Staro 15.08.2016., 19:13   #1
Nvidia Geforce WHQL Driver Info Thread
Poštovani kolege,
obzirom da je do sada bila navika i praksa da se svakim izlaskom novog nVidia drivera otvara i nova tema, odlučili smo da sada pa ubuduće imamo jednu temu za drivere.
Naravno, slobodni ste i dalje linkati driver i napisati changelog kao i u prijašnjim temama, samo što ćemo sada sve izlaske novih drivera popratiti u ovoj temi, bez naknadnih otvaranja novih.
Zahvaljujem
Staro 16.08.2016., 10:28   #2
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Datum registracije: Dec 2011
Postovi: 218
New feature and fixes in driver 372.54
Game Ready - Provides the optimal experience for No Man’s Sky, Deus Ex: Mankind Divided, Obduction, F1 2016, and the Open Beta for Paragon
http://www.geforce.com/drivers
New Features -
Support for updated BatteryBoost technology.
Enabled mclk switches on 144 Hz G-SYNC monitors in multi-monitor use cases in order to lower power consumption.
Support OpenGL VR SDK 1.4 (Windows).
Added a Windows cross-API interop between Vulkan and DirectX 11. This enables Vulkan app compatibility with existing DirectX 11-based HMD runtimes.
Added driver support for DXGI 2 VR.
SLI Profile - Added or updated the following SLI profiles:
Deus Ex: Mankind Divided - added DirectX 11 SLI profile
No Man’s Sky - added (Beta) SLI profile
Space Engineers - added DirectX 11 SLI profile
Fixes:
[368.69, GP104] Corrected high DPC latency.
[Space Engineers] Need SLI profile for DirectX 11 version.
{Mac OS X] Higher quality CUDA icon needed to take advantage of Retina display.
[368.69, GeForce GTX 1080] CUDA 7.5 and CUDA 8.0RC fail bandwidth test.
[SLI, Witcher 3] Shadow darkness intensity changes randomly during gameplay.
[368.81, Windows 10 x64] Netflix Windows Store app stutters in full-screen mode.
[GeForce GTX 980 Ti, Windows 10 x64] Low GPU usage/scaling in Guild Wars 2 with SLI + Surround.
[Call of Duty: Black Ops III] Illegal instruction crashes occur on NVIDIA hardware.
[Quadro K5000, Windows 10 x64] Hyper-threading performance loss of 4–16 times with recent Quadro drivers compared to 354.56.
[364.51, Windows 10] After driver update, Steam controller on-screen keyboard shows only white screen.
[SLI, 368.39, GP104] GTX 1080 SLI can't be enabled if third graphics card installed in system.
High GPU idle clocks occur with two DisplayPort displays. [1739442]
[Steam VR] Vive on the Link Box mini-DisplayPort is not detected after a sleep/resume or a hot unplug/plug.
RFE: Vulkan ability to auto-promote border-less full screen to full-screen exclusive.
[368.39, Windows 10, Windows 8] Micro-stuttering and lower OpenGL performance compared to Windows 7 occurs on Optimus notebooks.
RIP Šaban (21.6.2016)
Staro 16.08.2016., 17:58   #3
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,617
napomenuo bih samo da taj 372.54 kod downloada nudi Windows 10 Anniversary Update, tak da valjda su i po tome nekaj prčkali
Staro 27.08.2016., 16:01   #4
Upravo digo ove zadnje drivere. Samo pregazio stare. Problemi 0 bodova ni tijekom instalacije ni gameplaya.
Staro 30.08.2016., 18:17   #5
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Izašao je novi driver:
WHQL 372.70
http://www.geforce.com/drivers/results/107008
Game Ready Driver Release Notes
http://us.download.nvidia.com/Window...ease-notes.pdf
Glavas_ZG je offline   Reply With Quote
Staro 30.08.2016., 20:35   #6
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,795
Meni je ovaj 372.54 rušio Handbrake. Prilikom dodavanja video fajla u Handbrake Nvidia bi javila ono unable to remove device i puff nema drivera više. Restartam stroj i sve ok dok ne probam ponovno. Win7 je u pitanju.
