Staro 10.05.2016., 23:15   #451
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Op Op
Ajde napokon nešto za zaigrati malo
Staro 11.05.2016., 09:19   #452
ivan77
Odlična je igra, uzeo je za ps4. Trenutno samo lovim životinje i radim side queste, lvl 7 i kartam. Mislio sam da je bug u igri, a onda skužio da potione treba samo jednom kreirati i da se pune meditacijom dok god ima alkohola
Staro 25.05.2016., 22:54   #453
Bishop
Postovi: 470
http://www.pcgamer.com/the-witcher-3...d-wine-review/
prvi reviewi za zadnju ekspanziju su vrlo pozitivni, ovo je sa pcgamera
Of course he's dead, you can see his brain
Bishop je offline   Reply With Quote
Staro 31.05.2016., 12:18   #454
TheProfiler
Gamer 2 the Bone
TheProfiler's Avatar
Lokacija: Zagreb, oko centra...
Postovi: 1,640
Upravo izasao pozamašan patch, priprem avaljda za Blood and wine, masa promjena:
CD Projekt RED has just released patch 1.20 for The Witcher 3: Wild Hunt. Update version 1.20 brings a wealth of improvements to Geralt's adventure, including a completely revamped inventory menu.
If you want to take a look at everything that the patch alters, adds, and fixes, be sure to click through here. This massive 2.7GB patch is currently available on Steam, GOG and Origin.
Adds book titled ‘A Miraculous Guide to Gwent’ which displays number of gwent cards missing from player’s base-game collection and information on where to find them, thus facilitating completion of achievement titled Collect ‘Em All. Tome in question can be obtained either from gwent playing scholar in Prologue or from merchant near St. Gregory’s Bridge in Gildorf district of Novigrad.
Adds option to display herb names above available interactions.
Adds option in Options/Gameplay to enable enemy level upscaling. If foes are too easy to defeat due to level difference, upscaling will render them a challenge. Change will not affect experience point gain, loot, or quest rewards. Option can be enabled or disabled at any time, even during combat (however, Vitality/Essence of foes is then fully restored).
Adds option in Options/Gameplay to disable automatic drawing and sheathing of sword.
Increases incidence of, and thus chances of finding, several monster-based ingredients required for crafting high level alchemy formulae.
Improves Player Statistics panel, adding maneuverable Geralt model. Improves visuals in panel for better readability.
Adds new functionality to books and scrolls. When first collected, they can be read immediately using single button without need of navigating to Inventory panel. All found but not yet read books and scrolls are stored in Quest Items and Other categories. Once read, books and scrolls can be sold as their content is saved in Books section of Glossary.
Improves overall visuals in Character Development panel.
Improves Inventory whereby items are divided into additional subcategories within their grids: weapons and armor; oils, potions and bombs; quest items and others; food and equestrian gear; crafting and alchemy. Additionally, introduces redesign of
tooltips enabling their resizing with single button. Also, item comparison is easier than ever given addition of summary of changes in stats.
Improves Inventory navigation when using gamepad. Slots are divided into sections and right stick can be used to jump between them.
Improves Crafting panel in merchant shops. Adds option to purchase missing diagram components directly from Crafting panel when talking to merchant, as well as clearer descriptions and option to resize item descriptions.
Introduces redesign of Repair panel in merchant shops. Adds single button enabling players to repair all equipped items.
Improves Remove Upgrade panel in merchant shops.
Improves Quick Access Menu whereby it can be accessed in one of two modes, with action either paused or slowed depending on button used.
Adds functionality whereby crossbow bolts can be switched via Quick Access Menu rather than being equipped from Inventory.
Adds counter for bombs and crossbow bolts to Quick Access Menu.
Improves region maps by adding pin filtering, more intuitive quest tracking, and a region overview for faster navigation.
Adds three new custom pins allowing players to mark areas for future reference.
Improves Adrenaline Bar which better displays number of stored Adrenaline Points and their status.
Improves display and behavior of Buffs, displayed in more intuitive manner showing time left, strength percentage, stacks, charges, or permanence where applicable. Buff icons now blink for approx. 10 seconds before expiration. For improved visibility,
names and exact expiration times for all effects are only visible when Quick Access menu is active.
Changes icons for decoctions, rendering them recognizable at first glance.
Changes icons for oils, rendering them recognizable at first glance.
Changes gwent card icons in shops, rendering factions recognizable at first glance.
Changes icons for mutagens.
Adds feature whereby equipment exceeding player character level can be previewed on character.
Improves sorting in Journal whereby active quest tab is always open and tracked quest is at top of quest list.
Improves quest item visuals so that Hearts of Stone and Blood and Wine quest items are now tagged with blue and red exclamation points, respectively
- Nothing in this world is certain.
