#1171 |
Lokacija: Cro
Postovi: 1,044
#1172 |
Postovi: 67
#1174 | |
Lokacija: Cro
Postovi: 1,044
isti je hladnjak ko na g1 (maxwell) sad su rješili što se tiče gašenja venta u idle. Nisam baš bio nezadovoljan s bukom, al nije da sam bio pre zadovoljan. Alergičan sam na buku...fakat I sad sam dobio gtx 980ti strix, i to je brutalno dobra grafička (bolja i od g1 1070), al bučna jbga 250W https://www.youtube.com/watch?v=3-FRuIvGF7U Al ono što nalazim je da je g1 glasnija od ostatka http://www.guru3d.com/articles_pages...review,11.html g1 ima 42 db, a msi gaming x ima 38 E sad...ljudi misle da je razlika mala....al nije, to je logaritamska skala http://www.soundmaskingblog.com/2012...nge-isnt-good/ Jbga, ja sam freak za buku, i meni znači tišina, i za nju sam spreman i za lošiju karticu (sporiju), nadoplatit. |
#1175 |
Lokacija: Cro
Postovi: 1,044
Usporedba moje trenutne strix 980ti i msi gaming x 1070 strix 39 db https://www.techpowerup.com/reviews/...Gaming/29.html gaming x 30 db https://www.techpowerup.com/reviews/...ming_X/23.html metodologija testiranja: The tested graphics card is installed in a system that does not emit any noise on its own, using a passive PSU, passive CPU cooler, passive cooling on the motherboard, and a solid state drive. Noise results of other cards on this page are measurements of the respective reference design. This setup allows us to eliminate secondary noise sources and test only the video card. To be more compliant with standards like DIN 45635 (we are not claiming to be fully DIN 45635 certified), the measurement is conducted at a distance of 100 cm and 160 cm off the floor. Ambient background noise inside the room was well below 20 dBA for all measurements. Please note that the dBA scale is not linear but logarithmic. 40 dBA is not twice as loud as 20 dBA since a 6 dBA increase results in double the sound pressure. The human hearing perception is a bit different, and it is generally accepted that a 10 dBA increase doubles the perceived sound level. 3D load noise levels are tested with a stressful game, not with Furmark. |
#1177 |
Džabe si krečio!
Postovi: 5,191
Da, onda ocito na MSI posto je najtisa po reviewima... Makar taj idle zero fan mode je po meni BS. Radije da mi se ventovi na grafi vrte na 800rpm sto je "skoro" necujno pa je gpu idle na 30 *C, nego zero fan mode pa gpu chilla na 45-50 *C... |
#1178 |
Vršni visioc
Postovi: 2,209
Bez potpisa. |
#1179 | |
Lokacija: Cro
Postovi: 1,044
Troše se ležajevi na ventilatorima i vuče bezveze par wata...nije neka potrošnja al ono, čemu... Tišina mi je bitna i dao sam dosta love za sve...., imam silent kućište, silent ventilatore kućišta, noctua nhd14 (s silent adapterima) i još regulaciju svih ventilatora na ploči i naravno ssd. 99% vremena samo gledam filmove, i tad mi je jedino što sam čuo bio ventilator na staroj grafičkoj (wf3 maxwell)...nije bilo bučno, al sam ga čuo i nikako osim flashanjem biosa ga se nije dalo ugasit (a i to bi napravio da je bio jedan bios....a ono gledam i ono dva). Dok gledam filmove ne treba mi ni jedan ventilator radit, ni na kućištu, ni na napajanju ni na procesoru, ni na grafičkoj. |
#1181 |
Baš sam to mislio reći. Gaming stroj od 10000+ kn i da je nečujan. McLaren SLR bi gazio 280 km/h ali da se čuje ko Prius na elektrik modu. Nešto ćeš čuti, coil whine sigurno. A i opet s druge strane, 1070 koja će 99% vremena vrtit filmove? Al dobro, ti znaš najbolje. |
#1182 |
Lokacija: Cro
Postovi: 1,044