Sent from my G2
Staro 30.08.2016., 20:58   #7
Bariarnil
Update sa .54 na .70 prošao u redu
Staro 30.08.2016., 22:44   #8
Smoki_Gs
Smoki_Gs's Avatar
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
I ja sam presao na .70 ,i NAPOKON mi se rijesio jedan problem,kojeg nisam imao na GTX 970 a na GTX 1060 jesam sa ovom verzijom prije .70 ... Naime problem je bio taj sto dok gledam na jednom monitoru film/seriju a na drugom monitoru igram Football Manager trzala je igra,tocnije imala microsttuter i video je imao neke trzaje,kao da grafa nije imala snage za to dvoje Sada nema tih problema,evo sad dok pisem ovo,FM u pozadini tekma ide i na drugom monitoru serija,i sve glatkooo Druge igre nisam jos ni pokrenuo,ali ni u jednoj nisam imao problema,tako da mislim da necu ni skuzit razliku...
Staro 30.08.2016., 23:51   #9
Bariarnil
Autor Smoki_Gs Pregled postova
To je čak frustrirajuće.Daj mi reci kolko si para dao za 1060,i gdje si kupio?I kolko je glasna
Staro 31.08.2016., 00:34   #10
Smoki_Gs
Smoki_Gs's Avatar
Lokacija: Gospić
Postovi: 452
Ma to je bio dio neke zamjene s frendom,970 za 1060 Sto se tice grafe,prezadovoljan,fenomenalan clocker,sto se tice buke,buke nema Sama grafa drzi ventove u idle do 58/60(nisam siguran koje od to dvoje) stupnjeva,i uz to u Fractalu R4,i kad se zavrte ne cujem ju.
Evo,jos gledam seriju i igram Football Manager,grafa je na 47 stupnjeva,ventovi nula
Staro 06.10.2016., 18:09   #11
softwaremaniac
Datum registracije: Mar 2015
Lokacija: Doma
Postovi: 144
softwaremaniac je offline   Reply With Quote
Staro 06.10.2016., 19:21   #12
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Postovi: 218
Instalirani i nema problema za sada. Svakako ovdje javim ako bude nešto.
Staro 21.10.2016., 18:21   #13
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Postovi: 218
NVIDIA GeForce 375.57 WHQL Game Ready Drivers
Battlefield 1, Titanfall 2, Civilization 6 Game Ready Driver Released
Staro 22.10.2016., 19:17   #14
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Postovi: 218
Oprez kada instalirate nove 375.57 driver
Known issue Windows 10:
Windows Tile Crashing Issue + Windows Mail Crashing Issue Acknowledged -- Will be hotfixed
[Forza Horizon 3] Possible driver memory leak. [1826143]
[SLI] [GeForce GTX 970M] Level loading hangs in Gears of War 4. [1826307]
[GeForce GTX 1070][Alienware Graphics Amplifier] The graphics card is not detected upon installing the driver. [200236450]
[347.09, GM204] Blank screen observed on an ASUS Tiled display when system resumes from shutdown or hibernation with Fast boot option enabled from BIOS.[1591053]
Known issue Windows 7:
[SLI] Blank display is observed on disabling SLI with two displays connected. [200172046]
Staro 23.10.2016., 21:38   #15
Lynnfield
Zmaj od Bosne
Lynnfield's Avatar
Postovi: 218
nVidia izdala 375.63 driver za gore navedene probleme.
Staro 03.11.2016., 12:09   #16
Glavas_ZG
Postovi: 218
Novi 375.70 driver
http://www.guru3d.com/files-details/...-download.html
koji se i nije pokazao kao najidealniji te je izdan hotfix
375.76
Staro 03.11.2016., 12:21   #17
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,566
nesto se spominje bloatware i "spija" s*anja u novijim driverima.
jel to tako?
mene osobno samo interesira driver i physx. ostatak nikad ne stavljam...
edit:
http://forums.guru3d.com/showthread.php?t=410729&page=2
jel netko ovdje proba ovo iz posta 43? mislim da cu odsad tako instaliravat...
Zadnje izmijenjeno od: geronimo_2. 04.11.2016. u 10:36.
Staro 16.11.2016., 00:05   #18
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,020
Izašao je novi driver, 375.86.