That's the only certain thing I know. -
TheProfiler je offline   Reply With Quote
Staro 04.06.2016., 17:43   #455
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Jel igra tko?
Napokon sam počeo malo guštat, nisam stvarno dugo ništa pošteno igrao
Igra, tj. ova nova pokrajina Toussaint izgleda fenomenalno
Staro 04.06.2016., 17:58   #456
TheProfiler
Gamer 2 the Bone
Postovi: 1,640
I je, level dizajn je na nivoum a i questovi. Meni zasad 10/10.
Staro 04.06.2016., 18:14   #457
blava
blava's Avatar
Lokacija: スラボニア
Postovi: 3,061
Igra se naravno,samo sam level 35 i od većine monstera bjezim jer je uključen enemy upscaling i dosta je izazovnija borba.
Uglavnom igra je optimiziranija,trava je još gušća i prirodnija,mediteranski stih odlično docaran,a naracija i questovi standard za CDR.
Suma sumarum,vecina developera naprave dlc i zovu igrom,a CDR napravi igru i nazove dlc-om.
Staro 04.06.2016., 19:05   #458
Lun
Lun's Avatar
Datum registracije: Jan 2010
Postovi: 418
Mislio sam da CDPR nemože bolje od TW3, dok nije došao HoS - po meni jedna od najboljih ekspanzija ikad. I onda ulete sa B&W - za sada uživam, tek sam započeo main quest line, uglavnom se bavim treasure huntom i side questovima.
NEvjerovatna igra skupa sa ekspanzijama, 11/10
Lun je offline   Reply With Quote
Staro 04.06.2016., 19:46   #459
Spikeman
Lokacija: bi volio znat?
Postovi: 1,221
Odigrao blood and wine, sta rec... meni osobno najbolja igra koju sam ikad igrao, cijeli taj "zivi" svijet koji je CDPR team stvorio je i vise nego impresivan, izvrsno okarakterizirani likovi, svi moguci main i sidequestovi su zanimljivi svaki na svoj nacin. Hrpa hrpa detalja od armora, oruzja, raznih witcher setova, apgrejdanje geralta sa raznim sposobnostima ovisno sto igracu pase, ma cudo sto su napravili od igre, zasluzuju svaku kunu/euro/dolar koju su dobili
U mom slucaju ovo je jedina igra koja je kupljena day one kao i ove dve popratne ekspanzije i koje apsolutno opravdavaju kupovinu
Sent from my LG G2
Staro 04.06.2016., 20:46   #460
Garro
Postovi: 2,394
Tko nije igrao, ne zna što propušta. CDPR FTW!
Garro je online   Reply With Quote
Staro 05.06.2016., 10:40   #461
TheProfiler
Gamer 2 the Bone
Postovi: 1,640
Autor Spikeman Pregled postova
Sent from my LG G2
Totalno potpisujem. Napravili su čudo.
Evo ja riješio sve side questove, lvl 45, sad samo još složim si grandmaster wolven armor (imam već mastercrafted) i završim main story. Do kraja dana brijem. A onda na New Game +. Bolje Witcher po drugi put nego neka ova nova sranja od igara
Btw probao iz fore krenut sad New Game + ali mi ne nudi, zašto? Postoje neki uslovi?
Staro 05.06.2016., 11:39   #462
ivan77
Što reći, slažem se sa svima, kupio season pass
za ps4, igra je stvarno zakon. Ono, nekad samo 2 sata idem konjem po mapi, a side questovi su bolji nego main questovi u 95% RPG-a
Staro 05.06.2016., 11:52   #463
Spikeman
Postovi: 1,221
onaj sidequest sa bankom mi je genijalan, krepo sam od smijeha xD meni je ostalo hrpa upitnika i vjerojatno gro markera koje jos nisam otkrio al to cu sad s gustom narednih tjedana rjesavat malo po malo, skupljat grandmaster setove i tak to
i Geraltu sam kucu renovirao do kraja, dobijemo i trofej za to nazvan "playing house" xD
Sent from my iPad
Staro 05.06.2016., 12:24   #464
TheProfiler
Gamer 2 the Bone
Postovi: 1,640
Sent from my iPad
misliš na vinograd? ja ga isto cijelog renovirao ali nisam ništa dobio
Staro 05.06.2016., 12:28   #465
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Pa dobijate one boostove, kad spava na svom krevetu, imas onaj grindstone u armorer table, u vrtu si herbove bereš, konj ima bolju stamimu jer ima stablese, etc.
Blah, mislim da nije vrijedno para
Staro 05.06.2016., 12:30   #466
Spikeman
Postovi: 1,221
Autor TheProfiler Pregled postova
da, kucu i vinograd, sve moras pokupovat pa ti iskoci trofej, ja igram na PS4 al vjerujem da i za steam ima slican ačivment
Sent from my iPad
Staro 05.06.2016., 13:20   #467
TheProfiler
Gamer 2 the Bone
Postovi: 1,640
a, to. M ja mislio na ingame trofeje, npr imaš 3 mjesta u kući za njih i tri komada u igri, dosad našao jedan.
