#3421 |
RESPECT MY AUTHORITAH
Postovi: 7,507
Kako Iskonovci ne žele poslati tehničara nevjerojatno... Prošla je godinu dana od moje prošle prijave kvara, naime samo moja zgrada/izvod ima atenuaciju 21db, sve okolne su oko 16-18db i max nešto manji. Prošle godine iskonov teničar s mjernim uređajem ustanovio oštećenje/kratki spoj na 150m od izvoda (cca spojnica) i ht nije sanirao problem. Tako ja za točno godinu dana od prijave opet prijavim kvar, navedem da imam manju marginu nego prije (prije cca 15db margina u dl, sada 12-13db) i svakih pola sata mi se javlja error sekunda zadnjih par mjeseci, htio bi imati više a ne mogu. Te da prijave tehničaru da opet izađe kako bi se moglo opet proslijediti ht-u. Code:
VDSL Training Status: Showtime
Mode: VDSL2 Annex B
VDSL Profile: Profile 8b
Traffic Type: PTM Mode
Link Uptime: 0 day: 0 hour: 16 minutes
VDSL Port Details Upstream Downstream
Line Rate: 4.315 Mbps 22.527 Mbps
Actual Net Data Rate: 4.316 Mbps 22.528 Mbps
Trellis Coding: ON ON
SNR Margin: 6.1 dB 11.2 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 7.9 dBm 18.5 dBm
Receive Power: 0.3 dBm 1.2 dBm
Actual INP: 12.0 symbols 27.0 symbols
Total Attenuation: 8.1 dB 17.3 dB
Attainable Net Data Rate: 4.500 Mbps 30.192 Mbps
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 14.2 52.9 N/A N/A 26.0 65.5 N/A
Signal Attenuation(dB): 14.2 52.5 N/A N/A 23.1 65.3 N/A
SNR Margin(dB): 6.1 6.2 N/A N/A 11.2 11.3 N/A
Transmit Power(dBm): 3.5 5.9 N/A N/A 18.4 2.5 N/A
VDSL Counters
Downstream Upstream
Since Link time = 25 min 59 sec
FEC: 1250 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 8 min 44 sec
FEC: 767 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 430 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 18 hours 8 min 44 sec
FEC: 73834 148
CRC: 585 0
ES: 27 0
SES: 10 0
UAS: 58 48
LOS: 1 0
LOF: 8 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 33513 161
CRC: 43 0
ES: 26 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Total time = 1 days 18 hours 8 min 44 sec
FEC: 446005 2012
CRC: 887 0
ES: 254 0
SES: 10 0
UAS: 81 71
LOS: 1 0
LOF: 8 0
LOM: 0 0
![]() I danas me nazovu i kaže da error sekunda u pola sata nema veze jer nemam tv, da mi veza ne puca, da imam ugovorenu brzinu i da neće poslati tehničara. Ja se svađam i cura mi kaže da kada bi imao paket od 50Mbps a dobivam 26mbps onda bi mogli poslati ali ovako ne mogu. No u prodaji ne dozvoljavaju da ugovorim 50mbps jer to ne mogu imati a i u paketu 30mbps bi imao min 70% i tako ništa od tehničara i sanacije problema. Problem ostaje ![]()
#3422 |
Datum registracije: Feb 2015
Lokacija: Sisak
Postovi: 827
Ti barem imaš upload 4120kbps. Ja sam zapeo na 1200kbps u paketu od 20/5mbps i ne ide više. |
#3423 |
Postovi: 708
Sig-5 redova normalne veličine max
#3424 |
do you speak it?
