#9151 |
Datum registracije: Feb 2015
Postovi: 596
1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box 1 x ASRock H81M-HDS R2.0 (s1150,DDR3,USB 3.0,SATA III,DVI/VGA/HDMI) mATX,Usb 3.0 header 1 x Sapphire Radeon RX460 2GB, 128bit GDDR5 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x HDD Western Digital Caviar Blue 1TB, 7200rpm 1 x Fortron Hexa+ 400W, 80+ 1 x Kućište MS Mercury 2 Ukupno: 4031,54 kn (besplatno slaganje i dostava) 1 x Intel Core i3-6100 (3,7 GHz, Skylake, Socket 1151, 51W), Intel HD 530, box 1 x Asrock H110M-DGS (s1151,DDR4,USB 3.0,SATA III,LAN,DVI) mATX 1 x Sapphire Radeon RX460 2GB, 128bit GDDR5 1 x Crucial DRAM 8GB DDR4 2133 MT/s (PC4-17000) CL15 SR 1 x HDD Western Digital Caviar Blue 1TB, 7200rpm 1 x Fortron Hexa+ 400W, 80+ 1 x Kućište MS Mercury 2 Ukupno: 3693,77 kn (besplatno slaganje i dostava) 1 x Intel Core i3-6100 (3,7 GHz, Skylake, Socket 1151, 51W), Intel HD 530, box 1 x Asrock H110M-DGS (s1151,DDR4,USB 3.0,SATA III,LAN,DVI) mATX GIGABYTE GeForce GTX 950 GDDR5 2GB, HDMI/2xDVI/DP 1 x Crucial DRAM 8GB DDR4 2133 MT/s (PC4-17000) CL15 SR 1 x HDD Western Digital Caviar Blue 1TB, 7200rpm 1 x Fortron Hexa+ 400W, 80+ 1 x Kućište MS Mercury 2 Ukupno: 3843,77 kn (besplatno slaganje i dostava) Zadnje izmijenjeno od: ODO. 18.08.2016. u 17:56. |
#9152 |
Datum registracije: Mar 2011
Postovi: 2,707
Kingmax 1x8GB DDR4 2133 GLJG, KIN-8GB DDR4 2133 SEAGATE HDD Desktop Barracuda 7200 ST1000DM003 (3.5",1TB,64MB,SATA III-600) Procesor Intel Core i5 6402P Gigabyte RX 460WF2 OC, 2GB DDR5, HDMI, DVI Fortron napajanje Hexa Plus 400W, 80+ MSI H110M PRO-D, LGA 1151, DDR4-2133, Military Class 4 MS VOYAGER 2 kućište bez napajanja 3.994,11kn |
#9153 |
Datum registracije: Apr 2016
Lokacija: Solin
Postovi: 8
Konf
Ispričavam se ako sam bio nejasan ali potreban mi je i monitor. |
#9154 |
Asshole
Lokacija: RH
Postovi: 2,361
evo ljepotane, monitor https://www.uzishop.hr/monitori/4731...a-dvi-zvu.html konfa https://www.uzishop.hr/uzi-gamer-rac...750ti-mk1.html Zadnje izmijenjeno od: coconut. 19.08.2016. u 08:14. |
#9155 |
Postovi: 596
Intel Core i3-6100 Asrock H110M-DGS Crucial DDR4 8GB (1x8GB) 2133MHz CL15 SAPPHIRE NITRO Radeon ™ R7 360 2G D5 WESTERN DIGITAL Blue 1TB, WD10EZRZ be quiet! SYSTEM POWER 8 400W Kućište Mercury 2 Monitor Acer V6 V226HQL 21.5" Crno Full HD 4 054,60 kn (besplatno slaganje i dostava, te forumski popust uključeni) |
#9156 |
Asshole
Lokacija: RH
Postovi: 2,361
tesko da moze bolje od ovoga, eventualno bi ja mozda graficku i monitor isao na polovno mozda s njuskala, jer ovako su graficka i monitor teski minimum zbog ogracnicenog budgeta Zadnje izmijenjeno od: coconut. 19.08.2016. u 08:14. |
#9157 |
Lokacija: Beertopia
Postovi: 2,013
