Staro 31.03.2016., 13:28   #8881
MatJAM
Datum registracije: Dec 2015
Postovi: 6
Pozz.
Trebam komp za gaming(gtaV,csgo) i za crtanje u autocadu,catia itd.
Budzet je 5000-6000 kn i komp bi trebali sastavit oni u trgovini.
Recite mi kod koje trgovine u zg to najbolje rade(adm,futura,magazin ...)
Ak moze vise konf u tom rangu
MatJAM je offline   Reply With Quote
Staro 31.03.2016., 13:40   #8882
ibme74
ibme74's Avatar
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,635
1x Intel i5 4460
1x MSI H81M-E33 iH81
1x Kingston DDR3 8GB 1600MHz
1x MSI GTX970 TTOC 4GB GDDR5 256bit
1x Patriot SSD Blast R560/W425, 120GB, 7mm, 2.5"
1x HDD Toshiba 1TB
1x Fortron Raider S PSU 550W 80+
1x BitFenix Nova Midi Tower
UKUPNO: 6.051,65kn
ibme74 je offline   Reply With Quote
Staro 31.03.2016., 15:15   #8883
Doc
Postovi: 430
Autor ibme74 Pregled postova
Doc je offline   Reply With Quote
Staro 31.03.2016., 15:37   #8884
ibme74
ibme74's Avatar
Postovi: 1,635
Autor Doc Pregled postova
Da, i?
Staro 01.04.2016., 14:36   #8885
MatJAM
Postovi: 6
moze li jos par konfi jeftinijih?
Staro 01.04.2016., 14:45   #8886
ibme74
ibme74's Avatar
Postovi: 1,635
1x Procesor AMD X8 FX-8300
1x LC-CC-120
1x Gigabyte GA-970A-DS3P
1x Kingston HyperX Fury 8GB DDR3 1866MHz
1x Gigabyte GTX960 4GB
1x Toshiba DT01ACA100 1TB 3.5''
1x XFX TS Series 450W PSU, XFX-P1-450S-GREN
1x Zalman Z1 Midi Tower
Ukupno: 4.985,17kn
Staro 01.04.2016., 14:52   #8887
ODO
Datum registracije: Feb 2015
Postovi: 600
Procesor Intel Core i5 4460
Matična ploča ASRock H81M-HDS R2.0
GIGABYTE Video Card GeForce GTX 960 GDDR5 4GB/128bit, 1127MHz/7010MHz, PCI-E 3.0 x16, HDMI, 2xDVI, 3
Kingston DDR3 1600MHz,C11, 8GB, KVR16N11/8
SEAGATE HDD Desktop Barracuda 7200 ST1000DM003 (3.5",1TB,64MB,SATA III-600)
SanDisk X400 256GB SSD, 2.5” 7mm, SATA 6 Gbit/s, Read/Write: 540 MB/s / 520 MB/s, SD8SB8U-256G-1122 (5 godina garancija)
Zalman kućište Z3 PLUS mid tower case black Z3+, USB 3.0, bez napajanja, ZAL-Z3 PLUS
Fortron napajanje Raider S PSU 550W,80+ (5 godina garancija)
5.597,29kn (besplatno slaganje)
ODO je offline   Reply With Quote
Staro 01.04.2016., 23:25   #8888
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Da, i?
ploča nema fronta panel za USB3.0, pa je malo glupo metnuti kućište sa usb3.0 koje ne bude mogao koristiti
Ali ajde, ko šljivi usb port na kućištu... ali TT grafu gurati u miditower nema smisla
Uglavnom, i dalje slažeš loše konfe i tiskaš sve živo i neživo samo da bi dobio "jači komp"...jbš to, to more i moj pas raditi
Autor MatJAM Pregled postova
Pozz.
Procesor: INTEL Core i5-6500 (3.20GHz,1MB,6MB,65W,1151) Box, INTEL HD 530
Matična ploča: Asus H110M-C (s1151,USB 3.0,SATA III,LAN,DDR4) mATX
Memorija: 16GB (2x8) Kingston 2133MHz DDR4 CL15
SSD: SanDisk X400 128GB SSD, 2.5” 7mm, SATA 6 Gbit/s, 60mj.
Disk: Toshiba P300 1TB, 64MB, 7200rpm
Grafička: Gigabyte GF GTX950 WF2 OC, 2GB GDDR5, DVI, DP, HDMI
Napajanje: Fortron Hyper 500W, 80+ - 60mj.