Lokacija: ::1
Postovi: 1,631
pisi PREPORUCENO !!!! hakomu, iako su oni mrtva puhala... u 2016 godini, oni ne odgovaraju na e-mail, ali na preporucene posiljke moraju odgovoriti... drzavni pos'o |
#3425 |
Postovi: 116
pozdrav svima ako može savjet nude mi u Splitu u našoj zgradi uvođenje fttb plaćali bi nam 200kn + 50kn za struju ja sam predstavnik stanara , pošto nisam u toku dali da im to odobrim ili ne inače u zgradi imamo bnet i parice Hvala svima na odgovorima |
#3426 |
Lokacija: Sisak
Postovi: 827
Po mom mišljenju bilo bi pametno iskoristiti priliku, razgovaraj malo sa stanarima kakva su njihova mišljenja. FTTB ti je inace optika do same zgrade. U prostoriji zgrade bilo hodnik, podrum ti smjeste ormarić sa opremom. Nema bušenja i kanalica po stubištu pošto koristi parice unutar zgrade, za neke stanare koji su možda odustali od b-neta jer im moraju bušiti po stanu da uvedu kabal bi dobro došlo ako žele veću brzinu preko VDSL-a koja je max 80/40Mbps. |
#3427 | |
super user
Lokacija: Houston, TX
Postovi: 1,805
Svakako prihvati, to je prilika koja se ne propusta a jos cete dobit 250kn u pricuvu sto nije za bacit. Zadnje izmijenjeno od: viper. 02.05.2016. u 00:38. |
#3428 | |
Postovi: 55
#3429 | |
Datum registracije: Apr 2015
Postovi: 1,560
Zaprimljeno: 29.02.2016. Stanje: ŽALBA NA ČEKANJU (Donošenje odluke, prikupljanje dokumentacije) ~ 70 % Na jedan upit su mi odgovorili u roku od dva tjedna, stigao potpisani i skenirani PDF na mejl. |
#3430 |
Lokacija: Sisak
Postovi: 827
#3431 |
Datum registracije: May 2013
Postovi: 40
#3432 |
Postovi: 1,683
Imam iskon.duo i router P-2601HN-F3. Prije par tjedana tražio onaj paket 20/5 kaže ne možemo vam to pustiti jer imate lošu paricu (nalazim se 150m zračne udaljenosti od centrale) i digli mi na 10/5. I od onda mi cijelo vrijeme puca veza. Zovem danas korisničku službu i kaže da svaki put kada je pukla veza je bio velik upload (Torrente ne koristim) Ima kakve pomoci il da se pomirim sa time? |
#3433 | |
Lokacija: Sisak
Postovi: 827
Recimo imamo situaciju sa 20 stanova. 13 stanara su protiv 7 za prebacivanje. |
#3434 |
Postovi: 7,507
Zgrada mora biti veća, udaljenija od centrale. Samo predstavnik stanara mora potpisati dozvolu za postavljanje opreme u prizemlju, dozvole suvlasnika nisu potrebne (kao ni kod bneta i ht-a optike) Kada je kod nas bio iskonov čovjek rekao je da mora biti 15 zainteresiranih stanara da razmatraju dovođenje fttba do zgrade no kasnije su odustali od naše zgrade.
#3435 |
The Zappa
Postovi: 596
#3436 |
Postovi: 7,507
Pojasni malo Karabaja. Što, pa ne treba im 50% ili 100% potpisa suvlasnika. Kod nas je Bnet isto samo pitao predstavnicu i ona je potpisala. Imamo jednog stanara kojem sve živo smeta i odmah se pobunio kako nitko njega nije ništa pitao no odmah su ga spustili na zemlju. Gdje bi bili da treba 50% ili 100% pristanaka dozvole za postavljanjem kanalica ili nekog malog ormara u prizemlju. Dapače, to je na dobrobiti svih suvlasnika koji dobivaju mogućnost više usluga, jeftinije pakete a time im i vriejdnsot nekretnine raste budući da ako netko kupuje stan i u jednoj zgradi ima samo t-com parice a u drugoj optiku, bnet itd bi puno njih odabralo ovu drugu varijantu.
#3437 |
The Zappa
Postovi: 596
"Svi poslovi koje suvlasnici poduzimaju na zgradi imaju karakter redovne i izvanredne uprave. O redovnoj upravi suvlasnici odlučuju većinom glasova, dok je za izvanrednu upravu potrebna suglasnost svih suvlasnika. Poslovima redovne uprave smatraju se poslovi redovitog održavanja zajedničkih dijelova i uređaja nekretnine, te građevinski zahvati radi održavanja, zatim stvaranje zajedničke pričuve i uzimanje zajmova za pokriće troškova održavanja zgrade koji se ne mogu podmiriti iz sredstava redovite pričuve. Izvanrednom upravom koja premašuje okvir redovne uprave smatraju se promjene namjene, dogradnja, nadogradnja, poslovi preuređenja, davanje u zakup ili najam na dulje vrijeme, osnivanje hipoteke na zgradi odnosno davanje u zalog, davanje prava građenja, otuđenje." Skraćeno, zamjena, održavanje ili popravak postojeće dotrajale opreme ili instalacija spada u poslove redovne uprave i o tome se odlučuje većinom. Ugradnja nove ili nadogradnja je posao izvanredne uprave. Predstavnik se, bez potpisa svih suvlasnika, upušta u kaznenu sferu, Iskon riskira tužbu i rizik nadoknade štete, odnosno povratka u prethodno stanje. Dirati u tuđe vlasništvo bez dozvole, pa čak i u ovoj nedođiji od pravosuđa, je nešto što se nikad ne bi smjelo niti trebalo upuštati. Zato kažem, ili su maksimalno glupi ili imaju točan izračun rizika. Zadnje izmijenjeno od: karabaja. 04.05.2016. u 16:51. |
#3438 |
Postovi: 7,507
Daj molim te. Dobivaš uslugu koja je super jeftina, usluge brzog interneta itd a ti govoriš o nadoknadama štete itd. Zbog jednog ormara u prizemlju? Kakvu štetu? Kome i zašto smeta mali ormarić u prizemlju? Pa gdje bi bili da treba 100% potpisa suvlasnika koji ne kuže da ne moraju uzeti ako daju potpis, netko koji je uvijek protiv nečega itd. Ovo je zakon za veće zahvate kao možda postava lifta ili sanacija fasade koja zgradu i košta a ovo ne.