Jasno mi je da neće bit nečujna grafička, ni to ne tražim. Mislim da sam vrlo jasno napisao najtiša, i još nadodao zrakom hlađena. Našao sam trenutno dvije EVEGA i MSI koje su jednako tihe. Imam malu bebu doma, zato rijetko igram. Ljudi buraju komponente po berendovima, bojama i OC pičkama materinama, a ja gledam perf/w i perf/db...ne kužim kaj je to čudno I ne kužim kaj vam je nevjerovatno u tome da u isto vrijeme isti stroj može bit nečujan za gledanje filmova i vrlo malo čujan pri igrama Zadnje izmijenjeno od: markecSMB. 11.08.2016. u 14:11. Razlog: dodatak |
#1183 | |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,363
Kazes 99% vremena filmovi i onda grafa od 4000 kn unutra? bolje ond da si kupio neki Synology NAS i smart TV i vrtis sve direkt sa TVa sa njegovim daljincem i sve je necujno 100% umjesto zezancije sa PCom i slicno. Daleko bolji komfor, necujno, ucinkovito a moze sluziti i za druge stvari osim gledanja filmova. Sto se tice same grafe nezna konkrento za MSI ali sinoc sam testirao Gigbyte G1 Gaming (1080 ali vent je isti i na 1070) i stvarno je tiha, Tisa od mojih 780 STRIXova i od TitanXa ( on ima blower fan pa je to za ocekivati ali strixovi nisu inace bucni). I to u GPU renderu a kao i vecina njih danas ima i Fan Stop opciju da do odredjenih 55-65C ne pali ventove tako da je dobra opcija i za takve potrebe tihog kompa.
RS1 - MB: WS X299 Asus Sage, CPU: i7 9800X, RAM:128GB, GPUs: 3*RTX 3090 24GB RS2 - MB:Asus X99-E WS, CPU: i7 6850K, RAM:128GB, GPUs: 2*RTX 4090 24GB Zadnje izmijenjeno od: Lewis. 11.08.2016. u 14:42. |
#1185 | |
Lokacija: Cro
Postovi: 1,044
Na ovom forumu caruje fanboyizam, prekenjavanje tipa čiji je tata jači. I kad netko napiše razumno i jasno pitanje onda počne prekenjavanje (ne odnosi se na ovaj quote). Vjerujem da je 1070 g1 vrlo tiha grafička. Al nije najtiša od 1070 koja je brutalno tiha serija uz odlične performanse, da su mi samo performanse bitne, bez razmišljanja bi je uzeo. Sad na mobitelu imam smart remote, tak da mobitel koristim ko daljinski. NE postoji uređaj koji može zamjenit kompjuter, i kompjuter može bit nečujan bolji od bilo čega drugog za HTPC+je kompjuter pa možeš radit što hoćeš uz to. Današnji procesori bez ventilatora mogu vrtit filmove/muziku i da troše par W. Imam doma i RP 3, ali mi je zajebancija s tim, ne radi netflix i youtube trza (nisam se još pozajebavao s kodijem i adonom za youtube....nemam vremena). I jbga da, ja komp od 10000+ kn većinom koristim samo za surfanje i gledanje filmova...sam sam zaradio lovu za njega i želim u jednom imat sve (HTPC+gaming stroj+radnu stanicu). |
#1186 | ||
Freelancer
Postovi: 5,363
. Znaci imam na Samsung Smart TVu Synology app, upalim video station, photo station, audio station sto god zelim i playam sve direkt sa NASa na TV, navigacia normalno kroz TVov daljinac (i meni je bilo fora par puta korisitit mobitel kao daljinski ali sve vise puta je mobitel negdje dalje od TVa pa mi se neda ici po njega ). Taj setup je 1000% necujno i tishe od bilo kojeg PCa sa bar jednim fanom. Instalirao sami PLEX media/server app iz kojed vrtim filmove/serije sve sto zelim ako mi se nesvidja synologyev player/izgled.Prije toga sam vrtio sve preko XBMCa-KODIa koji mi stoji u polici ispod TVa instaliran na "mali" Gigabyte Brix sa intel i5, 16GB RAM NUC. Znaci 4 jezgreni 3+GHZ i5 CPU sa IntelHD grafom koji mi vrti 4K videe bez beda i trzanja (cak sam i rendoa na njemu jedna dan cist da vidim oce se pregrijati ) ali od kad sam uzeo novi TV sa synology/plex kombinacijom nisam ga upalio zadnjih 15+ mjeseci .Citiraj:
Da si reko da se igras 50% vremena onda nema nikakve dileme da ti treba takav GPU ali za 99% video/HTPC je kao sto rekoh po meni promasena investicija/setup a ima i jeftinijih a i tishih opcija. Ali svako svoje pare trosi kako hoce pa samo udri, sto se mene tice mozes i dvije 1070ke ubacit ako zelis pa ce browser jos brze scrollati .Htio sam ti dati info/prijedlog iz prve ruke jer sam i sam bio u tim kombinacijama "tihog HTPCa".
