Staro 29.06.2016., 18:47   #751
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Evo dobar summary svega sto je danas pokazano:
Performance summary:
1- Tom's put this card as below the GTX 970 and R9 390, but not by much.
2- TechPowerUp, Anandtech, PC Perspective, Hexus, HardwareCanucks, and KitGuru put the card at slightly above the GTX 970 and R9 390.
3- LegitReviews, GamerNexus and HardOCP puts the card on par with the GTX 970 and R9 390.
Details:
1- All reviews mention that the cards does considerably better on DX12, where it can beat the GTX 980
2- The reviews praise the card's overall power consumption, but note that it exceeds the standard limits (86W from PCIe, instead of 75W)
3- Most lament the temps of the reference cooler.
4- Most of the reviews note that the reference cooler does well on the noise. As good as nVidia? No, but this is something to note, considering the horrible reference jet engines of AMD's 290/290X cards.
5- Overclocking results are mixed, some reviewers getting up to 10% OC, and some barely 2%.
Overall:
A good launch for AMD. The card is slightly above the GTX 970/R9 390, and cheaper. Once non-reference versions are out, with better temps, this should be a great purchase.
Staro 29.06.2016., 19:04   #752
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,185
Autor RiSbO Pregled postova
Nisam bas po forumu stalno pa ne znam gdje ko radi u kojoj firmi..
Sent from my SM-G920F using Tapatalk
Ne radi u firmi nego je firma njegova tj. vlasnik je
Staro 29.06.2016., 19:11   #753
MikaHR
Postovi: 1,264
MikaHR je offline   Reply With Quote
Staro 29.06.2016., 19:16   #754
MikaHR
Postovi: 1,264
kad CF radi 2x480=1080 i puno bolje od 2x970
http://www.hardwareunboxed.com/rx-48...x-1070-killer/
Zadnje izmijenjeno od: MikaHR. 29.06.2016. u 19:32.
Staro 29.06.2016., 19:34   #755
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
wow to je dobro skaliranje za prosjek, ali still jebeš 2 grafe
Staro 29.06.2016., 19:42   #756
Brlja
Postovi: 874
2 grafe fail. Čuj Witcher i Fallout 4 neigrivi.
Brlja je offline   Reply With Quote
Staro 29.06.2016., 19:44   #757
MikaHR
Postovi: 1,264
Nisu samo moraš malo isključiti neke stvarčice kao temporal AA koji ubija frametime.
1425 MHz OC
http://oc.jagatreview.com/2016/06/te...r-3rd-party/2/
Zadnje izmijenjeno od: MikaHR. 29.06.2016. u 20:22.
Staro 29.06.2016., 20:28   #758
JC Denton
JC Denton's Avatar
Postovi: 3,185
Citat sa pcper.com:
"Another oddity – and one that may make enthusiast a bit more cheery – is that AMD only built a single reference design card for this release to cover both the 4GB and 8GB varieties. That means that the cards that go on sale today listed at 4GB models will actually have 8GB of memory on them! With half of the DRAM partially disabled, it seems likely that someone soon will find a way to share a VBIOS to enable the additional VRAM. In fact, AMD provided me with a 4GB and an 8GB VBIOS for testing purpose. It’s a cost saving measure on AMD’s part – this way they only have to validate and build a single PCB."
Kupujte 4gb modele, mozda se moze otkljucat jos 4gb memorije ��
Takodjer, u istom reviewu se objasnjava sto je u slucaju rx480 base clock i jako njusim bolje performanse sa custom coolerima.
Staro 29.06.2016., 21:04   #759
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,735
Autor JC Denton Pregled postova
Citat sa pcper.com:
https://www.reddit.com/r/pcmasterrac..._about/d4smvmo
In the market you will see a version with 8GB of physical memory, and a version of 4GB of physical memory. We sent reviewers an 8GB model with a BIOS that allows them to flash between 4GB and 8GB available memory so they could perform testing on both hardware configurations.
Staro 29.06.2016., 21:50   #760
Michel
Michel's Avatar
Lokacija: Dubrovnik
Postovi: 1,288
Citat sa pcper.com:
Ma lol.....
Ram je skup pogotovo za masovno tržište.... to što je isti pcb ne znaći da 4 gb model ima ugrađenih 8gb rama. Ovi su očito novinarima omogučili bios da ovu 8 ograniče na 4 da bi mogli testirati kao da su dobili obje a da im pošalju jednu.
Michel je offline   Reply With Quote
Staro 29.06.2016., 21:56   #761
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,507
Točno, to sam i pročitao na nekom komentaru "update" da je taj bios 8/4gb samo za recenzente modele koji su poslani s namjerom takvi.
Inače ja mislim da bi možda na mom 1080p ekranu u nekim igrama ipak vidio napredak s R9 380 2Gb na RX 480 s 4Gb.