trebam složit konficu za pajdaša, ali sam ja po difoltu prelijen, pa proslijeđujem ovamo ![]() Znači za do 3k (bolna granica 3.5k) krznenih treba nekaj da za surf / film i malo gaymanja (GTA, AC i slično) ima grafku (nisam ziher kaj točno, ali ak treba pitam i nadopišem) / kučište / monitor Treba mu ostalo - proc, matična, napajanje itd. Ako je moguće možda i kakav SSD za ubacit u sve kombinaciju ![]() Preferira Links, makar ja bi radije u FUTURI ili UZIju (znam da imaju popust za forumaše, pa to ja morem k'o proviziju zakaparit ).Hvala kome god da se da složit ![]()
54' / 74' / 90' / 2014
I'm only here to see how the story unfolds. Any self-respecting leading man would do the same. |
#9158 |
Postovi: 2,707
AMD Radeon R3 SATA III 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 530 MB/s / 470 MB/s Zalman 500W GVM Series Retail, ZAL-ZM500-GVM MS MONSTER gaming kućište bez napajanja s plavim LED ventilatorom Procesor Intel Core i5 6402P MSI H110M PRO-D, LGA 1151, DDR4-2133, Military Class 4 Kingmax 1x8GB DDR4 2133 GLJG, KIN-8GB DDR4 2133 3.211,19kn Kakva grafa ![]() |
#9159 |
Postovi: 596
Bilo bi lijepo znati grafičku, jer on bi kao malo gejmao, ali AAA naslove. ![]() Intel Core i5-6500 ASRock H110M HDS Crucial DDR4 8GB (1x8GB) 2133MHz CL15 Sandisk 240GB 2,5" SATA3 SSD Plus be quiet! SYSTEM POWER 8 500W 3 286,36 kn (besplatna dostava i forumski popust uključeni) |
#9160 |
Lokacija: Beertopia
Postovi: 2,013
da ne bi bilo - provjerih ![]() trenutno je na 7770 ![]() i hvala! ![]()
#9161 |
Datum registracije: May 2011
Lokacija: Koprivnica
Postovi: 131
Ekipa trebam konfiguraciju(CPU, SSD, GPU, MBO, RAM, NAPAJANJE) nije bitno AMD ili INTEL, konfiguracija bi služila za igranje, internet, programiranje. Cijena 3500-4200kn |
#9162 |
Postovi: 14,589
CPU INT Core i3 6098P MSI H110M PRO-D, LGA 1151, DDR4-2133, Military Class 4 Kingmax 1x8GB DDR4 2133 GLJG, KIN-8GB DDR4 2133 Sapphire RX 460 OC, 2GB GDDR5,HDMI, DP, DVI AMD Radeon R3 SATA III 240GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 530 MB/s / 470 MB/s, Random R Zalman 500W GVM Series Retail, ZAL-ZM500-GVM 3640kn Pojačavanja - i5 6402P (430kn gore) ili jaču grafičku ako ti je gaming izraženiji (gtx 960, R9 380, RX 470) |
#9163 |
Lokacija: split
Postovi: 34
Pozdrav svima! Trebam konfu do 4000kn, da sadrzi: - procesor (po mogucnosti intel i5), - maticnu sa integriranom grafikom i hdmi izlazom (ali takvu da mogu poslije bez problema uzeti neku graficku ako mi dodje igrati igre) - hard disk (1000gb) - ssd disk (120gb) - ram 8gb - napajanje - kuciste E sad, ono sto je najveci problem, da to bude sve u jednom ducanu i u Rijeci, znaci ne kupovina preko interneta nego recimo Links, hgspot, instar... Ja sam složio ovako nesto, u Links-u, molio bi misljenje i savjete i prijedloge: - Matična ploča ASROCK B85M Pro3, Intel B85, DDR3, zvuk, G-LAN, S-ATA, PCI-E 3.0, USB 3.0, D-SUB, DVI, HDMI, mATX, s. 1150 - Procesor INTEL Core i5 4460 BOX, s. 1150, 3.2GHz, 