Kućište: Zalman ZM-T4, USB3.0, micro atx
CIJENA: 5700,00 Kn / JAMSTVO: do 60mj. / Slaganje i dostava: besplatno, kroz 2 dana / Dostupno odmah u trgovini
Zadnje izmijenjeno od: FRipper. 01.04.2016. u 23:32.
Staro 06.04.2016., 20:47   #8889
Nedo
Datum registracije: Apr 2016
Postovi: 2
Pozfrav
Imam sina 12 godina, trebam računalo za njega max 4500 kn.
Normalno, za igre ali i za rad sa office paketom.
Budući nemam vještine potrebne za samogradnju treba mi i savjet kako i gdje to nabaviti.
Tipkovnicu, miša i monitor imam.
Molim pomoć
Nedo je offline   Reply With Quote
Staro 06.04.2016., 21:04   #8890
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Procesor: AMD FX X6 6300 (3,5GHz,14MB,95W,AM3+) box
Hladnjak: LC-CC-95, Intel/AMD, 90mm 4-pin
Matična ploča: GIGABYTE GA-970A-DS3P, AM3+, R2.0, 4+1 Phase, 125W CPU
Memorija: KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail
Grafička: Gigabyte NVIDIA GeForce GTX 950, 2GB GDDR5, 128bit
Kućište: Fortron GAB03 Game kućište, crno, USB3.0, ATX
Dodatno: 2x Xilence hladnjak za kućište 120mm, crno/crveni
CIJENA: 4500,00 Kn / JAMSTVO: do 60mj. / Slaganje i dostava: besplatno, kroz 2 dana / Dostupno odmah u trgovini
Iskustva s IT trgovinama + Nabava
Staro 06.04.2016., 22:06   #8891
PeterGriffin
PeterGriffin's Avatar
Lokacija: Županja
Postovi: 1
Poštovani,ako bi mi mogli sastaviti gaming računalo. Maksimalna cijena je 5000kn. Bez periferije također,hvala unaprijed!
PeterGriffin je offline   Reply With Quote
Staro 06.04.2016., 22:20   #8892
ODO
Postovi: 600
Autor Nedo Pregled postova
Pozfrav
Molim pomoć
Malo iznad 4500, ali sa i5 i GTX960
Intel Core i5-4460
ASRock H81M-HDS
Kingston Technology HyperX Fury Memory Blue 8GB 1600MHz DDR3
Gigabyte NVIDIA GeForce GTX 960 2GB
Toshiba 1TB 3.5" 7.2k SATA Gb/s 32MB
Sharkoon VG4-S Tower ATX kućište, bez napajanja, crno
FSP/Fortron Hexa+ 400
4 581,91 kn sa forumskim popustom (besplatno slaganje i dostava)
Staro 06.04.2016., 22:27   #8893
ODO
Postovi: 600
Autor PeterGriffin Pregled postova
Uz male preinake može stati i SSD
Intel Core i5-4460
ASRock H81M-HDS
Sapphire Radeon R9 380 Nitro 4GB
Seagate 1TB SATA HDD Barracuda, Serial ATA III, 1000 GB
Zalman Z3
Fortron FSP 500W HYPER 85+
4 870,30 kn sa forumskim popustom (besplatno slaganje i dostava)
Staro 06.04.2016., 22:33   #8894
ibme74
ibme74's Avatar
Postovi: 1,635
1x MSI H81M-P33 iH81 (S1150, DDR3, SATA II,SATA III,PS/2,USB2.0,USB3.0,LAN,Audio Line-In,Audi
1x Procesor Intel Core i5 4460
1x Kingston DDR3 1600MHz,C11, 8GB
1x Gigabyte R9 380X GAMING GDDR5 4GB/256it, 980MHz/5700MHz, PCI-E 3.0 x16, DP, HD
1x Toshiba P300 1TB, 64MB, 7200rpm HDWD110UZSVA
1x XFX 600W XT Series 80 Bronze, XFX-P1-600B-XTFR
1x Zalman Z1
Ukupno:5.017,88kn
Staro 07.04.2016., 12:23   #8895
Postovi: 34,123
Zašto XFX napajanje koje ima prilično velike šanse da prozuji u skorijoj budućnosti?
Staro 08.04.2016., 11:07   #8896
ElBaky
Postovi: 2
Prije svega, lijepi pozdrav svima!
