#241 |
#242 | |
Datum registracije: Mar 2008
Lokacija: Varazdin
Postovi: 21
#243 |
#244 |
#245 |
Zmaj od Bosne
Datum registracije: Dec 2011
Postovi: 218
Izašla nova verzija omiljenog nam 3DMark-a, evo i novosti : 3DMark 2.0.1979 New 3DMark UI has been redesigned and rebuilt to be faster and more flexible. Home screen recommends the best test for your PC based on your system details. Run other benchmarks and feature tests from the Benchmarks screen. Russian localization. Improved Each benchmark test can now be updated independently. Ice Storm Extreme and Ice Storm Unlimited are unlocked in 3DMark Basic Edition. SystemInfo module updated to 4.43 for improved hardware detection. VRMark preview Explore two test scenes in a preview of VRMark, our new benchmark for VR systems. The preview does not produce a score. The VRMark preview is not available in 3DMark Basic Edition or the Steam demo. Fixed Workaround for the AMD driver issue where the preview videos in the UI caused some AMD graphics cards to use low power mode and run at lower clock speeds.
RIP Šaban (21.6.2016)
#246 |
Datum registracije: Feb 2015
Postovi: 218
#247 |
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
Sjela nova grafa, MSI GTX 970 Gaming 4G... Imam ju neko vrijeme,ali danas sam odlucio vidjeti sto moze Proc na 4.5 GHz ofc,grafa na 1524/2052 Taktovi grafe su postignuti samo dizanjem power limita,bez diranja napona,nakon 5-6 postepenih dizanja taktova,mi je dosadilo joj trazit granice,pa cu se zadovoljit ovim testom.... Isto tako,vent joj je ostao na Auto10714
http://forum.pcekspert.com/faq.php |
#248 |
Datum registracije: Mar 2016
Lokacija: x
Postovi: 134
#249 | |
Procesor je na 3,8GHz, na stocku sa uključenim turbom:GTX 970 @ stock + CPU @ 3,8GHz GTX 970 @ OC + CPU @ 3,8GHz Iako sam reze okačio 8 postova iznad pred 3 mjeseca, sada je ovo sa zadnjim verzijama drivera i 3DM-a. Tko želi, neka si izvuče zaključke iz ovog usporednog testa. |
#250 | |
Lokacija: x
Postovi: 134
pa nisam ja ništa rekao,znam ja da je pukljava gtx 970 tu negdje sa eriskicama 480 tj. i bolja![]() ali ipak je rx 480 future-proof za dx12 itd. meni kao useru koji imam 144hz freesync kad izađu custom modelli eriksica onda se javi ![]() |
#251 |
Ma nije ovo merenje kurca s moje strane nego samo info da RX 480 nije namjenjena onima koji imaju GTX 970 ili R9 390, nego onima sa slabijim karticama od njih. RX 480 je odlična mainstream kartica. |
#252 | |
Lokacija: x
Postovi: 134
#253 |
Postovi: 870
Evo s jednom grafom i CPUom na 4GHz.. krajem tjedna stize i druga pa puknem rezultat.. http://www.3dmark.com/3dm/13117853? Kontam da bi rezultat isao jos gore kad bi naklokao proc.. |
#254 |
Postovi: 753
Mnogo lep graphic score Sent from my Redmi Note 3 using Tapatalk |
#255 |
Postovi: 870
#256 |
Datum registracije: Oct 2014
Lokacija: Bojnik
Postovi: 235
#257 |
Lokacija: Cro
Postovi: 1,045
#258 |
Postovi: 870
#262 | |
Džabe si krečio!
Postovi: 5,191
![]() Bit će da to ne leži AMD-u. Btw, ja nisam ništa OC-ao, samo sam stisnuo "OC Mode" u ovoj Gigabyte-ovoj aplikaciji... Ovo kratko što sam vidio, boosta se oko 1970 Mhz... ![]() |
#263 |
Evo da i ja okačim svoj score, malo sam nagazio grafu po ovoj osječkoj sparini ....CPU je 3570k na konzervativnih 4.4GHz pa je overall score nešto niži, no graphic score je o.k.Iako je "vulgaris" Phoenix-ica, taktove od GLH drži bez problema...dapače. Kada se malo iskristalizira situacija sa BIOS-ima, stavim gore GLH čisto da isprobam šta mala zapravo može (enable-an viši power limit sa GLH BIOS-om). "Otključani" BIOS-i će tek biti prava poslastica ![]() E, da, hladnjak je monstrum...ne vidi se sa SS-a, no max.temp za GPU je iznosila 52C. Brutalno... ![]() Zadnje izmijenjeno od: windfucker. 23.07.2016. u 00:32. |
#265 |
Džabe si krečio!
Postovi: 5,191
Fino, fino ![]() Poteguo sam i ja svoju samo radi radoznalosti na offset +130Mhz, i taktovi su varirali oko 2140Mhz. Tu je graphics score oko 19.500 (nisam spremio nikakav SS, jebiga). Grafe su stvarno zvjeri. A upravo to, ja sam uspio pogonit temp do 63 *C na auto fan profilu. Vrtim malo igre koje imam instalirane, čisto iz radoznalosti (na 1080p, jel)Ove stare ubojice, Cryis 3, Metro 2033, Witcher 3, sve leti. BTW, Call of Duty Advance Warfare sa sve maxed out i supersamplingom na 4X pojede 7,5Gb video rama To još nisam vidio ![]() I izgleda brutalno dobro sa finim lockom na 60 fps ![]() |
#266 |
Strpi se još koju reviziju drivera, pa onda odvrtimo usporedni test...o.k.? ![]() ... @Sam Fischer: Mene slider sluša do +233 za core, za memu mogu staviti +beskonačno, tu reagira sa taktom do 2166 i preko neće ni da mrdne neovisno o postavkama. Napon mi se čini ili zaključan, ili ima vrlo maleni utjecaj, overall...zbilja, neobično je clockati ove nove grafe, nikada ne znaš na čemu si kada pomakneš neki od parametara ("više" često ispadne manje u praksi). I, da ja sam preventivno stavio 100% fan profile, ne znam koliko je na automatici...zato imam "samo" 52C ![]() Custom BIOS-i sa otključanim naponima, dignutim power targetom i prilagođenim profilima se čekaju, 1070 može daleko više od ovoga. Pogotovo vodenjače, dočim se malo poslože stvari oko toga i prvi ozbiljniji setup-ovi krenu, biti će tu sjajnih rezultata ![]() Zadnje izmijenjeno od: windfucker. 23.07.2016. u 09:53. |
#267 | |
Imao sam 4gb xD |
#268 |
Postovi: 941
malo da osvjezimo i7 920 4200mhz, Ati Radeon 5850 1000/1225mhz https://s10.postimg.org/96eipe8gp/Fire_Stikr_3100.png |
#270 | |
RESPECT MY AUTHORITAH
Postovi: 7,508
http://www.3dmark.com/3dm/15282874 ![]()