6MB cache, GPU, Quad Core - Memorija PC-14900, 8 GB, KINGSTON HyperX Fury Black HX318C10FB/8 DDR3 1866MHz - Tvrdi disk 1000.0 GB SEAGATE ST1000DM003, SATA3, 64MB cache, 7200 okr/min, 3.5" - SSD 120.0 GB CORSAIR Force LS series CSSD-F120GBLSB, SATA3, 2.5", maks. do 540/450 MB/s - Napajanje 550W, LC POWER Silent Series, ATX V2.2, 120mm vent. - Kućište LC POWER PRO-923B Red Captor, MIDI, crno, bez napajanja-a Ukupno: 3.840,85 kn Zadnje izmijenjeno od: sime_b. 22.08.2016. u 22:42. |
#9164 |
Postovi: 2,707
Radije HGSpot onda, malo je jeftiniji. Procesor INTEL Core i5 6400, 2700/3300 MHz, Socket 1151 Memorija KINGSTON 8 GB DDR4, 2133 MHz, DIMM, CL15 Tvrdi disk 1 TB, TOSHIBA DT01ACA100, 3.5", SATA III Kućište ZALMAN Z1, bez napajanja Napajanje THERMALTAKE TR2 Gold, 500W SSD disk 240 GB, A-DATA SP550, 2.5", SATA III Matična ploča ASROCK H110M-HDS, socket 1151, DDR4 3.964,28kn 240GB SSD, puno bolje napajanje(ali možda ga nemaju), bolje kućište i Skylake/DDR4. |
#9165 |
Lokacija: split
Postovi: 34
ok, a jel moze drugo kuciste i da li je bolje uzeti 2 x 4gb ili jedan od 8gb: Procesor INTEL Core i5 6400, 2700/3300 MHz, Socket 1151 2 x Memorija KINGSTON 4 GB DDR4, 2133 MHz, DIMM, CL15 Tvrdi disk 1 TB, TOSHIBA DT01ACA100, 3.5", SATA III Kućište ZALMAN Z1 NEO, bez napajanja Napajanje THERMALTAKE TR2 Gold, 500W SSD disk 240 GB, A-DATA SP550, 2.5", SATA III Matična ploča ASROCK H110M-HDS, socket 1151, DDR4 4.010,78 kn Zadnje izmijenjeno od: sime_b. 23.08.2016. u 10:05. |
#9167 |
Postovi: 424
Treba bi konfa za bratica do max 4000kn jer mi je toliko dao ni lipe vise. Treba samo kuciste, namjena gaming, mislim da mu netreba ssd zbog buđeta, trgovine? E sad tu je najveci problem sto bi on komp sto prije znaci dolaze u obzir one za koje znate da imaju najveci dio komponenti dostupnih odmah jer bi trebao narucit danas popodne pa da mu stigne do recimo ponedjeljka ili tamo recimo srijede. Znaci da bude 7 dana rok dostave i njihove naruđbe tih stvari ako budu falile. Tnx
#9168 |
Postovi: 14,589
U većini shopova ti dođe za dan ili dva (i do osijeka). Provjereno 1 x Procesor Intel Core i3 6098P, 3.6GHz, 1151 1 x MSI H110M PRO-D (S1151, DDR4, USB3.1, SATA III, DVI, Audio, LAN) mATX Retail 1 x Kingston 8GB 2133MHz DDR4 Non-ECC CL15 DIMM 1Rx8 1 x Sapphire Radeon RX460 2GB, 128bit GDDR5 1 x HDD Western Digital Caviar Blue 1TB, 7200rpm 1 x Fortron Hyper 500W, 80+ - 60mj. 1 x Zalman Z3, USB3.0 black, 3x120mm 3950kn |
#9169 |
Postovi: 424
naručio: Zalman Z3 mid tower case MSI B150M Pro-VD, Intel Core i3-6100 ASUS DRW-24F1MT/BLK/B/AS SATA 1TB Seagate Barracuda, 3.5" Grafička kartica SAPPHIRE RX 460 2G D5, 2 GB DDR5 Napajanje 400W FSP Fortron/Source Hexa+ DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial Ukupno : 4,469.99 Kn Vrsta plaćanja : (-10 %) -447 Kn Ukupno : 4,022.99 Kn počastio sam ga s 23kn ![]()