Cijenio bih malu pomoć u izgradnji konfiguracije koju sam počeo slagati. Zasada imam sljedeće:
Silverstone Sugo SG12 (mATX kućište)
ASUS H170M-E D3 mATX,s. 1151
KINGSTON HyperX Fury Black DDR3 1866MHz, 2x8GB
SSD Samsung Evo Basic 250GB
Prije svega mi treba preporuka za napajanje, procesor i grafičku karticu da sve to stane u raspon od 3k-5k. Funkcija ove mATX konfe bi bila gaming na 1080p. Napominjem da kućište prima standardna ATX PS/2 napajanja i grafulje do 13.3 inča duljine. EDIT: Zaboravih napomenut da bi htio modularno napajanje radi cable managementa i, naravno, da je što tiše.
Unaprijed hvala na savjetima! Take care.
ElBaky je offline   Reply With Quote
Staro 08.04.2016., 18:57   #8897
Nedo
Postovi: 2
Odo Kako ovo realizirati?
Staro 09.04.2016., 10:13   #8898
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor ElBaky Pregled postova
MSI GeForce GTX970 Gaming, 4GB DDR5
Fractal napajanje Integra M 550W, 80+ BRONZE modul
Intel CPU Desktop Core i5-6400 (2.7GHz, 6MB,LGA1151) box
Ukupno: 5000,00 kn
Staro 09.04.2016., 20:23   #8899
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
@ELBaky
LC Power CPU Hladnjak LC-CC-95 - 90mm Intel/AMD
Grafička kartica MSI GeForce GTX 970 GAMING GDDR5 4GB/256bit
Procesor Intel Core i5 6402P
GIGABYTE B700H Power Supply 700W, Modular, 80+ Bronze
~4900kn
Malo sam više saznao o ovom napajanju... nešto slično Fortron Hyper M 700W, samo za jedan korak kvalitetnijim komponentama iznutra.
Staro 11.04.2016., 13:01   #8900
ElBaky
Postovi: 2
@Smartic, @FRipper
Dečki, puno hvala na savjetima!
Staro 16.04.2016., 13:30   #8901
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
Vidim da svi rade po meni kardinalne greške:
- Stavljati na H81 grafičku skuplju od 1000 kn nije preporučljivo, preporuka minimalno B85 chipset
- FX8 nije preporučljivo na 970 čipset, problemi s osmom jezgrom. 970 ide na FX6.
- Best buy napajanja u HR su Fortron Raider 550/650/750 ili Hyper 500/600/700W
- Skylake i DDR4 su neisplativi, bolje za razliku u novcu uzeti klasu bolju grafičku cca 45% bolju (tipa i5-6500, DDR4, Z170, GTX960, radije B85, 4460, DDR3, GTX970)
Nadalje, preporučljivo je sljedeće razmišljanje, vezano za napajanja za bezbrižan dugogodišnji rad:
Napajanje biramo grafičkoj kartici. Hyper i Raider imaju 5g jamstva, dok HEXA 3g jamstva.
MMA
Staro 16.04.2016., 14:43   #8902
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,589
Zašto? Slažem se da je b85 sada samo mrvu skuplji i isplativiji, ali ne vidim razlog zašto nebi išle grafe preko 1000kn. Pa ljudi furaju grafe i preko 2.5 soma na h81 (jest da je neprikladno, ali rade)
Koji problemi? Nisu sve 970 čispet ploče iste. Neke su šrot, a neke su skoro pa visoka klasa (recimo nova aurum). Mogu se i dosta klokati, recimo ASUS M5A97 EVO R2.0 je zvijer za OC, a 970 chipset
Ovisi o ponudi. Recimo fortron raider (barem onaj od 750) nije uopće dobio prolaznu ocijenu u nekim recenzijama, to su po kvaliteti napajanja tek nešto iznad mediokriteta, ali preporučuju se zbog visoke garancije i niske cijene. Kome recimo ne treba 650/750w može kupiti i kvalitetnija napajanja
Istina da je haswell još uvijek nešto povoljniji, ali i skylake je dosta pojeftinio, ddr4 mema košta isto ili manje od ddr3, ploče su još uvijek donekle skuplje od 1150, ali nije neki bauk kao na početku. Ugl. razlika između ekvivalentne 1151 i 1150 konfe sigurno ne čini razliku u cijeni između jedne gtx 960 i 970
Staro 16.04.2016., 21:38   #8903
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
(recimo nova aurum)
Misliš na aura?
https://www.asus.com/Motherboards/970-PRO-GAMING-AURA/
Ili ima joše nešto novo da nisam vidio?
