Povratak   PC Ekspert Forum > Internet i mrežne tehnologije > ISP > Iskon
Staro 29.04.2016., 17:00   #3421
Ag008
RESPECT MY AUTHORITAH
Ag008's Avatar
Postovi: 7,485
Kako Iskonovci ne žele poslati tehničara nevjerojatno...
Prošla je godinu dana od moje prošle prijave kvara, naime samo moja zgrada/izvod ima atenuaciju 21db, sve okolne su oko 16-18db i max nešto manji. Prošle godine iskonov teničar s mjernim uređajem ustanovio oštećenje/kratki spoj na 150m od izvoda (cca spojnica) i ht nije sanirao problem.
Tako ja za točno godinu dana od prijave opet prijavim kvar, navedem da imam manju marginu nego prije (prije cca 15db margina u dl, sada 12-13db) i svakih pola sata mi se javlja error sekunda zadnjih par mjeseci, htio bi imati više a ne mogu. Te da prijave tehničaru da opet izađe kako bi se moglo opet proslijediti ht-u.
Code:
    VDSL Training Status:   Showtime
                    Mode:   VDSL2 Annex B
            VDSL Profile:   Profile 8b
            Traffic Type:   PTM Mode
             Link Uptime:   0 day: 0 hour: 16 minutes
       VDSL Port Details       Upstream         Downstream
               Line Rate:      4.315 Mbps       22.527 Mbps
    Actual Net Data Rate:      4.316 Mbps       22.528 Mbps
          Trellis Coding:         ON                ON
              SNR Margin:        6.1 dB           11.2 dB
            Actual Delay:          0 ms              0 ms
          Transmit Power:        7.9 dBm          18.5 dBm
           Receive Power:        0.3 dBm           1.2 dBm
              Actual INP:       12.0 symbols      27.0 symbols
       Total Attenuation:        8.1 dB           17.3 dB
Attainable Net Data Rate:      4.500 Mbps       30.192 Mbps
      VDSL Band Status    U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB): 14.2    52.9     N/A     N/A    26.0    65.5     N/A
Signal Attenuation(dB): 14.2    52.5     N/A     N/A    23.1    65.3     N/A
        SNR Margin(dB):  6.1     6.2     N/A     N/A    11.2    11.3     N/A
   Transmit Power(dBm):  3.5     5.9     N/A     N/A    18.4     2.5     N/A
            VDSL Counters
           Downstream        Upstream
Since Link time = 25 min 59 sec
FEC:		1250		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 15 minutes time = 8 min 44 sec
FEC:		767		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Previous 15 minutes time = 15 min 0 sec
FEC:		430		0
CRC:		0		0
ES:		0		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Latest 1 day time = 18 hours 8 min 44 sec
FEC:		73834		148
CRC:		585		0
ES:		27		0
SES:		10		0
UAS:		58		48
LOS:		1		0
LOF:		8		0
LOM:		0		0
Previous 1 day time = 24 hours 0 sec
FEC:		33513		161
CRC:		43		0
ES:		26		0
SES:		0		0
UAS:		0		0
LOS:		0		0
LOF:		0		0
LOM:		0		0
Total time = 1 days 18 hours 8 min 44 sec
FEC:		446005		2012
CRC:		887		0
ES:		254		0
SES:		10		0
UAS:		81		71
LOS:		1		0
LOF:		8		0
LOM:		0		0
I danas me nazovu i kaže da error sekunda u pola sata nema veze jer nemam tv, da mi veza ne puca, da imam ugovorenu brzinu i da neće poslati tehničara. Ja se svađam i cura mi kaže da kada bi imao paket od 50Mbps a dobivam 26mbps onda bi mogli poslati ali ovako ne mogu. No u prodaji ne dozvoljavaju da ugovorim 50mbps jer to ne mogu imati a i u paketu 30mbps bi imao min 70% i tako ništa od tehničara i sanacije problema. Problem ostaje
Staro 29.04.2016., 18:42   #3422
Froxie24
Datum registracije: Feb 2015
Lokacija: Sisak
Postovi: 827
Ti barem imaš upload 4120kbps. Ja sam zapeo na 1200kbps u paketu od 20/5mbps i ne ide više.
Froxie24 je offline   Reply With Quote
Staro 29.04.2016., 19:08   #3423
sharkri
sharkri's Avatar
Postovi: 704
Autor Froxie24 Pregled postova
Nisi jedini, ista stvar i kod mene.