#9170 |
Datum registracije: Sep 2010
Postovi: 90
Pozdrav ekipa! Ovako, zamolila bih vas za preporuku gejmerske konfe za malog brata, budget je 4000 kuna i monitor ne treba jer to već imamo! Po mogućnosti sve u istom shopu. Dakle, treba mu ful gejmerska konfa (najbolja moguća grafička, druge komponente su manje bitne) bez monitora koja bi mogla bez problema igrati najnovije AAA igre ako je to uopće moguće sa ovim budgetom. Nadam se da jest ![]() |
#9171 |
Postovi: 2,707
Procesor AMD X4 FX-4320 Patriot Sig.,D3, 1600Mhz, 8GB (1x 8GB) PSD38G16002 Toshiba P300 1TB, 64MB, 7200rpm HDWD110UZSVA CORSAIR Power Supply, Builder Series CX 80+ Bronze, 430 Watt, ATX, EPS12V, PS/2, EU Version MS VOYAGER 2 kućište bez napajanja 2x MS PC COOL 12cm hladnjak za kućište LC Power CPU Hladnjak LC-CC-95 - 90mm Intel/AMD ASRock 980DE3/U3S3, AM3 XFX RADEON RX 470 Single Fan 4GB GDDR5 True OC, XFX-RX-470P4SFD5 Sveukupno: 4.007,91kn Evo naglaska na grafičku ...samo je još nedostupna.Dosta bi pomoglo ako se možeš protegnuti za još 300kn. Ubacila bi se bolja matična i grafička s boljim hlađenjem |
#9172 |
Postovi: 90
Hvala Smartic, što više opcija to bolje ![]() Kako bi izgledala bolja matična i grafička? A Intel varijanta? |
#9174 |
Postovi: 371
može preporuka gaming konfe za kolegu, bez periferije monitora i ostaloga, iznos cca 4500, eventualno do 5000, plaćanje amex 12 rata. i bilo bi dobro da se može ubacit neka rx470/480 Zadnje izmijenjeno od: CheCola. 25.08.2016. u 14:04. |
#9175 |
Postovi: 90
Molim za mišljenje o ove dvije konfiguracije složene u Uzi shopu. http://i.imgur.com/EntDUNb.png http://i.imgur.com/ZwR4G9k.png |
#9176 |
Postovi: 2,707
@lucija85 http://imgur.com/a/2I8jp Dobiješ 3% popusta kao član ovog foruma kod UziShopa pa je to ispod 4100kn Grafička je i prejaka za ovaj procesor(dosta jača od R9 380), ali će moći to nadograditi.@ODO Ti sad ispadaš lud nakon mojeg edita ![]() Zadnje izmijenjeno od: Smartic. 25.08.2016. u 19:41. |
#9177 | |
Postovi: 596
Smartic, hebi se ![]() Citiraj:
Matična ploča GIGABYTE GA-970A-DS3P Cooler LC POWER LC-CC-95 Grafička kartica PCI-E GIGABYTE AMD RADEON RX 470 G1 Gaming, 4GB DDR5, HDMI, DP, DVI Memorija PC-14900, 8 GB, MUSHKIN Essentials, 992132, DDR3 1866Mhz Tvrdi disk 1000.0 GB SEAGATE ST1000DM003, SATA3, 64MB cache, 7200 okr/min, 3.5" Kućište RAIJINTEK Arcadia, MIDI, bijelo, bez PS Napajanje 560W, LC POWER Silent Giant GREEN POWER LC6560GP3 V2.3, 140mm vent. 5.131,90 kn (cijena je za web narudžbu) Ako baš mora biti 5, onda nek ide na FX 6300 Za i5 mu treba 300-tinjak kn više Zadnje izmijenjeno od: ODO. 25.08.2016. u 19:43. |
#9178 |
Postovi: 90
@Smartic Ako malo dignem budget i u kombinaciji sa RX 470 ubacim i i3-6100 procesor jel onda treba još i dodatni cooler? Sa drugom matičnom naravno. To mi izgleda super. |
#9180 |
Postovi: 90
Super, hvala! |