Staro 16.04.2016., 22:03   #8904
Manuel Calavera
Postovi: 14,589
Imaš dosta am3+ ploča koje su došle prošle ili ove godine.
Od asusa ta aura, jedno 2-3 gigabytice, 1 biostarka (970), 2 msi (970 i 990) i par as rockica od prošle godine. Uglavnom se svode na usb 3.1 i/ili m.2 podršku
Staro 16.04.2016., 23:40   #8905
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
1) Radi dok ne prestane raditi. Prije ili kasnije završe na reklamaciji bilo grafičke bilo matične
2) Istina je da je M5A97 EVO R2.0 OK, ali problem je dobavljivost u HR. 990 riješava problem osme jezgre
3) Review koji navodiš ili je imao zaista loš primjerak ili nije vjerodostojan
4) DDR4 koju navodiš je sporija od DDR3 1866MHz. I da, čini razliku kada čovjek zabrije na Z170A, i5-6500 i DDR4 i R9380X, a onda mu se složi B85, 4460, DDR3 i GTX970
Jedini DDR4 koji ima smisla uzeti na HR tržištu je trenutno Kingston Savage DDR4 2400MHz CL12. Ostalo je još uvijek bolji DDR3.
Na kraju ADM koji poklanja 4 igre gratis u vrijednosti "925 kn" je ako ništa radi najčešće bolje cijene i još jedan razlog zašto ne složiti PC u njih.
Ovo čisto kažem jer vidim da ekipa to ne zna, iako na sve strane oglašavaju da poklanjaju 4 igre. Doduše, tehnički su to 3 igre, ali nećemo sad cjepidlačiti, lijepo u svakom slučaju.
Previše sam računala nakupovao i testirao. Razlika je kada se nešto složi, upali i onda ekipa zaključi: "To radi", a razlika je kada se svjetla ugase pa se za par mjeseci to isto računalo vrati na servis. U interesu je preporučiti nekom nešto što će raditi minimalno 3 godine, a ciljano min 5 godina bez da završi na servisu osim u slučaju čišćenja od prašine.
MMA
Zadnje izmijenjeno od: Sa_Stilom. 16.04.2016. u 23:45.
Staro 16.04.2016., 23:46   #8906
Manuel Calavera
Postovi: 14,589
I dalje mi nije jasan ovaj dio o grafičkoj na h81 ploči i 8 jezgri na 970 čipsetu. Nikad čuo ni vidio te probleme. Imaš ovdje barem na desetke forumaša koji uredno furaju te kombinacije duže vrijeme
Ako je krepala neka h81 ploča, ili grafa od 1000+ kn na istoj, to ziher nije zbog te kombinacije, nego zbog ploče ili same grafe samostalno. Stvari jednostavno krepavaju tu i tamo. Oboje su budžet kombinacije i u svijetu valjda postoji na milijune takvih kombinacija. Da je to tako kao što tvrdiš svijet bi znao za "problem". Isto kao i ovo za 970 čipsetom, možda se radi o neispravnoj ili prejadnoj ploči
Zadnje izmijenjeno od: Manuel Calavera. 16.04.2016. u 23:52.
Staro 17.04.2016., 00:22   #8907
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
@Sa_Stilom
zabrijao si malo previše, 20god slažem konfe i nikada nisam imao problema sa nekim "8im jezgrama" niti da su mi grafičke izgorile jer je ploča bila 970 umjesto bačenih para na 990... Ako si imalo slagao i duže se bavio kompovima, znao bi da više i češće skupe stvari krepavaju nego jeftine
Uz to uopće sada u ovoj raspravi ne vidim tamo neke 4 gratis igre u ADM-u... kakve pobogu to sada ima veze sa svime ovime? Svaka čast Croteamu na poklonima, ali opet nije tema sada za to.