Staro 12.06.2016., 11:07   #468
ivan77
Zbilja je zarazan Cijeli dan visim pred tv om sa kontrolerom, žena mi je navečer ugasila plejku i rekla da ako me pali sivi frajer na ekranu odem u ****, a čim sa se probudio mislim na još koji witcher contract ili gwent karte
Staro 12.06.2016., 14:17   #469
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Ja sam ga igrao u vlaku od Dortmunda od Frankfurta (cca 3h vožnja) na laptopu neki dan, sav stisnut
Onda znaš koliko je sati xD
Staro 01.07.2016., 17:36   #470
zuiko
Postovi: 456
Mogu li igrati trojku na svom računalu u full HD?
Koliko i kako se dvojka i trojka razlikuju od jedninice.
Nije mi legao način igranja kod jedninice Više mi se sviđa kako se igraju TES i WoW.
Probao bih Fallout 4 i ovo tijekom ljeta ak ne moram dirat komp
zuiko je offline   Reply With Quote
Staro 01.07.2016., 20:45   #471
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,487
Da, ali na medium postavkama. Grafička nije nešto.
Staro 02.07.2016., 00:33   #472
zuiko
Postovi: 456
Hvala!
A kakva je dvojka u usporedbi s jedninicom i trojkom po načinu igranja?
Staro 12.07.2016., 22:01   #473
max111
max111's Avatar
Postovi: 543
Igram ekspanziju Blood and Wine i zbilja je zanimljiva baš kao i prethodna Hearts of Stone, CDPR radi odličan posao ali ne znam da li budu uspijeli nadmašiti serijal Witchera sa svojim budućim projektima iako sama ideja nije njihova ali realizacija je remek dijelo gaminga.
Nigh is the Time of the Sword and Axe!
None will fight war on our stead!
Nigh is the Time of Madness and Disdain!
CPU Intel i7 6700K
MBO ASRock Z270 Extreme4
RAM Kingston HyperX (2x8GB)
VGA MSI GTX970 4G TF5
HDD (1TB Samsung F3, Samsung 960 EVO, WD Caviar Green 3TB)
PSU Corsair AX750W
Windows 10 x64
max111 je offline   Reply With Quote
Staro 13.07.2016., 11:45   #474
TheProfiler
Gamer 2 the Bone
Postovi: 1,640
Istina, ja završio blood & wine, sad idem ispočetka na new game +, ovaj put skupljam i gwent karte čak. Mrak igra.
Staro 13.07.2016., 22:48   #475
Garro
Postovi: 2,394
Gwent je bolest, navukao sam se na to skoro više nego na W3.
Staro 14.07.2016., 09:15   #476
Sam Fischer
Džabe si krečio!
Postovi: 5,190
Ja sam uporno od početka igranja W3 odbijao taj Gwent
Možda je stvarno i meni polako vrijeme za new game+ i laganini kad dođe nova grafa
Staro 14.07.2016., 10:47   #477
TheProfiler
Gamer 2 the Bone
Postovi: 1,640
Ma i ja prvi put, igra mi bila predobra da bi gubio vrijeme na kartanje, htio sam priču ganjat. Ali sad mi je skroz fora skupljat karte i pobjeđivat ekipu.
Btw skupio sam ih sve, ali ima novi set cijeli sa blood & wine, bacam se na to uskoro.
Staro 01.08.2016., 13:10   #478
Kristijan1
Kristijan1's Avatar
Lokacija: Čepin
Postovi: 1,512
Napokon uhvatio sam vremena i počeo igrati Witcher 3 .
Trebam par savjeta kako bi mi igra radila što bolje "fluidnije" .
Postavke sam stavio na HIGH "1920*1080" i dobivao sam nekih 30-35 fps .
Nisam baš bio oduševljen sa fluidnosti igre pa sam malo proučavao po netu mogu li nekako to poboljšati .
Isključio sam u postavkama Hairworks i VSync i dobio 55-58 fps tokom igre .
Dali se može još nešto napraviti kako bi igra bila što fluidnija , a da ne gubim na detaljima ?!
Staro 01.08.2016., 13:17   #479
Postovi: 17,032
S tom grafom tih 50-tak fps-a je čisto solidno. Nećeš nešto puno dobiti.
Probaj sve na low i vidjeti ćeš da nema baš nekih velikih razlika u FPS-u. Ja s svojim kompom nisam dobio više od 70 FPS-a.
Staro 01.08.2016., 14:16   #480
Kristijan1
Kristijan1's Avatar
Lokacija: Čepin
Postovi: 1,512
Na kojim postavkama ?