Poslano sa mog D6503 koristeći Tapatalk
Sig-5 redova normalne veličine max
Staro 01.05.2016., 21:00   #3424
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,629
pisi PREPORUCENO !!!! hakomu, iako su oni mrtva puhala...
u 2016 godini, oni ne odgovaraju na e-mail, ali na preporucene posiljke moraju odgovoriti... drzavni pos'o
MasterX je offline   Reply With Quote
Staro 01.05.2016., 21:32   #3425
ipa
Postovi: 118
pozdrav svima
ako može savjet
nude mi u Splitu u našoj zgradi uvođenje fttb
plaćali bi nam 200kn + 50kn za struju
ja sam predstavnik stanara , pošto nisam u toku
dali da im to odobrim ili ne
inače u zgradi imamo bnet i parice
Hvala svima na odgovorima
ipa je offline   Reply With Quote
Staro 01.05.2016., 22:31   #3426
Froxie24
Lokacija: Sisak
Postovi: 827
Po mom mišljenju bilo bi pametno iskoristiti priliku, razgovaraj malo sa stanarima kakva su njihova mišljenja.
FTTB ti je inace optika do same zgrade. U prostoriji zgrade bilo hodnik, podrum ti smjeste ormarić sa opremom. Nema bušenja i kanalica po stubištu pošto koristi parice unutar zgrade, za neke stanare koji su možda odustali od b-neta jer im moraju bušiti po stanu da uvedu kabal bi dobro došlo ako žele veću brzinu preko VDSL-a koja je max 80/40Mbps.
Staro 01.05.2016., 23:06   #3427
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Autor ipa Pregled postova
pozdrav svima
ako može savjet
Isto su i nama tj meni ponudili,baci oko na zadnji par strana ove teme.
Svakako prihvati, to je prilika koja se ne propusta a jos cete dobit 250kn u pricuvu sto nije za bacit.
Zadnje izmijenjeno od: viper. 01.05.2016. u 23:38.
viper je offline   Reply With Quote
Staro 02.05.2016., 08:06   #3428
vex69
vex69's Avatar
Postovi: 55
Autor viper Pregled postova
Aha na zapadu su sad. Garantiraju ti brzinu jer si s tim prakticki na centrali.
Ima tu ljudi koji to vec imaju ,prolistaj par stranica unatrag. Tamo negdje imas post iz 2-3 mj di je stavljena i statiska iz rutera . 80/40 ide bez problema jer ipak je vecinom to optika pa tu nema problema.
Jesu gotovi s radovima ili ce tek pocet?
Gotovi su radovi, raskopali su ispred zgrade, postavili ormarić i podijelili letke. Nemam šta više misliti za tu cijenu, prebacujem se kod njih.
vex69 je offline   Reply With Quote
Staro 02.05.2016., 09:59   #3429
franzD
Datum registracije: Apr 2015
Postovi: 1,542
Autor MasterX Pregled postova
Hakom uredno odgovara na žalbe predane preko onog sučelja na web stranici. Predaš žalbu, dobiješ urudžbeni broj i preko njega pratiš stanje rješavanja. Jest da im treba poduže da riješe, ali evidentirano je i moraju odgovoriti.
Zaprimljeno: 29.02.2016.
Stanje: ŽALBA NA ČEKANJU (Donošenje odluke, prikupljanje dokumentacije) ~ 70 %
Na jedan upit su mi odgovorili u roku od dva tjedna, stigao potpisani i skenirani PDF na mejl.
franzD je online   Reply With Quote
Staro 02.05.2016., 10:06   #3430
Froxie24
Lokacija: Sisak
Postovi: 827
Autor vex69 Pregled postova
Cek ormaric su postavili izvan zgrade ili unutar zgrade?
Staro 02.05.2016., 11:00   #3431
Pogy
Datum registracije: May 2013
Postovi: 40
Ormarić ide u zgradu a on misli što su raskopali ispred zgrade jer oni stave svoj mali šaht u zemlju uz postojeći šaht HT kojim su došli do zgrade( valjda je to razdijelni šaht - neznam )
Pogy je offline   Reply With Quote
Staro 03.05.2016., 16:53   #3432
zgmmax
zgmmax's Avatar
Postovi: 1,673
Imam iskon.duo i router P-2601HN-F3.
Prije par tjedana tražio onaj paket 20/5 kaže ne možemo vam to pustiti jer imate lošu paricu (nalazim se 150m zračne udaljenosti od centrale) i digli mi na 10/5.
I od onda mi cijelo vrijeme puca veza.
Zovem danas korisničku službu i kaže da svaki put kada je pukla veza je bio velik upload (Torrente ne koristim)
Ima kakve pomoci il da se pomirim sa time?
Staro 04.05.2016., 10:05   #3433
Froxie24
Lokacija: Sisak
Postovi: 827
Zanima me jedno. Kako to ide, koliki postotak stanara mora pristati prebaciti se na FTTB da bi ugrađivali?
Recimo imamo situaciju sa 20 stanova. 13 stanara su protiv 7 za prebacivanje.