Doduše, dolazi i RX 470 4Gb od 150$-1000kn. Ne znam kakva bi ta kartica bila u usporedbi s mojom sadašnjom ili RX 480 4gb.
Ag008 je online   Reply With Quote
Staro 29.06.2016., 21:59   #762
MikaHR
Postovi: 1,264
a šta ako su ih fizički odpilili? ;P
ali, ovo je ono što očekujem od nove generacije i skoka od 2 procesa. Mogu me pljuvati kolko hoće, ali NVidijin Pascal ne da nije donio poboljšanje nego pogoršanje u odnosu na prošlu generaciju (970/1070 i 980/1080). A 480 4GB je sama na vrhu jadna ;P
480 - 32% poboljšanje performanse/kuni
1070 - 7,5% pogoršanje performanse/kuni
1080 - 20% pogoršanje performanse/kuni
i to na stocku, bez da istražujemo kolko se Maxwell bolje kloka od Pascala pa bi izgledalo još gore....
Zadnje izmijenjeno od: MikaHR. 29.06.2016. u 22:07.
Staro 29.06.2016., 22:05   #763
markecSMB
Lokacija: Cro
Postovi: 1,044
Autor MikaHR Pregled postova
Onda intel HD ima najbolji performance per dolar, jer je džabe.
Staro 29.06.2016., 22:05   #764
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,735
AMEN!
Staro 29.06.2016., 22:14   #765
MikaHR
Postovi: 1,264
A što se tiče ovog linka
3234 FS Ultra @1425 MHz
ovo dole bi bio rezultat na 1500 MHz, ne na 1266 MHz (kao šti sam i ranije rekao u analizi), ali...1500 MHz FTW
Zadnje izmijenjeno od: MikaHR. 29.06.2016. u 22:26.
Staro 29.06.2016., 22:15   #766
ivosimec
Datum registracije: Jul 2014
Lokacija: Pojatno
Postovi: 613
Autor nino Pregled postova
Mislim da ce sutra ili jos veceras biti 8gb za 2.400 i 4gb za 1.990
Sent from my D5803 using Tapatalk
Nino već si sve rasprodao?
ivosimec je offline   Reply With Quote
Staro 29.06.2016., 22:20   #767
MikaHR
Postovi: 1,264
Koji je to Intel džabe? Uzimam 10 komada odma
Staro 29.06.2016., 22:21   #768
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
po ovome vidjenome, znaci da bi ta grafa trebala vrtiti sve igre u aposlutno high detaljima sasvim fluidno u 50-60fps na 1080p monitoru?
Staro 29.06.2016., 22:21   #769
Ag008
Ag008's Avatar
Postovi: 7,507
Nije mu ni došlo niti je rasprodao već je u najavi. Ja bum ih naručio kada padne na 1800kn za koji tjedan jer su već sada ispod 1700kn u Njemačkoj PowerColor 480 4Gb.
Tako da mjesta za smanjenje ima.
Još da se pojave malo bolji, modani modeli sa boljim hladnjacima po cijeni ovih...
Za mjesec-dva predviđam cijenu 4gb modela 1700kn i to u verziji "gaming" s dva venta.
Autor darkydark Pregled postova
Došle Safirke i XFX kod dobavljača, za sad nismo stavili količine, cijene su ok
Sapphire XFX 1990 za 4GB
Sapphire XFX 2400 za 8GB
sutra iza 14.00 kad saznamo da smo ih ufatili budu aktivirane za nardužbe,
Očekujemo ih krajem idućeg tjedna u poslovnici.
EDIT: Evo dodani linkovi za obe četiri.
Staro 29.06.2016., 22:26   #770
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,735
http://videocardz.com/61667/what-rev...specifications
EPIC fail ako je istina.
BTW, nemojte ako boga znate kliknut na onaj link iz Cartmanovog siga!
GOD does not approve!
Staro 29.06.2016., 22:30   #771
Autor Asus30 Pregled postova
Direktor is spoken ceka se uvazeni syss
Kaže se "Direktor HAS spoken". Nebi bilo loše uložit i u tečaj engleskog
Sta se tice memorije tu je kiler u odnosu na gtx 970, 3.5 vs 8gb
Ko o čemu, AMD fanboj od 3,5GB
Budući je frend u Americi i stiže u 9. mjesecu, stignem mu javiti da mi donese sa Newegga jednu sa aftermarket coolerom, recimo Sapphire Nitro verziju kad izađe.
Nema teorije da okinem 2700 za referentnu karticu.
Mozda mi vec sutra dode jer je vec predana na postu,bas sam uzbuden
Veliš, ni ovu navijačicu nebi stisno koliko si napaljen na unboxing ? Pošteno.