#1187 |
Uptime freak
Lokacija: Ri, Cro
Postovi: 2,968
Upgrade 980Ti na 1080?
Da li se isplati raditi taj upgrade? Igra se na 4K. Postojeca 980TI je Zotac GTX 980 Ti AMP! Extreme (ZT-90505-10P) sa tvornickim OC base clocka na 1253MHz + boost na 1355MHz. Usput, kartica je kupljena 15.09.2015. i koliko bi se moglo dobiti za nju sad? Da ne otvaram novi thread u procjenama. Jer vidim nove 1080 su po 6000kn, a 980Ti se moze nova nabaviti vec za 4000kn, sto znaci da je ovima jako pala cijena, posto je ova 980 placena 6400kn u Uziju... Hvala |
#1189 | |
Lokacija: Cro
Postovi: 1,044
I ja ne igram igre ne zato što ne želim, već što ne mogu...ne da ne igram, nego ne spavam... A sad već imam grafičku koja je jača od 1070...mislim jača je relativno da me se ne drži za riječ...negdje jača negdje slabija... tak da nije da ću ja keširat 4300kn za novu, već samo nadoplata |
#1190 | |
Džabe si krečio!
Postovi: 5,191
![]() Meni je jedina želja bila tjerati naslove u 1080p lockanih na 60fps sa max detaljima (+AA ako je moguće). Usudio bih se reći da mi je želja ispunjena tek sad sa ovom GTX1070. Prije godišnjeg sam malo zaigrao Crysis 3 i Metro Last Light Redux (baš ove stare zahtjevne naslove) + Witcher 3, i oni bez beda potjeraju karticu u boost preko 2100Mhz da bi održala tih 60fps (malo sam joj dao oduška da se boosta, jel )A tek ekipa sa 120-144Hz monitorima - mogu mislit. Ako išta, kolega Ranez me sigurno razumije ![]() A ekipa je prije pisala da mi je bivša 290X overkill za 1080p... @ Samoborski markec Napravili smo znanost oko pizdarija ![]() Brate, uzmi MSI Gaming, natijša je u loadu čini se - i gotovo. A što se tiče G1 Gaming,tj. bilo koje kartice - možeš ju podesit kako te volja sa ovim novim GPU boostom. Fixirat joj ventove na 1000rpm, postaviti termal limit na recimo 80 - i kolko ide ide u boostu. Što je najgore, ne bi puno žrtvovao performanse pretpostavljam, samo bi radila toplije (i tiše, jel). Mogu se i ja malo poigrati kada dođem u ZG, pa javim rezultate. |
#1191 |
Postovi: 1,370
Ja se igram na 980 ti, imao i 1080... Igram se na 4k, naravno... Pa ako lova nije problem, pocastis se ![]() Kartusa jest nesto brza i jaca, medjutim, ako patis na ultra detalje, za to ipak nije dovoljno jaka niti 980 ti niti 1080... Racunaj da ces za svoju dobiti cirka 3000 kn pa bi jos trebao doplatiti toliko za nekih 20% - 30% bolje performanse... Da je isplativo i nije, ali gust ionako nema cijenu ![]()
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2 |
#1192 |
Lokacija: Cro
Postovi: 1,044
I ja imam 980ti. Bratić je prodao meni. Prešao je s strix 980ti, na msi gaming x 1080. Kaže da je osjetio na 1440p. Ja osobno na njegovom kompu nisam baš osjetio razliku....cca 25% performansi osim buke, koja je znatno manja. Za mene je 1070, 980ti su iste i FHD kartice, 1080 1440p kartica. Njemu lova nije problem, ak nije tebi ztašto ne....ja osobno ispod 30-50% ne vidim razliku za mijenjanje |
#1193 |
Freelancer
Postovi: 5,363
