na nas-u i napraviti port forward na ruteru.
Staro 21.11.2016., 18:13   #3
telefunken
telefunken's Avatar
Postovi: 718
ajde onda ti probaj pa javi, željno očekujem informacije
Pošten trgovac
Staro 26.11.2016., 19:24   #4
telefunken
telefunken's Avatar
Postovi: 718
ubo sam nordvpn i evo uništavam se već danima kako to poriktat. slijedio sam tutorijal:
https://support.nordvpn.com/hc/en-us...QNAP-NAS-setup
no u log fajlu mi kaže:
Code:
Sat Nov 26 18:13:03 2016 OpenVPN 2.3.6 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov  2 2016
Sat Nov 26 18:13:03 2016 library versions: OpenSSL 1.0.0t 3 Dec 2015, LZO 2.05
Sat Nov 26 18:13:03 2016 WARNING: file '/share/CACHEDEV1_DATA/Download/VPN/nordpass.txt' is group or others accessible
Sat Nov 26 18:13:03 2016 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Sat Nov 26 18:13:03 2016 NOTE: --fast-io is disabled since we are not using UDP
Sat Nov 26 18:13:03 2016 Control Channel Authentication: tls-auth using INLINE static key file
Sat Nov 26 18:13:03 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 26 18:13:03 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Nov 26 18:13:03 2016 Socket Buffers: R=[65536->131072] S=[65536->131072]
Sat Nov 26 18:13:03 2016 Attempting to establish TCP connection with [AF_INET]95.211.224.1:443 [nonblock]
Sat Nov 26 18:13:06 2016 TCP: connect to [AF_INET]95.211.224.1:443 failed, will try again in 5 seconds: No route to host
Sat Nov 26 18:13:12 2016 TCP: connect to [AF_INET]95.211.224.1:443 failed, will try again in 5 seconds: No route to host
Sat Nov 26 18:13:20 2016 TCP: connect to [AF_INET]95.211.224.1:443 failed, will try again in 5 seconds: No route to host
imam amisov Eltek smeće router i u njemu sam podesio u NAT->PAT postavkama port forwarding za IP od NAS-a i to TCP 443 i UDP 1194 (ta dva koriste nordvpn)
pomoć kako da ovo riješim?
Pošten trgovac
Staro 28.11.2016., 17:37   #5
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
ne trebas otvarati portove, jer tvoj QNAP je OpenVPN client a ne OpenVPN Server
OpenVPN Server (Provider) ti je tvoj NordVPN
daj prvo probaj namjestiti vezu sa pc-a OpenVPN client software prema NordVPN-u, da budes siguran da imas sve ispravne podatke (cert, user, pass itd.)
tek onda predji na troubleshooting QNAP OpenVPN-a, iako tu nema previse mudrosti, ako radi na PC-u trebalo bi raditi na NAS-u
MasterX je offline   Reply With Quote
Staro 29.11.2016., 00:00   #6
telefunken
telefunken's Avatar
Postovi: 718
evo uspio sam spojiti qnap i openvpn, glupi detalj nisu naveli u setupu pa nsiam obraćao pažnju na njega. sve u svemu, spojio sam nas i qnap
no... sad imam drugih problema: transmission torent client se ne želi više seedati, kaže "error: could not connect to the tracker". to mi kaže za sve trackere i to kaže instant čim pokrenem seedanje torenta (imam ih na čekanju skinute). dal je to možda do VPN-a da je blacklistan ili se mora nešto posebno podesiti na qnap-u uz VPN da bi mogao koristiti p2p kako spada?
EDIT:
evo sad sam ubio VPN vezu i torenti rade kako spada... dakle do VPN-a je
EDIT #2:
promijenio sam server, prvih minutu je sve radilo, čak i IP magnet no onda je prestao. torrenti koji su na seedanju se seedaju i dalje a koje sam stavio friško skinuti imaju error "could not connect to the tracker".
Pošten trgovac
Zadnje izmijenjeno od: telefunken. 29.11.2016. u 00:27.
Staro 29.11.2016., 19:24   #7
telefunken
telefunken's Avatar
Postovi: 718
evo probao sam preko utorrenta u windowsima i radi preko VPN-a bez po frke, na ipMagnetu uredno pokazuje IP od VPN-a. dakle nešto je*e u QNAP-u...
Pošten trgovac
Staro 30.11.2016., 15:22   #8
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
testiraj sa https://www.dnsleaktest.com/ extended test pa vidi da nemas IP leak ili DNS leak
putty, ssh, port, socks5, tako da mozes simulirati kao da ides direktno sa QNAP-a
https://www.adamfowlerit.com/2013/01...a-socks-proxy/
Staro 01.12.2016., 18:28   #9
telefunken
telefunken's Avatar
Postovi: 718
Autor MasterX Pregled postova
testirao sam i nema leakova. ali to je samo za windowse... neznam kako da testiram time qnap?
nije ti bolje da koristim VPN aplikaciju za windowse od nordVPN-a tako da mi sav promet s kompa ide drito kroz VPN na net a ne da prvo ide kroz qnap? jer mogu imati 5 veza prema VPN-u istodobno s tim akauntom pa nevidim potrebe da koncentriram promet na qnap
Pošten trgovac
Staro 02.12.2016., 00:04   #10
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
Autor telefunken Pregled postova
kao sto sam ti napisao, prati upute, spoji se sa svog win PC-a preko putty-em na SSH na tvoj QNAP (prije toga definiraj port u Putty-u, prati link koji sam ti postao)
onda preko SOCKS5 proxy-a (npr. Firefox) testiraj da li imas leakova na samom QNAP-u, na taj nacin ces testirati direktno NAS
ako ces koristiti QNAP za nesto osjetljivo, mozda nebi bilo lose da slozis i skriptu za "kill-switch" tj. kada se prekine VPN veza da nebi doslo do leak-a (IP, DNS, itd.)
testiraj sa visestrukim SSH vezama, preko jedne npr. ping 8.8.8.8
preko druge veze "ifconfig "naziv-vpn-interface-a" down" pa vidi da li ping i dalje prolazi