Staro 04.05.2016., 10:23   #3434
Ag008
Ag008's Avatar
Postovi: 7,485
Zgrada mora biti veća, udaljenija od centrale. Samo predstavnik stanara mora potpisati dozvolu za postavljanje opreme u prizemlju, dozvole suvlasnika nisu potrebne (kao ni kod bneta i ht-a optike)
Kada je kod nas bio iskonov čovjek rekao je da mora biti 15 zainteresiranih stanara da razmatraju dovođenje fttba do zgrade no kasnije su odustali od naše zgrade.
Staro 04.05.2016., 15:15   #3435
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Autor Ag008 Pregled postova
Jednom će se opeći na tome. Ili su izračunali rizik ili su nevjerojatno glupi. Samo neka naiđu na nekoga s puno slobodnog vremena i para.
karabaja je offline   Reply With Quote
Staro 04.05.2016., 15:33   #3436
Ag008
Ag008's Avatar
Postovi: 7,485
Pojasni malo Karabaja. Što, pa ne treba im 50% ili 100% potpisa suvlasnika.
Kod nas je Bnet isto samo pitao predstavnicu i ona je potpisala.
Imamo jednog stanara kojem sve živo smeta i odmah se pobunio kako nitko njega nije ništa pitao no odmah su ga spustili na zemlju.
Gdje bi bili da treba 50% ili 100% pristanaka dozvole za postavljanjem kanalica ili nekog malog ormara u prizemlju. Dapače, to je na dobrobiti svih suvlasnika koji dobivaju mogućnost više usluga, jeftinije pakete a time im i vriejdnsot nekretnine raste budući da ako netko kupuje stan i u jednoj zgradi ima samo t-com parice a u drugoj optiku, bnet itd bi puno njih odabralo ovu drugu varijantu.
Staro 04.05.2016., 15:43   #3437
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
"Svi poslovi koje suvlasnici poduzimaju na zgradi imaju karakter redovne i izvanredne uprave. O redovnoj upravi suvlasnici odlučuju većinom glasova, dok je za izvanrednu upravu potrebna suglasnost svih suvlasnika.
Poslovima redovne uprave smatraju se poslovi redovitog održavanja zajedničkih dijelova i uređaja nekretnine, te građevinski zahvati radi održavanja, zatim stvaranje zajedničke
 pričuve i uzimanje zajmova za pokriće troškova održavanja zgrade koji se ne mogu podmiriti iz sredstava redovite pričuve.
Izvanrednom upravom koja premašuje okvir redovne uprave smatraju se promjene namjene,
 dogradnja, nadogradnja, poslovi preuređenja, davanje u zakup ili najam na dulje vrijeme,
 osnivanje hipoteke na zgradi odnosno davanje u zalog, davanje prava građenja, otuđenje."
Skraćeno, zamjena, održavanje ili popravak postojeće dotrajale opreme ili instalacija spada u poslove redovne uprave i o tome se odlučuje većinom. Ugradnja nove ili nadogradnja je posao izvanredne uprave. Predstavnik se, bez potpisa svih suvlasnika, upušta u kaznenu sferu, Iskon riskira tužbu i rizik nadoknade štete, odnosno povratka u prethodno stanje. Dirati u tuđe vlasništvo bez dozvole, pa čak i u ovoj nedođiji od pravosuđa, je nešto što se nikad ne bi smjelo niti trebalo upuštati. Zato kažem, ili su maksimalno glupi ili imaju točan izračun rizika.
Zadnje izmijenjeno od: karabaja. 04.05.2016. u 15:51.
Staro 04.05.2016., 16:01   #3438
Ag008
Ag008's Avatar
Postovi: 7,485
Daj molim te. Dobivaš uslugu koja je super jeftina, usluge brzog interneta itd a ti govoriš o nadoknadama štete itd. Zbog jednog ormara u prizemlju? Kakvu štetu? Kome i zašto smeta mali ormarić u prizemlju?
Pa gdje bi bili da treba 100% potpisa suvlasnika koji ne kuže da ne moraju uzeti ako daju potpis, netko koji je uvijek protiv nečega itd.
Ovo je zakon za veće zahvate kao možda postava lifta ili sanacija fasade koja zgradu i košta a ovo ne.
Staro 04.05.2016., 18:13   #3439
Froxie24
Lokacija: Sisak
Postovi: 827
Pa po meni što se tiče samog podstavljanja mislim da bi bilo u redu da svi sustanari imaju pravo glasa.
Ono što mene je zanimalo uz potpis dozvole ugradnje koliki bi trebao biti broj stanara koji bi stvarno prešli u tom slučaju na Iskon da se ugradi FTTB. Ili je njima bitno samo do dobiju potpise za odobrenje gradnje.