@MikaHR / Manuel
Vi ste ovdje jedni od razboritijih i informiranijih po pitanju AMD kartica. Sapphire Nitro su OK kartice koliko čitam, pogotovo što se hlađenja tiče. Nije da me briga koliko troše više u nodnosu na referentne, ali me zanima jesu li one već malo OC-ane out-of-box ili radi na default taktovima?
Autor kopija Pregled postova
Ujebote... kad krenu ploče krepavat, pogotovo ove 1156/1155. Nadam se da nije istina.
KREEEEEEEEEEE !!!
Staro 29.06.2016., 22:35   #772
MikaHR
Postovi: 1,264
Pa biti će ocane, već XFX ima referentnu "black edition" koja radi na 1328 MHz out of the box.
A ono, MSI (ali oni nešto glume Asusa s cijanama u zadnje vrijeme ;P ) Sapphire su bile top na 300 seriji. Powercolor i XFX su uvijek nekako neš jeftinije i malo lošije, Gigabyte je zaključao voltažu na 300 seriji ali nije bio loš inače. Asus nije bio dobar s AMD karticama već duže vrijeme.
Treba vidjeti šta će izbaciti tko, Gigabyte recimo ima predobre nevidije, možda se iskupe za 300 seriju ;P
Staro 29.06.2016., 22:36   #773
Ag008
Ag008's Avatar
Postovi: 7,507
@ag008
Kao veliki stručnjak za grafičke kartice od danas, primjetio sam da "gaming" "nitro" itd verzije i kod msi-ja dođu clockanije na početnoj postavci ali se lako i clockaju uz bolje hlađenje.
Staro 29.06.2016., 22:48   #774
Znam da sam jednom davno drulao na Safirku Nitro 5870 ali tada se nije imalo para sjećam se da je bila predobra kartica.
Ako bude i ova dobra, i ako na Neweggu bude OK cijena (max 2000kn), why not. 970-tka ionako se da prodat za 1800-2000kn ko od šale. Jedino ne znam kak je sa garancijom ako kartica dođe iz US. Valjda ima kakvo EU jamstvo.
Nego, čisto ako netko želi, nudim se za benčanje. Ne u svrhu merenja kurca nego čisto da usporedimo mi forumaši kakva je situacija. Svi ti reviewovi su biased više ili manje. Vi recite koje benčeve, dogovorimo iste postavke i opletemo, vi sa 480, ja sa 970.
Staro 29.06.2016., 22:49   #775
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,735
A to mislite stavit u Kurajber konfu?
Ili bi ćeli imat 8GB memorije grafičke pa prodajete 970?
Staro 29.06.2016., 22:51   #776
Ne prodajem još ništa, samo razmišljam na glas. Kao što rekoh, mene ne jebe 3,5GB RAM-a jer sve što igram leti debelo preko 60FPS-a na max postavkama @ 1080P, pogotovo DooM što mi je sada najjača igra na koju upražnjavam vrijeme
Staro 29.06.2016., 22:55   #777
Ag008
Ag008's Avatar
Postovi: 7,507
Da se vratimo na temu:
Btw ima li kakva fora naručivanja iz DE za dostavu u HR i koliko košta. Znam da je netko govorio o tome u "najbolja ponuda". Bilo bi fora da netko ima rođaka u njemačkoj pa da nam šalje te po 1655kn.
Staro 29.06.2016., 22:59   #778
Manuel Calavera
Postovi: 14,589
Druže Brko, ako je iz amerike samo gledaj s kojom bi mogao ostvarit garanciju u nekakvom europskom zastupništvu, nebitno čija (nereferentan model naravno). Ako budeš mogao birati između više njih otom potom. Sad ne znam, možda ima netko na ovom forumu sa iskustvima reklamacije. Mislim da je netko pisao da je xfx psu slao uspješno na reklamaciju u nizozemsku? Sad dali vrijedi i za grafe pitanje je.
Inače neće za ovu grafu trebat izvodit neke kerefeke s coolerima, vidim najavljen ovaj novi strix sa 3 fana, čemu to, nepotrebno poskupljuje grafu. Treba samo najobičniji dual fan katolički cooler, 8-pin ili 2x6 pin i to je beba.
Staro 29.06.2016., 23:02   #779
Imam jako dobra iskustva sa EU reklamacijama i povratima robe (OK, uglavnom su to bili diskovi, RAM-ovi i matične ploče) tako da nebi trebalo biti problema ni sa karticama.
Budemo vidili kad se za koji tjedan pojave normalni modeli, a ne ovi sa ovim drek-ventom.
Staro 29.06.2016., 23:06   #780
Manuel Calavera
Postovi: 14,589
Ne znam jesi vidio sapphire model (vjerojatno će ih imati više)? Nekim je jako ružan pa zato pitam
RGB logo, boja ovisno o brzini rpm ili nešto tako