Ima li koga hrabrog da isproba?
http://www.geforce.com/drivers/results/111026
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 17.11.2016., 08:21   #19
Glavas_ZG
Postovi: 218
Autor vedranzeman Pregled postova
Nvidia driveri postaju s vremenom sve traljaviji II , fixeva sve više i više:
GeForce 375.86 WHQL
Windows 10 Fixed Issues
[375.70] Smearing and ghosting reported with latest NVIDIA drivers. [1834593]
[375.63, GeForce GTX 980 Ti] Artifacts in GIFs after driver update. [1831043]
[SLI, GeForce GTX 1080] Unable to enable Surround with SLI HB bridge; singleribbon SLI bridge works fine. [1827915]
Battle Carnival is falsely detected as Bionic Commando. [1825885]
[G-SYNC, 372.70, GeForce GTX 1080] G-SYNC monitor flickers at 144 Hz, not reproduced with 368.81. [1822079]
[SLI, 372.54] Wrong memory usage values in games on Pascal GPUs in SLI mode. [1801306]
[G-SYNC, GP102] Periodic flickering on desktop at 165 Hz when dragging or resizing windows with G-SYNC enabled. [1799297]
Windows 8.1/Windows 8/Windows 7 Fixed Issues
GeForce Experience icon missing on system notification tray. [200248470]
[GeForce GTX 980 Ti] Unable to detect multiple TV models from Loewe Technologies GmbH. [1788948]
Zadnje izmijenjeno od: Glavas_ZG. 17.11.2016. u 08:47.
Staro 17.11.2016., 10:06   #20
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,257
Ja ih stavio neki dan. Ne primjetim ništa loše..
Odgovoran trgovac:1, 2, 3, 4, 5, 6, 7, 8, 9,10
Staro 17.11.2016., 10:18   #21
Staro 17.11.2016., 20:05   #22
Omerta
Omerta's Avatar
Postovi: 3,257
Vidim ja da meni Mafia 3 još lošije radi nego neki dan.
Evo možebitnog razloga
http://www.pcgamer.com/nvidias-lates...ffer_pcgamerfb
Staro 17.11.2016., 20:31   #23
vedranzeman
Postovi: 1,020
E hebi ga sad, ja instalirao ove zadnje jučer, jer sam morao maknuti one hotfix 375.76 jer su bili u banani, fajl "C:\Users\xyz\AppData\Local\NVIDIA\NvBackend\backend.log" mi je u kratkom roku bio narastao na 500+ GB!
Nvidia u zadnje vrijeme nikako da izbaci dobre drivere.
Staro 18.11.2016., 02:24   #24
alen.s
alen.s's Avatar
Postovi: 1,441
od svih onih điđa-miđa sta instalira na "expres" na kraju san sve dizejbla....11 procesa za grafu je fakin nepotrebno...sad mi katalist oliti crimson i ne izgleda toliko lose lol..
Name:	Desktop 11.16.2016 - 17.12.39.01.jpg‎
Staro 18.11.2016., 10:47   #25
Glavas_ZG
Postovi: 218
Autor Omerta Pregled postova
Izašao je Hotfix koji rješava taj problem sa niskim klokovima memorije:
https://www.techpowerup.com/227928/n...hotfix-drivers
Staro 19.11.2016., 22:38   #26
vedranzeman
Postovi: 1,020
Ovi hotfix/beta 375.95 postali WHQL, skidaju se...
Staro 19.11.2016., 23:38   #27
Omerta
Omerta's Avatar
Postovi: 3,257
Stavljeni jos sinoc. Sad je ok.
Staro 20.11.2016., 21:26   #28
thubanx6
thubanx6's Avatar
Datum registracije: Aug 2011
Postovi: 533
Da li itko ima problema sa crashanjem drivera ( nvlddmkm has stopped working ).
Manifestira se kao crni ekran od par sekundi.
Jedino što uspješno rješava problem je "prefer maximum performance" mode u nvidia control panelu ali mi se onda grafa nikad ne downclocka što je dosta iritantno. Probao sam 10 različitih drivera s prethodnim čišćenjem DDU-om, ne pomaze.
Konfa je gigabyte z87m-d3h, MSI gtx960 4GB, 4670k, 16gb kingston rama. Corsair ax850
Windows 10 64bit
thubanx6 je offline   Reply With Quote
Staro 20.11.2016., 22:14   #29
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,838
Imaš isključenu Intel grafičku?
Staro 20.11.2016., 22:21   #30
thubanx6
thubanx6's Avatar
Postovi: 533
Autor Sinac Pregled postova
Kako misliš, da je disableam u biosu?