#3439 |
Lokacija: Sisak
Postovi: 827
Pa po meni što se tiče samog podstavljanja mislim da bi bilo u redu da svi sustanari imaju pravo glasa. Ono što mene je zanimalo uz potpis dozvole ugradnje koliki bi trebao biti broj stanara koji bi stvarno prešli u tom slučaju na Iskon da se ugradi FTTB. Ili je njima bitno samo do dobiju potpise za odobrenje gradnje. Evo recimo situacije kod mene. Bio je B-net dao ponudu predstavniku koji je obavijestio sve sustanare i prikupio potpise koji su za a koji protiv da se ugradi. Većina je bila za pa je dao odobrenje, ugradili oni to već ima 2 godine i za sad su samo dva korisnika prešla na B-net. Iako mislim da bi kod Iskona bila veća zainteresiranost radi cijena. Možda ne bi odmah prešli ali nakon isteka ugovora sa trenutnim operaterom sigurno bi. |
#3441 |
Lokacija: Sisak
Postovi: 827
Ok, znači u zgradi sa 30 stanova 25 stanara potpiše za odobrenje ugradnje a njih 10 uzme paket preko FTTB-a. I to je ok. To je vrlo bitno znati jer zbog neinformiranosti neki stanari odbijaju potpisati jer misle da će morati preseliti se na drugog operatera. Predstavnik mora biti dobro informiran u takvim situacijama da može sustanarima objasniti što i kako. Upravo iz razloga da se izbjegnu nepotrebne greške. |
#3442 |
super user
Postovi: 1,805
Tesko da ce ulazit u zgradu od 30 stanova... ali svasta je moguce. Kad jednom potpisete ugovor s Iskonom onda vise nije bitno kolko ce stanara uzet taj paket a kolko nece. Iskonovci idu po stanovima(sklapaju ugovore s krajnjim korisnicima) nakon ugradnje fttba ..ali recimo kod susjeda je bilo obratno pa je cekao malo duze. |
#3443 | |
The Zappa
Postovi: 596
Ne, izvanredna uprava je baš ono što piše. |
#3444 |
super user
Postovi: 1,805
Ma tko se u nasoj drzavi drzi zakona ,daj molim te...mrtvo slovo na papiru. Predstavnik radi sta hoce dok se za to nezna i nevidi,ak ima neku vezu u GSKG onda moze i fiktivne racune radit (bivsi predstavnik moj zgrade). Nije iskon jedini koji ulazi u zgrade samo s odoborenjem predstavnika. |
#3445 |
Datum registracije: Apr 2016
Postovi: 144
Kakvi su routeri koje Iskon daje za VDSL usluge? Zblesuju li se često? Kakav im je WIFI? |
#3447 | |
Postovi: 780
#3448 |
The Zappa
Postovi: 596
#3449 |
Lokacija: Rijeka/Zagreb
Postovi: 45
Vidim da je još nekoliko ljudi u situaciji pucanja veze ili dužeg laga nakon prebacivanja brzine. Sredinom prošlog mjeseca uzeo sam novu ugovornu obvezu i prebačen sam sa 5/0.3-0.4 + IPTV na 10/0.6 vezu + IPTV. Prije sam prilikom gašenja IPTVa regularno imao stabilnu 9-10Mbps vezu, a sada se sa nominalnom 10 mučim konstantno, kao da postoji bitni lag u učitavanju stranica više puta dnevno. Šum i ping bi trebali biti u redu, parica podržava do 16Mbps i dvostruko veći upload nego dobivam, pa ne znam u čemu je problem; događa li se ovo često? |
#3450 |
Lokacija: Sisak
Postovi: 827
Zadnje izmijenjeno od: Froxie24. 09.05.2016. u 11:56. |