Evo recimo situacije kod mene. Bio je B-net dao ponudu predstavniku koji je obavijestio sve sustanare i prikupio potpise koji su za a koji protiv da se ugradi. Većina je bila za pa je dao odobrenje, ugradili oni to već ima 2 godine i za sad su samo dva korisnika prešla na B-net. Iako mislim da bi kod Iskona bila veća zainteresiranost radi cijena. Možda ne bi odmah prešli ali nakon isteka ugovora sa trenutnim operaterom sigurno bi.
Staro 04.05.2016., 19:58   #3440
viper
super user
viper's Avatar
Postovi: 1,805
Ne gleda se broj stanara koji bi presli na Iskon nego ukupni broj stanova po ulazu zgrade.
Staro 04.05.2016., 20:19   #3441
Froxie24
Lokacija: Sisak
Postovi: 827
Ok, znači u zgradi sa 30 stanova 25 stanara potpiše za odobrenje ugradnje a njih 10 uzme paket preko FTTB-a. I to je ok.
To je vrlo bitno znati jer zbog neinformiranosti neki stanari odbijaju potpisati jer misle da će morati preseliti se na drugog operatera.
Predstavnik mora biti dobro informiran u takvim situacijama da može sustanarima objasniti što i kako. Upravo iz razloga da se izbjegnu nepotrebne greške.
Staro 04.05.2016., 20:36   #3442
viper
super user
viper's Avatar
Postovi: 1,805
Tesko da ce ulazit u zgradu od 30 stanova... ali svasta je moguce.
Kad jednom potpisete ugovor s Iskonom onda vise nije bitno kolko ce stanara uzet taj paket a kolko nece.
Iskonovci idu po stanovima(sklapaju ugovore s krajnjim korisnicima) nakon ugradnje fttba ..ali recimo kod susjeda je bilo obratno pa je cekao malo duze.
Staro 04.05.2016., 21:26   #3443
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Čuj, nisam ja to izmislio. Suvlasništvo je općenito zayeban koncept.
Ne, izvanredna uprava je baš ono što piše.
Staro 04.05.2016., 21:39   #3444
viper
super user
viper's Avatar
Postovi: 1,805
Ma tko se u nasoj drzavi drzi zakona ,daj molim te...mrtvo slovo na papiru. Predstavnik radi sta hoce dok se za to nezna i nevidi,ak ima neku vezu u GSKG onda moze i fiktivne racune radit (bivsi predstavnik moj zgrade).
Nije iskon jedini koji ulazi u zgrade samo s odoborenjem predstavnika.
Staro 06.05.2016., 14:58   #3445
BigMac
Datum registracije: Apr 2016
Postovi: 144
Kakvi su routeri koje Iskon daje za VDSL usluge? Zblesuju li se često? Kakav im je WIFI?
BigMac je offline   Reply With Quote
Staro 06.05.2016., 22:56   #3446
Zvonimir_s
Zvonimir_s's Avatar
Postovi: 406
Autor BigMac Pregled postova
ok...ne, al znaju...WIFI slab..
Zvonimir_s je offline   Reply With Quote
Staro 07.05.2016., 18:50   #3447
okarm
Postovi: 772
Autor karabaja Pregled postova
zamisli sad situaciju, prijavis smetnju za internet, tehnicar detektira da se lokalna otkvacila na izvodu i kaze ti "cuj, moramo prvo napraviti glasanje, pa ti tek onda mogu spojiti uslugu nazad"
Staro 08.05.2016., 17:20   #3448
karabaja
The Zappa
karabaja's Avatar
Postovi: 595
Autor okarm Pregled postova
Pogrešno si shvatio što sam napisao. Pomalo smo već OT.
Staro 08.05.2016., 22:00   #3449
Glitch
Glitch's Avatar
Lokacija: Rijeka/Zagreb
Postovi: 45
Vidim da je još nekoliko ljudi u situaciji pucanja veze ili dužeg laga nakon prebacivanja brzine.
Sredinom prošlog mjeseca uzeo sam novu ugovornu obvezu i prebačen sam sa 5/0.3-0.4 + IPTV na 10/0.6 vezu + IPTV.
Prije sam prilikom gašenja IPTVa regularno imao stabilnu 9-10Mbps vezu, a sada se sa nominalnom 10 mučim konstantno, kao da postoji bitni lag u učitavanju stranica više puta dnevno.
Šum i ping bi trebali biti u redu, parica podržava do 16Mbps i dvostruko veći upload nego dobivam, pa ne znam u čemu je problem; događa li se ovo često?
Glitch je offline   Reply With Quote
Staro 09.05.2016., 10:50   #3450
Froxie24
Lokacija: Sisak
Postovi: 827
Nakon godinu dana i dalje stabilan i brz.
Zadnje izmijenjeno od: Froxie24. 09.05.2016. u 10:56.