Ja guze dajem gratis uz svoje polovne konfe pa me opet nitko baš ne doživljava...očito se slabo reklamiram
p.s. drži se ti radije WEB-a a ne ovoga ostalog
Staro 17.04.2016., 02:38   #8908
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,724
Autor FRipper Pregled postova
@Sa_Stilom
Neću sada mlatiti qitom čija je veća, 20-25 godina, nije ni bitno, no ja i dalje ne bih nikome složio H81 i GTX950 ili GTX960. Slažemo se da se ne slažemo i to je to. MBO i PSU su dvije najbitnije stvari, a na istima svi štede. 99% kupaca je krivo informirano po internetu i uzaludno bacaju novac. Smatram da pošto se računalo sastoji od više komponenata, da budget treba biti kvalitetno raspoređen, a ne kvantitetno. Nažalost, svi će bubreg prodati samo da prodaju jeftiniju konfu od susjeda, a mušterija je ta koja na kraju ispašta. Volim svoje mušterije i oni mene jer se ne vidimo po 2-3 godine. Složim im uvijek odlično optimizirane konfe, da, plate me 500 kn za instalaciju OSa i setup, ali dobe samo-održivi sustav i doslovno me ne vide i po 3 godine.
Nadalje, 99% ljudi misli da je AMD X8 jeftiniji od i5, a nije. Zabluda je mnogo, zabrijanovića također, ali svatko ima svoje. Btw, ne radim ja web.
MMA
Staro 17.04.2016., 09:49   #8909
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Ajde, ako već započneš temu oko toga, da onda mi i daš malo bolje objašnjenje zašto i kako bi ti složio. Jer ovo sve što pišeš nema nikakvog smisla.
H81 / B85 je širok pojam. Govoriš da ne bi metnuo H81 ploču i GTX 950/960 grafu nikada, a ne pišeš zašto ne bi? Zašto je po tvojem bolje B85?
Kako to da AMD nije jeftini?
Uzmimo konkretan primjer:
Intel i5 4460 -- Intel i5 4460 -- AMD FX 8300 + LC-CC-120
Asrock H81M-HDS -- Asrock B85M-HDS -- GA-970A-DS3P
Gigabyte GTX 950 WF2 -- Gigabyte GTX 950 WF2 -- Gigabyte GTX 950 WF2
cc 3200kn --- cc 3250kn --- cc 3000kn
Čisto usporedbe koliko je Skylake skuplji:
i5 6400 + Asrock H110M-DGS + Gigabyte GTX 950 WF2 = cc 3350kn
tu se slažem da je i dalje bolje ići na i5 4460, jer je isto a jeftinije i bolje tih 150kn dati za grafu, napajanje, kućište...
Zašto je bolje dati 50kn više za B85 ako je to ista ploča, samo je razlika doslovce u više sata3 konektora.
Sata3 konektori ovise da bi računalo bilo dugotrajnije?
Zašto jedna hladna GTX 950 ne bi mogla ići na krš od ploče? Što točno takva hladna i "rastrošna" grafa može učiniti ploči?
Konfa tri je AMD kako se i vidi, kako 200-250kn nije jeftinije nego intel? Još uz to na DS3P ploči FX8300 uredno ide na 4.2GHz bez da radi ikakve probleme
Slažem se da treba paziti i na odabir ploče, ali ne u takvim slučajevima kojima ti pišeš već u kombinaciji jakih, toplih, masivnih grafa (tipa R9 390, Fury itd... tu treba paziti da se ne ide na male i loše ploče, već gledati ATX ploče).
Staro 17.04.2016., 12:19   #8910
Namokran
Lokacija: Sisak
Postovi: 7
Pozdrav dobri ljudi i poštovanje,
trebao bih savjet i pomoć oko konfiguracije jer je nakon 5 godina došlo vrijeme za promjene. Čitajući po forumima i recenzijama došao sam do sljedeće konfiguracije.
MBO: Gigabyte GA-970A-DS3P, sAM3+
CPU: AMD X6 FX-6300 (14M Cache, up to 4.10 GHz), sAM3+
GPU: Gigabyte R9 380 4Gb GDDR5
MEM: DDR3 8GB (2x4GB) PC3-14900 1866MHz CL10 Kingston HyperX Fury
PSU: Corsair VS Series, 550W
Tremao bih preporuku i za jedan SSD. Cilj je napraviti konfiguraciju koja bi mogla izdražati još 4 do 5 godina. Primarna svrha su igrice, budžet je oko 4500 kuna. Monitor, tipkovnicu, miš, kućište. Imam i jedan obični hard od 250 Gb.
Prijedlozi i preporuke su dobro došle.Hvala na pomoći.
Namokran je offline   Reply With Quote