Evo da bacim jedan test sto sma odradio u prijasnjih sat i pol a nisu igre .Uglavnom testirao sam svoj setup za GPU Render (Octane - https://home.otoy.com/render/octane-render/) Komp je pod "moj komp" uglavnom 3 grafe su bile unutra odjendom a 4 sveukupno ali se nisma sjetio 780 istestirati "solo" prije nego sam je izvadio iz kucista . Scena je jedan klasicni Arch-Viz interijer renderiran na 2500 samplova PT kernel i 960*540 reza (samo za test, final obicno ide 2.5k pa potraje 1,2,3,4h frame zavisno od hardwarea )Graficke su: 1. Evga TitanX SC (Maxwell, overclock 1448MHz) 2. Asus Strix 780 OC 6GB (overclock 1280 MHz) 3. GigaByte G1 1080 (auto boost 1940-1999 MHz vecinom 1979MHz) 4. GigaByte G1 1080 (auto boost 1940-1999 MHz vecinom 1979Mhz) Rezultati testa: Solo - TitanX(M) - 8m 10sec - GTX 1080 - 8m 53sec Multi - TitanX(M)+780 OC - 6m 2sec - TitanX(M)+GTX 1080 - 4m 42sec - TitanX(M)+2xGTX 1080 - 3m 6sec S time da za sada jos uvijek Octane Render koristi hibridni CUDA 7.5+Cuda 8.0 SDK da uopce moze suportati Nvidia seriju 10 jer Nvidia jos nije izdala final SDK CUDA 8.0 (ocekuje se ovaj mjesec). Znaci Serija 10 bi nakon toga trebala dobiti jos nekih optimizacija/ubrzanja kad bude sve specificirano. Sve u svemu sasvim zadovoljavajuci rezultati vec sad i kad bi ostavio mog TTX(M) na defualt clocku bez tih todatnih 220+ MHZ boosta onda bi u tom slucaju default 1080 bila i nesto sitno brza. Srecom ovaj Evgin Titan X SC se clocka ko lud i temp u overclocku i nakon vise sati rendanja nika ne prelaze 70C (u mom kucistu TTw200) Tokom ovog testa temperature grafickih su bile: 1. TitanX(M) - 66 C (slot 4) 2. Strix 780 OC - 68 C (slot 1) 3. GTX G1 1080 - 56C gornja (slot 1) i 48C donja (slot 7) Pozicije u kucistu su bile slotovi 1, 4 ,7 a slot 1 sam mjenjao 780 za drugu 1080. Sto se tice ukupne Buke, mogu samo reci - NIJE za Dnevnu sobu .
#1194 |
Uptime freak
Lokacija: Ri, Cro
Postovi: 2,968
Ajme sad vidim da sam falio topic... potpuno pomjesao AMD i nVidiu... moze move tamo... izmjesali mi se modeli... BTW ja se igram na R9 280X, cisto za usporedbu... frend me pitao dal se isplati raditi upgrejd pa ja pitao ovdje. Nemam ja novaca ni za upgrejd 280-tke... ![]() |
#1195 | |
Postovi: 14,589
Ovo mu reci i ti si svoje napravio: Citiraj:
IMO trebalo je frknuti 980Ti dok su nove bile po 6-6500kn, sad je pitanje koliko će dobiti. Zajebano se igrati sa tim high endom ![]() Ali takvima je novac često kao kiki-riki pa ono, ako mu je gušt... |
#1197 | |
Lokacija: Dubrovnik
Postovi: 1,288
Ali u gamingu bi trebale biti dobre sluške na glavi, preko solidne zvučne. U takvim okolnostima se grafa ne bi trebala praktički čuti nimalo kroz dobre sluške i utišano kućište ?
S3 Trio 64 , Voodoo 2 , Kyro 3d , GeForce MX 440 SE , Radeon 9000Pro , 6600 GT , 9600 GT , 260GTX , 560GTX , 760GTX, 1060 GTX, 1080 GTX, 3080 RTX |
#1200 |
Vocna iglica u mudante
Lokacija: Beograd
Postovi: 2,838
pa ako on ne zna dal će mu to valjat, a daje tolike pare za gpu, onda ne znam stvarno.. ja ne bi SLI.. kud se grije, kud ne znaš kako će se skalirat performanse.. |
